OASIS Request for '02 F350 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by fgtex, this thread has received 4 replies and been viewed 1043 times.
post #1 of 5 (permalink) Old 07-24-2006, 06:50 PM Thread Starter
I would like an OASIS report for the following vehicle that a friend has for sale. I know he is the second owner and hasn't done much with it. The first owner I have no info about.
2002 F350 7.3 - 1FTSW31F52ED70118
Thank you in advance,
fgtex
fgtex is offline
post #2 of 5 (permalink) Old 07-25-2006, 10:25 PM
Squatch's Avatar
OASIS RESULT:
1FTSW31F52ED70118
07/25/2006
17:25:00
© Copyright 2002-2006 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2002 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
7.3L TURBO - DI
TRANSMISSION
4R100 4SP (DIESEL) AXLE CODE
ENGINE CALIBRATION
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
08/24/2002 BUILD DATE
06/25/2002 SALE MILEAGE
ARN MESSAGES
BEFORE REPLACING DIESEL HIGH PRESSURE PUMP (-9A543-) SEE TSB 04-04-04
BEFORE REPLACING 7.3L DIESEL TURBO PEDESTALS (-6N639-) SEE TSB 04-20-02
WARNING MESSAGES
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
NO REPAIR HISTORY ON VEHICLE
END OF OASIS REPORT FOR 1FTSW31F52ED70118
Standard Claims List For Model Year 2002
1FTSW31F52ED70118 T/F7 F T/BC T/CD T/E A1 T/D8 T/DS 25-JUN-2002 24-AUG-2002 152016 USA 6 1H03 030008 3C3Z 9J460 AA D02 42 10996
AWS Claim Key: 4730640 Trx Code: S07 Labor Hrs: 3
Dlr Cd-Sub Cd: 02417 - * Name: DON DAVIS FORD, INC. Ph: 817-2614261 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:15-FEB-2003 Doc #:460562B
Cust Comments: CRANK NO START
Tech Comments: 10999 EBP SENSOR RAN PERFORMANCE SHEET,DIAGNOSED THE EBP TO BE SHORTED INTERNALLY ,CAUSING THE VREF TO BE AT 0 VOLTS,I THEN DIAGNOSED THE EBP TO BE DEFECTIV AND REPLACED THE SENSOR AND ALL IS FINE,ERASED CODES AND TEST DROVE...Q.C.TESTED BY K.D.
1FTSW31F52ED70118 T/F7 F T/BC T/CD T/E A1 T/D8 T/DS 25-JUN-2002 24-AUG-2002 152016 USA 9 5U02 020201 * 5C036 * B09 D4 15651
AWS Claim Key: 5935241 Trx Code: E84 Labor Hrs: 3.5
Dlr Cd-Sub Cd: 02417 - * Name: DON DAVIS FORD, INC. Ph: 817-2614261 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:05-MAY-2003 Doc #:468227B
Cust Comments: GROANING NOISE FROM REAR END WHEN GOING OVER BUMPS
Tech Comments: 15651 CAB MOUNTS VERIFIED CUST CONCERN. PERFORMED EAR CHASIS TEST AND THEN FOUND THAT NOISE WAS COMING FROM THE MOUNTS AND THEN RAISED CAB AND ADDED TEFLON GREASE TO MOUNT AND REMOUNTED CAB AND NESSARY TO REMOVE BACK SEAT. ROADTESED WITH EAR CHASIS EVERY THING OK AT THIS ITME.BASE PART #5C036 QC BY DO
1FTSW31F52ED70118 T/F7 F T/BC T/CD T/E A1 T/D8 T/DS 25-JUN-2002 24-AUG-2002 152016 USA 12 6J02 011404 F81Z 2626413 AA N59 41 19878
AWS Claim Key: 6988454 Trx Code: E84 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 02417 - * Name: DON DAVIS FORD, INC. Ph: 817-2614261 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:11-AUG-2003 Doc #:478563C
Cust Comments: POPPING GROANING NOISE COMING FROM REAR OF VEHICLE DURING TAKE OFFS AFTER HARD STOPS
Tech Comments: 19878 DRIVER SIDE REAR DOOR LATCH VERIFIED CUSTOMER CONCERN,FOUND THAT THE DRIVER SIDE REAR DOOR LATCH WAS THE PROBLEM.REMOVED DOOR PANEL TO GET ACCES TO THE LATCH.R&R DRIVER SIDE REAR DOOR LATCH.REINATLLED ALL BACK AND THEN TEST DROVED ALL OK AT THIS TIME. QC BY JUAN GUTIRREZ
1FTSW31F52ED70118 T/F7 F T/BC T/CD T/E A1 T/D8 T/DS 25-JUN-2002 24-AUG-2002 152016 USA 17 2H01 030008 F81Z 6C640 CA L65 D1 25873
AWS Claim Key: 8608221 Trx Code: E84 Labor Hrs: 4.2
Dlr Cd-Sub Cd: 02417 - * Name: DON DAVIS FORD, INC. Ph: 817-2614261 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:30-DEC-2003 Doc #:492559C
Cust Comments: OIL LEAKING FROM ENGINE AREA , MD0312301
