Oasis Report request - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by charlanay, this thread has received 1 replies and been viewed 802 times.
post #1 of 2 (permalink) Old 09-24-2010, 12:14 AM Thread Starter
I bought an 03 with 104k on it and am curious as to what was done to it prior to me. Thanks a million!
VIN# 1FTNW21P83EC73643
charlanay is offline
post #2 of 2 (permalink) Old 09-24-2010, 07:00 PM
Standard Claims List For Model Year 2003
1FTNW21P83EC73643 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 19-MAR-2003 03-APR-2003 171432 USA 2 6H11 011103 F81Z 2521453 AA B64 34 3221
AWS Claim Key: 1293610 Trx Code: 1 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 20363 - * Name: TOM JONES FORD Ph: 602-3864429 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:13-MAY-2003 Doc #:04939401
1FTNW21P83EC73643 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 19-MAR-2003 03-APR-2003 171432 USA 2 2G01 031401 * 12A650 * D21 42 3221
AWS Claim Key: 1293609 Trx Code: S07 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 20363 - * Name: TOM JONES FORD Ph: 602-3864429 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:13-MAY-2003 Doc #:04939701
1FTNW21P83EC73643 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 19-MAR-2003 03-APR-2003 171432 USA 3 7H01 120301 * 19703 * C02 42 7056
AWS Claim Key: 1512322 Trx Code: 2 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 20328 - * Name: SUNSET FORD, INC. Ph: 623-9778888 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:13-JUN-2003 Doc #:180152C
Cust Comments: AC DOESNT COOL ENOUGH IN HOT WEATHER
Tech Comments: AC DIAG HOOK UP MCAHINE CHECKED PRESSURES LOW SIDE140 HIGH 300. RECLAIM SYSTEM VACCUM TEST, CHARGED SYSTEM PROPERLY... PRESSURE ARE NOW 60 LOW 220 HI GH. AC WAS OVER CHARGED
1FTNW21P83EC73643 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 19-MAR-2003 03-APR-2003 171432 USA 4 6Y20 000001 * MISC * A98 82 7690
AWS Claim Key: 1784290 Trx Code: P01 Labor Hrs: 0
Dlr Cd-Sub Cd: 20328 - * Name: SUNSET FORD, INC. Ph: 623-9778888 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:15-JUL-2003 Doc #:182983A
Cust Comments: CUSTOMER SEEKS REIMBURSEMENT
Tech Comments: CUSTOMER SEEKS REIMBURSEMENT FOR 1 MONTH VEHICLE PAYMENT PER A.J. ROHDE
1FTNW21P83EC73643 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 19-MAR-2003 03-APR-2003 171432 USA 7 2G05 031405 * RECAL * D42 42 14783
AWS Claim Key: 2850840 Trx Code: E84 Labor Hrs: 1.6
Dlr Cd-Sub Cd: 20328 - * Name: SUNSET FORD, INC. Ph: 623-9778888 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:07-OCT-2003 Doc #:190107A
Cust Comments: VEH HAS LOW POWER...AND POOR FUEL ECONOMY
Tech Comments: VERIFY CONCERN CHECK OASIS CHECK FOR CODES MONITORAND RECORD PID DATA CHECFK BOOST OK UPDATE FICM T CM AND PCM MODULES WITH LATEST CALIBRATION AVAILABLE PER TSB 03 20 12 ROAD TEST
1FTNW21P83EC73643 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 19-MAR-2003 03-APR-2003 171432 USA 13 1D01 030008 3C3Z 6701 AA L65 D8 26558
AWS Claim Key: 5662704 Trx Code: E84 Labor Hrs: 5.8
Dlr Cd-Sub Cd: 20328 - * Name: SUNSET FORD, INC. Ph: 623-9778888 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:20-APR-2004 Doc #:207705A
Cust Comments: CK FLUID LEAK..OIL DRIPPING OFF BELL HOUSING
Tech Comments: DIAG OIL LEAKS. R AND I TRANSMISSION AND TRANSFER CASE. REPLACED REAR MAIN SEAL. TEST DROVE AFTER REPAIR.
