Ford Oasis Reports Please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by stangclassic66, this thread has received 1 replies and been viewed 1686 times.
post #1 of 2 (permalink) Old 12-29-2008, 07:41 AM Thread Starter
Hello,
I'm helping my dad look for a good used diesel. Would appreciate any Oasis reports to these VIN numbers please.
1FTSW21P45EA71176
1FTNW21P44EC01646
1FTSW20P36EC09373
1FTWW31P65EB32325
1FTSW21P66ED74218
Thanks in advance.
Erik
stangclassic66 is offline
post #2 of 2 (permalink) Old 12-30-2008, 02:30 AM
OASIS RESULT:
1FTSW21P45EA71176
12/29/2008
22:25:25
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
5F710N0A
WARNING MESSAGES
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
12/28/2004 BUILD DATE
09/14/2004 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
12/17/2008
DEALER: Diablo Ford
WARRANTY CLAIM NUMBER: 009007 ODOMETER: 045455M
LABOR OP
CONDITION CODE
CONDITION DESC
12B599 IDM MOD ASY-FUELINJ 000 6005F 42 DOES NOT OPERATE PROPERLY
000 6005F1
000 6005F1X1
000 6005F2
000 6005F6
000 6005F8
000 6005F9
000 6005F22
000 6005F45
000 12650D81
08/26/2008
DEALER: Diablo Ford
WARRANTY CLAIM NUMBER: 006959 ODOMETER: 040146M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 9F452AA TRANSDCR-EGR BACK PR 001 6005F 42 DOES NOT OPERATE PROPERLY
W302725 001 6005F1
F6TZ 9160AA GSKT- FUEL FLTR BOWL 002 6005F1X1
PM 22A MOTORCRAFT BATTERY 001 6005F2
W301321 001 6005F6
W301333 002 6005F39
3C3Z 9433BE GASKET SET-MANIFOLD 001 9424A
W301447 002 12650D30
N802900S 003 OSL
VC 7B 002
3C3Z 6766CA CAP ASY OIL FILLER 001
3C3Z 6750AA INDICATOR ASY OIL LE 001
439INSP AND FOUND CHECK ENGINE LIGHT ON.PERFORME D KOEO AND KOER FOUND CODE P1335.EGR NOT PERFORMING.PERFORMED VISUAL INSPECTION.PERFORMED DATALOGER
05/12/2008
DEALER: Diablo Ford
WARRANTY CLAIM NUMBER: 004765 ODOMETER: 037122M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9F838A SENSR ASY F/I TIMING 001 6005F 42 DOES NOT OPERATE PROPERLY
5C3Z 12224A 3 WAY VACUUM CONNECT 001 6005F1
000 12650D84
000 14200A
000 9838A
000 6005F1X1
379 INSPECT AND VERIFY INTERMITTANT ROLLING IDLE. PERFORM EEC TESTS- K OEO KOER-PASS. CMDTS- P2289 P0299. CLEAR CODES AND RETEST-P1000. PE RFORMED DIESEL DIAG, PID DATA LOGGER INSPECTION-ALL PASS. PERFORMED WIGGLE T EST TO ENGINE HARNESS FOR INTERMITTANT CONCERNS- FOUND CONCERN APPEARS TO B E AT ICP CONNECTOR AND SENSOR. REPLACED ICP CONNECTOR AND SENSOR. REPROGRA
OASIS RESULT:
1FTNW21P44EC01646
12/29/2008
22:26:02
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
4F710N0A
WARNING MESSAGES
ARN MESSAGES
WARRANTY START DATE
04/21/2004 BUILD DATE
01/06/2004 SALE MILEAGE
00017
EXTENDED COVERAGES
0784 - EXPIRED
STANDARD DEDUCTIBLE: 0 USD
OWNER NAME: ROBERT LARSEN
OPTIONS:
EXPIRATION DATE: 04/21/2008
DISTANCE: 51,000
RENTAL: 0 UP TO 0 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 00669
ESP CONTRACT START DATE: 04/21/2004
For competitive make ESP part verification click here
1FTNW21P44EC01646 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 06-JAN-2004 21-APR-2004 172016 USA 0 6Y05 000001 * TDRIVE * A96 82 5
AWS Claim Key: 376792 Trx Code: R7U Labor Hrs: 0.4
Dlr Cd-Sub Cd: 00669 - * Name: MICHAEL STEAD'S HILLTOP FORD LINCOLN MERCURY Ph: 510-2224444 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:19-JAN-2004 Doc #:04235603
Cust Comments: SPECIAL ROAD TEST ALLOWANCE FOR 6.0L DIESEL
Tech Comments: . ROAD TESTED 4 MILES AND INSPECTED ALL OK
1FTNW21P44EC01646 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 06-JAN-2004 21-APR-2004 172016 USA 0 2C01 030603 3C3Z 11002 AARM D50 42 5
AWS Claim Key: 376790 Trx Code: 1 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 00669 - * Name: MICHAEL STEAD'S HILLTOP FORD LINCOLN MERCURY Ph: 510-2224444 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:19-JAN-2004 Doc #:04235604
Cust Comments: STARTER HAS DEFECT IN IT
Tech Comments: VERIFIED STARTER DEFECT REMOVED AND REPLACED DEFECTIVE STARTER
1FTNW21P44EC01646 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 06-JAN-2004 21-APR-2004 172016 USA 0 1A03 030101 * 6007 * D50 79 5
AWS Claim Key: 376791 Trx Code: 1 Labor Hrs: 14.4
Dlr Cd-Sub Cd: 00669 - * Name: MICHAEL STEAD'S HILLTOP FORD LINCOLN MERCURY Ph: 510-2224444 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:19-JAN-2004 Doc #:04235601
Cust Comments: PERFORM RECALL 04T03 UPGRADE PRIOR TO SALE. ENGINE CRANKSHAFT CONCERN.
