Oasis report please. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by sidssm, this thread has received 2 replies and been viewed 2016 times.
post #1 of 3 (permalink) Old 01-04-2009, 02:07 AM Thread Starter
sidssm's Avatar
1ftww33f2xeb06621
sidssm is offline
post #2 of 3 (permalink) Old 01-04-2009, 02:11 AM Thread Starter
sidssm's Avatar
Also to who ever can do the oasis, I am not in a hurry I just have some shifting issues and would like to see if there has ever been any before. Thanks Seth
sidssm is offline
post #3 of 3 (permalink) Old 01-04-2009, 04:44 PM
OASIS RESULT:
1FTWW33F2XEB06621
01/04/2009
12:43:07
FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION
1999 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
7.3L TURBO - DI
TRANSMISSION
4R100 (E4OD) 4SP O/D AXLE CODE
F2 ENGINE CALIBRATION
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
09/19/1998 BUILD DATE
05/31/1998 SALE MILEAGE
07S57
CAMSHAFT POSITION (CMP) SENSOR INSPECTION / REPLACEMENT
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
1FTWW33F2XEB06621 T/F7 F T/BC T/CD T/E A1 T/DE T/DS 31-MAY-1998 19-SEP-1998 156444 USA 0 * NANANA 90 34 F81Z PA E65 38 8
AWS Claim Key: 139875 Trx Code: MVC Labor Hrs: 0.4
Dlr Cd-Sub Cd: 01108 - * Name: GO FORD WEST Ph: 303-4215350 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:25-JUN-1998 Doc #:124467A
Tech Comments: REMOVE AND REPLACE FUEL FILLER NECK. MOBILE SERVICE TECH. TRUCK IS A DIESEL AND HS UNLEADED GAS FILLER NECK
1FTWW33F2XEB06621 T/F7 F T/BC T/CD T/E A1 T/DE T/DS 31-MAY-1998 19-SEP-1998 156444 USA 0 5Q02 110203 F81Z 3A714 AA L68 D1 145
AWS Claim Key: 214018 Trx Code: 2 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 03151 - * Name: FORMBY INTERSTATE FORD, INC. Ph: 303-8336700 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:20-JUL-1998 Doc #:3569001
1FTWW33F2XEB06621 T/F7 F T/BC T/CD T/E A1 T/DE T/DS 31-MAY-1998 19-SEP-1998 156444 USA 2 5C02 050100 * 4602 * N51 82 1627
AWS Claim Key: 409532 Trx Code: 2 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 03130 - * Name: PHIL LONG FORD OF DENVER, LLC Ph: 303-9323673 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:21-OCT-1998 Doc #:32543903
Cust Comments: CHATTER CLNKING FROM REAR END ON SHARP TURNS
Tech Comments: ADD FRICTION MODIFIER TO REAR DIFF
1FTWW33F2XEB06621 T/F7 F T/BC T/CD T/E A1 T/DE T/DS 31-MAY-1998 19-SEP-1998 156444 USA 2 7C05 1801XX FOAZ 14N089 A D50 33 1627
AWS Claim Key: 409533 Trx Code: 2 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 03130 - * Name: PHIL LONG FORD OF DENVER, LLC Ph: 303-9323673 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:21-OCT-1998 Doc #:32543902
Cust Comments: RELAY BY POWER DIST BOX WAS HANGING DOWN UNDER FRONT END
Tech Comments: INSTALLED NEW 4X4 RELAY, CARRIER FELL OUT ONTO GROUND
1FTWW33F2XEB06621 T/F7 F T/BC T/CD T/E A1 T/DE T/DS 31-MAY-1998 19-SEP-1998 156444 USA 2 7T09 180501 * 14B205 * D03 82 1627
AWS Claim Key: 409534 Trx Code: 2 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 03130 - * Name: PHIL LONG FORD OF DENVER, LLC Ph: 303-9323673 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:21-OCT-1998 Doc #:32543901
Cust Comments: HARD TO START WHEN COLD CRANKS TOO LONG
Tech Comments: 1 DIAGNOSE HARD START NO CODES, NO PROBLEMS FOUND AT THIS TIME
1FTWW33F2XEB06621 T/F7 F T/BC T/CD T/E A1 T/DE T/DS 31-MAY-1998 19-SEP-1998 156444 USA 3 2B03 030703 * 12A342 * D03 12 4747
