Newbie request for Oasis - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by ovruigo, this thread has received 1 replies and been viewed 554 times.
post #1 of 2 (permalink) Old 04-26-2006, 02:40 AM Thread Starter
TDG Mafia 23
ovruigo's Avatar
Images: 10
Vin # Iftsf31p44ea93733
Thanx
ovruigo is offline
post #2 of 2 (permalink) Old 04-28-2006, 12:55 PM
Squatch's Avatar
OASIS RESULT:
1FTSF31P44EA93733
04/28/2006
07:54:38
© Copyright 2002-2006 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-350 RC PICKUP 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
6 SPEED MANUAL AXLE CODE
D1 ENGINE CALIBRATION
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
04/30/2004 BUILD DATE
09/25/2003 SALE MILEAGE
ARN MESSAGES
BEFORE REPLACING MIRROR ASSEMBLY (-17682/17683-), SEE TSB 03-23-02
BEFORE ADDRESSING VEHICLE VIBRATION CONCERNS, SEE TSB 05-26-24
BEFORE REPLACING FS-10 A/C COMPRESSOR (19703), PLEASE SEE TSB 06-04-09
CUDL MESSAGES
THIS VEHICLE HAS A CLOSED CUDL CONTACT
WARNING MESSAGES
LESS THAN TWO DEALER APPROVED AWA REPAIR VISITS PAID TO DATE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
03/29/2006
DEALER: Bert Wolfe Ford, Inc.
WARRANTY CLAIM NUMBER: 275929 ODOMETER: 044269M
LABOR OP
CONDITION CODE
CONDITION DESC
YC3Z 2C026BB ROTOR-RR WHL DISC BK 002 34 DISTORTED/WRINKLED/WAVY
R&R BOTH REAR ROTORS
03/21/2006
WARRANTY CLAIM NUMBER: 275418 ODOMETER: 044249M
LABOR OP
CONDITION CODE
CONDITION DESC
000 06E17B
PERFORMED RECALL
03/21/2006
LABOR OP
CONDITION CODE
CONDITION DESC
000 59B01A
PERFORMED RECALL
03/21/2006
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9F452A TRANSDCR-EGR BACK PR 001 12650D 41 STICKS/BINDS/GRABS
PM 17A MOTORCRAFT BATTERY 001 12650DX1
000 12650D30
EEC TEST REPLACED EGR UPDATED SYSTEM
10/12/2005
WARRANTY CLAIM NUMBER: 266610 ODOMETER: 035240M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6K854DA PIPE (TURBO INLET LO 001 9438A 42 DOES NOT OPERATE PROPERLY
3C3Z 6N640AA GASKET TURBO TO MANI 001 9438A2
W300013 002
W300006 002
W300050 004
VERFIED CONCERN RPL TURBOCHARGER
10/12/2005
LABOR OP
CONDITION CODE
CONDITION DESC
2C3Z 3504AARM GEAR ASY-STEERING 001 3504A 41 STICKS/BINDS/GRABS
RPL STEERING BOX ASSEMBLY BINDING
10/12/2005
LABOR OP
CONDITION CODE
CONDITION DESC
1C3Z 11654AAB SWITCH ASY LT CNTRL 001 11654A 01 BROKEN/CRACKED
RPL KNOB BROKEN
10/12/2005
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6375BA FLYWHEEL ASY 001 7003A 34 DISTORTED/WRINKLED/WAVY
3C3Z 6379CA BOLT-FLYWHEEL TO CRA 010 7003A6
5C3Z 7563A PLATE & COVER-P 001
4C3Z 7550BARM DISC ASY-CLUTCH 001
VERFIED R AND I TRANS RPL CLUTCH AND FLYWHEEL
09/02/2005
WARRANTY CLAIM NUMBER: 264274 ODOMETER: 032291M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6616BA PLATE ASY OIL PUMP 001 6007A 12 IMPROPER ASSEMBLY
3C3Z 6619FA GASKET (OIL PUMP) 001 MTACCESS
3C3Z 6608BA ROTOR & SHAFT-OIL PU 001
3C3Z 6C751AA KIT-VLV OIL PRESS RE 001
3C3Z 6700BA OIL SEAL CYL FRT COV 001
VC 7A 003
REPLACED CVR SEAL AND FRT PUMP SEAL
08/18/2005
WARRANTY CLAIM NUMBER: 263337 ODOMETER: 031049M
LABOR OP
CONDITION CODE
CONDITION DESC
1102 HUB & ROTOR ASY FRON 000 2001BF 42 DOES NOT OPERATE PROPERLY
000 2001B2PT
ROAD TESTED CHECKED ROTORS REFACED FRT ROTORS
08/18/2005
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 3304BA ROD ASY-STR ARM TO I 001 3130AD 42 DOES NOT OPERATE PROPERLY
REPLACED TIE ROD
END OF OASIS REPORT FOR 1FTSF31P44EA93733
Standard Claims List For Model Year 2004
1FTSF31P44EA93733 T/F7 F T/BB T/CD T/E A1 T/VG T/YB 25-SEP-2003 30-APR-2004 147204 USA 0 2G05 031405 * RECAL * D50 79 10
AWS Claim Key: 190675 Trx Code: 1 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 06791 - * Name: AMHERST MOTORS INC Ph: 434-9467761 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:03-DEC-2003 Doc #:134726A
Cust Comments: RECALL 03T02
Tech Comments: 10 RECALL 03T02.