Tech Comments: REMOVED OIL PAN INSPECTED CRANK FOUND L4 MARKED ON CRANK RAN OASIS # 116512565 REPORT #4ASHB020 REMOVED TURBO AND ADAPTOR PIPE REMOVED OIL SUPPLY TUBE REMOVED TURBO INLET TUBE REMOVED PEDISTAL REMOVED
1FTNW21P44EC01646 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 06-JAN-2004 21-APR-2004 172016 USA 2 6Y05 000001 * MAINT * A96 82 2992
AWS Claim Key: 1009305 Trx Code: 0784S Labor Hrs: 1.3
Dlr Cd-Sub Cd: 00669 - * Name: MICHAEL STEAD'S HILLTOP FORD LINCOLN MERCURY Ph: 510-2224444 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:29-MAY-2004 Doc #:04855601
Cust Comments: CUSTOMER REQUESTS 3000 MILE SERVICE AS PER FORD QCM OPTIONAL
Tech Comments: 1 3K SERVICE COMPLETED CHANGED OIL AND FILTER TOPED WASHER FLUID SET TIRES PRESSURE 55PSI FRONT 70PSI REAR TREAD DEPTH
1FTNW21P44EC01646 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 06-JAN-2004 21-APR-2004 172016 USA 3 6Y05 000001 * MAINT * A96 82 6007
AWS Claim Key: 1142622 Trx Code: 0784S Labor Hrs: 1.4
Dlr Cd-Sub Cd: 00669 - * Name: MICHAEL STEAD'S HILLTOP FORD LINCOLN MERCURY Ph: 510-2224444 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:21-JUN-2004 Doc #:04961201
Cust Comments: PERFORM 6,000 MILE SERVICE PER QCM SERVICE CONTRACT.
Tech Comments: 1 CHANGE 15 QUARTERS OF 15W 40 AND OIL FILTER , TIRE ROATION COMPLETED,
1FTNW21P44EC01646 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 06-JAN-2004 21-APR-2004 172016 USA 4 6Y05 000001 * MAINT * A96 82 9766
AWS Claim Key: 1484894 Trx Code: 0784S Labor Hrs: 1.1
Dlr Cd-Sub Cd: 08541 - * Name: LAKE CITY FORD LINCOLN-MERCURY Ph: 208-6649211 St:ID Ctry Cd: USA Reg Cd: NA Repr Date:23-JUL-2004 Doc #:16710401
Cust Comments: CST STS TO PERFROM SCHEDULED SERVICE
Tech Comments: PERFORMED SERVICE AS PER SCHEDULED MAINTENANCE
1FTNW21P44EC01646 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 06-JAN-2004 21-APR-2004 172016 USA 4 2A01 031202 4C3Z 6C646 DA D50 33 9766
AWS Claim Key: 1484895 Trx Code: 2 Labor Hrs: 2.7
Dlr Cd-Sub Cd: 08541 - * Name: LAKE CITY FORD LINCOLN-MERCURY Ph: 208-6649211 St:ID Ctry Cd: USA Reg Cd: NA Repr Date:23-JUL-2004 Doc #:16710402
Cust Comments: CST STS TURBO TUBES BLOW OFF WHEN PULLING HILLS
Tech Comments: VERIFIED FND SIGNS OF BOTH TURBO TUBES BLOWING OFF RMVD BOTH TUBES AND CLEANED SURFACES OF BOTH TURBO AND INTER COOLER FND COLD SIDE TUBE BAD REPLACE COLD SIDE TUBE AND REFIT OTHER TUBE POST ROAD TEST WHILE MONITORING PIDS OK NOW
1FTNW21P44EC01646 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 06-JAN-2004 21-APR-2004 172016 USA 4 2G05 031405 * RECAL * E29 42 12525
AWS Claim Key: 1535221 Trx Code: E84 Labor Hrs: 1.4
Dlr Cd-Sub Cd: 00669 - * Name: MICHAEL STEAD'S HILLTOP FORD LINCOLN MERCURY Ph: 510-2224444 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:07-AUG-2004 Doc #:05173602
Cust Comments: CUSTOMER STATES THAT TRUCK HAS A ROUGH IDLE AND AN INTERMINT ENT CHECK ENGINE LIGHT. CHECK AND ADVISE.
