2003 F-350 Oasis Report - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by FireRescueFL, this thread has received 4 replies and been viewed 1230 times.
post #1 of 5 (permalink) Old 10-05-2010, 08:00 PM Thread Starter
Exclamation 2003 F-350 Oasis Report
Hi guys. I'm new here and I'm looking at buying a used F-350. I went to the local Ford dealer who tried to get me a report but their system is down for maintenance until the 9th! I'm looking to buy this truck in the next day or two. Can anyone here help out a noobie ASAP?
1FTSW31P53EC34680
Thanks in advance!
---Chris
FireRescueFL is offline
post #2 of 5 (permalink) Old 10-11-2010, 03:06 PM
Standard Claims List For Model Year 2003
1FTSW31P53EC34680 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-FEB-2003 27-FEB-2003 124227 USA 3 2E01 030008 3C3Z 9F838 EA D50 42 3744
AWS Claim Key: 1201200 Trx Code: 1 Labor Hrs: 4.1
Dlr Cd-Sub Cd: 03073 - * Name: MULLINAX FORD Ph: 407-8897600 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:13-MAY-2003 Doc #:359329F
Cust Comments: D13 ENG IDLES ROUGH
Tech Comments: INSPECTED AND PERFORMED DIESEL DIAG 1 14 AND REPLACED ICP SENSOR AND RETESTED DTC P2285
1FTSW31P53EC34680 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-FEB-2003 27-FEB-2003 124227 USA 3 * * * * * * * 3744
AWS Claim Key: 1190104 Trx Code: 57B98 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 03073 - * Name: MULLINAX FORD Ph: 407-8897600 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:13-MAY-2003 Doc #:359329B
Cust Comments: A99 57B98 DIESEL OIL AND FILTER PER RECALL
Tech Comments: 3745 57B98 FREE DIESEL OIL AND FILTER CHANGE FOR PERFORMED RECALLS 03B05 06 57B98B 0.5 LABOR
1FTSW31P53EC34680 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-FEB-2003 27-FEB-2003 124227 USA 3 2G05 * * * * * * 3744
AWS Claim Key: 1190103 Trx Code: 03B06 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 03073 - * Name: MULLINAX FORD Ph: 407-8897600 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:13-MAY-2003 Doc #:359329A
Cust Comments: A99 03B06 COLD CAL PER RECALL
Tech Comments: 3745 03B06B .7 PERFORMED RECALIBRATIONS PER RECALL
1FTSW31P53EC34680 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-FEB-2003 27-FEB-2003 124227 USA 10 2G01 * * * * * * 18065
AWS Claim Key: 3678735 Trx Code: 03L12 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 04984 - * Name: KEY SCALES FORD, INC. Ph: 352-7873511 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:09-DEC-2003 Doc #:13683302
Tech Comments: PERFORM RECALL 03L12
1FTSW31P53EC34680 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-FEB-2003 27-FEB-2003 124227 USA 10 2G05 031405 * RECAL * D13 82 18065
AWS Claim Key: 3678734 Trx Code: E84 Labor Hrs: 5.3
Dlr Cd-Sub Cd: 04984 - * Name: KEY SCALES FORD, INC. Ph: 352-7873511 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:09-DEC-2003 Doc #:13683301
Cust Comments: COLD START,ERATIC IDLE,SHAKES WHEN PUT INTO GEAR.
Tech Comments: ENG PERF TESTS 1 15,NO CODES IN MEMORY,NO ACTIVE CODES. PERFORM TSB 03 20 12,REPROGRAM FICM,TCM,PCM.
1FTSW31P53EC34680 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-FEB-2003 27-FEB-2003 124227 USA 11 1F01 030301 * 8005 * C07 82 20495
AWS Claim Key: 4059953 Trx Code: E84 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 04984 - * Name: KEY SCALES FORD, INC. Ph: 352-7873511 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:12-JAN-2004 Doc #:13718901
Cust Comments: NO HEAT INTERMITTENTLY WHILE DRIVING STARTED GETTING COLD.
Tech Comments: VERIFY,HEAT INOP AT STOPS AND AT IDLE. FOUND COOLANT LEVEL LOW,ADD COOLANT,HEAT OPERATING PROPERLY NOW.,NO LEAKS FOUND.