AWS Claim Key: 538144 Trx Code: 2 Labor Hrs: 2
Dlr Cd-Sub Cd: 03151 - * Name: FORMBY INTERSTATE FORD, INC. Ph: 303-8336700 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:02-DEC-1998 Doc #:3574321
Tech Comments: HARD START COLD CK GLOW PLUGS NO GLOW PLUGS RIGHT BANK CONNECTOR FROM GLOW POOER MILEAGE PLUGS TO INNER VALVE COVER GASKET WASNTE SEATED PAROPERLY
1FTWW33F2XEB06621 T/F7 F T/BC T/CD T/E A1 T/DE T/DS 31-MAY-1998 19-SEP-1998 156444 USA 8 2A01 031201 F81Z 9600 BA D50 42 11568
AWS Claim Key: 2042264 Trx Code: S07 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 03130 - * Name: PHIL LONG FORD OF DENVER, LLC Ph: 303-9323673 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:12-MAY-1999 Doc #:35847303
Cust Comments: AIR CLEANER FILLED UP WITH WATER DURING HEAVY SNOW RAIN
Tech Comments: REPLACED AIR CLEANER ASSY
1FTWW33F2XEB06621 T/F7 F T/BC T/CD T/E A1 T/DE T/DS 31-MAY-1998 19-SEP-1998 156444 USA 8 5A06 050201 F81Z 4026 AA N51 42 11568
AWS Claim Key: 2042266 Trx Code: 2 Labor Hrs: 4.4
Dlr Cd-Sub Cd: 03130 - * Name: PHIL LONG FORD OF DENVER, LLC Ph: 303-9323673 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:12-MAY-1999 Doc #:35847301
Cust Comments: CHATTER GRABBING FROM REAR WHEELS ON ACCEL AND TURNING HAD FRICTION MODIFIER ADDED AT 1627 MILES
Tech Comments: R&I DIFF COVER TO INSPECT, REMOVED DIFF ASSY, DISASSEMBLED LOCKER & CHECKED OUT, REPLACED ASSY, REPLACED CARRIER
1FTWW33F2XEB06621 T/F7 F T/BC T/CD T/E A1 T/DE T/DS 31-MAY-1998 19-SEP-1998 156444 USA 8 * * * * * * * 11568
AWS Claim Key: 2042265 Trx Code: 98B29 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 03130 - * Name: PHIL LONG FORD OF DENVER, LLC Ph: 303-9323673 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:12-MAY-1999 Doc #:35847302
Cust Comments: RECALL 98B29
Tech Comments: WE PERFORMED RECALL REPLACED GEM MODULE
1FTWW33F2XEB06621 T/F7 F T/BC T/CD T/E A1 T/DE T/DS 31-MAY-1998 19-SEP-1998 156444 USA 9 5K02 040403 F81Z 1130 JC B65 33 12238
AWS Claim Key: 2280159 Trx Code: E84 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 03130 - * Name: PHIL LONG FORD OF DENVER, LLC Ph: 303-9323673 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:03-JUN-1999 Doc #:36220902
Cust Comments: L REAR HUB CAP FELL OFF
Tech Comments: INSTALLED BOTH MISSING HUBCAPS
1FTWW33F2XEB06621 T/F7 F T/BC T/CD T/E A1 T/DE T/DS 31-MAY-1998 19-SEP-1998 156444 USA 9 3A11 070100 * 7000 * P59 82 12238
AWS Claim Key: 2280160 Trx Code: E84 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 03130 - * Name: PHIL LONG FORD OF DENVER, LLC Ph: 303-9323673 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:03-JUN-1999 Doc #:36220901
Cust Comments: SHUDDER IN TRANS SHIFTING FROM 2ND TO 3RD ON LIGHTER ACCEL UP HILLS WORSE IN OVERDRIVE BUT ALSO OUT OF O D HAPPENS
Tech Comments: PERFORMED ELEC TRANS DIAG, MONITOR PID, RECORD DRIVE CYCLE TEST NORMAL OPERATION & SHIFT FEEL
1FTWW33F2XEB06621 T/F7 F T/BC T/CD T/E A1 T/DE T/DS 31-MAY-1998 19-SEP-1998 156444 USA 15 6J14 011407 * 38218A42 * N40 33 21812
AWS Claim Key: 6868326 Trx Code: E84 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 03130 - * Name: PHIL LONG FORD OF DENVER, LLC Ph: 303-9323673 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:01-DEC-1999 Doc #:39449207
Cust Comments: RATTLE FROM DRIVER DOOR LOCK AREA ON BUMPS
Tech Comments: R&R DOOR PANEL TIGHTEN LINKAGE, INSULATE ACTUATOR ARMS.