Tech Comments: PERFORM INSPECITON. UNABLE TO VERIFY CUSTOMER CONCERN. RUN EEC TEST. KOEC P0603 60 KOEO PASS KOEO INJECTOR TEST PASS REPROGRAM PCM, FICM, TCM AS PER SSM 17571 TO LATEST CALIBRATION. RECHECK OK AT THIS TIME. RECOMMEND EXTENDED
1FTNW21P44EC01646 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 06-JAN-2004 21-APR-2004 172016 USA 4 6Y05 000001 * MAINT * A96 82 12525
AWS Claim Key: 1535222 Trx Code: 0784S Labor Hrs: 1.4
Dlr Cd-Sub Cd: 00669 - * Name: MICHAEL STEAD'S HILLTOP FORD LINCOLN MERCURY Ph: 510-2224444 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:07-AUG-2004 Doc #:05173601
Cust Comments: PERFORM 12,000 MILE SERVICE PER QCM SERVICE CONTRACT.
Tech Comments: 1 PERFORMED 12K SERVICE OIL CHANGE ROTATED TIRES TOPPED OFF FLUIDS ALL BRAKES 11MM.
1FTNW21P44EC01646 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 06-JAN-2004 21-APR-2004 172016 USA 6 6Y05 000001 * MAINT * A96 82 15175
AWS Claim Key: 1906253 Trx Code: 0784S Labor Hrs: 1.8
Dlr Cd-Sub Cd: 00669 - * Name: MICHAEL STEAD'S HILLTOP FORD LINCOLN MERCURY Ph: 510-2224444 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:18-SEP-2004 Doc #:05359001
Cust Comments: PERFORM 15K SERVICE PER FORD QUALITY CARE MAINT PLAN
Tech Comments: CHANGED 15QTS OF 15 40 AND OIL FILTER,ROTATED TIRES,FRONT AND REAR TIREM TREAD AT 9 32NDS,FRONT BRAKE PADS AT 8MM 1
1FTNW21P44EC01646 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 06-JAN-2004 21-APR-2004 172016 USA 7 6Y05 000001 * MAINT * A96 82 18031
AWS Claim Key: 2346083 Trx Code: 0784S Labor Hrs: 0.7
Dlr Cd-Sub Cd: 00669 - * Name: MICHAEL STEAD'S HILLTOP FORD LINCOLN MERCURY Ph: 510-2224444 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:25-OCT-2004 Doc #:05525901
Cust Comments: CUSTOMER REQUEST 18K WARRANTY SERVICE PER AGREEMENT
Tech Comments: 1 18K COMPLETED SERVICE, 15W 40 PLUS FILTER
1FTNW21P44EC01646 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 06-JAN-2004 21-APR-2004 172016 USA 10 6Y05 000001 * MAINT * A96 82 21583
AWS Claim Key: 3488441 Trx Code: 0784S Labor Hrs: 1.3
Dlr Cd-Sub Cd: 00669 - * Name: MICHAEL STEAD'S HILLTOP FORD LINCOLN MERCURY Ph: 510-2224444 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:29-JAN-2005 Doc #:05923501
Cust Comments: PERFPRM 20K SERVICE PER FORD QUALITY CARE MAINT PLAN
Tech Comments: 1 LUBED STEERING. CHANGED OIL AND FILTER,15 40W. ROTATED TIRES ,SET PSI AT 55 70LBS. BRAKES 8MM. LIGHTS,WIPERS,FLUID LEVELS
1FTNW21P44EC01646 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 06-JAN-2004 21-APR-2004 172016 USA 10 2G05 031405 * RECAL * N22 42 21583
AWS Claim Key: 3488440 Trx Code: E84 Labor Hrs: 1
Dlr Cd-Sub Cd: 00669 - * Name: MICHAEL STEAD'S HILLTOP FORD LINCOLN MERCURY Ph: 510-2224444 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:29-JAN-2005 Doc #:05923502
Cust Comments: CUST STATES VIBRATION FROM GAS PEDAL AT IDLE
Tech Comments: DID NOT VERIFY CONCERN. WDS TO TEST KOEO PO605 IN MEMORY. TESTED MODE 6 DATA,NO CONCERNS. TESTED DCL DATALOG PIDS,ALL UPDATED PCM TO 4U7A 12A650 BGD. ROAD TESTED 3 MILES,RECHECKE D FOR VIBRATION. SLIGHT VIBRATION AT LOW SPEEDS ON ACCEL.MAY
1FTNW21P44EC01646 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 06-JAN-2004 21-APR-2004 172016 USA 13 6Y05 000001 * MAINT * A96 82 25152
AWS Claim Key: 5125534 Trx Code: 0784S Labor Hrs: 1.3
Dlr Cd-Sub Cd: 00669 - * Name: MICHAEL STEAD'S HILLTOP FORD LINCOLN MERCURY Ph: 510-2224444 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:07-MAY-2005 Doc #:06347901
Cust Comments: PERFORM 24K SERVICE AS PER FORD QUALITY CARE MAINT PLAN
Tech Comments: 1 PERFORMED 24 K SERVICE TOP OFF FLUIDS SET TIRE PRESSURE. OIL FILTER SERVICE. CHECK UNDERHOOD COMPONENTS.
