Oasis Report Please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 06harley250, this thread has received 3 replies and been viewed 495 times.
post #1 of 4 (permalink) Old 07-17-2006, 02:05 AM Thread Starter
Oasis Report Please
1FTSW21P46EC47497 and 1FMSU43P44EC36443 First one '06 and second one is '04
Thanks,
Steve
06harley250 is offline
post #2 of 4 (permalink) Old 07-18-2006, 03:19 AM
Squatch's Avatar
OASIS RESULT:
1FTSW21P46EC47497
07/17/2006
22:18:36
© Copyright 2002-2006 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2006 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
37 ENGINE CALIBRATION
6F710C0A
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
03/10/2006 BUILD DATE
01/11/2006 SALE MILEAGE
ARN MESSAGES
BEFORE ADDRESSING VEHICLE VIBRATION CONCERNS, SEE TSB 05-26-24
BEFORE REPLACING FS-10 A/C COMPRESSOR (19703), PLEASE SEE TSB 06-04-09
BEFORE REPLACING HIGH PRESS. PUMP FOR HARD START OR OIL LEAK, SEE TSB 06-14-06
WARNING MESSAGES
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
NO REPAIR HISTORY ON VEHICLE
END OF OASIS REPORT FOR 1FTSW21P46EC47497
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
post #3 of 4 (permalink) Old 07-18-2006, 03:20 AM
Squatch's Avatar
OASIS RESULT:
1FMSU43P44EC36443
07/17/2006
22:19:42
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 EXCURSION BODY STYLE
LIMITED 4 DR 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
WARRANTY START DATE
06/21/2004 BUILD DATE
02/13/2004 SALE MILEAGE
ARN MESSAGES
WARNING MESSAGES
EXTENDED COVERAGES
0862 - EXPIRED
STANDARD DEDUCTIBLE: 0 USD
OWNER NAME: STEVEN WEAVER
OPTIONS:
EXPIRATION DATE: 06/21/2005
DISTANCE: 16,098
RENTAL: 0 UP TO 0 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 04633
ESP CONTRACT START DATE: 06/21/2004
REPAIR HISTORY
05/02/2006
DEALER: Gurley-Leep Ford Lincoln Mercu
WARRANTY CLAIM NUMBER: 786125 ODOMETER: 032871M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6A831AA GSKT-OIL FLTR ELEM S 001 6007D D8 FAILED GASKET/SEAL
3C3Z 6A642AA COOLER CRANKCASE OI 001 6642A
3C3Z 9433AA GASKET SET-MANIFOLD 001
OSP 001
TEST FOR LEAKS-HAS ENGINE OIL LEAK FROM OIL COOLER REPLACE OIL COOLER ASSY
04/19/2006
WARRANTY CLAIM NUMBER: 783176 ODOMETER: 032503M
LABOR OP
CONDITION CODE
CONDITION DESC
1102 HUB & ROTOR ASY FRON 000 2001BT 42 DOES NOT OPERATE PROPERLY
000 2001B2PT
ROAD TEST, PULLED ALL WHEELS TO INSPECT, RESURFACED FRT ROTORS, RETEST OK
03/22/2006
WARRANTY CLAIM NUMBER: 776744 ODOMETER: 028909M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6619EA GASKET (OIL PUMP) 001 9456A D8 FAILED GASKET/SEAL
3C3Z 9E933BA GSKT-EGR TO-TH-BDY 001 6007D
3C3Z 9E933AA GSKT-EGR TO-TH-BDY 001 8005D
4C3Z 9P456AC COOLER - EGR 001
VC 7B 001
XO 15W40QSD 002
DYE TEST AND COOLANT PRESSUR TEST EGR COOLER GASKET LEAKING-EGR TUBE INSTA LL NEW EGR COOLER KIT TOPPED OFF FLUIDS AND CHECK COOLANT LEVE ROAD TESTED O .K
03/08/2006
WARRANTY CLAIM NUMBER: 773418 ODOMETER: 028451M
LABOR OP
CONDITION CODE
CONDITION DESC
6781 GASKET SET-OIL PAN 000 6007D 33 LOOSE PART
OSP 002
PERF OIL DYE TEST-ADDED DYE, TIGHTEND OIL PAN BOLTS TO SPECS-10 LBS, RETST O K
02/16/2006
WARRANTY CLAIM NUMBER: 768994 ODOMETER: 028310M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 3049DA JOINT ASY-FRT SUSP L 002 3049AT 33 LOOSE PART
5C3Z 3050A KIT-FRT SUSP LWR SPD 002
N642570S425 007
BALL JOINT LOOSE REPLACE ALL BALL JOINTS
11/21/2005
WARRANTY CLAIM NUMBER: 748751 ODOMETER: 025264M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9J460A SENSOR ASY EGR PR VL 001 05E15G
5C3Z 12224A 3 WAY VACUUM CONNECT 001
1 REPLACE EXHAUST BACK PRESS WIRE AND REPROGRAM PCM
11/21/2005
LABOR OP
CONDITION CODE
CONDITION DESC
000 59B01A
RD TEST PROGRAM
11/21/2005
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9F452A TRANSDCR-EGR BACK PR 001 6005F 42 DOES NOT OPERATE PROPERLY