1FTWW33F2XEB06621 T/F7 F T/BC T/CD T/E A1 T/DE T/DS 31-MAY-1998 19-SEP-1998 156444 USA 15 2D01 160201 F81Z 9H465 BA P31 42 21812
AWS Claim Key: 6868325 Trx Code: S07 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 03130 - * Name: PHIL LONG FORD OF DENVER, LLC Ph: 303-9323673 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:01-DEC-1999 Doc #:39449209
Cust Comments: FRONT HUBS WONT ALWAYS ENGAGE ON AUTO MODE
Tech Comments: STICKS AT TIMES. TEST SYSTEM REPLACE 4X4 SHIFT VALVE
1FTWW33F2XEB06621 T/F7 F T/BC T/CD T/E A1 T/DE T/DS 31-MAY-1998 19-SEP-1998 156444 USA 15 2A01 031201 XC3Z 9K635 AA D35 42 21812
AWS Claim Key: 6868328 Trx Code: E84 Labor Hrs: 2.5
Dlr Cd-Sub Cd: 03130 - * Name: PHIL LONG FORD OF DENVER, LLC Ph: 303-9323673 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:01-DEC-1999 Doc #:39449205
Cust Comments: OWNER FEELS FUEL MILEAGE IS LOW 9 MPG ON HIGHWAY
Tech Comments: 1 PERFORMED ALL DIESEL PERFORMANCE TESTS LOW BOOST PRESS DUE TO INTAKE RESTRICTION. PERFORMED 99 06 04 A, REPLACED AIR
1FTWW33F2XEB06621 T/F7 F T/BC T/CD T/E A1 T/DE T/DS 31-MAY-1998 19-SEP-1998 156444 USA 15 5A12 050206 F81A 4001 AUH N58 42 21812
AWS Claim Key: 6923117 Trx Code: E84 Labor Hrs: 8.8
Dlr Cd-Sub Cd: 03130 - * Name: PHIL LONG FORD OF DENVER, LLC Ph: 303-9323673 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:01-DEC-1999 Doc #:39449201
Cust Comments: REAR END GRABS POPS WHEN TURNING CORNERS
Tech Comments: DISASSEMBLE, DIAGNOSE REAR END CALL FORD. REPLACED REAR DIFF ASSY. (4640)
1FTWW33F2XEB06621 T/F7 F T/BC T/CD T/E A1 T/DE T/DS 31-MAY-1998 19-SEP-1998 156444 USA 15 * * * * * * * 21812
AWS Claim Key: 6868327 Trx Code: 99S32 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 03130 - * Name: PHIL LONG FORD OF DENVER, LLC Ph: 303-9323673 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:01-DEC-1999 Doc #:39449206
Cust Comments: RECALL 99S32
Tech Comments: WE PERFORMED RECALL 99S32
1FTWW33F2XEB06621 T/F7 F T/BC T/CD T/E A1 T/DE T/DS 31-MAY-1998 19-SEP-1998 156444 USA 17 3A11 070100 F81Z 7000 LBRM N18 42 25775
AWS Claim Key: 7181281 Trx Code: E84 Labor Hrs: 4.7
Dlr Cd-Sub Cd: 03130 - * Name: PHIL LONG FORD OF DENVER, LLC Ph: 303-9323673 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:02-FEB-2000 Doc #:40479501
Cust Comments: SHUDDER FROM TRANS UNDER LOAD IN HILLS
Tech Comments: ELEC TRANS DIAG, R&R TRANS INSTALL REMAN TRANS ASSY, CHECK COOLER FLOW. ROAD TEST.
