OASIS request please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by WldHrt, this thread has received 4 replies and been viewed 534 times.
post #1 of 5 (permalink) Old 10-21-2010, 01:02 AM Thread Starter
I am still diligently looking for "my" powerstroke. I found a nice repo, 3FTNW21F92MA07421. Would so appreciate an OASIS on it. Thanks in advance.
WldHrt is offline
post #2 of 5 (permalink) Old 10-21-2010, 01:24 PM
Standard Claims List For Model Year 2002
3FTNW21F92MA07421 T/F7 F T/BC T/BD T/E A2 T/D8 T/DS 20-SEP-2001 12-OCT-2001 123306 USA 13 2E03 100103 YC3Z 9J323 CA L65 42 31224
AWS Claim Key: 3248172 Trx Code: S07 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 06578 - * Name: COURTESY MOTORS, INC. Ph: 601-5448111 St:MS Ctry Cd: USA Reg Cd: NA Repr Date:28-OCT-2002 Doc #:069157A
Cust Comments: OIL LINE THAT CAME LOOSE ON TOP OF ENGINE
Tech Comments: 31224 CK OIL LEAK W95 CHECK FOR OIL LEAK INSPECTED AND FOUND LEAK AT HIGH PRESSURE PUMP REPLACED HIGH PRESSURE LINE ASY AND FITTING ASY CHECK FOR LEAKS OK CAUSE PART LOOSE FIT ON LINE
3FTNW21F92MA07421 T/F7 F T/BC T/BD T/E A2 T/D8 T/DS 20-SEP-2001 12-OCT-2001 123306 USA 13 5I01 110204 * 3A674 * H22 42 31239
AWS Claim Key: 3248173 Trx Code: E84 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 06578 - * Name: COURTESY MOTORS, INC. Ph: 601-5448111 St:MS Ctry Cd: USA Reg Cd: NA Repr Date:30-OCT-2002 Doc #:069255A
Cust Comments: WHEN PUTTING IN GEAR IT HAS NO POWER STEERING
Tech Comments: 31245 CHECK P S SYSTEM BLEED P S SYSTEM ROAD TEST SHOWED CUST S M #15446
3FTNW21F92MA07421 T/F7 F T/BC T/BD T/E A2 T/D8 T/DS 20-SEP-2001 12-OCT-2001 123306 USA 15 2G88 000615 * NPF * L29 42 35998
AWS Claim Key: 3978275 Trx Code: E83 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 06578 - * Name: COURTESY MOTORS, INC. Ph: 601-5448111 St:MS Ctry Cd: USA Reg Cd: NA Repr Date:30-DEC-2002 Doc #:070825B
Cust Comments: RIGHT TURN SIGNAL INDICATOR ON INSTRUMENT PANEL STARTED BLINKING FAST LIKE BULB WAS BLOWN OUTSIDE,BUT IT WAS NOT & THEN IT STARTED BLINKING NORMAL AGAIN CUST WANTED TO MAKE
Tech Comments: 35999 W 95 CHECK BULBS & CHECK FOR SHORT NO PROBLEM FOUND
3FTNW21F92MA07421 T/F7 F T/BC T/BD T/E A2 T/D8 T/DS 20-SEP-2001 12-OCT-2001 123306 USA 15 2G88 000615 * NPF * C50 42 35998
AWS Claim Key: 3978274 Trx Code: E84 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 06578 - * Name: COURTESY MOTORS, INC. Ph: 601-5448111 St:MS Ctry Cd: USA Reg Cd: NA Repr Date:30-DEC-2002 Doc #:070825A
Cust Comments: CUSTOMER SAYS STEERING WHEEL WILL NOT TURN WHEN SITTING STILL NO ASSIST UNTIL YOU MOVE
Tech Comments: 35999 W 95 CHECK FOR LEAKS & CHECK FLUID LAVEL & ITS OK & RUN ON OASIS & THIS IS NORMAL
3FTNW21F92MA07421 T/F7 F T/BC T/BD T/E A2 T/D8 T/DS 20-SEP-2001 12-OCT-2001 123306 USA 100 * * * * * * * 225132
AWS Claim Key: 17500230 Trx Code: 07S57 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 06578 - * Name: COURTESY MOTORS, INC. Ph: 601-5448111 St:MS Ctry Cd: USA Reg Cd: NA Repr Date:02-DEC-2009 Doc #:143212B
Cust Comments: RECALL 07 S 57
Tech Comments: PERFORM RECALL 07S57 REPLACE SENSOR
AWS Claim Key: 17500229 Trx Code: 09S09 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 06578 - * Name: COURTESY MOTORS, INC. Ph: 601-5448111 St:MS Ctry Cd: USA Reg Cd: NA Repr Date:02-DEC-2009 Doc #:143212A
Cust Comments: RECALL 09 S 09
Tech Comments: CONNECTED WIRE HARNESS
2000 F-350 supercrew 4x4. Banks new ram air, Autometer guages(Thanks GOS)Boost, pyro, trans temp. DP tuner F8.(Thanks Diane and Jody)
00f3fiddy is offline
post #3 of 5 (permalink) Old 10-21-2010, 01:24 PM
The Following User Says Thank You to 00f3fiddy For this addition to TDG:
WldHrt (10-21-2010)
post #4 of 5 (permalink) Old 10-21-2010, 01:26 PM
sorry about the duplicate. got the fat finger this morning.
WldHrt (10-21-2010)
post #5 of 5 (permalink) Old 10-21-2010, 01:52 PM Thread Starter
No worries about the duplicate fiddy, I appreciate your help so much. Thanks. This truck has 247,000 but I think I might want it, maybe get a reasonable price as the bank has it as a repo.
WldHrt is offline
Oasis request please tman945 Ford Oasis requests 1 01-06-2008 01:42 AM
Oasis Request jaydam Ford Oasis requests 1 01-05-2008 03:29 AM
Oasis request please bushpilot Ford Oasis requests 1 12-15-2007 02:35 PM
OASIS request please calrton Ford Oasis requests 1 01-23-2007 12:21 AM
OASIS REQUEST Please! ash_flat_diesel Ford Oasis requests 1 01-19-2007 04:14 AM