000 6005F1
000 6005F1X1
000 6005F2
000 6005F6
000 6005F8
000 6005F9
000 6005F11
000 6005F12
000 6005F13
000 6005F14
000 6005F18
000 6005F19
000 6005F20
000 6005F21
000 6005F22
000 6005F23
000 6005F33
000 6005F25
000 VERIFY60
000 12650D30
COMPLETE ENGINE DIG PER FORD--REPLACE EGR VALVE
08/04/2005
WARRANTY CLAIM NUMBER: 722366 ODOMETER: 019994M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 5335AA BRKT FRT SPG SHKL 001 MT5335 42 DOES NOT OPERATE PROPERLY
REMOVED AND INSTALLED NEW ONE: ROAD TESTED NOISE GONE
08/04/2005
LABOR OP
CONDITION CODE
CONDITION DESC
4C7Z78644A18BAA CVR FRT ST CTR A/R 001 64422A 33 LOOSE PART
REPL COVER, LOOSE
END OF OASIS REPORT FOR 1FMSU43P44EC36443
Standard Claims List For Model Year 2004
1FMSU43P44EC36443 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 13-FEB-2004 21-JUN-2004 148067 USA 13 * * * * * * * 17581
AWS Claim Key: 5735035 Trx Code: 05S34 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 04633 - * Name: GURLEY-LEEP FORD LINCOLN MERCURY Ph: 574-2916910 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:20-JUN-2005 Doc #:70999501
Cust Comments: PERFORM OPEN RECALL 05S24 FICM
Tech Comments: 1 COMPLETED HAS KN FILTER AND AFTERMARKET EXHAUST
1FMSU43P44EC36443 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 13-FEB-2004 21-JUN-2004 148067 USA 13 2H01 * * * * * * 17581
AWS Claim Key: 5735034 Trx Code: 05B29 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 04633 - * Name: GURLEY-LEEP FORD LINCOLN MERCURY Ph: 574-2916910 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:20-JUN-2005 Doc #:70999505
Cust Comments: PERFORM OPEN RECALL 05B29 AIR COOLER
Tech Comments: COMPLETED: KN FILTER ADD ON
1FMSU43P44EC36443 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 13-FEB-2004 21-JUN-2004 148067 USA 13 2G05 031405 * RECAL * D50 42 17581
AWS Claim Key: 5697424 Trx Code: E84 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 04633 - * Name: GURLEY-LEEP FORD LINCOLN MERCURY Ph: 574-2916910 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:20-JUN-2005 Doc #:70999506
Cust Comments: CHECK PCM FOR LATEST CALIBRATION
Tech Comments: TSB 4 13 8 REPROGRAM PCM TCM AND FICUM
1FMSU43P44EC36443 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 13-FEB-2004 21-JUN-2004 148067 USA 14 5G01 040101 3C3Z 5335 AA N59 42 19994
AWS Claim Key: 6568175 Trx Code: E84 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 04633 - * Name: GURLEY-LEEP FORD LINCOLN MERCURY Ph: 574-2916910 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:04-AUG-2005 Doc #:72236601
Cust Comments: CLUNKING FRONT END....SOP ROAD TESTED NOISE: FOUND BRAKET LOOSE RT. FRONT SHAKLE
Tech Comments: REMOVED AND INSTALLED NEW ONE: ROAD TESTED NOISE GONE
1FMSU43P44EC36443 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 13-FEB-2004 21-JUN-2004 148067 USA 14 6D05 011001 4C7Z 78644A18 BAA B95 33 19994
AWS Claim Key: 6568174 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 04633 - * Name: GURLEY-LEEP FORD LINCOLN MERCURY Ph: 574-2916910 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:04-AUG-2005 Doc #:72236603
Cust Comments: MIDDLE ROW, LFT SEAT BY DOOR, ARM REST COVER LOOSE
Tech Comments: REPL COVER, LOOSE
1FMSU43P44EC36443 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 13-FEB-2004 21-JUN-2004 148067 USA 18 * * * * * * * 25264
AWS Claim Key: 7725360 Trx Code: 05E15 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 04633 - * Name: GURLEY-LEEP FORD LINCOLN MERCURY Ph: 574-2916910 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:21-NOV-2005 Doc #:74875101
Cust Comments: RECALL 05E15 PCM RECAL
Tech Comments: 1 REPLACE EXHAUST BACK PRESS WIRE AND REPROGRAM PCM