1FTNW21P44EC01646 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 06-JAN-2004 21-APR-2004 172016 USA 15 6Y05 000001 * MAINT * A96 82 26555
AWS Claim Key: 5671733 Trx Code: 0784S Labor Hrs: 0.7
Dlr Cd-Sub Cd: 00669 - * Name: MICHAEL STEAD'S HILLTOP FORD LINCOLN MERCURY Ph: 510-2224444 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:21-JUN-2005 Doc #:06542103
Cust Comments: PERFORM 27K SERVICE AS PER QCMP
Tech Comments: PERFORMED 27K QCM SERVICE LUBE OIL FILTER CHANGE TOPPED OF FLUIDS. ROTATED TIRES, ALL TIRES AT 5 32. BRAKES FRONT AT 10MM REAR AT 8MM. INSPECTED LIGHTING, WIPERS, HORN BELTS AND HOSES, FIL 1
1FTNW21P44EC01646 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 06-JAN-2004 21-APR-2004 172016 USA 15 7F02 011601 YF1Z 17528 AB A99 30 26555
AWS Claim Key: 5671732 Trx Code: 0784D Labor Hrs: 0.2
Dlr Cd-Sub Cd: 00669 - * Name: MICHAEL STEAD'S HILLTOP FORD LINCOLN MERCURY Ph: 510-2224444 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:21-JUN-2005 Doc #:06542104
Cust Comments: CUST STATES FRONT WIPERS ARE STREAKY
Tech Comments: VERIFIED CONCERN, FOUND WIPERS STREAKING REPLACED WIPERS AND RETESTED, PASSED CAUSAL PART 17528 AB CONDITION CODE 14
1FTNW21P44EC01646 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 06-JAN-2004 21-APR-2004 172016 USA 15 2H01 * * * * * * 26555
AWS Claim Key: 5671734 Trx Code: 05B29 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 00669 - * Name: MICHAEL STEAD'S HILLTOP FORD LINCOLN MERCURY Ph: 510-2224444 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:21-JUN-2005 Doc #:06542101
Cust Comments: RECALL 05B29 CHARGE AIR COOLER DUCT REPLACEMENT.
Tech Comments: 1 COMPLETED RECALL 05B29.REPLACED CHARGE AIR COOLER DUCT AND TEST DROVE VEHICLE PASSED.
1FTNW21P44EC01646 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 06-JAN-2004 21-APR-2004 172016 USA 15 * * * * * * * 26555
AWS Claim Key: 5671731 Trx Code: 05S34 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 00669 - * Name: MICHAEL STEAD'S HILLTOP FORD LINCOLN MERCURY Ph: 510-2224444 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:21-JUN-2005 Doc #:06542102
Cust Comments: RECALL 05S34 FUEL INJECTOR CONTROL MODULE WIRING HARNESS REP AIR.
Tech Comments: COMPLETED RECALL 05S34.INSPECTED FICM WIRING HARNESS.REINFOR CED HARNESS INSULATION AND INSTALLED CONNECTOR PROTECTORS. WRAPPED WIRING HARNESS WITH TAPE.REPLACED ICP CONNECTOR AND REINFORCED HARNESS INSULATION TO ICP.TEST DROVE VEHICLE PER RECALL.
