Oasis Please 1FTWW31P15EA19446 (05 F350) - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BKB, this thread has received 1 replies and been viewed 579 times.
post #1 of 2 (permalink) Old 01-04-2009, 11:43 PM Thread Starter
BKB
Thanks you very much
1FTWW31P15EA19446
BKB is offline
post #2 of 2 (permalink) Old 01-05-2009, 10:22 AM
OASIS RESULT:
1FTWW31P15EA19446
01/05/2009
06:22:04
FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
09/27/2004 BUILD DATE
08/03/2004 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
1FTWW31P15EA19446 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 03-AUG-2004 27-SEP-2004 152768 USA 1 3A15 070102 4C3Z 7G383 AA P59 42 673
AWS Claim Key: 97102 Trx Code: S07 Labor Hrs: 3.4
Dlr Cd-Sub Cd: 04283 - * Name: VARSITY FORD LINCOLN MERCURY, INC. Ph: 979-7790664 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:04-OCT-2004 Doc #:220336A
Cust Comments: TRANS WILL NOT OR VERY SLOW TO ENGAGE IN GEAR, WHEN IT SHIFTS GEARS RPMS RACE UP THEN IT SLAMS INTO GEAR
Tech Comments: PERFORMED ELECTRONIC TRANSMISSION DIAGNOSIS. PI NPOINT TEST. R AND I VALVE BODY AND REPLACED PC A SOLENOID. ROAD TEST.
1FTWW31P15EA19446 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 03-AUG-2004 27-SEP-2004 152768 USA 2 7S02 180102 * 14401 * L26 28 2129
AWS Claim Key: 147377 Trx Code: 1 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 04283 - * Name: VARSITY FORD LINCOLN MERCURY, INC. Ph: 979-7790664 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:04-NOV-2004 Doc #:222303A
Cust Comments: PASSENGER HEADLIGHT INOP
Tech Comments: PINPOINT TEST. REPAIRED GN R WIRE AND BLK GROUN D WIRE AT RIGHT HEADLAMP AND REPLACED BULB.
1FTWW31P15EA19446 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 03-AUG-2004 27-SEP-2004 152768 USA 2 2E06 030008 4C3Z 9E527 AA D50 42 2535
AWS Claim Key: 161923 Trx Code: S07 Labor Hrs: 7.5
Dlr Cd-Sub Cd: 04283 - * Name: VARSITY FORD LINCOLN MERCURY, INC. Ph: 979-7790664 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:15-NOV-2004 Doc #:222770B
Cust Comments: FOR THE 1ST 5 10 MILES IN AM, TRANS WILL SHUDDER WHEN SHIFTING INTO OVERDRIVE, AFTER THAT IT IS FINE
Tech Comments: RAN ENGINE PERFORMANCE TESTS 1 15. RAN COMPRESS ION TEST. REPLACED NO.1 INJECTOR. RETEST.
1FTWW31P15EA19446 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 03-AUG-2004 27-SEP-2004 152768 USA 3 5T03 110402 4C3Z 7210 BAA A85 42 3545
AWS Claim Key: 192477 Trx Code: 1 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 04283 - * Name: VARSITY FORD LINCOLN MERCURY, INC. Ph: 979-7790664 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:03-DEC-2004 Doc #:223850A
Cust Comments: TOWHAUL OVERDRIVE LIGHT INOP (SOP)
Tech Comments: BCE PINPOINT TEST. HOOKED UP WDS. PID AND MONIT OR SWITCH STATUS. REPLACED SHIFTER LEVER ASSEMB LY.
1FTWW31P15EA19446 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 03-AUG-2004 27-SEP-2004 152768 USA 18 * * * * * * * 25166
AWS Claim Key: 3705800 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 04283 - * Name: VARSITY FORD LINCOLN MERCURY, INC. Ph: 979-7790664 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:22-FEB-2006 Doc #:250088C
Cust Comments: 05E15 EBP RECALL
Tech Comments: PERFORMED RECALL 05E15
AWS Claim Key: 3705802 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 04283 - * Name: VARSITY FORD LINCOLN MERCURY, INC. Ph: 979-7790664 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:22-FEB-2006 Doc #:250088E
Cust Comments: 05B32 DE GAS BOTTLE RECALL
Tech Comments: PERFORMED RECALL 05B32
AWS Claim Key: 3705801 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 04283 - * Name: VARSITY FORD LINCOLN MERCURY, INC. Ph: 979-7790664 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:22-FEB-2006 Doc #:250088D
Cust Comments: 59B01 ONE TIME TEST DRIVE
Tech Comments: PERFORMED RECALL 59B01
cb44473 is offline
2001 Ford F350 fordman11 Whats Been Sold 1 01-17-2009 12:44 PM
F350 + GMC Brigader + Icy hills = A LITTLE FUN! STANG302 Towing and Hauling 7 01-17-2009 01:06 AM
Oasis Report Please NGHTRGR Ford Oasis requests 2 01-07-2009 01:21 PM
Oasis Please toshmago Ford Oasis requests 1 01-03-2009 02:50 AM
Oasis Request. wastedwagesracing Ford Oasis requests 1 12-27-2008 04:02 PM
