oasis report please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by roundsound, this thread has received 5 replies and been viewed 623 times.
post #1 of 6 (permalink) Old 10-27-2010, 05:40 PM Thread Starter
oasis report please
1ftsw31p33ed53442 Thank you, thank you, thank you!
roundsound is offline
post #2 of 6 (permalink) Old 10-28-2010, 02:54 PM
Standard Claims List For Model Year 2003
1FTSW31P33ED53442 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 09-JUN-2003 02-JUL-2003 171171 USA 11 6Y05 000001 * MAINT * A99 82 6526
AWS Claim Key: 5888337 Trx Code: 0713S Labor Hrs: 1.1
Dlr Cd-Sub Cd: 03786 - * Name: EARNHARDT FORD SALES COMPANY Ph: 480-8930000 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:03-MAY-2004 Doc #:856370G
Cust Comments: OIL CHANGE,ROTATE TIRES,MULTIPOINT INSPECTION
Tech Comments: 6526 PERFORMED LOF, ROTATE AND INSPECTION
1FTSW31P33ED53442 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 09-JUN-2003 02-JUL-2003 171171 USA 11 7Q02 191100 * 54519C42 * L69 42 6526
AWS Claim Key: 5907144 Trx Code: 2 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 03786 - * Name: EARNHARDT FORD SALES COMPANY Ph: 480-8930000 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:03-MAY-2004 Doc #:856370C
Cust Comments: CUST STATES FUEL MONITOR INOP MILES TO EMPTY DOESNT WORK
Tech Comments: 6562 VERIFIED OVERHEAD TRIP COMPUTER WAS DISPLAYING WRONG DISTANCE TO EMPTY, BCE TEST PULLED NO CODES, RAN OASIS, CONTACT #217 100 976, OASIS HAD NO RELATED TSB INFO, CALLED HOTLINE, CASE # 4EDHO022, FOUND PROCEDURE TO RECONFIGURE OVERHEAD TRIP COMPUTER, RECONFIGURED, RETESTED, ALL FUNCTIONS NORMAL.
1FTSW31P33ED53442 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 09-JUN-2003 02-JUL-2003 171171 USA 11 6C04 010505 * 5422666 * B43 33 6526
AWS Claim Key: 5888336 Trx Code: 2 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 03786 - * Name: EARNHARDT FORD SALES COMPANY Ph: 480-8930000 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:03-MAY-2004 Doc #:856370E
Cust Comments: DRIVER DOOR TRIM SCREW KEPS COMING LOOSE
Tech Comments: 6562 VERIFIED DRIVERS DOOR STRAP WAS LOOSE, RETIGHTENED NUTS, RETESTED, ALL FUNCTIONS NORMAL.
1FTSW31P33ED53442 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 09-JUN-2003 02-JUL-2003 171171 USA 11 2F01 000615 * DRIVE * D13 42 6526
AWS Claim Key: 5888334 Trx Code: 2 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 03786 - * Name: EARNHARDT FORD SALES COMPANY Ph: 480-8930000 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:03-MAY-2004 Doc #:856370A
Cust Comments: DIESEL ENGINE RUNS ROUGH,IDLES ROUGH
Tech Comments: 6528 COLD START AND PERFORM ENGINE PERFORMANCE DIAG. 1 4 PERFORM KOEO TEST PASS PERFORM KOER TEST PASS REPROGRAM PCM AS PER SSM. 16839 FOR ENGINE RUNS ROUGH AND SMOKES HOT OR COLD 6.0L
1FTSW31P33ED53442 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 09-JUN-2003 02-JUL-2003 171171 USA 11 6F04 010702 * 7825324 * R22 33 6526
AWS Claim Key: 5888335 Trx Code: 2 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 03786 - * Name: EARNHARDT FORD SALES COMPANY Ph: 480-8930000 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:03-MAY-2004 Doc #:856370B
Cust Comments: DRIVER DOOR WIND NOISE
Tech Comments: 6562 VERIFIED SLIGHT FLUTTER AT SPEEDS ABOVE 65 MPH, SONIC TEST PERFORMED FOUND NO LEAKS, FOUND LEFT REAR DOOR FRONT WEATHERSTRIP WAS LOOSE, INSULATED AND RESECURED WEATHERSTRIP, RETESTED, ALL FUNCTIONS NORMAL, NOTE TO CUSTOMER, TRAILER TOW MIRRORS MAKE A SMALL AMOUNT OF WINDNOISE THAT IS WITHIN DESIGN PERAMETERS.