1FTWW33F2XEB06621 T/F7 F T/BC T/CD T/E A1 T/DE T/DS 31-MAY-1998 19-SEP-1998 156444 USA 17 6C04 010505 * 3823942 * N50 33 25775
AWS Claim Key: 7181280 Trx Code: E84 Labor Hrs: 1.8
Dlr Cd-Sub Cd: 03130 - * Name: PHIL LONG FORD OF DENVER, LLC Ph: 303-9323673 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:02-FEB-2000 Doc #:40479502
Cust Comments: CLUNK IN L FRONT AT TIMES WHEN GOING FORWARD OR BACKWARD
Tech Comments: USED FELT TAP AND INSULATED BETWEEN DOOR PANEL AND DOOR. PAINT ON DOOR SHOWED SIGNS OF WEAR AND CREAKED WHEN PRESSED
1FTWW33F2XEB06621 T/F7 F T/BC T/CD T/E A1 T/DE T/DS 31-MAY-1998 19-SEP-1998 156444 USA 19 1D02 03XXXX F4TZ 9E436 A L65 D8 28287
AWS Claim Key: 8225816 Trx Code: E84 Labor Hrs: 2.2
Dlr Cd-Sub Cd: 03130 - * Name: PHIL LONG FORD OF DENVER, LLC Ph: 303-9323673 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:03-APR-2000 Doc #:41486501
Cust Comments: OIL DRIPPING OFF BOTTOM REAR OF ENGINE
Tech Comments: OIL LEAK DIAGNOSIS R&R INTERCOOLER PIPES, R&R INTAKE Y AND ALL HOSE COUPLERS, R&R PRESSURE SEAL AT TURBO. DEGREASE AND STEAM CLEAN
1FTWW33F2XEB06621 T/F7 F T/BC T/CD T/E A1 T/DE T/DS 31-MAY-1998 19-SEP-1998 156444 USA 22 2E01 030008 F81Z 9E527 BRM D36 28 29456
AWS Claim Key: 9709583 Trx Code: S07 Labor Hrs: 2.3
Dlr Cd-Sub Cd: 03130 - * Name: PHIL LONG FORD OF DENVER, LLC Ph: 303-9323673 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:15-JUN-2000 Doc #:42796801
Cust Comments: ENGINE STARTS MISSING BAD CK ENGINE LIGHT COMES ON WHEN ACCEL AND GOES OFF ON DECEL
Tech Comments: 1 RAN ALL DIESEL PERFORMANCE DIAGNOSTICS, FOUND DTC P0273 P01275. R AND R 5 FUEL FINJECTOR
1FTWW33F2XEB06621 T/F7 F T/BC T/CD T/E A1 T/DE T/DS 31-MAY-1998 19-SEP-1998 156444 USA 25 2A01 031202 YC3Z 6C646 AA D50 33 32894
AWS Claim Key: 12083957 Trx Code: E84 Labor Hrs: 0
Dlr Cd-Sub Cd: 03130 - * Name: PHIL LONG FORD OF DENVER, LLC Ph: 303-9323673 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:06-OCT-2000 Doc #:44827001
Cust Comments: TURBO PIPE BLEW OFF
Tech Comments: 1 PERFORMED DIESEL PERFORMANCE TESTS, REPLACED LEFT INTERCOOLER PIPE W UPDATED PART....464C
1FTWW33F2XEB06621 T/F7 F T/BC T/CD T/E A1 T/DE T/DS 31-MAY-1998 19-SEP-1998 156444 USA 29 6M02 010507 * 2624357 * N59 33 35442
AWS Claim Key: 13802846 Trx Code: E84 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 03130 - * Name: PHIL LONG FORD OF DENVER, LLC Ph: 303-9323673 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:09-JAN-2001 Doc #:46413501
Cust Comments: INTERMITTENT RATTLE FROM TOP REAR OF DRIVERS DOOR PANEL OR AT B PILLAR SOUNDS LIKE SOMETHING KNOCKING
Tech Comments: R&I DOOR PANEL AND INSULATED B PILLAR MOULDING 4237
1FTWW33F2XEB06621 T/F7 F T/BC T/CD T/E A1 T/DE T/DS 31-MAY-1998 19-SEP-1998 156444 USA 33 5B03 070100 * 4205 * N51 42 38116
