Oasis report please!! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Fred Bear, this thread has received 2 replies and been viewed 683 times.
post #1 of 3 (permalink) Old 10-13-2010, 11:39 PM Thread Starter
Smile Oasis report please!!
Hi, I'm new to the forum and hopefully soon to be new to the Ford F-350 diesel world.
I have an opportunity to purchase one of two Ford F-350's at an upcoming auction.
Thinking the cleaner one of the two oasis reports will be the deciding factor on which one I buy or try to buy.
#1 2007 Ford F-350 1FTSW21P77EA08642
#2 2006 Ford F-350 1FTWW31P46ED48367 Original vin #(# was cloned and vehicle now has a new vin) If new number also needed I can get it.
I am looking for vehicle specs, warranty service info,recalls,date of original sale
km reading during service or warranty visits??/
I really appreciate the help, been considering a diesel for a few yrs now and really like the look of these trucks from the outside.Can picture myself driving one for sure!!
Fred Bear
Fred Bear is offline
post #2 of 3 (permalink) Old 10-14-2010, 06:07 PM
Standard Claims List For Model Year 2007
1FTSW21P77EA08642 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 16-JUN-2006 02-JAN-2007 123406 USA 0 7N02 011103 YC3Z 1523394 AA G07 42 5
AWS Claim Key: 7244 Trx Code: 1 Labor Hrs: 1
Dlr Cd-Sub Cd: 06000 - * Name: COUNTRY FORD, INC. Ph: 662-3494300 St:MS Ctry Cd: USA Reg Cd: NA Repr Date:29-JUN-2006 Doc #:192847A
Cust Comments: RT FRT DOOR GLASS INOP
Tech Comments: 5 IMPROPER OPER 42 RUN BCE WIRING DIAG. PINPOINT TEST. R&R RT FT DOOR PANEL. REPLACE RT FT POWER WINDOW MTR
1FTSW21P77EA08642 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 16-JUN-2006 02-JAN-2007 123406 USA 1 7M01 150101 * 18806 * A16 42 306
AWS Claim Key: 173328 Trx Code: 1 Labor Hrs: 0
Dlr Cd-Sub Cd: 06000 - * Name: COUNTRY FORD, INC. Ph: 662-3494300 St:MS Ctry Cd: USA Reg Cd: NA Repr Date:04-JAN-2007 Doc #:199376A
Cust Comments: CHECK FOR CD NOT OPERATING
Tech Comments: R AND R RADIO
1FTSW21P77EA08642 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 16-JUN-2006 02-JAN-2007 123406 USA 1 7M01 150101 6C3T 18C815 AB A07 42 306
AWS Claim Key: 227160 Trx Code: 2 Labor Hrs: 0
Dlr Cd-Sub Cd: 48915 - * Name: VISTEON AFTERMARKET - U.S. Ph: *-* St:MI Ctry Cd: USA Reg Cd: NA Repr Date:05-JAN-2007 Doc #:53201500
Tech Comments: REQUESTING DEALER'S P/A CODE 03604
1FTSW21P77EA08642 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 16-JUN-2006 02-JAN-2007 123406 USA 14 2C01 030603 6C2Z 11002 AA D02 42 20719
AWS Claim Key: 1840636 Trx Code: E84 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 06000 - * Name: COUNTRY FORD, INC. Ph: 662-3494300 St:MS Ctry Cd: USA Reg Cd: NA Repr Date:01-FEB-2008 Doc #:212550A
Cust Comments: CUSTOMER STATES STARTER MAKES GRINDING NOISE WHEN TRYING TO START
Tech Comments: DIAG FOUND STARTER WAS MAKING A GRINDING NOISE AT TIMES REPLACED STARTER
1FTSW21P77EA08642 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 16-JUN-2006 02-JAN-2007 123406 USA 22 7A01 140101 BXT 65 750 C25 28 23296
AWS Claim Key: 3748592 Trx Code: E83 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 04587 - * Name: HELFMAN FORD, INC. Ph: 281-2403673 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:29-SEP-2008 Doc #:09261153
Cust Comments: HAVING TO JUMP START TRUCK
Tech Comments: TEST AND REPLACED BOTH BATTERIES TEST ALT CH1RGES 14.2 100JSTH3W06Q0 XE02N 100JRJDKS0DG0 XE02N
1FTSW21P77EA08642 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 16-JUN-2006 02-JAN-2007 123406 USA 22 2D03 030803 * 12226 * C02 42 23296
AWS Claim Key: 3425272 Trx Code: S07 Labor Hrs: 1.1
Dlr Cd-Sub Cd: 04587 - * Name: HELFMAN FORD, INC. Ph: 281-2403673 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:29-SEP-2008 Doc #:09261154
Cust Comments: CUSTOMER SAYS AC IS NOT COOLING WEEL
Tech Comments: DIAG ATC PERFORMED PINPOINT TESTS FOUND VACUUM LINE LEAKING AT HEATER CONTROL VALVE REPAIRED LINE RETEST AC OPERATES PROPERLY
1FTSW21P77EA08642 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 16-JUN-2006 02-JAN-2007 123406 USA 28 6X08 010902 5C3Z 17682 EAA M05 42 31565