AWS Claim Key: 7725359 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 04633 - * Name: GURLEY-LEEP FORD LINCOLN MERCURY Ph: 574-2916910 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:21-NOV-2005 Doc #:74875102
Cust Comments: 59B01 RD TEST
Tech Comments: RD TEST PROGRAM
1FMSU43P44EC36443 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 13-FEB-2004 21-JUN-2004 148067 USA 18 1H03 030008 4C3Z 9F452 A D50 42 25264
AWS Claim Key: 7740809 Trx Code: S07 Labor Hrs: 6.8
Dlr Cd-Sub Cd: 04633 - * Name: GURLEY-LEEP FORD LINCOLN MERCURY Ph: 574-2916910 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:21-NOV-2005 Doc #:74875103
Cust Comments: CHK FOR NO POWER ON ACCEL FROM STOPS EXCESSIVE SMOKE FROM EXHAUST AND EXHAUST HAD ODOR TURBO HAD NO BOOST
Tech Comments: COMPLETE ENGINE DIG PER FORD REPLACE EGR VALVE
1FMSU43P44EC36443 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 13-FEB-2004 21-JUN-2004 148067 USA 21 5G02 040103 4C3Z 3049 DA N59 33 28310
AWS Claim Key: 8589531 Trx Code: E84 Labor Hrs: 2.6
Dlr Cd-Sub Cd: 04633 - * Name: GURLEY-LEEP FORD LINCOLN MERCURY Ph: 574-2916910 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:16-FEB-2006 Doc #:76899401
Tech Comments: BALL JOINT LOOSE REPLACE ALL BALL JOINTS
1FMSU43P44EC36443 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 13-FEB-2004 21-JUN-2004 148067 USA 21 1D01 031001 * 6781 * L65 33 28451
AWS Claim Key: 8772825 Trx Code: E84 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 04633 - * Name: GURLEY-LEEP FORD LINCOLN MERCURY Ph: 574-2916910 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:08-MAR-2006 Doc #:77341802
Cust Comments: CHECK ON ENGINE OIL LEAKING. ADVISE
Tech Comments: PERF OIL DYE TEST ADDED DYE, TIGHTEND OIL PAN BOLTS TO SPECS 10 LBS, RETST OK
1FMSU43P44EC36443 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 13-FEB-2004 21-JUN-2004 148067 USA 22 1A06 0301XX 3C3Z 9E933 AA L65 D8 28909
AWS Claim Key: 8906339 Trx Code: S07 Labor Hrs: 5.7
Dlr Cd-Sub Cd: 04633 - * Name: GURLEY-LEEP FORD LINCOLN MERCURY Ph: 574-2916910 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:22-MAR-2006 Doc #:77674401
Cust Comments: CHK FOR ENGINE OIL LEAK SEE HISTORY
Tech Comments: DYE TEST AND COOLANT PRESSUR TEST EGR COOLER GASKET LEAKING EGR TUBE INSTALL NEW EGR COOLER KIT TOPPED OFF FLUIDS AND CHECK COOLANT LEVE ROAD TESTED O.K
1FMSU43P44EC36443 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 13-FEB-2004 21-JUN-2004 148067 USA 23 5V01 060301 * 1102 * N27 42 32503
AWS Claim Key: 9160596 Trx Code: E84 Labor Hrs: 2.1
Dlr Cd-Sub Cd: 04633 - * Name: GURLEY-LEEP FORD LINCOLN MERCURY Ph: 574-2916910 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:19-APR-2006 Doc #:78317602
Cust Comments: OWNER STATES BRAKES PULSATE AT HIGHWAY SPEEDS CAN FEEL ON BRAKE APPLICATION COMING OFF HIGHWAY RAMP
Tech Comments: ROAD TEST, PULLED ALL WHEELS TO INSPECT, RESURFACED FRT ROTORS, RETEST OK
1FMSU43P44EC36443 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 13-FEB-2004 21-JUN-2004 148067 USA 23 1B03 030204 3C3Z 6A642 AA L65 D8 32871
AWS Claim Key: 9273589 Trx Code: E84 Labor Hrs: 5.8
Dlr Cd-Sub Cd: 04633 - * Name: GURLEY-LEEP FORD LINCOLN MERCURY Ph: 574-2916910 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:02-MAY-2006 Doc #:78612501
Cust Comments: CHK FOR RED FLUID LEAK FROM RIGHT FRONT UNDER ENGINE AREA
Tech Comments: TEST FOR LEAKS HAS ENGINE OIL LEAK FROM OIL COOLER REPLACE OIL COOLER ASSY
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
post #4 of 4 (permalink) Old 07-24-2006, 06:39 PM
Oasis Report Please
My first post I am currently looking for a F-350 crew cab I found one Vin# 1FTWW31P15EA78495 . I would appreciate any info the report shows
https://www.thedieselgarage.com/forum...ies/thanks.gif
:thanks:
Thank.
Tarman30 is offline