AWS Claim Key: 16560377 Trx Code: P05 Labor Hrs: 2.6
Dlr Cd-Sub Cd: 03130 - * Name: PHIL LONG FORD OF DENVER, LLC Ph: 303-9323673 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:04-JUN-2001 Doc #:48726101
Cust Comments: CLUNKSHUDDER IN REAR END WHEN TURNING OR ACCEL AFTER WARMED UP NOTICE MOST WHEN BACKING UP
Tech Comments: ROAD TESTED, R&I REAR DIFF COVER TO INSPECT, PERFORMED REAR DIFF DIAGNOSIS, INSPECT CLUTCH OK, CLEANED & REASSEMBL DIFF, ADDED CLEAN LUBE & FRICTION MODIFIER, ROAD TESTED
1FTWW33F2XEB06621 T/F7 F T/BC T/CD T/E A1 T/DE T/DS 31-MAY-1998 19-SEP-1998 156444 USA 46 5G02 050301 2C3Z 3050 AA H22 42 43648
AWS Claim Key: 21062778 Trx Code: P05 Labor Hrs: 5.3
Dlr Cd-Sub Cd: 03130 - * Name: PHIL LONG FORD OF DENVER, LLC Ph: 303-9323673 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:11-JUN-2002 Doc #:54820301
Cust Comments: FRONT END SEEMS TIGHT WANTS TO GO EITHER LEFT OR RIGHT AND NOT TRACK STRAIGHT
Tech Comments: STEERING TORQUETES, REPLACED UPPER AND LOWER BALL JOINTS, MEASURE AND ADJUST PRELOAD, VERIFIED STIFF STEERING AND
1FTWW33F2XEB06621 T/F7 F T/BC T/CD T/E A1 T/DE T/DS 31-MAY-1998 19-SEP-1998 156444 USA 46 2E01 030008 F81Z 9E527 BRM D13 42 44765
AWS Claim Key: 21163121 Trx Code: S07 Labor Hrs: 2.8
Dlr Cd-Sub Cd: 03406 - * Name: STONE'S FORD-MERCURY Ph: 641-3944105 St:IA Ctry Cd: USA Reg Cd: NA Repr Date:17-JUN-2002 Doc #:01662501
Tech Comments: DIESEL DIAG PERF DIAG SHEET NGS TEST REPL INJECTOR 6 REPL OIL AND FILTER WPI
1FTWW33F2XEB06621 T/F7 F T/BC T/CD T/E A1 T/DE T/DS 31-MAY-1998 19-SEP-1998 156444 USA 50 1G02 030008 F81Z 8501 ARM L87 D8 49764
AWS Claim Key: 21738417 Trx Code: E72 Labor Hrs: 2.7
Dlr Cd-Sub Cd: 03130 - * Name: PHIL LONG FORD OF DENVER, LLC Ph: 303-9323673 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:17-OCT-2002 Doc #:56826601
Cust Comments: WATER PUMP LEAKING
Tech Comments: PRESSURE TESTED COOLING SYSTEM, REPLACED WATER PUMP, THERMOSTAT AND HOUSING
1FTWW33F2XEB06621 T/F7 F T/BC T/CD T/E A1 T/DE T/DS 31-MAY-1998 19-SEP-1998 156444 USA 69 2G01 031401 F7TZ 12B599 AC D02 42 67935
AWS Claim Key: 23254827 Trx Code: P01 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 03142 - * Name: LAKEWOOD FORDLAND, INC. Ph: 303-2322200 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:17-MAY-2004 Doc #:02704451
Cust Comments: WILL NOT START TURBO DIESEL
Tech Comments: HARD START NO START DIAGNOSTICS DIESEL ENGINE DIAGNOSI
cb44473 is offline
Oasis section back 4cstr Ford Oasis requests 5 01-08-2009 12:50 AM
Ford oasis report please "THE DEMIZE" Ford Oasis requests 2 01-03-2009 06:46 PM
Oasis Please toshmago Ford Oasis requests 1 01-03-2009 02:50 AM
Ford Oasis Reports Please stangclassic66 Ford Oasis requests 1 12-30-2008 02:30 AM
Oasis Request. wastedwagesracing Ford Oasis requests 1 12-27-2008 04:02 PM
