Oasis request - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Rollingrock, this thread has received 2 replies and been viewed 460 times.
post #1 of 3 (permalink) Old 10-27-2010, 06:50 PM Thread Starter
Oasis request
Hello, looking for an oasis report for a friend looking at truck to buy.
1FTSW21P57EA69746
My buddy and I thank you in advance for the info.
RR
RollingRock, Keller Texas
2006 F250 PSD, King Ranch
Rollingrock is offline
post #2 of 3 (permalink) Old 10-28-2010, 02:55 PM
Standard Claims List For Model Year 2007
1FTSW21P57EA69746 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-AUG-2006 09-FEB-2007 152020 USA 25 2E01 030404 3C3Z 9C064 DA L65 D1 34886
AWS Claim Key: 4251638 Trx Code: E84 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 02531 - * Name: BOB TOMES FORD-LINCOLN-MERCURY Ph: 214-5445000 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:12-FEB-2009 Doc #:67972503
Cust Comments: AXLE/DIFFERENTIAL CUST STATES HAS BURNING SMELL FROM LR WHEEL AREA AFTER DRIVING A WHILE
Tech Comments: ADD OIL DYE FOUND OIL LEAKING FROM CAM AND CRANK SENSOR ORING REPLACE CAM AND CRANK SENSOR ORINGS CLEAN ENG NPF
1FTSW21P57EA69746 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-AUG-2006 09-FEB-2007 152020 USA 25 6Y20 000000 * TAP3 * A99 82 35459
AWS Claim Key: 4231287 Trx Code: TAP3 Labor Hrs: 0
Dlr Cd-Sub Cd: 02531 - * Name: BOB TOMES FORD-LINCOLN-MERCURY Ph: 214-5445000 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:25-FEB-2009 Doc #:68058104
Tech Comments: CP:TAP3 XXXXXXXXXXXXXX
1FTSW21P57EA69746 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-AUG-2006 09-FEB-2007 152020 USA 25 2A01 031202 6C3Z 6C640 A L65 D1 35459
AWS Claim Key: 4204760 Trx Code: S07 Labor Hrs: 1.8
Dlr Cd-Sub Cd: 02531 - * Name: BOB TOMES FORD-LINCOLN-MERCURY Ph: 214-5445000 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:25-FEB-2009 Doc #:68058102
Cust Comments: DIESEL ENGINE CONCERN L65 CUST STATES ENGINE HAS BURNT OIL ODOR
Tech Comments: ADDED ENGINE OIL DYE, FOUND CAC TUBE LEAKING AT TURBO, REPLACED HOSE END, ALSO FOUND CAM SENSOR O RINGS LEAKING, R&R SENSOR AND REPLACED O RINGS, WASHED ENGINE
1FTSW21P57EA69746 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-AUG-2006 09-FEB-2007 152020 USA 25 7K11 130101 6C3Z 10849 EC A37 42 35459
AWS Claim Key: 4204759 Trx Code: S07 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 02531 - * Name: BOB TOMES FORD-LINCOLN-MERCURY Ph: 214-5445000 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:25-FEB-2009 Doc #:68058101
Cust Comments: BODY ELECTRICAL A37 CUSTOMER STATES SPEEDO INOP SOP HERE
Tech Comments: TESTED SYS RAN PIN TEST ON SYS AND FOUND CLUSTER GOING OPEN INTERNALLY REPLACED CLUSTER SYS WORKINGTO PROPER SPECS.
2000 F-350 supercrew 4x4. Banks new ram air, Autometer guages(Thanks GOS)Boost, pyro, trans temp. DP tuner F8.(Thanks Diane and Jody)
00f3fiddy is offline
The Following User Says Thank You to 00f3fiddy For this addition to TDG:
Rollingrock (12-01-2010)
post #3 of 3 (permalink) Old 10-28-2010, 03:42 PM Thread Starter
thank you very, very much!
Looks pretty good.
OASIS request, please plainredtruck Ford Oasis requests 1 03-26-2009 11:00 PM
OASIS Request Please 2008fx4diesel Ford Oasis requests 2 03-11-2009 09:01 PM
OASIS Request Please SparkyLV Ford Oasis requests 3 03-11-2009 05:30 AM
oasis request please 86 1 tonhauler Ford Oasis requests 2 03-10-2009 05:44 PM
Oasis Request Please gigjoec Ford Oasis requests 1 09-27-2007 12:35 AM