Tech Comments: 25873 ORANGE INTAKE HOSES AND HIGH PRESS O RINGS LEAK DIESEL PERF DIAG,NO DTCS,NO AMPD FOUND,OIL DYE TEST,FOUND TWO O RINGS UNDER HIGH PRESSURE FITTINGS ON LEFT CYLINDER HEAD LEAKING,REPLACED O RINGS ON HIGH PRESSURE OIL RAIL,CLEANED ENGIN E,ROADTEST,RETEST,FOUND OIL LEAKING FROM INTAKE HOSES,REMOVED AIR INTAKE TUBE,CAC TUBES,INTAKE PLENUM FOR ACCESS,CLEANED AND INSPECTED TUBES,
1FTSW31F52ED70118 T/F7 F T/BC T/CD T/E A1 T/D8 T/DS 25-JUN-2002 24-AUG-2002 152016 USA 22 2E02 030008 F4TZ 9N693 A L65 D1 32575
AWS Claim Key: 10436177 Trx Code: E84 Labor Hrs: 7.8
Dlr Cd-Sub Cd: 02417 - * Name: DON DAVIS FORD, INC. Ph: 817-2614261 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:02-JUN-2004 Doc #:408691D
Cust Comments: OIL LEAKING FROM ENGINE AREA , MD0406023
Tech Comments: 32582 OIL LEAK FROM ENGINE AREA. CHECKED ENGINE OIL SYS, FOUND OIL SOAKED AREAS AND CLEANED. USED OIL DYE AND BLACKLIGHT TO DETERMINE SOURCE. FOUND OIL LEAKING FROM PASS SIDE HEAD OIL GALLEY PLUGS. ALSO FOUND TURBO BOLTS LOOSE IN HOUSING. REPLACED ALL PASS SIDE OIL GALLEY PLUG O RINGS. ALSO REMOVED TURBO TO REPLACED TURBO HOUSING BOLTS. REMOVED ALL CAC TUBES AND HOSES AND CLEANED OF
1FTSW31F52ED70118 T/F7 F T/BC T/CD T/E A1 T/D8 T/DS 25-JUN-2002 24-AUG-2002 152016 USA 25 1D01 030008 F4TZ 6701 A L65 D1 37706
AWS Claim Key: 11566549 Trx Code: E72 Labor Hrs: 9.9
Dlr Cd-Sub Cd: 02417 - * Name: DON DAVIS FORD, INC. Ph: 817-2614261 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:09-SEP-2004 Doc #:419699B
Cust Comments: OIL LEAKING FROM ENGINE AREA ,SEE MANUEL
Tech Comments: 37711 REAR MAIN SEAL AND REAR BLOCK COVER,PLUG AND FUEL LINE O RING SEALS RAN OIL DYE TEST,FOUND THE OIL TO BE LEAKING FROM THE PLUG ON THE FRONT CORNER OF THE BLOCK AND THE REAR BLOCK COVER,REAR MAIN SEAL... I THEN REMOVE DTHE PLUG AND RESEALED IT WITH TEFLON AND CLEANED THE AREA,ALSO REMOVED THE 4X4 AUTO TRANS AND REPLACED THE REAR BLOCK COVER AND REAR MAIN SEAL,STEAM CLEANED THE AREA
1FTSW31F52ED70118 T/F7 F T/BC T/CD T/E A1 T/D8 T/DS 25-JUN-2002 24-AUG-2002 152016 USA 25 1G02 030008 F81Z 8501 ARM L85 D1 37706
AWS Claim Key: 11566548 Trx Code: E72 Labor Hrs: 1.9
Dlr Cd-Sub Cd: 02417 - * Name: DON DAVIS FORD, INC. Ph: 817-2614261 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:09-SEP-2004 Doc #:419699D
Cust Comments: COOLANT LEAKING FROM ENGINE AREA ,MD0409091
Tech Comments: 37706 PRESSURE TESTED THE COOLANT SYSTEM,FOUND THE WATER PUMP AND THERMOSTAT HOUSING BOTH LEAKING, I THEN REPLACED THE WATER PUMP AND THERMOSTAT HOUSING,ADDED NEW COOLANT AND TEST DROVE... CONFIRMED THE REPAIRS... Q.C.TESTED BY K.D.
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
post #3 of 5 (permalink) Old 07-26-2006, 12:15 AM Thread Starter
thanks
Squatch,
Thank you very much. Does not look that bad.
fgtex
fgtex is offline
post #4 of 5 (permalink) Old 07-27-2006, 05:49 AM
Tornsteel's Avatar
OASIS please
I need a report for a 2000 PSD.
VIN#1FTNW21F7YED01009
Thank you.
2006 XLT 6.0, 72,000 miles. First owner. Build date 10/05, CC,LB,3.73LS,SRW,ISSPRO Pyro-Boost-Trans on the APillar,ARP Studs,Stock HG's,ELITE SCT Tadd's Tunes,Sinister SCT,Innovative tunes,EGR delete,4" turbo back dual exhst, zoodad, ccv mod, Coolant bypass filter, Cage leveling kit,upfitter high idle, running Amsoil 3000 with Archoil, 6.4 banjo's, Blue spring, 03 Turbo w/ 03 pedestal.
Issues: Rear main seal at 1'700 mls. EGR valve, EGR cooler and Oil cooler @ about 43k, Stock Head Gaskets @55k, Black Onyx HG's @72k.
https://www.thedieselgarage.com/galle...028_393362.jpg
Sean H
Tornsteel is offline
post #5 of 5 (permalink) Old 07-27-2006, 05:51 AM
Tornsteel's Avatar
sorry wrong spot
Sean H
