Oasis please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by fedman, this thread has received 1 replies and been viewed 655 times.
post #1 of 2 (permalink) Old 10-14-2010, 07:18 PM Thread Starter
Oasis please
Saw this today and would really appreciate an Oasis if possible. Thanks in advance. 1FTWW33P85EA86641
08' F350 Lariat DRW
fedman is offline
post #2 of 2 (permalink) Old 10-14-2010, 07:33 PM
Standard Claims List For Model Year 2005
1FTWW33P85EA86641 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 01-OCT-2004 26-OCT-2004 113500 USA 9 5N01 110301 5C3Z 3E651 CA L85 D8 1359
AWS Claim Key: 1434094 Trx Code: 1 Labor Hrs: 1
Dlr Cd-Sub Cd: 20524 - * Name: CARMODY FORD-MERCURY INC Ph: 518-6922246 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:18-JUL-2005 Doc #:03089601
Cust Comments: CUSTOMER STATES THERE WERE TWO SPOTS UNDER TRUCK. ONE SPOT LOOKED CLEAR AND OILY, THE OTHER SPOT LOOKS LIKE OIL OR GREASE. UNDER FRONT OF VEHICLE. INSPECT FOR SOURCE OF LEAK AND ADVISE.
Tech Comments: LEAKING SEAL REPLACED STEERING STABILIZER.
1FTWW33P85EA86641 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 01-OCT-2004 26-OCT-2004 113500 USA 46 * * * * * * * 7098
AWS Claim Key: 10215295 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 20524 - * Name: CARMODY FORD-MERCURY INC Ph: 518-6922246 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:04-AUG-2008 Doc #:04884006
Cust Comments: PERFORM CAMPAIGN 05B32. ALL 2005 MODEL YEAR F250 350 450 F550 AND EXCURSION VEHICLES EQUIPPED WITH 6.0L DIESEL ENGINE
Tech Comments: CAMPAIGN PROCEDURE INSTALLED LABEL AND IF NECESSARY REMOVED FLUID FROM DEGAS BOTTLE AS PER CAMPAIGN PROCEDURES.
AWS Claim Key: 10215297 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 20524 - * Name: CARMODY FORD-MERCURY INC Ph: 518-6922246 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:04-AUG-2008 Doc #:04884004
Cust Comments: PERFORM CAMPAIGN 05E15. 2004 2005 MODEL YEAR F250 350 450 550, EXCURSION AND E250 450 VEHICLES EQUIPPED WITH 6.0L
Tech Comments: CAMPAIGN PROCEDURE REPLACED EXHAUST BACKPRESSURE SENSOR AND RECALIBRATED POWERTRAIN CONTROL MODULES. 2004 2005 SUPER DUTY AND
AWS Claim Key: 10215296 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 20524 - * Name: CARMODY FORD-MERCURY INC Ph: 518-6922246 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:04-AUG-2008 Doc #:04884005
Cust Comments: PERFORM CUSTOMER ASSURANCE TEST DRIVE PROCEDURE AFTER COMPLETION OF BOTH 05S34 AND 05B29 PROGRAMS.
Tech Comments: QUALITY CONTROL PERFORMED TEST DRIVE AFTER COMPLETION OF CAMPAIGNS TO VERIFY THAT NO OTHER ENGINE RELATED CONCERNS EXIST WITH VEHICLE.
1FTWW33P85EA86641 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 01-OCT-2004 26-OCT-2004 113500 USA 53 2H01 0300XX * 6K682 * E29 42 11830
AWS Claim Key: 10809225 Trx Code: S07 Labor Hrs: 3.7
Dlr Cd-Sub Cd: 20524 - * Name: CARMODY FORD-MERCURY INC Ph: 518-6922246 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:03-MAR-2009 Doc #:05218401
Cust Comments: CUSTOMER STATES CHECK ENGINE LIGHT ON RUNS OK CHECK AND ADVISE NEEDED REPAIRS
Tech Comments: TURBOCHARGER STICKING VERIFIED CUSTOMER CONCERN OF CHECK ENGINE LIGHT. SCAN TEST FAULT CODE P0299. FOLLOWED TSB 08 16 13 FOR DIAGNOSIS AND REPAIR PROCEDURE. REMOVED TURBOCHARGER FROM VEHICLE AND DISASSEMBLED FOR INSPECTION. CLEANED TURBO AS PER TSB AND REASSEMBLED. REINSTALLED ONTO VEHICLE. CLEARED FAULT CODE AND ROAD TESTED AFTER REPAIR.
1FTWW33P85EA86641 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 01-OCT-2004 26-OCT-2004 113500 USA 59 1F01 031202 3C3Z 6K775 AA D42 01 16575
AWS Claim Key: 11133819 Trx Code: S07 Labor Hrs: 1.9
Dlr Cd-Sub Cd: 20524 - * Name: CARMODY FORD-MERCURY INC Ph: 518-6922246 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:17-AUG-2009 Doc #:05495901
Cust Comments: CUSTOMER STATES WHILE DRIVING THERE WAS A LOUD BANG NOISE FOLLOWED BY A LACK OF POWER AND A LOT OF SMOKE OUT OF THE EXHAUST. VEHICLE STILL RUNNING BUT HAS NO POWER. INSPECT AND ADVISE OF R
Tech Comments: FAULTY CHARGE AIR COOLER INSPECTED FOR CUSTOMER CONCERN OF POWER LOSS FOLLOWING A LOUD NOISE UNDER THE HOOD. CHECK ENGINE LIGHT ON. SCAN TEST CODE P2262, WHISTLE NOISE FROM CHARGE AIR COOLER AND GASKET FOR SIDE OF CAC BLOWN RIGHT OUT. REMOVED AND REPLACED THE CHARGE AIR COOLER. CLEARED FAULT CODE AND ROAD TESTED OK.
2000 F-350 supercrew 4x4. Banks new ram air, Autometer guages(Thanks GOS)Boost, pyro, trans temp. DP tuner F8.(Thanks Diane and Jody)
00f3fiddy is offline
The Following User Says Thank You to 00f3fiddy For this addition to TDG:
fedman (10-14-2010)
