Oasis Request Please and Thanks - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 08F350, this thread has received 2 replies and been viewed 439 times.
post #1 of 3 (permalink) Old 09-21-2010, 09:03 AM Thread Starter
08F350's Avatar
Vin:
1FTWW31R08EA13871
Thank-you
2008 Job 1 F350 CC Lariat FX4 6.4
FOR SALE - July 26 2014 - pm 4 details
5" Turbo Back Flo-Pro Exhaust
S&B CAI
Spartan TCM
Running Spartan's 275 Tune mostly....
Dirty Diesel Customs Cold Side Intercooler Pipe
All added strictly for "mileage".....if my wife asks
Hang the heck On!!
08F350 is offline
post #2 of 3 (permalink) Old 09-21-2010, 05:22 PM
Standard Claims List For Model Year 2008
1FTWW31R08EA13871 T/F7 F T/BC T/CD T/E A1 T/BE T/QL 31-JAN-2007 28-FEB-2007 4A6792 CAN 0 7Q01 110601 * 9C888 * A25 42 3
AWS Claim Key: 2779 Trx Code: 1 Labor Hrs: 2
Dlr Cd-Sub Cd: A6792 - * Name: M G M FORD LINCOLN SALES LTD. Ph: 403-3466621 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:17-FEB-2007 Doc #:16840102
Cust Comments: CONCERN FOR CRUISE CONTROL DOES NOT WORK
Tech Comments: VERIFIED CONCERN. PERFORMED IDS TEST. NO CODES. CALLED TECH LINE TOLD TO USE IDS TO ENABLE CRUISE PERFORMED PROGRAMING AND RE TEST ALL WORKS FINE NOW. MT9C735 IS FOR REPROGRAMMING CRUISE CONTROL
1FTWW31R08EA13871 T/F7 F T/BC T/CD T/E A1 T/BE T/QL 31-JAN-2007 28-FEB-2007 4A6792 CAN 3 * * * * * * * 2198
AWS Claim Key: 38454 Trx Code: 07S49 Labor Hrs: 0.5
Dlr Cd-Sub Cd: B6198 - * Name: RAINBOW FORD SALES INC. Ph: 403-8453673 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:30-APR-2007 Doc #:050555A
Cust Comments: RECALL 07S49
Tech Comments: *PERFORMED RECALL 07S49B
1FTWW31R08EA13871 T/F7 F T/BC T/CD T/E A1 T/BE T/QL 31-JAN-2007 28-FEB-2007 4A6792 CAN 15 2E02 * * * * * * 15982
AWS Claim Key: 889477 Trx Code: 08B03 Labor Hrs: 0.9
Dlr Cd-Sub Cd: B6198 - * Name: RAINBOW FORD SALES INC. Ph: 403-8453673 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:12-MAY-2008 Doc #:056447C
Cust Comments: RECALL 08B03
Tech Comments: *PERFORMED RECALL 08B03B
1FTWW31R08EA13871 T/F7 F T/BC T/CD T/E A1 T/BE T/QL 31-JAN-2007 28-FEB-2007 4A6792 CAN 15 6E01 * * * * * * 15982
AWS Claim Key: 889478 Trx Code: 08C01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: B6198 - * Name: RAINBOW FORD SALES INC. Ph: 403-8453673 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:12-MAY-2008 Doc #:056447D
Cust Comments: RECALL 08C01
Tech Comments: *PERFORMED RECALL 08C01B
1FTWW31R08EA13871 T/F7 F T/BC T/CD T/E A1 T/BE T/QL 31-JAN-2007 28-FEB-2007 4A6792 CAN 15 2G05 031405 * RECALEM * D50 04 15982
AWS Claim Key: 911567 Trx Code: S07 Labor Hrs: 0.6
Dlr Cd-Sub Cd: B6198 - * Name: RAINBOW FORD SALES INC. Ph: 403-8453673 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:12-MAY-2008 Doc #:056447B
Cust Comments: LACKS POWER WILL NOT MAINTAIN SPEED
Tech Comments: *DIAG LACK POWER ROADTEST EEC TEST PASS CHECK OASIS PROPABLY GOING INTO REGEN REPROGRAMMED PCM TCM AND IC LATEST CALIBRACTION AS PER TSB 07 17 03 GOOD
1FTWW31R08EA13871 T/F7 F T/BC T/CD T/E A1 T/BE T/QL 31-JAN-2007 28-FEB-2007 4A6792 CAN 21 1F01 * * * * * * 21140