AWS Claim Key: 4363093 Trx Code: E84 Labor Hrs: 0.5
Dlr Cd-Sub Cd: A6792 - * Name: M G M FORD LINCOLN SALES LTD. Ph: 403-3466621 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:01-APR-2009 Doc #:20263802
Cust Comments: CONCERN FOR PASS SIDE MIRROR GLASS VIBRATES AT HWY SPEEDS
Tech Comments: TEST DROVE AT ALL SPEEDS VERIFIED WHOLE MIRROR ASSY VIBRATE NOT GLASS UPPER PIVOT ARM WORN/LOOSE CHECKED OASIS FOR CONCERN NOTHING FOUND MIRROR ASSY COMES AS COMPLETE CANNOT GET PIVOT BUSHINGS SEPERATELY REMOVED DOOR PANEL ASSY DISCONNECTED ELECTRICAL CONNECT MIRROR MOUNT BOLTS AND MIRROR REMOVED ORIGINAL COVER AND INSTALLED ON NEW MIRROR UNIT INSTALLATION REVERSE REMOVAL VERIFIED REPAIR
1FTSW21P77EA08642 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 16-JUN-2006 02-JAN-2007 123406 USA 28 6J06 011405 F75Z 9943170 AA B05 42 31565
AWS Claim Key: 4363092 Trx Code: E84 Labor Hrs: 0.7
Dlr Cd-Sub Cd: A6792 - * Name: M G M FORD LINCOLN SALES LTD. Ph: 403-3466621 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:01-APR-2009 Doc #:20263801
Cust Comments: CONCERN FOR TAILGATE WILL NOT OPEN
Tech Comments: VERIFIED TAILGATE WILL NOT OPEN REMOVED TAILGATELINER INSPECTED LATCH RODS AND LOCK CYLS LATCH LOCK NEVER FAILED NEED TO REPLACE LATCH WITH NEW REMOVED AND REPLACED LATCH WITH NEW ASSY ADJUSTED TAILGATE STRIKER RODS LUBED LATCHES TAILGATE NOW OPERATED PROPERLY
1FTSW21P77EA08642 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 16-JUN-2006 02-JAN-2007 123406 USA 28 6X08 010902 * 17682 * M05 42 31565
AWS Claim Key: 4369365 Trx Code: E84 Labor Hrs: 0
Dlr Cd-Sub Cd: A6792 - * Name: M G M FORD LINCOLN SALES LTD. Ph: 403-3466621 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:01-APR-2009 Doc #:20263804
Cust Comments: CONCERN FOR DR & PASS SIDE HEATED MIRRORS DO NOT WORK
Tech Comments: VERIFIED HEATED MIRRORS INOP CHECKED SYSTEM FUSES FOUND FUSE 2.39 15A BLOWN REMOVED AND REPLACED FUSE WITH NEW HEATED MIRRORS NOW OPERATING PROPERLY PERFORMED WIGGLE TEST ON WIRING TO CHECK FOR POSSIBLE SHORT FUNCTION TESTED MIRROR THROUGH FULL RANGE OF MOTION COULD NOT DUPLICATE EXCESSIVE AMPERAGE THAT CAUSED FUSE TO BLOW VERIFIED REPAIR
1FTSW21P77EA08642 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 16-JUN-2006 02-JAN-2007 123406 USA 28 3B01 070202 * 7D273 * L73 33 32389
AWS Claim Key: 4432340 Trx Code: E84 Labor Hrs: 1
Dlr Cd-Sub Cd: A4802 - * Name: MERLIN FORD LINCOLN Ph: 306-9316611 St:SK Ctry Cd: CAN Reg Cd: NA Repr Date:13-APR-2009 Doc #:30566101
Cust Comments: CHECK FOR TRANNY LEAK
Tech Comments: CHECKED FOR TRANNY LEAK, VISUAL INSPECTION, CLEANED UNDERNEATH, ADDED DYE TO CHECK FOR LEAK, NEED MOREOBSERVATION, RETIGHTENED TRANS COOLER TUBE MT TIME TO DIAG LEAK AND TIGHTEN COOLER TUBE
2000 F-350 supercrew 4x4. Banks new ram air, Autometer guages(Thanks GOS)Boost, pyro, trans temp. DP tuner F8.(Thanks Diane and Jody)
00f3fiddy is offline
The Following User Says Thank You to 00f3fiddy For this addition to TDG:
Fred Bear (10-14-2010)
post #3 of 3 (permalink) Old 10-14-2010, 06:09 PM
Standard Claims List For Model Year 2006
1FTWW31P46ED48367 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 29-MAR-2006 20-JUN-2006 4B6019 CAN 20 1H03 030804 * 9J460 * E29 42 19728
AWS Claim Key: 5346564 Trx Code: S07 Labor Hrs: 1.8
Dlr Cd-Sub Cd: B6019 - * Name: FOURLANE FORD SALES LTD. Ph: 403-2273311 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:14-JAN-2008 Doc #:09473001
Cust Comments: CHECK ENGINE LIGHT ON
Tech Comments: PERFORMANCE DIAG. EBP SENSOR CKT MALF. MONITORED PIDS. EBP SENSOR BIASED. REPL ACED SENSOR RETESTED AND ROAD TESTED.
BRANDED TITLE - ALL WARRANTY CANCELLED TOTAL LOSS PER FORD CREDIT CANADA
Oasis Report Please cuebird Ford Oasis requests 1 07-28-2007 04:18 AM
Oasis Report Plz 03RescueDiesel Ford Oasis requests 1 07-28-2007 04:10 AM
can i get an oasis report please 86 1 tonhauler Ford Oasis requests 1 11-10-2006 02:13 AM
OASIS Report Please lilgsx Ford Oasis requests 1 11-02-2006 01:52 AM
oasis report please darthmullet67 Ford Oasis requests 1 11-01-2006 09:38 PM
