1FTWW31R68ED25550 T/F7 F T/BC T/CD T/E A1 T/BE T/QL 23-JAN-2008 05-MAR-2008 158600 USA 3 5K06 040402 * TWC01 * TA1 42 1261
AWS Claim Key: 1140820 Trx Code: 1 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 09757 - * Name: LUTHER FAMILY FORD Ph: 701-2822350 St:ND Ctry Cd: USA Reg Cd: NA Repr Date:16-MAY-2008 Doc #:169415B
Cust Comments: CUSTOMER STATES THE PASSENGER FRONT TIRE IS COMING APART
Tech Comments: REPLACE TIRE DUE TO TIRE FAILURE
1FTWW31R68ED25550 T/F7 F T/BC T/CD T/E A1 T/BE T/QL 23-JAN-2008 05-MAR-2008 158600 USA 6 4C01 090201 7C3Z 5H221 CA D42 42 7364
AWS Claim Key: 1365618 Trx Code: S07 Labor Hrs: 1.4
Dlr Cd-Sub Cd: 09757 - * Name: LUTHER FAMILY FORD Ph: 701-2822350 St:ND Ctry Cd: USA Reg Cd: NA Repr Date:14-AUG-2008 Doc #:178709A
Cust Comments: CUSTOMER STATES THE VEHICLE WILL SMOKE AT TIMES, KIND OF AN INTERMITTENT PROBLEM BUT IT HAPPENED 5 TIMES ON MONDAY, WHEN IT DOES THIS IS RUNS A BIT DIFFENTLY, KIND OF ROUGH
Tech Comments: 7364 HOOKED UP SCAN TOOL RAN SELF TEST PASSED NO CODES PERFORMED SYSTEM CHART 8 IN THE PCED PERFORMED ALL STEPS PERFOMRED POWER BALANCE AND ENHANCED POWER BALANCE RUNNING SMOOTH PEROFMRED RELATIVE COMPRESSION TEST PASSED ALL SENSOR ARE GOOD EGR SYSTEM GOOD PERFORMED CRANK CASE PRESSURE TEST PASSED FOUND DPF TO BE BAD R AND R DPF RESET DPF AND REPROGRAMED PCM AND IC TO
1FTWW31R68ED25550 T/F7 F T/BC T/CD T/E A1 T/BE T/QL 23-JAN-2008 05-MAR-2008 158600 USA 7 7S11 180107 7C3Z 14489 AA A88 X2 8408
AWS Claim Key: 1558496 Trx Code: 1 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 09757 - * Name: LUTHER FAMILY FORD Ph: 701-2822350 St:ND Ctry Cd: USA Reg Cd: NA Repr Date:16-SEP-2008 Doc #:181784A
Cust Comments: CUSTOMER STATES THE READOUT ON THE DASH SAYS TRAILER BRAKE FAULT, CHECK AND ADVISE
Tech Comments: 8408 EEC CK TRAILER BRAKE MODULE CODE 2806 SHORT TO POWER ON TRAILER BRAKE OUTPUT LINE PPT D1 D4 CIRCUIT CHECKING HAVE VOLTAGE SHORT TO POWER WHEN TURN ON RIGHT BLINKER AND BRAKE LIGHTS TRUCK HAS ADDITION 5 WHEEL TRAILER CONNECTOR WIRED ON AND MOUNTED ON BOX CUT INSULATION OFF AND INSPECT ADD ON WIRING ALL LOOKS OK REASSAMBLE INSPECT 7 PIN CONNECTOR REMOVE AND FOUND WAS FULL OF WATER
1FTWW31R68ED25550 T/F7 F T/BC T/CD T/E A1 T/BE T/QL 23-JAN-2008 05-MAR-2008 158600 USA 16 2E03 030402 8C3Z 9E527 A D36 42 14056
AWS Claim Key: 3794768 Trx Code: S07 Labor Hrs: 6.3
Dlr Cd-Sub Cd: 09757 - * Name: LUTHER FAMILY FORD Ph: 701-2822350 St:ND Ctry Cd: USA Reg Cd: NA Repr Date:23-JUN-2009 Doc #:208784A
Cust Comments: CUSTOMER STATES THE VEHICLE IS RUNNING ROUGH, USUALLY AFTER FIRST START UP BUT NOT ALWAYS AND ONCE HE GETS UP TO SPEED SOMETIMES IT WILL GET BETTER
Tech Comments: 14065 EEC CK NO CODES PASS POWER BALANCE ALL LOOK OK PREFOMRED ENHANCED POWERBALANCE TEST SLIGHT MISSFIRE CYL 2 AND 5 AT TIMES RELATIVE COMPRESSION TEST MONITOR PIDS SHORT FUEL TRIMS CYL NO 2 PLUS 7 REST 2 TO 3 REPLACE NO 2 AND 5 INJECTORS 1 EACH SIDE RESET ADAPTIVE FUEL TABLES ROAD TEST AFTER REPAIRS ENGINE RAN GOOD 6.4L
1FTWW31R68ED25550 T/F7 F T/BC T/CD T/E A1 T/BE T/QL 23-JAN-2008 05-MAR-2008 158600 USA 26 1H03 030804 8C3Z 9D475 D E29 42 23128
AWS Claim Key: 5623795 Trx Code: S07 Labor Hrs: 2.3
Dlr Cd-Sub Cd: 09757 - * Name: LUTHER FAMILY FORD Ph: 701-2822350 St:ND Ctry Cd: USA Reg Cd: NA Repr Date:31-MAR-2010 Doc #:237979A
Cust Comments: CUSTOMER STATES THE CHECK ENGINE LIGHT IS ON AND THE VEHICLE HAS NO POWER, BARELY RUNS WHEN TRYING TO ACCELERATE
Tech Comments: MONITOR PIDS EGR VALVE STUCK OPEN 1.95VOLTS ATTEMPT TO REMOVE EGR VALVE WAS STUCK IN HOUSING PUNCH SEPERATE TO REPLACE EGR VALVE HOUSING REMOVE HOUSING REPLACE HOUSING AND EGR VALVE REASSAMBLE CLEAR CODES ROAD TEST ENINE RAN GOOD KOEO SELF TEST PASS
Related Threads
The Diesel Garage
1.2M posts
57.2K members
Since 2005
