Oasis report please - 1FTSX21P56ED52532 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by ChadSD, this thread has received 2 replies and been viewed 581 times.
post #1 of 3 (permalink) Old 10-31-2010, 04:40 AM Thread Starter
VIN - 1FTSX21P56ED52532
Thank you so much!
ChadSD is offline
post #2 of 3 (permalink) Old 11-01-2010, 02:04 PM
Standard Claims List For Model Year 2006
1FTSX21P56ED52532 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 01-APR-2006 17-APR-2006 183000 USA 15 5C04 050100 5C3Z 4A376 F N12 42 20028
AWS Claim Key: 3906760 Trx Code: E84 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 07461 - * Name: JACK KEY FORD LINCOLN MERCURY Ph: 575-5462765 St:NM Ctry Cd: USA Reg Cd: NA Repr Date:22-JUN-2007 Doc #:19107501
Cust Comments: CUSTOMER STAES HEARS CLUNKING NOISE COMING FROM FRNT END
Tech Comments: FRONT DRIVESHAFT HAS RATTLE IN IT REMOVED AND REPLACED FRONT DRIVESHAFT, ROAD TEST OK
1FTSX21P56ED52532 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 01-APR-2006 17-APR-2006 183000 USA 44 2E03 030402 4C3Z 9E527 BRM D42 42 94374
AWS Claim Key: 8778926 Trx Code: S07 Labor Hrs: 6.7
Dlr Cd-Sub Cd: 07461 - * Name: JACK KEY FORD LINCOLN MERCURY Ph: 575-5462765 St:NM Ctry Cd: USA Reg Cd: NA Repr Date:12-NOV-2009 Doc #:24663001
Cust Comments: CUSTOMER STATES VEHICLE EXIBITS NO OIL PRESSURE AT GUAGES VEHICLE WILL NOT START
Tech Comments: SELF TEST ALL CMDTCS TCM PASS,ABS B2900,B11900 GEM B1318, B1483.IC B1318,B1352,B1360,U1900 PCM PO232,PO269,PO275,PO299 PO0470,PO500,P2291,U0306 RCMB1318,B1869 REPROGRAM MODULES FOR FICM PROGRAM FAULT KOEO PASSED.PASS KOER.POWER BALANCE AND TEST DRIVE MODERATE ACCEL NUMBERS 2,4,7 CYLINDERS HAVE POSIBLE FUEL SYSTEM CONCERN.TEST FUEL PRESSURE 42PSI MINIMUM 45 AT ILDE WOT 16PSI MIN 50PSI BYPASS AND R
2000 F-350 supercrew 4x4. Banks new ram air, Autometer guages(Thanks GOS)Boost, pyro, trans temp. DP tuner F8.(Thanks Diane and Jody)
00f3fiddy is offline
post #3 of 3 (permalink) Old 11-02-2010, 12:12 AM Thread Starter
Thank you!
ChadSD is offline
Oasis report, please machine Ford Oasis requests 2 04-20-2009 02:44 PM
Oasis Report Please aline1986 Ford Oasis requests 1 01-06-2008 02:02 AM
Oasis Report Please Knightime Ford Oasis requests 2 09-15-2007 06:28 PM
OASIS report please strokin350 Ford Oasis requests 1 09-15-2007 02:26 PM
Oasis Report Please ruger9 Ford Oasis requests 2 02-02-2007 08:40 PM