1FTSW31P53EC34680 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-FEB-2003 27-FEB-2003 124227 USA 11 6Y05 000001 * ESPRCR * A96 82 20624
AWS Claim Key: 4359847 Trx Code: RCR Labor Hrs: 0
Dlr Cd-Sub Cd: 04984 - * Name: KEY SCALES FORD, INC. Ph: 352-7873511 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:15-JAN-2004 Doc #:13724105
1FTSW31P53EC34680 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-FEB-2003 27-FEB-2003 124227 USA 11 1H03 030008 3C3Z 9P456 AC L87 D1 20624
AWS Claim Key: 4447531 Trx Code: E84 Labor Hrs: 10.3
Dlr Cd-Sub Cd: 04984 - * Name: KEY SCALES FORD, INC. Ph: 352-7873511 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:15-JAN-2004 Doc #:13724101
Cust Comments: COOLANT LEAK DRIPPING BEHIND RIGHT FRONT WHEEL.
Tech Comments: PRESSURE TEST SYSLEAK RHT RAER SIDE IF ENG. CALL H/L AL SAID MOST LIKELY EGR COOLER. REPLACE EGR COOLER,R/R TURBO,REAR BOLT STRIPED,CALL H/L ONLY ACCESS BOLT HEAD R/R TRANS AND EXHAUST TUBE,RADIATOR,UNDO ENG MOUNTS,SLIDE ENG FORWARD,REPLACE EGR COOLER,CHANGE OIL AND FILTER. NOW THERE IS A AIR NOISE,CALL H/L,WDS TEST,USE ELEC EARS,NESS TO R/R TURBO,AND REPAIR BURR ON TURBO MOUNTING SURFACE TO EXHA
1FTSW31P53EC34680 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-FEB-2003 27-FEB-2003 124227 USA 11 1H03 030804 * 9D448 * N12 D1 20624
AWS Claim Key: 4558051 Trx Code: E84 Labor Hrs: 0
Dlr Cd-Sub Cd: 04984 - * Name: KEY SCALES FORD, INC. Ph: 352-7873511 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:15-JAN-2004 Doc #:13724102
Cust Comments: AIR NOISE WHEN AT IDLE,AND ON ACCEL.
Tech Comments: VERIFY,WDS TEST,NOISE DIAG WITH ELEC EARS,NESSASARY TO R/R TURBO AND REPOSITION EXHAUST TUBES,NOISE IS LESSENED,BUT NOT COMPLETELY GONE,TOLD CUST VE TRUCK,AND IF THEY FIND THE NOISE IS STILL MORE THAN THEY ACCEPT,TO BRING IT BACK,AND WE WILL REPLACE THE EXHAUST TUBES.
1FTSW31P53EC34680 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-FEB-2003 27-FEB-2003 124227 USA 13 1H05 031004 3C3Z 6766 BA D02 42 21294
AWS Claim Key: 4786200 Trx Code: S07 Labor Hrs: 4.7
Dlr Cd-Sub Cd: 04984 - * Name: KEY SCALES FORD, INC. Ph: 352-7873511 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:23-FEB-2004 Doc #:13770702
Cust Comments: ENGINE CRANKS WILL NOT START.
Tech Comments: ENG PERF TESTS 1 15,P/P TEST,R 1 CODE 2623,R 2 9.0 OHMS,CALL HOTLINE JOHN,TOLD TO REPLACE IPR VALVE,CLEAR CODES,RETEST.
1FTSW31P53EC34680 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-FEB-2003 27-FEB-2003 124227 USA 13 2H01 090301 3C3Z 6N646 AA D50 42 21294
AWS Claim Key: 4786199 Trx Code: E84 Labor Hrs: 7.2
Dlr Cd-Sub Cd: 04984 - * Name: KEY SCALES FORD, INC. Ph: 352-7873511 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:23-FEB-2004 Doc #:13770701
Cust Comments: AIR NOISE COMMING FROM ENGINE.
Tech Comments: CALLED H/L,TOLD TO REPLACE TURBO EXHAUST TUBES,KNOWN CONCERN. R/R TRANS AND TURBO,REPLACE TURBO EXHAUST TUBES. VERIFY REPAIR.