AWS Claim Key: 1974223 Trx Code: 08B06 Labor Hrs: 0.3
Dlr Cd-Sub Cd: B6198 - * Name: RAINBOW FORD SALES INC. Ph: 403-8453673 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:01-NOV-2008 Doc #:059023A
Cust Comments: RECALL 08B06
Tech Comments: PERFORM RECALL 08B06 INSTALL VENTURI TUBE
AWS Claim Key: 2006976 Trx Code: 08B06 Labor Hrs: 2.3
Dlr Cd-Sub Cd: B6198 - * Name: RAINBOW FORD SALES INC. Ph: 403-8453673 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:01-NOV-2008 Doc #:059023B
Cust Comments: COOLANT LEAK
Tech Comments: RR LEAKING RADIATOR
1FTWW31R08EA13871 T/F7 F T/BC T/CD T/E A1 T/BE T/QL 31-JAN-2007 28-FEB-2007 4A6792 CAN 31 2G01 * * * * * * 22092
AWS Claim Key: 4201616 Trx Code: 08B07 Labor Hrs: 0.5
Dlr Cd-Sub Cd: A6792 - * Name: M G M FORD LINCOLN SALES LTD. Ph: 403-3466621 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:24-AUG-2009 Doc #:20821701
Cust Comments: RECALL 08B07
Tech Comments: PERFORMED RECALL
1FTWW31R08EA13871 T/F7 F T/BC T/CD T/E A1 T/BE T/QL 31-JAN-2007 28-FEB-2007 4A6792 CAN 35 1F05 030306 * 8A616 * N50 42 29709
AWS Claim Key: 4956338 Trx Code: E84 Labor Hrs: 1.8
Dlr Cd-Sub Cd: A6792 - * Name: M G M FORD LINCOLN SALES LTD. Ph: 403-3466621 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:15-DEC-2009 Doc #:21253502
Cust Comments: CONCERN FOR JINGLING/RATTLING NOISE FROM FEAD AREA AFTER JOB 1
Tech Comments: VERIFIED CONCERN CHECKED OASIS FOUND NOTHING WITH VEH RUNNING PINPOINTED NOISE TO BE COMING FROM CENTER FEAD BELT AREA REMOVED UPPER FAN SHROUD REMOVED BELT STARTED VEH NOISE NOT PRESENT CHECKED ALL PULLIES ALL GOOD REINSTALLED BELT HOOK UP IDS AND MANUALLY SPED UP THE FAN IN DOING SO NOISE WENT AWAY REMOVED AND REPLACED FAN CLUTCH REINSTALLED BELT AND UPPER FAN SHROUD RETESTEDVERIFIED REPAIR
1FTWW31R08EA13871 T/F7 F T/BC T/CD T/E A1 T/BE T/QL 31-JAN-2007 28-FEB-2007 4A6792 CAN 35 1G03 030507 * 8620 * N50 42 29709
AWS Claim Key: 4956337 Trx Code: E84 Labor Hrs: 1.7
Dlr Cd-Sub Cd: A6792 - * Name: M G M FORD LINCOLN SALES LTD. Ph: 403-3466621 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:15-DEC-2009 Doc #:21253501
Cust Comments: CONCERN FOR SQUEALING NOISE FROM FEAD AREA
Tech Comments: VERIFIED CONCERN CHECKED OASIS FOUND TSB 09 9 8 FOLLOWED TSB REMOVED UPPER FAN SHROUD REMOVED AND REPLACED BELT AND IDLER PULLEY REINSTALLED NESC PARTS VERIFIED REPAIR
2000 F-350 supercrew 4x4. Banks new ram air, Autometer guages(Thanks GOS)Boost, pyro, trans temp. DP tuner F8.(Thanks Diane and Jody)
00f3fiddy is offline
post #3 of 3 (permalink) Old 09-21-2010, 05:34 PM Thread Starter
08F350's Avatar
Thanks very much...greatly appreciated
S&B CAI
Spartan TCM
Hang the heck On!!
08F350 is offline
Oasis request please! EJ Krueger Ford Oasis requests 1 04-09-2009 03:35 PM
Oasis request please bushpilot Ford Oasis requests 1 12-04-2007 12:22 PM
Oasis Request dck Ford Oasis requests 1 12-02-2007 08:01 PM
Oasis request riggz Ford Oasis requests 0 03-15-2007 01:38 PM
Oasis Request Please imported_gratcliffe Ford Oasis requests 1 03-12-2007 10:55 PM