1FTSF31P44EA93733 T/F7 F T/BB T/CD T/E A1 T/VG T/YB 25-SEP-2003 30-APR-2004 147204 USA 11 1F05 030306 4C3Z 8A616 AA A85 33 16781
AWS Claim Key: 4291133 Trx Code: E84 Labor Hrs: 1.1
Dlr Cd-Sub Cd: 01928 - * Name: BERT WOLFE FORD, INC. Ph: 304-3441601 St:WV Ctry Cd: USA Reg Cd: NA Repr Date:09-MAR-2005 Doc #:253235A
Cust Comments: C S VEH HAS WIRES LOOSE DAMANGED AT THE FAN
Tech Comments: REPLACED WIRING FOR FAN
1FTSF31P44EA93733 T/F7 F T/BB T/CD T/E A1 T/VG T/YB 25-SEP-2003 30-APR-2004 147204 USA 11 1B01 03XXXX 3C3Z 6619 FA L65 12 16781
AWS Claim Key: 4291134 Trx Code: E84 Labor Hrs: 1
Dlr Cd-Sub Cd: 01928 - * Name: BERT WOLFE FORD, INC. Ph: 304-3441601 St:WV Ctry Cd: USA Reg Cd: NA Repr Date:09-MAR-2005 Doc #:253235B
Cust Comments: C S VEH HAS A OIL LEAK AT FRONT OF ENG BY OIL PRESSURE RELIEF VALVE
Tech Comments: REPLACED SEAL AT FRT OF ENGINE
1FTSF31P44EA93733 T/F7 F T/BB T/CD T/E A1 T/VG T/YB 25-SEP-2003 30-APR-2004 147204 USA 16 5V01 0603XX * 1102 * N27 42 31049
AWS Claim Key: 6518433 Trx Code: E84 Labor Hrs: 1.6
Dlr Cd-Sub Cd: 01928 - * Name: BERT WOLFE FORD, INC. Ph: 304-3441601 St:WV Ctry Cd: USA Reg Cd: NA Repr Date:18-AUG-2005 Doc #:263337A
Cust Comments: C S BRAKES HAS SHUDDER ON STOPS
Tech Comments: ROAD TESTED CHECKED ROTORS REFACED FRT ROTORS
1FTSF31P44EA93733 T/F7 F T/BB T/CD T/E A1 T/VG T/YB 25-SEP-2003 30-APR-2004 147204 USA 16 5N01 110301 4C3Z 3304 BA N27 42 31049
AWS Claim Key: 6518434 Trx Code: E84 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 01928 - * Name: BERT WOLFE FORD, INC. Ph: 304-3441601 St:WV Ctry Cd: USA Reg Cd: NA Repr Date:18-AUG-2005 Doc #:263337C
Cust Comments: C S TIE ROD HAS PLAY AT STEERING BOX
Tech Comments: REPLACED TIE ROD
1FTSF31P44EA93733 T/F7 F T/BB T/CD T/E A1 T/VG T/YB 25-SEP-2003 30-APR-2004 147204 USA 17 1D01 03XXXX 3C3Z 6700 BA L65 12 32291
AWS Claim Key: 6740850 Trx Code: E84 Labor Hrs: 15.8
Dlr Cd-Sub Cd: 01928 - * Name: BERT WOLFE FORD, INC. Ph: 304-3441601 St:WV Ctry Cd: USA Reg Cd: NA Repr Date:02-SEP-2005 Doc #:264274A
Cust Comments: C S VEH HAS A OIL LEAK IN THE FRONT
Tech Comments: REPLACED CVR SEAL AND FRT PUMP SEAL
1FTSF31P44EA93733 T/F7 F T/BB T/CD T/E A1 T/VG T/YB 25-SEP-2003 30-APR-2004 147204 USA 18 2H01 030008 3C3Z 6K854 DA E41 42 35240
AWS Claim Key: 7445432 Trx Code: E84 Labor Hrs: 3.1
Dlr Cd-Sub Cd: 01928 - * Name: BERT WOLFE FORD, INC. Ph: 304-3441601 St:WV Ctry Cd: USA Reg Cd: NA Repr Date:12-OCT-2005 Doc #:266610A
Cust Comments: C S VEH HAS EXHAUST ODOR IN CAB WHEN AC IS ON
Tech Comments: VERFIED CONCERN RPL TURBOCHARGER
1FTSF31P44EA93733 T/F7 F T/BB T/CD T/E A1 T/VG T/YB 25-SEP-2003 30-APR-2004 147204 USA 18 5O01 110201 2C3Z 3504 AARM C50 41 35240