1FTSW31P53EC34680 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-FEB-2003 27-FEB-2003 124227 USA 19 2E03 03XXXX 3C3Z 9C968 AA D03 42 31136
AWS Claim Key: 7544237 Trx Code: S07 Labor Hrs: 4.1
Dlr Cd-Sub Cd: 01200 - * Name: NICK NICHOLAS FORD, INC. Ph: 352-7261231 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:28-AUG-2004 Doc #:00213451
Cust Comments: CUSTOMER STATES CRANK NO START INTEMITTTLY
Tech Comments: DIESEL DIAGNOSIS DIAG SYSTEM AND RETEST REPLACE IPR VALVE RETEST ROAD TEST
1FTSW31P53EC34680 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-FEB-2003 27-FEB-2003 124227 USA 19 * * * * * * * 31136
AWS Claim Key: 7576509 Trx Code: 04S15 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 01200 - * Name: NICK NICHOLAS FORD, INC. Ph: 352-7261231 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:28-AUG-2004 Doc #:00213452
Cust Comments: 04S15 RECALL
Tech Comments: RECALL 04S15 COMPLETED
1FTSW31P53EC34680 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-FEB-2003 27-FEB-2003 124227 USA 22 6P07 01XXXX 2C3Z 7811586 BAB B54 01 35612
AWS Claim Key: 8510114 Trx Code: E84 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 04984 - * Name: KEY SCALES FORD, INC. Ph: 352-7873511 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:18-NOV-2004 Doc #:01068601
Cust Comments: CUSTOMER STATES: OVERHEAD CONSOLE DOOR FELL OFF CC B54
Tech Comments: INSTALLED SOP OVERHEAD CONSOLE DOOR BROKEN
1FTSW31P53EC34680 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-FEB-2003 27-FEB-2003 124227 USA 30 2E05 100106 3C3Z 9B249 AB G29 42 58761
AWS Claim Key: 11679839 Trx Code: E72 Labor Hrs: 2.1
Dlr Cd-Sub Cd: 01200 - * Name: NICK NICHOLAS FORD, INC. Ph: 352-7261231 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:10-AUG-2005 Doc #:01784551
Cust Comments: WATER IN FUEL LIGHT ON
Tech Comments: ERRATIC ENGINE PERFORMANCE DIAGNOSTICS DIESEL ENGINE DIAGNOSIS
1FTSW31P53EC34680 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-FEB-2003 27-FEB-2003 124227 USA 38 * * * * * * * 74734
AWS Claim Key: 13559982 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 01200 - * Name: NICK NICHOLAS FORD, INC. Ph: 352-7261231 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:10-APR-2006 Doc #:02940648
Cust Comments: RECALL 06E17 RECALIBRATE CONTROL MODULE
Tech Comments: RECALL RECALIBRATE CONTROL MODULE
AWS Claim Key: 13559981 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 01200 - * Name: NICK NICHOLAS FORD, INC. Ph: 352-7261231 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:10-APR-2006 Doc #:02940647
Cust Comments: CUSTOMER ASSURANCE TEST DRIVE
Tech Comments: RECALL ROADTEST FOR OVERALL VEHICLE PERFORMANCE
1FTSW31P53EC34680 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-FEB-2003 27-FEB-2003 124227 USA 39 1H03 030008 4C3Z 9F452 A D42 42 74817
AWS Claim Key: 13598932 Trx Code: E72 Labor Hrs: 3.1
Dlr Cd-Sub Cd: 01200 - * Name: NICK NICHOLAS FORD, INC. Ph: 352-7261231 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:14-APR-2006 Doc #:02963251
Cust Comments: CUST STATES THAT THE VEH HAS NO POWER ON ACCEL,ESP SINCE LAST SERVICE AND RECALL
Tech Comments: DIESEL DIAGNOSIS DIAG SYSTEM AND REPLACE EGR VALVE AND MAP SENSOR RETEST
1FTSW31P53EC34680 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-FEB-2003 27-FEB-2003 124227 USA 39 2E01 030008 3C3Z 9F838 EA D42 42 75166
AWS Claim Key: 13712671 Trx Code: E72 Labor Hrs: 4.9
Dlr Cd-Sub Cd: 01200 - * Name: NICK NICHOLAS FORD, INC. Ph: 352-7261231 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:25-APR-2006 Doc #:03012452
Cust Comments: CHECK FOR LACK OF POWERE ON ACCEL,CUST HAS REINSTALLED FACTORY EXH.