1FTNW21P83EC73643 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 19-MAR-2003 03-APR-2003 171432 USA 15 5S01 100101 YC3Z 9002 MA E68 42 28157
AWS Claim Key: 6230508 Trx Code: S07 Labor Hrs: 1.9
Dlr Cd-Sub Cd: 20328 - * Name: SUNSET FORD, INC. Ph: 623-9778888 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:28-MAY-2004 Doc #:211243A
Cust Comments: CHECK FOR FUEL LEAK...SOP
Tech Comments: DIAG SMOKE TEST NEC TO R AND I SKID PLATE TO ACCESS FUEL TANK REPLACE RETEST OK
1FTNW21P83EC73643 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 19-MAR-2003 03-APR-2003 171432 USA 15 2G05 031405 * RECAL * D42 42 28948
AWS Claim Key: 6466902 Trx Code: E84 Labor Hrs: 1.7
Dlr Cd-Sub Cd: 20328 - * Name: SUNSET FORD, INC. Ph: 623-9778888 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:15-JUN-2004 Doc #:212869A
Cust Comments: CHECK ENGINE LIGHT WAS ON LAST NIGHT NOT ON THE AM
Tech Comments: DIAG 1 15 PID MONITOR PINPOINT TEST NEC TO REPROGRAM PCM FICM AND TCM FOR UPDATE
1FTNW21P83EC73643 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 19-MAR-2003 03-APR-2003 171432 USA 16 * * * * * * * 30402
AWS Claim Key: 6780597 Trx Code: 04S15 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 20328 - * Name: SUNSET FORD, INC. Ph: 623-9778888 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:09-JUL-2004 Doc #:214949B
Cust Comments: RECALL 04S15 NEGATIVE BATTERY TERMINAL TO ENGINE BLOCK CONNECTION
Tech Comments: INSPECT AND REPLACE GROUND BOLT LOOSE AS PER RECALL 04S15.
1FTNW21P83EC73643 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 19-MAR-2003 03-APR-2003 171432 USA 25 1H03 030008 * 9F452 * D42 41 46430
AWS Claim Key: 10535106 Trx Code: E72 Labor Hrs: 1.8
Dlr Cd-Sub Cd: 20329 - * Name: DON SANDERSON FORD LINCOLN MERCURY Ph: *-* St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:16-APR-2005 Doc #:25812901
Cust Comments: CUST STS LAST NIGHT WHILE DRIVING ON FREEWAY VEHICLE BUCKED LOST POWER AND BLEW A BIG CLOUD OF WHITE SMOKE, NOW VEHICLE
Tech Comments: PERFORMED EEC TEST CODE P0404 PERSENT.MONITORED EGR WHILE COMMANDING IT OPEN AND CLOSED WITH WDS.FOUND EGR STUCK. REPLACED EGR VALVE.NECESSRAY TO REPROGRAM PCM WITH 3U7A 12A650 FTE.ROAD TEST ENG RUNS RUNS NORMAL.RERAN QUICK TEST KOEO PADSS KOER PASS
1FTNW21P83EC73643 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 19-MAR-2003 03-APR-2003 171432 USA 33 2G01 * * * * * * 57145
AWS Claim Key: 12541711 Trx Code: 03L12 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 20301 - * Name: DON SANDERSON FORD LINCOLN MERCURY Ph: 623-8428600 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:18-NOV-2005 Doc #:30707103
Cust Comments: RECALL 03L12 EECI LABEL REPLACEMENT
Tech Comments: 1 INSTALLED EECI LABEL.