AWS Claim Key: 7445433 Trx Code: E84 Labor Hrs: 1.4
Dlr Cd-Sub Cd: 01928 - * Name: BERT WOLFE FORD, INC. Ph: 304-3441601 St:WV Ctry Cd: USA Reg Cd: NA Repr Date:12-OCT-2005 Doc #:266610B
Cust Comments: C S VEH HARD TO STEER AT TIMES ALSO HAS PLAY IN STEERING AFTER STEERING HAS BEEN LOCKING UP
Tech Comments: RPL STEERING BOX ASSEMBLY BINDING
1FTSF31P44EA93733 T/F7 F T/BB T/CD T/E A1 T/VG T/YB 25-SEP-2003 30-APR-2004 147204 USA 18 7C01 170501 1C3Z 11654 AAB L29 01 35240
AWS Claim Key: 7445434 Trx Code: E83 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 01928 - * Name: BERT WOLFE FORD, INC. Ph: 304-3441601 St:WV Ctry Cd: USA Reg Cd: NA Repr Date:12-OCT-2005 Doc #:266610C
Cust Comments: C S HEAD LIGHT KNOB BROKEN
Tech Comments: RPL KNOB BROKEN
1FTSF31P44EA93733 T/F7 F T/BB T/CD T/E A1 T/VG T/YB 25-SEP-2003 30-APR-2004 147204 USA 18 4A02 030008 3C3Z 6375 BA P09 34 35240
AWS Claim Key: 7461812 Trx Code: E84 Labor Hrs: 3.9
Dlr Cd-Sub Cd: 01928 - * Name: BERT WOLFE FORD, INC. Ph: 304-3441601 St:WV Ctry Cd: USA Reg Cd: NA Repr Date:12-OCT-2005 Doc #:266610D
Cust Comments: C S TRANSMISSION HAS NOISE WHEN SHIFTING
Tech Comments: VERFIED R AND I TRANS RPL CLUTCH AND FLYWHEEL
1FTSF31P44EA93733 T/F7 F T/BB T/CD T/E A1 T/VG T/YB 25-SEP-2003 30-APR-2004 147204 USA 24 * * * * * * * 44249
AWS Claim Key: 8876829 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 01928 - * Name: BERT WOLFE FORD, INC. Ph: 304-3441601 St:WV Ctry Cd: USA Reg Cd: NA Repr Date:21-MAR-2006 Doc #:275418A
Cust Comments: 06E17 RECALIBRATION RECALL
Tech Comments: PERFORMED RECALL
AWS Claim Key: 8876830 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 01928 - * Name: BERT WOLFE FORD, INC. Ph: 304-3441601 St:WV Ctry Cd: USA Reg Cd: NA Repr Date:21-MAR-2006 Doc #:275418B
Cust Comments: 59B01 TEST DRIVE RECALL
1FTSF31P44EA93733 T/F7 F T/BB T/CD T/E A1 T/VG T/YB 25-SEP-2003 30-APR-2004 147204 USA 24 1H03 030008 4C3Z 9F452 A D50 41 44249
AWS Claim Key: 8876831 Trx Code: S07 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 01928 - * Name: BERT WOLFE FORD, INC. Ph: 304-3441601 St:WV Ctry Cd: USA Reg Cd: NA Repr Date:21-MAR-2006 Doc #:275418C
Cust Comments: C S VEH HAS ENGINE MISS
Tech Comments: EEC TEST REPLACED EGR UPDATED SYSTEM
1FTSF31P44EA93733 T/F7 F T/BB T/CD T/E A1 T/VG T/YB 25-SEP-2003 30-APR-2004 147204 USA 24 5Y01 060401 YC3Z 2C026 BB N27 34 44269
AWS Claim Key: 8961891 Trx Code: P05 Labor Hrs: 0
Dlr Cd-Sub Cd: 01928 - * Name: BERT WOLFE FORD, INC. Ph: 304-3441601 St:WV Ctry Cd: USA Reg Cd: NA Repr Date:29-MAR-2006 Doc #:275929A
Cust Comments: C S VEH HAS BRAKE SHUDDER IN REAR WHEN BRAKING
Tech Comments: R&R BOTH REAR ROTORS
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