Tech Comments: DIAG SYSTEM REPLACE ICP SENSOR AND CONNECTOR RETEST
1FTSW31P53EC34680 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-FEB-2003 27-FEB-2003 124227 USA 48 2E01 030008 3C3Z 9F838 EA L65 D1 91937
AWS Claim Key: 14801721 Trx Code: E72 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 04984 - * Name: KEY SCALES FORD, INC. Ph: 352-7873511 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:19-JAN-2007 Doc #:03278403
Cust Comments: ENGINE OIL LEAK
Tech Comments: BLACK LIGHT TEST,FOUND ICP SENSOR LEAKING.REPLACED AND RETEST TO VERIFY REPAIR.
1FTSW31P53EC34680 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-FEB-2003 27-FEB-2003 124227 USA 48 2E03 03XXXX 3C3Z 9C968 AA D21 42 91937
AWS Claim Key: 14801722 Trx Code: E72 Labor Hrs: 3.8
Dlr Cd-Sub Cd: 04984 - * Name: KEY SCALES FORD, INC. Ph: 352-7873511 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:19-JAN-2007 Doc #:03278401
Cust Comments: CUSTOMER STATES ENGINE STALLS WHILE DRIVING PERFORMANCE TEST,CODE P2263,REPLACED IPR VALVE,ALSO FOUND
Tech Comments: SCREEN STUCK IN H.P.PUMP.REMOVED SCREEN.PERFORMED FICM WIRE HARNESS CHAFE REPAIR. RETEST TO VERIFY REPAIR.
1FTSW31P53EC34680 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-FEB-2003 27-FEB-2003 124227 USA 50 2E03 030008 3C3Z 9A543 AARM D50 42 95700
AWS Claim Key: 15000477 Trx Code: E72 Labor Hrs: 13.4
Dlr Cd-Sub Cd: 01200 - * Name: NICK NICHOLAS FORD, INC. Ph: 352-7261231 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:19-MAR-2007 Doc #:04481151
Cust Comments: CUSTOMER STATES QUIT AND NOW CRANK NO START, RUNS ROUGH
Tech Comments: DIAG SYSTEM HIGH PRESSURE PUMP FAILED PER TSB 06 23 02 CLEANED TURBO PER TSB PASS INSPECTION TOOK BOTH VALVE COVERS PRESSURE TEST OIL RAILS PRESSURE TEST HIGH PRESSURE SYSTEM REMOVE HIGH PRESSURE PUMP PRESSURE TEST PUMP LEAKING REPLACE PUMP AND REPALCE IPR VALVE STICKING RETEST REPROGRAM
2000 F-350 supercrew 4x4. Banks new ram air, Autometer guages(Thanks GOS)Boost, pyro, trans temp. DP tuner F8.(Thanks Diane and Jody)
00f3fiddy is offline
post #3 of 5 (permalink) Old 10-12-2010, 12:53 AM Thread Starter
Thank you so much 00f3fiddy! I really appreciate it. Do you see anything in there that would cause you to run away screaming from it?
---Chris
post #4 of 5 (permalink) Old 10-12-2010, 01:24 PM
Nothing more than every other 6.0's had done.
post #5 of 5 (permalink) Old 10-13-2010, 09:03 PM
KT Performance's Avatar
Good luck with getting the truck Chris, I know you've been looking for a while.
KT Performance is offline
2003 -6.0 Oasis Report and HELP Needed 02Chief Ford Oasis requests 0 02-14-2010 08:41 PM
Oasis Report - 2003 F250 Fighting Irish Ford Oasis requests 3 02-22-2008 05:35 AM
Oasis Report Please....2003 Excursion 6.0L Rays98GoVols Ford Oasis requests 0 11-30-2007 01:54 PM
Oasis report 2003 6.0L snerdle Ford Oasis requests 1 09-03-2007 11:48 PM
Oasis Report - 2003 Ecursion Joe's Towtruck Ford Oasis requests 1 07-28-2007 04:11 AM
