Oasis PLEASE - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Thnkfst, this thread has received 1 replies and been viewed 409 times.
post #1 of 2 (permalink) Old 10-27-2010, 07:48 PM Thread Starter
Thnkfst's Avatar
Images: 4
Oasis PLEASE
1FTWX31P26EA28364
SOLD-2005 F250 Elite and Spartan tunes, EGR block, ARP studs, 4" Magnaflow no Cat
2008 F250 DPF delete and Spartan
Thnkfst is offline
post #2 of 2 (permalink) Old 10-28-2010, 02:56 PM
Standard Claims List For Model Year 2006
1FTWX31P26EA28364 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 13-JUN-2005 03-AUG-2005 171498 USA 7 * * * * * * * 11401
AWS Claim Key: 457446 Trx Code: 05E16 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 05493 - * Name: PASO ROBLES FORD LINC-MERC Ph: 805-2393673 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:16-FEB-2006 Doc #:11044701
Cust Comments: FACTORY RECALL 05E16 ENGINE CONTROL MODULES RECALIBRATION
Tech Comments: RECALIBRATE MODULES PER 05E16
1FTWX31P26EA28364 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 13-JUN-2005 03-AUG-2005 171498 USA 26 5I01 110204 3C3Z 3A674 AARM N58 42 39614
AWS Claim Key: 4571537 Trx Code: P05 Labor Hrs: 1.9
Dlr Cd-Sub Cd: 05493 - * Name: PASO ROBLES FORD LINC-MERC Ph: 805-2393673 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:20-SEP-2007 Doc #:12371901
Cust Comments: STEERING WHEEL MAKING A RUBBING NOISE WHEN TURNING
Tech Comments: VERIFY CONCERN CHECK P S PUMP PRESSURE FOUND TO BE LOW AND NO BRAKE ASSIST REPLACED POWER STEERING PUMP RETEST OK
1FTWX31P26EA28364 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 13-JUN-2005 03-AUG-2005 171498 USA 29 2E01 030404 3C3Z 9C064 AA D02 D8 42609
AWS Claim Key: 5103508 Trx Code: E72 Labor Hrs: 5
Dlr Cd-Sub Cd: 05493 - * Name: PASO ROBLES FORD LINC-MERC Ph: 805-2393673 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:03-DEC-2007 Doc #:12529002
Cust Comments: VEHICLE TAKING LONGER TIME THAN NORMAL TO TURN OVER
Tech Comments: VERIFY CONCERN PERFORM HARD START DIAG PERFORMED KOEO PASS INJECTOR TEST PASS KOER PASS FUEL PSI OK OIL OK ICP AND EGR PASS GLOW PLUGS PASS FOUND IPR VALVE OVRECOMPENSATING FOR SMALL LEAK R AND I LHAND VALVE COVER TO INSPECT ORINGS AL OK
2000 F-350 supercrew 4x4. Banks new ram air, Autometer guages(Thanks GOS)Boost, pyro, trans temp. DP tuner F8.(Thanks Diane and Jody)
00f3fiddy is offline
