Oasis Report Please, Thanks! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by rcm9, this thread has received 1 replies and been viewed 663 times.
post #1 of 2 (permalink) Old 10-05-2010, 02:28 PM Thread Starter
1FTSX21P46EC70839
rcm9 is offline
post #2 of 2 (permalink) Old 10-11-2010, 03:04 PM
Standard Claims List For Model Year 2006
1FTSX21P46EC70839 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 19-JAN-2006 05-SEP-2006 144012 USA 20 5O05 110301 8C3Z 3E652 A N27 42 15758
AWS Claim Key: 5935212 Trx Code: E84 Labor Hrs: 1.4
Dlr Cd-Sub Cd: 00503 - * Name: C BASIL FORD INC Ph: 716-8973673 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:31-MAR-2008 Doc #:276957C
Cust Comments: CK FRONT END SHAKES UNCONTROLABLE OVER BUMPS
Tech Comments: 15758 PERFORM DAIG INSTALL STABILIZER AS PER TSB 07 10 10
1FTSX21P46EC70839 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 19-JAN-2006 05-SEP-2006 144012 USA 20 2G05 031405 * RECALEM * E29 04 15758
AWS Claim Key: 5935211 Trx Code: S07 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 00503 - * Name: C BASIL FORD INC Ph: 716-8973673 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:31-MAR-2008 Doc #:276957A
Cust Comments: CUSTOMER STATES CHECK ENGINE LIGHT IS ON *AMBER IN COLOR*
Tech Comments: 15758 PERFOMRDAIG CODE P0460 REPROGRAM PCM PER TSB06 13 11
1FTSX21P46EC70839 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 19-JAN-2006 05-SEP-2006 144012 USA 20 6N04 010802 5C3Z 16720 VA B63 33 15758
AWS Claim Key: 5944673 Trx Code: E84 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 00503 - * Name: C BASIL FORD INC Ph: 716-8973673 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:01-APR-2008 Doc #:277054A
Cust Comments: CUSTOMER STATES THAT NAME PLATES ARE PEELING
Tech Comments: REMOVE 3 NAME PLATES,CLEAN UP OLD GLUE,REINSTAL L 3 NEW NAME PLATES
1FTSX21P46EC70839 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 19-JAN-2006 05-SEP-2006 144012 USA 28 1H03 030008 5C3Z 9J460 B E29 42 31941
AWS Claim Key: 7592878 Trx Code: S07 Labor Hrs: 1
Dlr Cd-Sub Cd: 00503 - * Name: C BASIL FORD INC Ph: 716-8973673 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:11-DEC-2008 Doc #:296668A
Cust Comments: CUSTOMER STATES CHECK ENGINE LIGHT IS ON *AMBER IN COLOR* 0
Tech Comments: 31951 CHECKED CODES ANDS FOUND P0470. CHECKED WIRING FROM EBP SENSOR TO PCM AND FOUND OK. REPLACED SENSOR AND CLEARED CODES TEST DROVE OK
1FTSX21P46EC70839 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 19-JAN-2006 05-SEP-2006 144012 USA 36 5O01 110201 7C3Z 3504 A H22 42 33765
AWS Claim Key: 8529891 Trx Code: E84 Labor Hrs: 4.2
Dlr Cd-Sub Cd: 00503 - * Name: C BASIL FORD INC Ph: 716-8973673 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:13-AUG-2009 Doc #:315127C
Cust Comments: CUSTOMER STATES THAT THE STEERING IS BINDING (JERKS THEN IS HARD TO GET BACK TO CENTER
Tech Comments: 33772 TEST DROVE AND FOUND THAT STEERING IS HARD. FOUND FRONT HUBS FROZEN,FOUND POWER STEERING PUMP LEAKING AND GEAR VERY HARD TO TURN OVER CENTER. REPLACED FRONT HUBS AND PUMP. REPLACED GEAR. HAD TO REPLACED LINE FROM GEAR TO HYDRO BOOST BECAUSE IT WAS FROZEN IN GEAR.BLEED SYSTEM AND PERFORMED FRONT ALIGNMENT. TEST DROVE OK
1FTSX21P46EC70839 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 19-JAN-2006 05-SEP-2006 144012 USA 36 2H01 03XXXX * 6K682 * E29 42 33765
AWS Claim Key: 8538176 Trx Code: S07 Labor Hrs: 8.2
Dlr Cd-Sub Cd: 00503 - * Name: C BASIL FORD INC Ph: 716-8973673 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:13-AUG-2009 Doc #:315127B
Cust Comments: CUSTOMER STATES THAT THE ENGINE LIGHT IS ON AND OFF, AND IS RUNNING ROUGH
Tech Comments: 33772 TEST DROVE AND FOUND RUNNING ROUGH. RAN THRU PERFORMANCE SHEET.CHECKEDOIL LEVEL AND FUEL OK. CHECKED FOR CODES AND FOUND P0263,P0284,P0299,P0300,P0487,P0611. RAN BUZZ TEST AND FOUND CODE P0611.REPROGRAM PCM FICM AND TCM.RERAN BUZZ TEST AND STILL GOT GOT P0611.REPLACED FICM. PERFORMED CYLINDER BALANCE AND FOUND #1 AND #8 INJECTORS MISSINGS. REPLACED INJECTORS (ONE ON EACH
2000 F-350 supercrew 4x4. Banks new ram air, Autometer guages(Thanks GOS)Boost, pyro, trans temp. DP tuner F8.(Thanks Diane and Jody)
00f3fiddy is offline
Oasis Report Please JamesP Ford Oasis requests 2 02-04-2008 04:29 AM
oasis report please #2 firedude26 Ford Oasis requests 2 02-04-2008 12:22 AM
Oasis Report Please BozoTheClown Ford Oasis requests 1 02-03-2008 10:42 PM
Oasis Report Please 760 PSD Ford Oasis requests 1 01-11-2008 07:13 PM
OASIS Report CombatSent Ford Oasis requests 1 12-13-2006 12:51 PM