1FTSW31P33ED53442 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 09-JUN-2003 02-JUL-2003 171171 USA 25 6Y05 000001 * MAINT * A99 82 12596
AWS Claim Key: 11170532 Trx Code: 0713S Labor Hrs: 1.1
Dlr Cd-Sub Cd: 03786 - * Name: EARNHARDT FORD SALES COMPANY Ph: 480-8930000 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:21-JUN-2005 Doc #:893754A
Cust Comments: 10000 MILES (16000 KMS) MAINT. L
Tech Comments: 12596 LOF COMPLETE 15 QRTS 15W40 ALL FLUIDS TOPPED OFF TIRES ROTATED WHEELS TORQUED AT 140 LBS TIRES GOOD ALL TIRES TREAD DEPTH AT 11,32 ALL BRAKES AT 9MM GOOD INSPECTION COMPLEYTE ENGINE COOLANT OK BELTS HOSES GOOD NO LEAKS FOUND ALL, GREEN
1FTSW31P33ED53442 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 09-JUN-2003 02-JUL-2003 171171 USA 30 2E06 030008 3C3Z 9E527 AE P59 42 18229
AWS Claim Key: 12679962 Trx Code: S07 Labor Hrs: 9.1
Dlr Cd-Sub Cd: 20443 - * Name: BILL ALEXANDER FORD LINCOLN MERCURY, INC. Ph: 928-3442200 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:25-NOV-2005 Doc #:38672503
Cust Comments: SEE LINE 1 FOR INFO. ADVISE CUST STATES TRANS SLIPPING
Tech Comments: WDS PERFORMANCE DIAG 1 5 RETREIVED DTC P2285 FOUND CRANK CASE OVERFILLED POSSIBLY FROM FUEL CONTAMINATION PERFORMED TSB 04 09 03 INSTRUCTED TO DRAIN OIL DRAINED 23 QUARTS INSP TURBO FOR CONSEQUENTIAL DAMAGE PER SECTION 303 04D RADIAL AND LATERAL RUN OUT OK NO BINDING OR DISCOLORATION OK ADD 1OZ OF DYE TO FUEL SYS BLOCKED FUEL LINE TO LEFT CYL HEAD AND INSTRUCTED PRESSURE GAUGE TO CONFIRM CONSTANT
1FTSW31P33ED53442 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 09-JUN-2003 02-JUL-2003 171171 USA 30 6Y20 000001 * MISC * A99 82 18229
AWS Claim Key: 12679963 Trx Code: P98 Labor Hrs: 0
Dlr Cd-Sub Cd: 20443 - * Name: BILL ALEXANDER FORD LINCOLN MERCURY, INC. Ph: 928-3442200 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:25-NOV-2005 Doc #:38672504
Cust Comments: P98 LOANER $140.00 5 DAYS
Tech Comments: CRC AUTHO M01ST
1FTSW31P33ED53442 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 09-JUN-2003 02-JUL-2003 171171 USA 32 7S22 180106 F2UZ 14526 P D02 46 23179
AWS Claim Key: 13155454 Trx Code: S07 Labor Hrs: 2.2
Dlr Cd-Sub Cd: 20305 - * Name: BERGE FORD Ph: 480-4971111 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:14-FEB-2006 Doc #:38025101
Cust Comments: CUSTOMER STATES THE VEHICLE WILL NOT CRANK OVER OR START BUT ALL LIGHTS DO COME ON
Tech Comments: VERIFIED CUSTOMERS CONCERN OF NO CRANK NO START, PERFORMED DIESEL DIAG SHEET, FOUND ALL VISUAL INSPECTIONS OKAY, ATTEMP TED TO PERFORM SELF TEST, UNABLE TO COMMUNICATE WITH PCM, CHECKED ALL RELATED FUSES IN FUSE PANEL, FOUND FUSE F2.22 BLOWN(ENGINE CONTROLS 20AMP) REMOVED FUSE AND CHECKED FOR SH ORT, NONE FOUND, INSTALLED NEW FUSE AND ATTEMPTED TO START,
1FTSW31P33ED53442 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 09-JUN-2003 02-JUL-2003 171171 USA 33 * * * * * * * 23397
AWS Claim Key: 13405577 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 20443 - * Name: BILL ALEXANDER FORD LINCOLN MERCURY, INC. Ph: 928-3442200 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:20-FEB-2006 Doc #:39599804
AWS Claim Key: 13405576 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 20443 - * Name: BILL ALEXANDER FORD LINCOLN MERCURY, INC. Ph: 928-3442200 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:20-FEB-2006 Doc #:39599805
1FTSW31P33ED53442 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 09-JUN-2003 02-JUL-2003 171171 USA 33 2H01 030008 3C3Z 6K682 AARM D50 42 23397
AWS Claim Key: 13405575 Trx Code: S07 Labor Hrs: 14.7
Dlr Cd-Sub Cd: 20443 - * Name: BILL ALEXANDER FORD LINCOLN MERCURY, INC. Ph: 928-3442200 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:20-FEB-2006 Doc #:39599801
Cust Comments: CUST STATES VEHICLE CAUGHT ON FIRE
