Oasis report - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by firedog68, this thread has received 2 replies and been viewed 450 times.
post #1 of 3 (permalink) Old 10-26-2010, 12:58 PM Thread Starter
Post Oasis report
Hello I have recently purchased an f350 6.0 . It has about 110000 miles
The vin is 1FTWW31PX5EC61913. Seeing if anyone could run a
Oasis report. Thank you
firedog68 is offline
post #2 of 3 (permalink) Old 10-26-2010, 04:57 PM
Standard Claims List For Model Year 2005
1FTWW31PX5EC61913 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 11-APR-2005 24-JUN-2005 152740 USA 6 1H02 120307 6C3Z 2A451 A C05 41 16694
AWS Claim Key: 2918275 Trx Code: E84 Labor Hrs: 1.8
Dlr Cd-Sub Cd: 08758 - * Name: RIATA FORD Ph: 512-2813673 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:19-DEC-2005 Doc #:13883603
Cust Comments: C S HEATER & A C ONLY WORK IN DEFROST
Tech Comments: VACUUM PUMP BURNED OUT VERIFIED CONCERN, R&I INSTRUMENT CLUSTER PANEL, FOUND NO VACUUM TO AC MODE SWITCH. FOUND CORRECT POWER & GROUND AT VACUUM PUMP CONNECTOR, REPLACED VACUUM PUMP.
1FTWW31PX5EC61913 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 11-APR-2005 24-JUN-2005 152740 USA 6 2G05 031405 * RECAL * D21 07 16694
AWS Claim Key: 2918276 Trx Code: E84 Labor Hrs: 1.1
Dlr Cd-Sub Cd: 08758 - * Name: RIATA FORD Ph: 512-2813673 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:19-DEC-2005 Doc #:13883602
Cust Comments: C S VEHICLE DIED WHILE DRIVING, STARTED BACK UP BUT ACTS LIKE ITS GOING TO DIE
Tech Comments: PCM NOT PROGRAMMED TO LATEST CALIBRATION VERIFIED CONCERN & RECALIBRATED PCM,TCM, FICM
1FTWW31PX5EC61913 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 11-APR-2005 24-JUN-2005 152740 USA 43 * * * * * * * 91628
AWS Claim Key: 10678194 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 02530 - * Name: PEGUES-HURST MOTOR COMPANY Ph: 903-7586211 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:30-DEC-2008 Doc #:076747D
Cust Comments: RECALL 05B32
Tech Comments: 91628 RECALL COMPLETE
1FTWW31PX5EC61913 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 11-APR-2005 24-JUN-2005 152740 USA 43 2E01 030408 4C3Z 9B246 C D02 42 91628
AWS Claim Key: 10678193 Trx Code: E72 Labor Hrs: 10.9
Dlr Cd-Sub Cd: 02530 - * Name: PEGUES-HURST MOTOR COMPANY Ph: 903-7586211 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:30-DEC-2008 Doc #:076747A
Cust Comments: CHECK FOR DIED WHILE DRIVING DOWN INTERSTATE
Tech Comments: 91628 PERFORM TSB 08 18 06 F 4.2 C 1.8 D 4.9 DIAG PINPOINT TEST RR VALVE COVERS TEST RR H P PUMP AND REPLACE STC FITTING RETEST ROAD TEST OK
2000 F-350 supercrew 4x4. Banks new ram air, Autometer guages(Thanks GOS)Boost, pyro, trans temp. DP tuner F8.(Thanks Diane and Jody)
00f3fiddy is offline
post #3 of 3 (permalink) Old 10-27-2010, 02:41 AM Thread Starter
Wink Thanks
Thank you very much for the report!
Oasis report please Robert S. Ford Oasis requests 1 08-17-2009 06:14 PM
OASIS Report Please! memcgrath Ford Oasis requests 1 12-29-2006 04:13 AM
OASIS Report blownwhite03 Ford Oasis requests 2 12-14-2006 12:50 AM
oasis report please detailman Ford Oasis requests 2 12-13-2006 10:20 PM
OASIS Report Please jmj12396 Ford Oasis requests 2 12-13-2006 07:40 PM