1FTNW21P44EC01646 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 06-JAN-2004 21-APR-2004 172016 USA 17 * * * * * * * 29210
AWS Claim Key: 6850885 Trx Code: 05E15 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 00669 - * Name: MICHAEL STEAD'S HILLTOP FORD LINCOLN MERCURY Ph: 510-2224444 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:12-SEP-2005 Doc #:06912201
Cust Comments: RECALL 05E15 EXHAUST PRESSURE SENSOR REPLACEMENT
Tech Comments: PERFORM INSPECTION. REMOVE EBP SENSOR PART# 1837012 C13331C AS PER RECALL REPLACE WITH NEW REVISED EBP SENSOR. REPLACE CONNECTOR AND REPROGRAM PCM TO LATEST CALIBRATION. PCM PART# 4U7A 12A650 BGG
AWS Claim Key: 6830241 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 00669 - * Name: MICHAEL STEAD'S HILLTOP FORD LINCOLN MERCURY Ph: 510-2224444 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:12-SEP-2005 Doc #:06912202
Cust Comments: RECALL 59B01 ELIGIBLE FOR ONE TIME ONLY CUST ASSURANCE TEST DRIVE.
Tech Comments: PERFORM ROAD TEST
1FTNW21P44EC01646 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 06-JAN-2004 21-APR-2004 172016 USA 19 6Y05 000001 * MAINT * A96 82 30366
AWS Claim Key: 7476986 Trx Code: 0784S Labor Hrs: 2.4
Dlr Cd-Sub Cd: 00669 - * Name: MICHAEL STEAD'S HILLTOP FORD LINCOLN MERCURY Ph: 510-2224444 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:20-OCT-2005 Doc #:07096801
Cust Comments: PERFORM 30,000 MILE SERVICE PER QCM SERVICE CONTRACT.
Tech Comments: 1 30K SERVICE PERFORME0 CHANGED OIL AND FILTER FUEL AND FUEL AND WATER SEPARATOR ROTATE TIRES CHECKED TREAD L F 5 32 R F 4 32 REAR 3 32 CHECK BRAKES 8MM F R TOPPED FLUIDS AS NEEDED PERFORM VISUAL INSPECTION UNDER HOOD AND SUSPENSSION FOUND OIL LEAK FROM RIGHT SIDE OF ENGINE AND STEERING GEAR LEAKS P A PARTS
1FTNW21P44EC01646 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 06-JAN-2004 21-APR-2004 172016 USA 19 2G02 030008 4C2Z 12A690 AB L65 42 30366
AWS Claim Key: 7409542 Trx Code: S07 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 00669 - * Name: MICHAEL STEAD'S HILLTOP FORD LINCOLN MERCURY Ph: 510-2224444 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:20-OCT-2005 Doc #:07096806
Cust Comments: OIL LEAK AT TOP OF ENGINE.SEE 905.
Tech Comments: PERFORMED VISUAL INSPECTION.VERIFIED CUSTOMER CONCERN OF ENGINE OIL LEAK.PERFORMED DIESEL ENGINE OIL DYE TEST.PUT VEHICLE UP ON HOIST. FOUND ENGINE OIL LEAKING FROM GLOW PLUG HARNESS OUTLET.REMOVED CAC DUCT(HOT) AND GLOW PLUG WIRE HAR NESS.INSTALLED NEW HARNESS AFTER CLEANING OILY AREA.INSTALLE D CAC DUCT AND RECHECKED FOR LEAKS.
1FTNW21P44EC01646 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 06-JAN-2004 21-APR-2004 172016 USA 19 5O01 110201 2C3Z 3504 AARM L68 42 31200
AWS Claim Key: 7662170 Trx Code: E84 Labor Hrs: 1.4
Dlr Cd-Sub Cd: 00669 - * Name: MICHAEL STEAD'S HILLTOP FORD LINCOLN MERCURY Ph: 510-2224444 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:07-NOV-2005 Doc #:07173301
Cust Comments: CUSTOMER STATES THERE IS A POWER STEERING FLUID LEAK INSTALL SOP PREVIOUS RO 70968.
Tech Comments: CK AND VERIFY CUST CONCERN FOUND FLUID LEAK FROM TOP OF STEERING GEAR BOX CLEAN AREA AND VERIFY LEAKS COMING FROM GEAR BOX ALSO DETECT OIL LEAK FROM TOP OF ENGINE RIGH SIDE REMOVE GEAR BOX PITMAN ARM AND PRESSURER HOSES AND REPLACE GEAR BOX REINSTALL ALL COMPONENTS AND BLEED SYSTEM AND RECK FOR LEAKS NO MORE LEAKS DETECTED AT THIS TIME PERFORMED FRONT WHEEL ALIGNMENT ROAD TEST AND RECK VEHICLE OK
1FTNW21P44EC01646 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 06-JAN-2004 21-APR-2004 172016 USA 21 6Y05 000001 * MAINT * A96 82 32831
AWS Claim Key: 8054004 Trx Code: 0784S Labor Hrs: 0.7
Dlr Cd-Sub Cd: 00669 - * Name: MICHAEL STEAD'S HILLTOP FORD LINCOLN MERCURY Ph: 510-2224444 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:23-DEC-2005 Doc #:07390201
Cust Comments: 33K SERVICE PER QCM SERVICE CONTRACT.
