Oasis Request - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by dshunt, this thread has received 2 replies and been viewed 420 times.
post #1 of 3 (permalink) Old 10-25-2010, 06:46 PM Thread Starter
Oasis Request
Hi Guys,
LOVE TDG!!!
2004 F350 CCLB Duallie
Vin:
1FTWW33PX4ED30899
Thanks soooooooo much!
dshunt is offline
post #2 of 3 (permalink) Old 10-26-2010, 04:50 PM
Standard Claims List For Model Year 2004
1FTWW33PX4ED30899 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 30-APR-2004 11-SEP-2004 124224 USA 2 7D03 170304 F81Z 15444 AA A85 28 1630
AWS Claim Key: 2516607 Trx Code: 2 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 04822 - * Name: GREENWAY FORD, INC. Ph: 407-2753200 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:08-NOV-2004 Doc #:08902552
Cust Comments: O R 8 FOOT CLEARANCE LIGHT UNDER TAIL GATE HAS LIGHT OUT
Tech Comments: OPEN CIRCUIT IN LIGHT ASSEMBLY REPLACE 3 LIGHT BRACKET ASSEMBLY
1FTWW33PX4ED30899 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 30-APR-2004 11-SEP-2004 124224 USA 3 2G05 031405 * RECAL * D36 42 2200
AWS Claim Key: 2725601 Trx Code: 2 Labor Hrs: 4.1
Dlr Cd-Sub Cd: 04808 - * Name: KELLY FORD Ph: 321-2544283 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:30-NOV-2004 Doc #:06803001
Cust Comments: D36 ENGINE SURGES AT IDLE AND WHILE DRIVING ENGINE WILL REV ABOUT 1500 RPM
Tech Comments: 42 WDS DIESEL ENG PERF DIAG, SELF TEST KOEO PASS, CONT PASS, KOEO INJ ELEC PASS, KOER PASS, REPROGRAMMED PCM PER SSM,
1FTWW33PX4ED30899 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 30-APR-2004 11-SEP-2004 124224 USA 4 1H03 030008 3C3Z 9J460 AA D50 42 2563
AWS Claim Key: 2911945 Trx Code: S07 Labor Hrs: 7
Dlr Cd-Sub Cd: 04822 - * Name: GREENWAY FORD, INC. Ph: 407-2753200 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:10-DEC-2004 Doc #:09495151
Cust Comments: O R SURGES WHILE DRIVING WORSE AT STOPSTRYS TO STALL INTERMITTEN WORSE THAN OTHER TIMES
Tech Comments: EBP INOP ENGINE PERFORMANCE DIAGNOSTICS DIESEL ENGINE DIAGNOSIS
1FTWW33PX4ED30899 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 30-APR-2004 11-SEP-2004 124224 USA 8 3A03 * * * * * * 5562
AWS Claim Key: 4770738 Trx Code: 04B24 Labor Hrs: 6.4
Dlr Cd-Sub Cd: 04822 - * Name: GREENWAY FORD, INC. Ph: 407-2753200 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:11-APR-2005 Doc #:01947940
Cust Comments: RECALL 04B24 TRANSMISSION REVERSE PLANET REPLACEMENT
Tech Comments: PER PROGRAM 04B24 TRANS R&I, INSPECT AND REPLACE REAR PLANET ONLY
1FTWW33PX4ED30899 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 30-APR-2004 11-SEP-2004 124224 USA 11 * * * * * * * 7638
AWS Claim Key: 6252665 Trx Code: 05S34 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 04822 - * Name: GREENWAY FORD, INC. Ph: 407-2753200 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:01-AUG-2005 Doc #:04131040
Cust Comments: 05S34 FUEL INJECTOR CONTROL MODULE WIRING HARNESS REPAIR
Tech Comments: PER RECALL 05S34 INSP & REPAIR FICM WIRE HARNESS,INSTALL ICP CONN KIT
1FTWW33PX4ED30899 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 30-APR-2004 11-SEP-2004 124224 USA 13 * * * * * * * 8201
AWS Claim Key: 6898027 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 04822 - * Name: GREENWAY FORD, INC. Ph: 407-2753200 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:15-SEP-2005 Doc #:05074741
Cust Comments: 59B01 ELIGIBLE FOR ONE TIME CUSTOMER ASSURANCE TEST DRIVE. SEE EMISSIO
Tech Comments: PER PROGRAM 59B01 CUSTOMER ASSURANCE TEST DRIVE
AWS Claim Key: 6898026 Trx Code: 05E15 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 04822 - * Name: GREENWAY FORD, INC. Ph: 407-2753200 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:15-SEP-2005 Doc #:05074740
