Oasis Report Please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by NGHTRGR, this thread has received 2 replies and been viewed 995 times.
post #1 of 3 (permalink) Old 01-04-2009, 11:13 PM Thread Starter
NGHTRGR's Avatar
Oasis Report Please
2005 Ford Excursion Limited w/6.0L
1FMSU43P55EB81695
No hurry
Thanks...
NGHTRGR is offline
post #2 of 3 (permalink) Old 01-05-2009, 10:23 AM
OASIS RESULT:
1FMSU43P55EB81695
01/05/2009
06:23:07
FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 EXCURSION BODY STYLE
LIMITED 4 DR 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
5L110N0A
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
01/31/2005 BUILD DATE
12/20/2004 SALE MILEAGE
00015
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
| On-line 1878
END OF OASIS REPORT FOR 1FMSU43P55EB81695
1FMSU43P55EB81695 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 20-DEC-2004 31-JAN-2005 121444 USA 10 6Y20 000001 * MISC * A98 82 5
AWS Claim Key: 2409375 Trx Code: P01 Labor Hrs: 0
Dlr Cd-Sub Cd: 00193 - * Name: JACKY W JONES FORD INC Ph: 706-8652168 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:04-NOV-2005 Doc #:11382801
Cust Comments: GOODWILL PAYMENT
Tech Comments: GOODWILL VEHICLE PAYMENT
1FMSU43P55EB81695 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 20-DEC-2004 31-JAN-2005 121444 USA 14 6X04 010902 1C7Z 17683 AAA M10 33 14783
AWS Claim Key: 4013832 Trx Code: E84 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 00193 - * Name: JACKY W JONES FORD INC Ph: 706-8652168 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:15-MAR-2006 Doc #:11738301
Cust Comments: LEFT MIRROR GLASS KEEPS FALLING OUT PTS HERE
Tech Comments: REMOVED LEFT FRONT DOOR PANEL, SPEAKER AND REPLACED MIRROR DUE TO CLIPS ON HOUSING BROKEN, REINSTALLED SPEAKER AND DOOR PANEL
1FMSU43P55EB81695 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 20-DEC-2004 31-JAN-2005 121444 USA 19 * * * * * * * 17567
AWS Claim Key: 5445653 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 01013 - * Name: LUMBERTON FORD LINCOLN-MERCURY Ph: 910-7386281 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:31-JUL-2006 Doc #:05276040
Cust Comments: 05E15 EXHAUST PRESSURE SENSOR REPLACEMENT, ON BOARD DIAGNOSTIC SYSTEM A
Tech Comments: UNKNOWN EP SENSOR, CONNECTOR, AND RECALIBRATION
AWS Claim Key: 5445655 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 01013 - * Name: LUMBERTON FORD LINCOLN-MERCURY Ph: 910-7386281 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:31-JUL-2006 Doc #:05276042
Cust Comments: 05B32 DE GAS BOTTLE FILL LEVEL LABEL AND FLUID LEVEL ADJUSTMENT
Tech Comments: UNKNOWN DEGAS BOTTLE LABLE REPLACEMENT
AWS Claim Key: 5445654 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 01013 - * Name: LUMBERTON FORD LINCOLN-MERCURY Ph: 910-7386281 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:31-JUL-2006 Doc #:05276041
Cust Comments: 59B01 ELIGIBLE FOR ONE TIME CUSTOMER ASSURANCE TEST DRIVE. SEE EMISSIO
Tech Comments: UNKNOWN CUSTOMER ASSURANCE TEST DRIVE REPLACE
1FMSU43P55EB81695 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 20-DEC-2004 31-JAN-2005 121444 USA 19 7S06 180101 * 12B637 * E29 B4 17567
AWS Claim Key: 5445652 Trx Code: S07 Labor Hrs: 5.4
Dlr Cd-Sub Cd: 01013 - * Name: LUMBERTON FORD LINCOLN-MERCURY Ph: 910-7386281 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:31-JUL-2006 Doc #:05276051
Cust Comments: CHECK ENGINE LIGHT ON
Tech Comments: DAMAGED WIRE ENGINE PERFORMANCE DIAGNOSTICS DIESEL ENGINE DIAGNOSIS
1FMSU43P55EB81695 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 20-DEC-2004 31-JAN-2005 121444 USA 19 2H01 030407 4C3Z 6K682 ARM E29 42 17658
AWS Claim Key: 5632998 Trx Code: S07 Labor Hrs: 3.9
Dlr Cd-Sub Cd: 01013 - * Name: LUMBERTON FORD LINCOLN-MERCURY Ph: 910-7386281 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:03-AUG-2006 Doc #:05294751
Cust Comments: CUST STATES CHECK ENGINE LIGHT
Tech Comments: NOT OPERATING PROPERLY ENGINE PERFORMANCE DIAGNOSTICS DIESEL ENGINE DIAGNOSIS
1FMSU43P55EB81695 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 20-DEC-2004 31-JAN-2005 121444 USA 19 2H02 030008 * 6F089 * E29 42 18707
AWS Claim Key: 5645893 Trx Code: S07 Labor Hrs: 6.8
Dlr Cd-Sub Cd: 01013 - * Name: LUMBERTON FORD LINCOLN-MERCURY Ph: 910-7386281 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:16-AUG-2006 Doc #:05335551
1FMSU43P55EB81695 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 20-DEC-2004 31-JAN-2005 121444 USA 23 5V07 060704 5C7Z 2005 B L63 42 22176
AWS Claim Key: 6633881 Trx Code: E84 Labor Hrs: 1
Dlr Cd-Sub Cd: 00960 - * Name: LAFAYETTE FORD Ph: 910-4240281 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:06-DEC-2006 Doc #:02890553
Cust Comments: C S MASTER CYLINDER LEAKING
Tech Comments: VERIFIED CONCERN. VISUAL IUNSPECTION SHOWED HYDROBOOSTER LEAKING. REPLACED HYDROBOOSTER. RECHECK AND OK
1FMSU43P55EB81695 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 20-DEC-2004 31-JAN-2005 121444 USA 23 2E02 030408 3C3Z 9N693 HA L65 42 22176
AWS Claim Key: 6633880 Trx Code: E84 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 00960 - * Name: LAFAYETTE FORD Ph: 910-4240281 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:06-DEC-2006 Doc #:02890552
Cust Comments: C S OIL LEAKING
Tech Comments: VERIFIED CONCERN. DYE TEST SYSTEM. FOUND CAM AND CRANK SENSOR O RINGS LEAKING. REPLACED O RINGS. RECHECK OK.