Tech Comments: INSP VEH NO SIGNS OF FIRE ANYWHERE VEH ONLY OIL AT EXH PIPE REMOVE TURBO PIPING TO ISNP FOUND DAMAGED TURBINE WHEEL BEARINGS SEIZED TURBOS TURBINE WHEEL STUCK IN EXH DOWN PIPE AND INJ HARNESS CONN REPLACED INJ HARNESS REMOVED TURBO AND TWO SEIZED BOLTS REMOVED TRANS CROSS MEMBER TRANS DIP STICK TRANS LINES TO ACCESS DOWN PIPE LIFT VEH AND LOWER TRANS INSTALLED NEW PIPE TURBO RETEST ROAD TEST TO BU
1FTSW31P33ED53442 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 09-JUN-2003 02-JUL-2003 171171 USA 34 2E01 030008 3C3Z 9F838 EA D21 42 24011
AWS Claim Key: 13461753 Trx Code: S07 Labor Hrs: 8.9
Dlr Cd-Sub Cd: 20305 - * Name: BERGE FORD Ph: 480-4971111 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:24-MAR-2006 Doc #:38717001
Cust Comments: CUSTOMER STATES THE VEHICLE DIED OUT IN FLIGHT AND WILL NOT RESTART...ALL LIGHTS COME ON BUT NO CRANK...SAME CONCERN AS LAST TIME
Tech Comments: 6CXDW006 VERIFIED CUSTOMERS CONCERN, CHECKED FUSES, FOUND FUSE F2.22 BLOWN AGAIN, REPLACED FUSE AND VEHICLE STARTED, PERFORMED WIGGLE TEST, WHEN ENGINE HARNESS WAS WIGGLED AROUND GLOW PLU G MODULE ENGINE DIED, CHECKED FUSE AND FUSE WAS BLOWN AGAIN, REMOVED WIRING COVER, WAS UNABLE TO FIND SOURCE OF SHORT, CO NTACTED TECH HOTLINE(6CXDW006) WAS ADVISED TO REPLACE ENGINE
1FTSW31P33ED53442 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 09-JUN-2003 02-JUL-2003 171171 USA 34 6Y20 000001 * MISC * A99 82 24011
AWS Claim Key: 13446931 Trx Code: P01 Labor Hrs: 0
Dlr Cd-Sub Cd: 20305 - * Name: BERGE FORD Ph: 480-4971111 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:27-MAR-2006 Doc #:38757201
Cust Comments: REFUND TO CUSTOMER $1120. FOR RENTAL EXPENSE
Tech Comments: CUSTOMER REIMBURSEMENT
1FTSW31P33ED53442 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 09-JUN-2003 02-JUL-2003 171171 USA 36 6P07 010301 * 5420124 * L19 42 27112
AWS Claim Key: 13966597 Trx Code: E84 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 20305 - * Name: BERGE FORD Ph: 480-4971111 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:08-JUN-2006 Doc #:40032503
Cust Comments: DOOR AJAR LIGHT STAYS ON WHEN ALL DOORS ARE CLOSED
Tech Comments: LUBE ALL FOUR DOOR STRIKERS
2000 F-350 supercrew 4x4. Banks new ram air, Autometer guages(Thanks GOS)Boost, pyro, trans temp. DP tuner F8.(Thanks Diane and Jody)
00f3fiddy is offline
The Following User Says Thank You to 00f3fiddy For this addition to TDG:
roundsound (10-29-2010)
post #3 of 6 (permalink) Old 10-29-2010, 03:15 AM Thread Starter
Thank you, fiddy!
post #4 of 6 (permalink) Old 10-29-2010, 04:15 AM Thread Starter
Replace Engine?
Thanks again, Fiddy.
Can someone help me figure out if the engine was replaced on this truck, please?
3rd item from bottom: AWS Key 13461753-Hot line advised to replace engine.
2nd item from bottom: AWS key 13446931-Refund $1120 rental expense.
8th item from bottom: AWS key 12679963-Loaner $140 for 5 days (as compared to the $1120 above).
The dealer obviously kept the truck for a long time to rack up $1120 in rental expense, but the report doesn't claim that the engine was actually replaced, just that it was advised by the Hot Line to do so.
Thanks for the help.
post #5 of 6 (permalink) Old 10-29-2010, 01:09 PM
I think they left off harness. Should say replace engine harness. Ford will not replace an engine for an electrical problem.
post #6 of 6 (permalink) Old 10-30-2010, 02:35 AM Thread Starter
That makes sense. Thanks.
Oasis report please - thanks! MadMaxx61 Ford Oasis requests 2 08-11-2010 11:01 AM
Oasis Report(s) hntrjmpr1176 Ford Oasis requests 3 07-28-2010 07:03 PM
Oasis report please Robert S. Ford Oasis requests 1 08-11-2009 10:13 PM
OASIS Report blownwhite03 Ford Oasis requests 2 12-14-2006 12:50 AM
oasis report please detailman Ford Oasis requests 2 12-13-2006 10:20 PM