Tech Comments: 1 33KSERVICE PERFORMED CHANGE OIL AND FILTER TOPPED FLUIDS AS NEEDED VISUAL INSPECTION UNDER HOOD AND SUSP.VEHICLE OK.
1FTNW21P44EC01646 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 06-JAN-2004 21-APR-2004 172016 USA 21 2A01 031202 6C3Z 6C646 AA D50 42 33066
AWS Claim Key: 8082710 Trx Code: E84 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 00669 - * Name: MICHAEL STEAD'S HILLTOP FORD LINCOLN MERCURY Ph: 510-2224444 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:27-DEC-2005 Doc #:07399801
Cust Comments: OWNER STATES THERE IS NO POWER, WAS TOLD TURBO TUBE COMING LOOSE.
Tech Comments: PERFORM INSPECITON. FOUND TURBO CHARGER TUBE FROM TURBO TO INTERCOOLER SATURATED WITH OIL AND IS NOT CREATING GOOD SEAL. RECOMMEND REPLACE AND RETEST. REMOVE AND REPLACE TURBO CHARGER TUBE AND RETEST. PERFORM EXTENDED ROAD TEST. OK AT THIS TIME.
1FTNW21P44EC01646 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 06-JAN-2004 21-APR-2004 172016 USA 21 1A03 030101 * 6007 * L87 42 33066
AWS Claim Key: 8082709 Trx Code: E84 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 00669 - * Name: MICHAEL STEAD'S HILLTOP FORD LINCOLN MERCURY Ph: 510-2224444 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:27-DEC-2005 Doc #:07399802
Cust Comments: OWNER STATES THERE IS A COOLANT LEAK.
Tech Comments: PERFORM INSPECTION. UNABLE TO VERIFY A LEAK CONCERN. COOLANT BOOTLE IS FULL. PRESSURE TEST COOLING SYSTEM AND FOUND SYSTEM HOLDS PRESSURE. ADD COOLANT DYE INTO VEHICLE. WILL NEED ROAD TEST AND R RECHECK FOR COOLANT LEAK AFTER EXTENDED ROAD TEST AND AT TIME UNABLE TO LOCATE AND LEAKS USING BLACK LIGHT. MORE DRIVING TIME IS RECOMMENDED AND RECHECK AT LATER TIME.
1FTNW21P44EC01646 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 06-JAN-2004 21-APR-2004 172016 USA 23 6Y05 000001 * MAINT * A96 82 35658
AWS Claim Key: 8708218 Trx Code: 0784S Labor Hrs: 1.3
Dlr Cd-Sub Cd: 00669 - * Name: MICHAEL STEAD'S HILLTOP FORD LINCOLN MERCURY Ph: 510-2224444 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:21-FEB-2006 Doc #:07665101
Cust Comments: CUSTOMER REQUESTS 36K SERVICE PER QCM
Tech Comments: 1 36K SERVICE PERFORMED CHNAGE OIL AND FILTER CHECK AND TOPPED OFF FLUIDS AS NEEDED TIRES 4 32 FRONT 2 32 REAR RECOMMEND REPLACE TWO REAR TIRES AND ROTATE TO FRONT BRAKES FRONT 6MM REAR 7MM P A TWO TIRES
1FTNW21P44EC01646 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 06-JAN-2004 21-APR-2004 172016 USA 23 1H03 030008 3C3Z 9P458 AA L87 42 35658
AWS Claim Key: 8708217 Trx Code: E84 Labor Hrs: 8.1
Dlr Cd-Sub Cd: 00669 - * Name: MICHAEL STEAD'S HILLTOP FORD LINCOLN MERCURY Ph: 510-2224444 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:21-FEB-2006 Doc #:07665102
