Oasis Report Request - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by ZZZX2, this thread has received 2 replies and been viewed 884 times.
post #1 of 3 (permalink) Old 09-25-2010, 04:10 PM Thread Starter
Cool Oasis Report Request
Hi,
I recently purchased a 2004 Ford F350 Diesel CC 4X4 SB from a private party that could not provide any service history beyond the past year. I'd really appreciate it if I could obtain an Oasis Report with the service history on this truck. The VIN is 1FTSW31P94EB40819.
Thanks,
Ray F
ZZZX2
ZZZX2 is offline
post #2 of 3 (permalink) Old 09-27-2010, 01:41 PM
Standard Claims List For Model Year 2004
1FTSW31P94EB40819 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-NOV-2003 02-DEC-2003 171084 USA 1 6Y05 000001 * MAINT * A96 82 2262
AWS Claim Key: 225092 Trx Code: 0784S Labor Hrs: 1.6
Dlr Cd-Sub Cd: 05466 - * Name: DREW FORD Ph: 619-4647777 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:12-DEC-2003 Doc #:07291751
Cust Comments: 3,000 MILE GAS AND G O MAINT.
Tech Comments: CHANGE OIL FILTER MULTI POINT INSPECTION ROTATE TIRES
1FTSW31P94EB40819 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-NOV-2003 02-DEC-2003 171084 USA 1 6H08 011105 * 15422B30 * G07 41 2314
AWS Claim Key: 250417 Trx Code: 2 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 05466 - * Name: DREW FORD Ph: 619-4647777 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:16-DEC-2003 Doc #:07363352
Cust Comments: REAR POWER SLIDER MAKES A GRIND NOISE WHEN CLOSING 3 36
Tech Comments: INSPECT AND FOUND REAR SIIDING WINDOW BINDING MT IS TO CLEAN AND LUBE TRACKS AND GLASS VERIFY REPAIRS
1FTSW31P94EB40819 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-NOV-2003 02-DEC-2003 171084 USA 1 6H18 011101 * 1503100 * G07 42 2314
AWS Claim Key: 250416 Trx Code: 2 Labor Hrs: 0
Dlr Cd-Sub Cd: 05466 - * Name: DREW FORD Ph: 619-4647777 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:16-DEC-2003 Doc #:07363351
Cust Comments: THERE IS A BLEMISH IN CENTER OF WINDSHIELD 3 36 HECKMAN TO REPAIR
Tech Comments: OSL OUTSIDE LABOR
1FTSW31P94EB40819 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-NOV-2003 02-DEC-2003 171084 USA 1 7D07 170202 F4DZ 13466 A L25 46 2480
AWS Claim Key: 241188 Trx Code: 2 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 05466 - * Name: DREW FORD Ph: 619-4647777 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:24-DEC-2003 Doc #:07537051
Cust Comments: PASS SIDE MAP LIGHT INOP
Tech Comments: DIAG AND TEST MAP AND DOME LAMP SWITCH USING A DVOM FOUND DOME LAMP BULB IN OVEN HOOD CONSOLE WAS BURNED OUT MT IS TO REMVOE CONSOLE AND REPLACE BULB VERIFY REPAIRS
1FTSW31P94EB40819 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-NOV-2003 02-DEC-2003 171084 USA 4 6Y05 000001 * MAINT * A99 82 5715
AWS Claim Key: 648874 Trx Code: 0784S Labor Hrs: 1.4
Dlr Cd-Sub Cd: 05466 - * Name: DREW FORD Ph: 619-4647777 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:30-MAR-2004 Doc #:09634852
Cust Comments: GAS & GO 6,000 MILE SERVICE
Tech Comments: CHANEG OIL FILTER MULTI POINT INSPECTION ROTATE TIRES
1FTSW31P94EB40819 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-NOV-2003 02-DEC-2003 171084 USA 4 2E03 031401 * 12B599 * D21 42 5715
AWS Claim Key: 662936 Trx Code: S07 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 05466 - * Name: DREW FORD Ph: 619-4647777 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:30-MAR-2004 Doc #:09634851
Cust Comments: ENG STALLS WHEN DRVIING INTER DIESEL 3 36 DIESEL DO NOT REFLASH PCM