1FMSU43P55EB81695 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 20-DEC-2004 31-JAN-2005 121444 USA 33 1A05 030104 * 9430 * E41 14 32425
AWS Claim Key: 8774246 Trx Code: S07 Labor Hrs: 2.9
Dlr Cd-Sub Cd: 00960 - * Name: LAFAYETTE FORD Ph: 910-4240281 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:20-SEP-2007 Doc #:04703252
Cust Comments: CHECK EXHAUST LEAK,SMELL IN CAB
Tech Comments: VERIFY CONCERN,INSTALLED MANIFOLD GASKETS PER TSB 05 13 09,ROAD TEST,OK
1FMSU43P55EB81695 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 20-DEC-2004 31-JAN-2005 121444 USA 33 1D01 03XXXX 3C3Z 6701 A L72 D8 32425
AWS Claim Key: 8774247 Trx Code: E84 Labor Hrs: 5.9
Dlr Cd-Sub Cd: 00960 - * Name: LAFAYETTE FORD Ph: 910-4240281 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:20-SEP-2007 Doc #:04703253
Cust Comments: CHECK OIL TRANS FLUID LEAK AT BELL HOUSING AREA
Tech Comments: VERIFY CONCERN,CLEANED AND ADDED OIL DYE,ROAD TESTED,LEAK FROM REAR ENGINE COVER,REMOVED TRANS,REPLACED REAR COVER GASKET AND REAR MAIN SEAL,ROAD TESTED,OK
1FMSU43P55EB81695 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 20-DEC-2004 31-JAN-2005 121444 USA 33 2E06 100106 6C3Z 9G282 AA D50 42 32425
AWS Claim Key: 8774248 Trx Code: E84 Labor Hrs: 2.3
Dlr Cd-Sub Cd: 00960 - * Name: LAFAYETTE FORD Ph: 910-4240281 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:20-SEP-2007 Doc #:04703256
Cust Comments: CHECK LACKS POWER ON ACCEL,MORE SO UNDER LOAD
Tech Comments: PERFORM PRECHECKS. CHECK OASIS. PERFORM STEPS 1 THROUGH 10A ON PERFORMANCE DIAG. SHEET. FUEL PUMP FAILED UNDER A LOAD ON A LONG RUN ABOVE 50MPH.
1FMSU43P55EB81695 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 20-DEC-2004 31-JAN-2005 121444 USA 35 6G08 011103 4C3Z 2521411 AA G02 D4 35241
AWS Claim Key: 9039092 Trx Code: E84 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 00960 - * Name: LAFAYETTE FORD Ph: 910-4240281 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:26-NOV-2007 Doc #:05146251
Cust Comments: CHECK SCRATCHES IN DRIVERS WINDOWUSE SPO 07283019, AUTH #PAA2W
Tech Comments: VERIFIED CONCERN,PICTURES FOR DIGITAL IMAGING,APPROVAL CODE PAA2W,REMOVE DOOR PANEL,CLEAN AND LUBE WINDOW RUN,REPLACE GLASS,OK
cb44473 is offline
The Following User Says Thank You to cb44473 For this addition to TDG:
NGHTRGR (01-12-2009)
post #3 of 3 (permalink) Old 01-07-2009, 01:21 PM Thread Starter
NGHTRGR's Avatar
Thanks brother
Black 05 Excursion -MBRP T-Back minus kitty, Airaid w/Zoodad, FS2500, Coolant Bypass, ATS Headstuds, ITP Reg Rtn, Full EGR Delete, DFUSER Light Harness, Keystone Heat Extractor Hood 2 Tone, CCV Reroute, 4-6" lift, 35" MT Baja MTZ's on Classic Locks, SCT X2 w/Innovative Extreme Race
NGHTRGR is offline
Oasis report pretty please barry1me Ford Oasis requests 1 01-05-2009 10:24 AM
Oasis report please. sidssm Ford Oasis requests 2 01-04-2009 04:44 PM
Ford oasis report please "THE DEMIZE" Ford Oasis requests 2 01-03-2009 06:46 PM
Oasis Please toshmago Ford Oasis requests 1 01-03-2009 02:50 AM
Oasis Request. wastedwagesracing Ford Oasis requests 1 12-27-2008 04:02 PM