Cust Comments: CUSTOMER STATES COOLANT LEAK CHECK AND ADVISE WE ADDED DYE L AST VISIT
Tech Comments: PERFORM INSPECITON OF COOLANT LEAK USING BLACK LIGHT. ISOLATE DYE SHOWING FROM REAR OF ENGINE RIGHT CYLINDER HEAD. TRACE DYE UP TO VALLEY OF ENGINE ON RIGHT SIDE. SUSPECT LEAK AT INTAKE MANIFOLD O REMOVE AND REPLACE EGR COOLER HOSE ADAPTER. REASSEMBLE VEHICLE AND RETEST OPERATION. PRESSURE TEST COOLING SYSTEM AND FOUND OK. PERFORM EXTENDED ROAD TEST AND RECHECK FOR COOLANT LEAK AND FOUND OK AT THI
1FTNW21P44EC01646 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 06-JAN-2004 21-APR-2004 172016 USA 26 6Y05 000001 * MAINT * A96 82 39237
AWS Claim Key: 9457754 Trx Code: 0784S Labor Hrs: 1.3
Dlr Cd-Sub Cd: 00669 - * Name: MICHAEL STEAD'S HILLTOP FORD LINCOLN MERCURY Ph: 510-2224444 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:25-MAY-2006 Doc #:08121601
Cust Comments: CUSTOMER REQUESTS A 39K SERVICE AS PER QCM
Tech Comments: PERFORMED 39K QCM.LUBE,OIL,FILTER CHANGE.TOPPED ALL FLUIDS. 1
1FTNW21P44EC01646 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 06-JAN-2004 21-APR-2004 172016 USA 29 6Y05 000001 * MAINT * A96 82 42526
AWS Claim Key: 10148865 Trx Code: 0784S Labor Hrs: 0.7
Dlr Cd-Sub Cd: 00669 - * Name: MICHAEL STEAD'S HILLTOP FORD LINCOLN MERCURY Ph: 510-2224444 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:24-AUG-2006 Doc #:08582501
Cust Comments: 42K SERVICE AS PER QCM 3K PLAN
Tech Comments: 1 PERFORMED 42K AS PER 3K PLAN LOF TIRE ROTATION CK FLUID LEVELS CK LIGHTS MULTIPOINT INSPECTION BRAKES 8MM FRT 7MM REAR TIRES 10 32 FRT & REAR
1FTNW21P44EC01646 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 06-JAN-2004 21-APR-2004 172016 USA 33 6Y05 000001 * MAINT * A96 82 46167
AWS Claim Key: 10814669 Trx Code: 0784S Labor Hrs: 1.7
Dlr Cd-Sub Cd: 00669 - * Name: MICHAEL STEAD'S HILLTOP FORD LINCOLN MERCURY Ph: 510-2224444 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:08-DEC-2006 Doc #:09087801
Cust Comments: CUSTOMER REQUESTS TO PERFORM THE 45K QCM SERVICE AS PER 3K PLAN MAKE SURE TO ROTATE TIRES
Tech Comments: 1 45K SERVICE PERFORMED CHANGE OIL AND FILTER ROTATE TIRES CHECK BRAKES 6MM F R TREAD 8 32 F R TOP FLUIDS AS NEEDED PERFORM MULTIPOINT INSPECTION OK.
1FTNW21P44EC01646 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 06-JAN-2004 21-APR-2004 172016 USA 34 7F02 011601 * 17528 * A99 30 47952
AWS Claim Key: 11109269 Trx Code: 0784D Labor Hrs: 0.2
Dlr Cd-Sub Cd: 00669 - * Name: MICHAEL STEAD'S HILLTOP FORD LINCOLN MERCURY Ph: 510-2224444 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:02-FEB-2007 Doc #:09348302
Cust Comments: CUST STATES WIPERS STREAK. CHECK AND ADVISE
Tech Comments: WIPERS WORN AND RUBBER HARDENED. REPLACE WIPERS RECHECK OK.