Tech Comments: INSPECT FOR CHAFED WIRING NEAR IPM UNABLE TO DUPLICATE ADD COOLANT ROADTEST OK FORD HOTLINE STATED CHAFING AT IPM WIRING ON V C ASSY MAY BE THE CAUSE
1FTSW31P94EB40819 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-NOV-2003 02-DEC-2003 171084 USA 7 6Y05 000001 * MAINT * A99 82 8987
AWS Claim Key: 1249216 Trx Code: 0784S Labor Hrs: 1.5
Dlr Cd-Sub Cd: 05466 - * Name: DREW FORD Ph: 619-4647777 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:21-JUN-2004 Doc #:01417151
Cust Comments: GAS & GO 9,000 MILE SERVICE PLEASE DRAIN FUEL SEPERATER
Tech Comments: MAINT 9K SERVICE
1FTSW31P94EB40819 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-NOV-2003 02-DEC-2003 171084 USA 8 6C06 010503 3C3Z 78519A70 AAA G29 42 9364
AWS Claim Key: 1249217 Trx Code: 2 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 05466 - * Name: DREW FORD Ph: 619-4647777 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:05-JUL-2004 Doc #:01723951
Cust Comments: OVERHEAD CUMPAS RESETS DIRECTION INTER S.O.P. IS HERE 3 36
Tech Comments: VERIFY CONCERN M TIME IS TO REPLACE HEAD TRIP COMPUTER VERIFY REPAIR
1FTSW31P94EB40819 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-NOV-2003 02-DEC-2003 171084 USA 10 1H03 030008 3C3Z 9J460 AA E29 42 11160
AWS Claim Key: 1739178 Trx Code: S07 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 05466 - * Name: DREW FORD Ph: 619-4647777 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:28-AUG-2004 Doc #:02904351
Cust Comments: THE CHECK ENGINE L IGHT WAS ON AND HAS NOW GONE OFF 336
Tech Comments: VERFIY ENGINE LIGHT ON REFER TO PCED SYMPTOM CHART #6 KOEO P0299 REFER TO PIN POINT TEST KA1 PRE CHECK PASS KA2 EOT PID PASS KA4 KOEO ICP .20VOLTS KA5 MONITOR BIAS SENSOR REPLACE FAULTY EBP SENSOR KOEO PASS MT NO OP REPLACE EBP SENSOR
1FTSW31P94EB40819 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-NOV-2003 02-DEC-2003 171084 USA 10 6Y05 000001 * MAINT * A99 82 11993
AWS Claim Key: 1885162 Trx Code: 0784S Labor Hrs: 1.8
Dlr Cd-Sub Cd: 05466 - * Name: DREW FORD Ph: 619-4647777 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:15-SEP-2004 Doc #:03278051
Cust Comments: 12,000 MILE SERVICE CUSTOMER NOTES PLEASE DRAIN FUEL AND WATER SEPARATOR AND DO NOT RE FLASH.
Tech Comments: CHANGE OIL AND FILTER ROTATE TIRES AND PERFORM MULTIPOINT INSPECTION
1FTSW31P94EB40819 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-NOV-2003 02-DEC-2003 171084 USA 12 6Y05 000001 * MAINT * A99 82 15193
AWS Claim Key: 2484951 Trx Code: 0784S Labor Hrs: 1.8
Dlr Cd-Sub Cd: 05466 - * Name: DREW FORD Ph: 619-4647777 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:05-NOV-2004 Doc #:04298851
Cust Comments: 15,000 MILE SERVICE 3K SERVICE HEAVY DUTY
1FTSW31P94EB40819 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-NOV-2003 02-DEC-2003 171084 USA 45 1B01 0302XX 3C3Z 6619 AA L65 D1 59225
AWS Claim Key: 11904760 Trx Code: E72 Labor Hrs: 5.8
Dlr Cd-Sub Cd: 02935 - * Name: DON KOTT FORD Ph: *-* St:CA Ctry Cd: USA Reg Cd: NA Repr Date:23-JUL-2007 Doc #:055791E
Cust Comments: VEHICLE IS LEAKING MOTOR OIL
Tech Comments: ADD OIL DYE AND PERF OIL LEAKS DIAG FOUND LEAKING AT OIL COOLER AREA REMOVE AND RESEL OIL COOLER CLEAN OIL RESIDUES AND PERF ROAD TEST AND REINSPE
1FTSW31P94EB40819 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-NOV-2003 02-DEC-2003 171084 USA 45 * * * * * * * 59225
AWS Claim Key: 11904757 Trx Code: 05S34 Labor Hrs: 1.1
Dlr Cd-Sub Cd: 02935 - * Name: DON KOTT FORD Ph: *-* St:CA Ctry Cd: USA Reg Cd: NA Repr Date:23-JUL-2007 Doc #:055791A
Cust Comments: PERORRM RECALL 05S34