Cust Comments: 05E15 EXHAUST PRESSURE SENSOR REPLACEMENT, ON BOARD DIAGNOSTIC SYSTEM A
Tech Comments: PER PROGRAM 05E15 REPL EP SENSOR, EP CONN, RECALIBRATE CONTROL MODULES
AWS Claim Key: 6941805 Trx Code: 05E15 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 04822 - * Name: GREENWAY FORD, INC. Ph: 407-2753200 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:15-SEP-2005 Doc #:05074743
Cust Comments: RELATED DAMAGE
Tech Comments: RELATED DAMAGE EBP SENSOR BROKEN OFF IN BRACKET, TIME TO RR BRACKET TO INST SENSO
1FTWW33PX4ED30899 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 30-APR-2004 11-SEP-2004 124224 USA 33 1D05 030008 3C3Z 6020 CA L65 D8 20170
AWS Claim Key: 11655717 Trx Code: E84 Labor Hrs: 12
Dlr Cd-Sub Cd: 04822 - * Name: GREENWAY FORD, INC. Ph: 407-2753200 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:21-MAY-2007 Doc #:06974451
Cust Comments: OIL LEAK FROM REAR OF ENGINE
Tech Comments: FRONT COVER AND REAR MAIN SEAL LEAKING GASKET OR CYLINDER FRONT COVER REMOVE AND INSTALL OR REPLACE
1FTWW33PX4ED30899 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 30-APR-2004 11-SEP-2004 124224 USA 35 2E05 100106 6C3Z 9B249 A G29 49 21077
AWS Claim Key: 11819072 Trx Code: E84 Labor Hrs: 2
Dlr Cd-Sub Cd: 04822 - * Name: GREENWAY FORD, INC. Ph: 407-2753200 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:28-JUN-2007 Doc #:07615451
Cust Comments: WATER IN FUEL LIGHT KEEPS COMING ON AND OFF WATER IS DRAINED REGULARLY
Tech Comments: WIF SENSOR CONTAMINATED, HARNESS UPDATE HEADER FUEL FILTER REPLACE
1FTWW33PX4ED30899 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 30-APR-2004 11-SEP-2004 124224 USA 37 2C01 030603 6C2Z 11002 AA D50 42 22028
AWS Claim Key: 12071727 Trx Code: E84 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 04822 - * Name: GREENWAY FORD, INC. Ph: 407-2753200 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:08-SEP-2007 Doc #:08836051
Cust Comments: O R WHEN STARTING VEHICLE, THE STARTER MADE A VERY LOUD HORRIBLE SOUND, THINKS STARTER AND FLEX PLATE MAY HAVE ISSUES.
Tech Comments: STATER INOP STARTER CIRCUIT CHECK
1FTWW33PX4ED30899 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 30-APR-2004 11-SEP-2004 124224 USA 37 7C01 01XXXX 2L2Z 11A127 AA G29 01 22028
AWS Claim Key: 12128887 Trx Code: E83 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 04822 - * Name: GREENWAY FORD, INC. Ph: 407-2753200 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:09-SEP-2007 Doc #:09066051
Cust Comments: USE SPO 07253071 INGNITION BELL INOP INTERMITTANTLY
Tech Comments: WARNING SWITCH BROKEN REPLACE WARNING SWITCH
1FTWW33PX4ED30899 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 30-APR-2004 11-SEP-2004 124224 USA 44 2E05 100106 6C3Z 9B249 A G32 42 25571
AWS Claim Key: 12595941 Trx Code: E90 Labor Hrs: 1.7
Dlr Cd-Sub Cd: 04822 - * Name: GREENWAY FORD, INC. Ph: 407-2753200 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:14-APR-2008 Doc #:02441951
Cust Comments: C S WATER IN FUEL LIGHT IS ON
Tech Comments: FUEL SENSOR CONTAMINATED KEY ON ENGINE OFF KOEO CHECK TEST
1FTWW33PX4ED30899 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 30-APR-2004 11-SEP-2004 124224 USA 53 2E05 100106 6C3Z 9B249 A D50 42 28932
AWS Claim Key: 13010022 Trx Code: E88 Labor Hrs: 1
Dlr Cd-Sub Cd: 04822 - * Name: GREENWAY FORD, INC. Ph: 407-2753200 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:23-DEC-2008 Doc #:05894251
Cust Comments: GOODFAITH DIAG, C S WIF LIGHT COMING ON AGAIN. SEE OAISIS FOR HISTORY. CUSTOMER DRAINED WIF, STATES NO WATER CAME OUT.