1FTNW21P44EC01646 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 06-JAN-2004 21-APR-2004 172016 USA 34 6Y05 000001 * MAINT * A96 82 47952
AWS Claim Key: 11109270 Trx Code: 0784S Labor Hrs: 1.5
Dlr Cd-Sub Cd: 00669 - * Name: MICHAEL STEAD'S HILLTOP FORD LINCOLN MERCURY Ph: 510-2224444 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:02-FEB-2007 Doc #:09348301
Cust Comments: PERFORM 48,000 MILE SERVICE. HAS 3K PLAN LUBE OIL AND FILTER, TIRES ROTATION AND MULTI POINT INSPECTION
Tech Comments: 1 PERFORM LUBE, OIL, AND OIL FILTER SERVICE. ROTATE TIRES. INSPECT BRAKES OK AT 7MM FRT AND REAR. CHECK TIRES OK AT 6 7 32 TREAD DEPTH LEFT. INSPECT STEERING SUSPENSION, EXH., ALL FLUID LEVELS. WIPER WASHER, REPLLACED WIPERS, HORN, BAT. AND CABLES , BELTS AND HOSE,ALL LAMPS APPEAR TO BE OK AT THIS TIME
OASIS RESULT:
1FTSW20P36EC09373
12/29/2008
22:28:17
FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2006 F-SERIES BODY STYLE
F-250 CREW CAB 4X2 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
6F710D0A
ARN MESSAGES
WARRANTY START DATE
06/08/2007 BUILD DATE
12/02/2005 SALE MILEAGE
00011
EXTENDED COVERAGES
0994 - USA 2007 NEW 60/60,000 P'TRAINCARE WRNTY W/ROADSIDE
STANDARD DEDUCTIBLE: 100 USD
OWNER NAME: FRANK RAFAELA
OPTIONS:
EXPIRATION DATE: 06/08/2012
DISTANCE: 60,000
RENTAL: 28 UP TO 10 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 40919
ESP CONTRACT START DATE: 06/08/2007
OWNER OF VEHICLE MUST MATCH OWNER NAME ON OASIS FOR COVERAGE TO APPLY
09/18/2008
DEALER: Novato Ford Lincoln Mercury
WARRANTY CLAIM NUMBER: 086078 ODOMETER: 022744M
LABOR OP
CONDITION CODE
CONDITION DESC
OSP 003 6007D D8 FAILED GASKET/SEAL
3C3Z 6020CA GASKET CYL TIMING GE 001 6007A
3C3Z 6E078BA GASKET SET LOWER 001 6007AZN
3C3Z 6D083AA GASKET-RR COVER 001 6007A38
5C3Z 6710AA GASKET SET-OIL PAN 001
3C3Z 9433AA GASKET SET-MANIFOLD 001
3C3Z 6619FA GASKET (OIL PUMP) 001
3C3Z 6701A CRANKSHAFT REAR SEAL 001
3C3Z 6731AA ELEMENT ASY OIL FILT 001
XO 15W405QSD 003
VC 7B 002
B7A 8287AA CLAMP ASY-RAD HOSE 008
3C3Z 9229B GASKET CARB FUEL INL 001
TA 29 MOTORCRAFT BATTERY 001
ZC 31A MOTORCRAFT BATTERY 001
382987S 012
3C3Z 9T514AD KIT-HDW TRBCH MTNG 001
OIL LEAK AT BEDPLATE. REMOVE ENGINE AND RESEAL BEDPLATE. RETEST OK
1FTWW31P65EB32325 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 10-NOV-2004 08-DEC-2004 158507 USA 26 * * * * * * * 7399
AWS Claim Key: 7001521 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 07955 - * Name: RON DUPRATT FORD Ph: 707-6785555 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:18-JAN-2007 Doc #:09469103
Cust Comments: PLEASE PERFORM FSA 59B01
Tech Comments: PERFORMED FSA 59B01
AWS Claim Key: 7001520 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 07955 - * Name: RON DUPRATT FORD Ph: 707-6785555 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:18-JAN-2007 Doc #:09469102
Cust Comments: PLEASE PERFORM FSA 05E15
Tech Comments: PERFORMED FSA 05E15
1FTWW31P65EB32325 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 10-NOV-2004 08-DEC-2004 158507 USA 26 2G05 031405 * RECAL * E29 07 7399
AWS Claim Key: 7001519 Trx Code: E84 Labor Hrs: 2.5
Dlr Cd-Sub Cd: 07955 - * Name: RON DUPRATT FORD Ph: 707-6785555 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:18-JAN-2007 Doc #:09469101
Cust Comments: PLEASE CHECK AND ADVISE VEHICLE HAD A CHECK
Tech Comments: UNABLE TO DUPLICATE CHECK ENGINE LIGHT ILLUMINATEDRAN KOEO AND RETRIEVED NO DTCS IN MEMORY PERFORMED WORKSHEET RAN KOEO AND KOER INJ SELF TEST REPROGRAMMED PCM TO LATEST CALIBRATION ROAD TEST VEHICLE AS IS OK AT THIS TIME
AWS Claim Key: 7001522 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 07955 - * Name: RON DUPRATT FORD Ph: 707-6785555 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:18-JAN-2007 Doc #:09469104
Cust Comments: PLEASE PERFORM FSA 05B32
Tech Comments: PERFORMED FSA 05B32
OASIS RESULT:
1FTSW21P66ED74218
12/29/2008
22:30:12
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
ARN MESSAGES
WARRANTY START DATE
06/15/2006 BUILD DATE
04/28/2006 SALE MILEAGE
00013
EXTENDED COVERAGES
cb44473 is offline
Oasis section back 4cstr Ford Oasis requests 5 01-08-2009 12:50 AM
Oasis Request. wastedwagesracing Ford Oasis requests 1 12-27-2008 04:02 PM
Fuel Mileage reports and questions BeauxPete 2008-2010 6.4L Power Stroke 3 12-25-2008 12:55 AM
FORD manuals Rcannon Ford - Modification instructions, Product installs and Tech Articles 0 12-23-2008 12:21 AM