1FTNW21P83EC73643 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 19-MAR-2003 03-APR-2003 171432 USA 33 2E01 030008 3C3Z 9F838 EA L65 42 57145
AWS Claim Key: 12541712 Trx Code: E72 Labor Hrs: 3.8
Dlr Cd-Sub Cd: 20301 - * Name: DON SANDERSON FORD LINCOLN MERCURY Ph: 623-8428600 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:18-NOV-2005 Doc #:30707101
Cust Comments: CUST STATES THERE IS AN OIL LEAK FROM TOP DOWN TO BELL HOUSING ADVISE
Tech Comments: BLACK LIGHT.ICP LEAKING OIL INTERNAL TO THE CONNECTOR. REMOVED FICM,FICM BRACKET,DEGASS BOTTLE,AIR FILTER BOX TO GAIN ACESS.REPLACED ICP AND CONNECTOR.CLEANED OIL OUT. M TIME TO GAIN ACESS AND CLEAN.
1FTNW21P83EC73643 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 19-MAR-2003 03-APR-2003 171432 USA 39 1D01 03XXXX 3C3Z 6701 AA L65 D8 65868
AWS Claim Key: 14010359 Trx Code: E72 Labor Hrs: 4.9
Dlr Cd-Sub Cd: 20301 - * Name: DON SANDERSON FORD LINCOLN MERCURY Ph: 623-8428600 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:12-JUN-2006 Doc #:35200002
Cust Comments: CUST STATES HE HAS A LEAK FROM THE REAR MAIN SEAL AREA CK AND ADVISE.
Tech Comments: 6701,,,FAILED SEAL. PERFORM OIL LEAK DIAG WITH BLACK LIGHT. PINPOINT TO REAR MAIN SEAL. NEC TO R&I TRANS AND REPLACE REAR MAIN SEAL 3 REINSTALL TRANS AND RETEST, ALL OK.
1FTNW21P83EC73643 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 19-MAR-2003 03-APR-2003 171432 USA 39 7S06 030008 3C3Z 12B637 BA D42 42 65868
AWS Claim Key: 14072669 Trx Code: E72 Labor Hrs: 20.7
Dlr Cd-Sub Cd: 20301 - * Name: DON SANDERSON FORD LINCOLN MERCURY Ph: 623-8428600 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:12-JUN-2006 Doc #:35200001
Cust Comments: CUST STATES VEHICLE HAS NO POWER. WHEN ACCELERATING RPM WILL GO UP AND THEN VEHICLE WILL GO AFTER A LONG DELAY CK AND ADVISE
Tech Comments: 12B637 HARNESS,,OPEN CKT. VERIFY6.0L CONCERN. LACKS POWER ON ACCEL. COMPLETE PERFORMANCE SHEET. ALL PRECHECKS OK. KOEO, PASS. INJ TEST,PASS. CMDTC,P0401,403,405. CLEAR AND RETEST, PASS. ITNAKE,3. EGR, TO REPALCE EGR VALVE DUE TO BINDING. RETEST. OK. STILL. FOUND EGR V ERRATIC. WIGGLE TEST AT HARNESS NEAR TURBO. NEC. TO REPLACE HARNESS. NEC TO R&I COOLANT BOTTLE,FICM MODULE, LH BATT AND TRAY,FAN,SH
1FTNW21P83EC73643 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 19-MAR-2003 03-APR-2003 171432 USA 88 * * * * * * * 116105
AWS Claim Key: 16686340 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 20360 - * Name: BELL FORD Ph: 602-8661776 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:11-JUN-2010 Doc #:34912003
Cust Comments: 06E17 CONTROL MODULE RECALIBRATION
Tech Comments: REPROGRAMMED ALL ENGINE CONTROL MODULES PER FSA 06E17
2000 F-350 supercrew 4x4. Banks new ram air, Autometer guages(Thanks GOS)Boost, pyro, trans temp. DP tuner F8.(Thanks Diane and Jody)
00f3fiddy is offline
Request OASIS report 300 H&H Ford Oasis requests 2 02-05-2008 01:14 PM
OASIS report request Pa_Pa Alan Ford Oasis requests 3 01-10-2008 02:15 PM
Request For Oasis Report Boaz Ford Oasis requests 1 01-05-2008 03:51 AM
OASIS Report Request BCFlyfisher Ford Oasis requests 3 10-24-2006 01:16 AM
OASIS Report Request Excursion_Nut Ford Oasis requests 1 10-20-2006 05:18 PM