Tech Comments: WIF SENSOR INOP KEY ON ENGINE OFF KOEO CHECK TEST
1FTWW33PX4ED30899 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 30-APR-2004 11-SEP-2004 124224 USA 58 1H03 030008 4C3Z 9F452 A D42 42 33484
AWS Claim Key: 13186396 Trx Code: S07 Labor Hrs: 2.4
Dlr Cd-Sub Cd: 04424 - * Name: JENNINGS ANDERSON FORD Ph: 830-7553673 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:06-JUN-2009 Doc #:07272551
Cust Comments: CUST STATES POWER LOSS BLACK SMOKE
Tech Comments: RAN KOEO P0401 P0404 RAN EGR TEST EGR FAILED CLEANED EGR RETETED PEROFRMED TSB 08 26 12 FAILED AGAIN REPLACED EGR ADDED FUEL ADDTIVE RETETED EGR PASSED KOER PASS ROAD TESTED WITH CUSTOMER RAN DATA LOGGER OK 27 PSI BOOT RAN FINC REPGORAMED PCM TCM AND FICM
1FTWW33PX4ED30899 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 30-APR-2004 11-SEP-2004 124224 USA 59 2H01 030407 6C3Z 9T515 A D50 42 38818
AWS Claim Key: 13214074 Trx Code: E72 Labor Hrs: 4.4
Dlr Cd-Sub Cd: 04822 - * Name: GREENWAY FORD, INC. Ph: 407-2753200 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:24-JUN-2009 Doc #:07940251
Cust Comments: CUST STATES VEHICLE IS LOOSING BOOST UNDER ACCEL (TURBO IS WHINNING UNDER ACCEL)
Tech Comments: STICKING TURBO ENGINE PERFORMANCE DIAGNOSTICS DIESEL ENGINE DIAGNOSIS
1FTWW33PX4ED30899 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 30-APR-2004 11-SEP-2004 124224 USA 59 2A01 031202 6C3Z 6C640 C D50 D1 38818
AWS Claim Key: 13204353 Trx Code: E72 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 04822 - * Name: GREENWAY FORD, INC. Ph: 407-2753200 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:24-JUN-2009 Doc #:07940252
Cust Comments: C S VEHICLE SEEM TO BE LEAKING OIL FROM CAC HOSE.
Tech Comments: CAC HOSE LEAKING ENGINE OIL LEAKS DIAGNOSIS
1FTWW33PX4ED30899 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 30-APR-2004 11-SEP-2004 124224 USA 59 2A01 031202 6C3Z 6C640 B D50 D1 39081
AWS Claim Key: 13216547 Trx Code: E72 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 04822 - * Name: GREENWAY FORD, INC. Ph: 407-2753200 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:07-JUL-2009 Doc #:08077051
Cust Comments: CUST STATES ENGINE STILL LEAKING OIL FROM BOTTOM HOSE. (REF RO#79402 DATE:6 25 09 MI:38818)
Tech Comments: LEAKING ENGINE OIL LEAKS DIAGNOSIS
2000 F-350 supercrew 4x4. Banks new ram air, Autometer guages(Thanks GOS)Boost, pyro, trans temp. DP tuner F8.(Thanks Diane and Jody)
00f3fiddy is offline
The Following User Says Thank You to 00f3fiddy For this addition to TDG:
dshunt (10-26-2010)
post #3 of 3 (permalink) Old 10-26-2010, 10:33 PM Thread Starter
Thanks ever so much, have had the truck a/b 4 mths and wasn't sure what had been done. Thanks again!!
dshunt is offline
oasis request tbiernat Ford Oasis requests 1 05-13-2009 05:27 PM
OASIS Request Wildland Ford Oasis requests 2 01-10-2008 08:48 PM
OASIS request ade_beer Ford Oasis requests 3 03-10-2007 06:42 AM
Oasis request gregc Ford Oasis requests 3 03-05-2007 05:21 PM
Oasis request, please. glarnold Ford Oasis requests 1 03-02-2007 02:25 AM