1FTSW31P94EB40819 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-NOV-2003 02-DEC-2003 171084 USA 45 2E03 030402 4C3Z 9E527 AA D50 42 59225
AWS Claim Key: 11921535 Trx Code: E72 Labor Hrs: 7.4
Dlr Cd-Sub Cd: 02935 - * Name: DON KOTT FORD Ph: *-* St:CA Ctry Cd: USA Reg Cd: NA Repr Date:23-JUL-2007 Doc #:055791D
Cust Comments: CJECK ENGIEN LIGHT IS ON
Tech Comments: PERF DIAG VERIFY ENGINE RUN ROUGH AND LACK OF POWER ENGINE PERF DIAG KOEO INJ ELECTRICAL SEL TEST TEST P0300 P0341 ICP TST PAS CK FUEL CONT OK FUEL PUMP PRESS OK 55SP CK OIL AERATION TEST OK FUEL AERATION OK OWER BALACE CYL 4 INOP AND CYLS 5 LOW CONT PERF PIN POINT TEST WIRE HARNESS CK FUEL PRESS OK 55PSI FURTHER REMOVE VCOVERS INSPECT FUEL INJ FOUND INJ5 LEAKING OIL RESEAL INJ5 AND REPLA
AWS Claim Key: 11904758 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 02935 - * Name: DON KOTT FORD Ph: *-* St:CA Ctry Cd: USA Reg Cd: NA Repr Date:23-JUL-2007 Doc #:055791B
Cust Comments: PERFORM RECALL 05E15
AWS Claim Key: 11904759 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 02935 - * Name: DON KOTT FORD Ph: *-* St:CA Ctry Cd: USA Reg Cd: NA Repr Date:23-JUL-2007 Doc #:055791C
Cust Comments: PERFORM RECALL 59B01
1FTSW31P94EB40819 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-NOV-2003 02-DEC-2003 171084 USA 56 2E03 030402 4C3Z 9E527 BRM D41 42 60697
AWS Claim Key: 12871820 Trx Code: S07 Labor Hrs: 4.5
Dlr Cd-Sub Cd: 03166 - * Name: PACIFIC FORD Ph: *-* St:CA Ctry Cd: USA Reg Cd: NA Repr Date:19-JUN-2008 Doc #:01075153
Cust Comments: AFTER REPAIR ON LINE 51 TRUCK RUNS ROUGH MISSING AND HAS LACK OF POWER CK ADVISE
Tech Comments: PERFORM DIESEL ENGINE DIAGNOSIS, KOEO PASS, KOER P0263, P0266. PERFORMED DIAGNOSIS PER TSB 06 13 03, NEGATIVE FUEL PRESSURE TEST PASS, COMBUSTION GAS INTO FUEL SYSTEM TEST PASSED ON BOTH BANKS, ERRATIC HIGH PRESSURE OIL SUPPLY TEST PASSED, CHECK VALVE DIAGNOSIS PASSED. PROBLEM IS INTERMITTENT AND UNDER LOAD UP HILLS. REPLACED FUEL INJECTORS #1 AND 2, ALSO NECESSARY TO REPLACE CATALYTIC CONVERTE
1FTSW31P94EB40819 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-NOV-2003 02-DEC-2003 171084 USA 56 1A01 030102 3C3Z 6049 CARM D02 42 60697
AWS Claim Key: 12878976 Trx Code: E72 Labor Hrs: 32.8
Dlr Cd-Sub Cd: 03166 - * Name: PACIFIC FORD Ph: *-* St:CA Ctry Cd: USA Reg Cd: NA Repr Date:19-JUN-2008 Doc #:01075151
Cust Comments: TOWED IN CUSTOMER STATES NO CRANK NO START CK ADVISE TURBO BOOST GOOD, 26.3PSI. PERFORM FINAL TEST, P
Tech Comments: VERIFIED ENGINE WON'T CRANK. STARTER SYSTEM GOOD. VISUAL INSPECTION, DEGAS BOTTLE EMPTY AND OIL SMELLED BURNT. REMOVED GLOW PLUGS, FOUND WATER IN CYLINDER. CRANKED ENGINE TO VENT LIQUID FROM CHAMBER. TEST DEGAS BOTTLE AND CAP, FAILED, REPLACED. PERFORM EGR COOLER LEAK TEST ON VEH. REMOVE COOLER AND BENCH TEST, FAIL. APPLY VACUUM TO OIL COOLER, DOES NOT HOLD VACUUM, REPL EGR COOLER. RD TEST W/IDS,
2000 F-350 supercrew 4x4. Banks new ram air, Autometer guages(Thanks GOS)Boost, pyro, trans temp. DP tuner F8.(Thanks Diane and Jody)
00f3fiddy is offline
post #3 of 3 (permalink) Old 09-30-2010, 05:22 AM Thread Starter
Cool Thank you
Thanks so much for your help. This gives me an excellent record of the dealer service work completed to date.
Ray F
ZZZX2
ZZZX2 is offline
OASIS Report Request flightlevel0 Ford Oasis requests 1 08-10-2010 09:19 PM
Oasis Report Request pstrang Ford Oasis requests 0 05-10-2010 07:01 PM
Oasis report request superfuzz Ford Oasis requests 2 12-10-2007 10:52 PM
OASIS Report Request Savoy John Ford Oasis requests 1 10-16-2006 12:05 AM
OASIS report request please OpenTrackRacer Ford Oasis requests 1 10-04-2006 02:29 AM
