Oasis Report needed..Please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by bigbirdF250, this thread has received 1 replies and been viewed 829 times.
post #1 of 2 (permalink) Old 07-27-2006, 03:23 PM Thread Starter
VIN. 1FTSW21P25EA92737
Thanks a million!!!
James
bigbirdF250 is offline
post #2 of 2 (permalink) Old 07-28-2006, 04:57 AM
Squatch's Avatar
OASIS RESULT:
1FTSW21P25EA92737
07/27/2006
23:56:58
© Copyright 2002-2006 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
02/10/2005 BUILD DATE
09/30/2004 SALE MILEAGE
00024
ARN MESSAGES
BEFORE REPLACING HIGH PRESS. PUMP FOR HARD START OR OIL LEAK, SEE TSB 06-14-06
BEFORE ADDRESSING VEHICLE VIBRATION CONCERNS, SEE TSB 05-26-24
BEFORE REPLACING FS-10 A/C COMPRESSOR (19703), PLEASE SEE TSB 06-04-09
WARNING MESSAGES
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
0712 - USA 2005 NEW 48/60,000 PREMIUM MAINT(M&W)6.0L DSL 7.5K
STANDARD DEDUCTIBLE: 0 USD
OWNER NAME: HUNNIE BISHOP
OPTIONS:
EXPIRATION DATE: 02/10/2009
DISTANCE: 61,000
RENTAL: 0 UP TO 0 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 04462
ESP CONTRACT START DATE: 02/10/2005
REPAIR HISTORY
05/11/2006
DEALER: Joe Myers Ford
WARRANTY CLAIM NUMBER: 519154 ODOMETER: 032472M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9E527AA NOZZLE ASY-FUEL INJE 001 9527AL 42 DOES NOT OPERATE PROPERLY
000 6005F
000 6005F1
000 6005F2
000 6005F6
000 6005F8
000 6005F9
000 6005F11
000 6005F12
000 6005F13
000 6005F14
000 6005F18
000 6005F20
000 6005F23
000 6005F25
000 6005F33
000 6005F1X1
32472 WF 36-36 9E527-42 RAN COMPLETE DIESEL DIAG SHEET FOUND ENGINE MIS FIR E CODE P0278 CYL #6,FOUND #6 INJ FAILED R-R DRIVER SIDE VALVE COVER,REPLAC ED #6 INJ *** Y,TEST DROVE,RAN REST OF DIAG SHEET TO CONFIRM REPAIRS,LL PRE SS IN SPEC,BOOST AT 25 PSI ALL OK AT THIS TIME
03/03/2006
DEALER: Randall Reed's Team Ford
WARRANTY CLAIM NUMBER: 353490 ODOMETER: 030875M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9E933AA GSKT-EGR TO-TH-BDY 001 9350E 42 DOES NOT OPERATE PROPERLY
3C3Z 9E933BA GSKT-EGR TO-TH-BDY 001 6005F18
6C3Z 9G282AA PMP & FLTR ASY-FUL 001
CHECKED FUEL PRESSURE AND FUEL PUMP ONLY PUTTING OUT 24PSI CAUSING THE ROUGH IDLE .REPLACE FUEL PUMP AND TEST DROVE VEHICLE ABOUT 20MILES.LET SET OVER N IGHT AND TEST DRIVE AGAIN IN THE MORING .
03/03/2006
LABOR OP
CONDITION CODE
CONDITION DESC
W300051 006 7000A 42 DOES NOT OPERATE PROPERLY
W300013 004 MT6K854
W300006 002
3C3Z 6N640AA GASKET TURBO TO MANI 001
5C3Z 6K854BA PIPE (TURBO INLET LO 001
5C3Z 6K854AA PIPE (TURBO INLET LO 001
VC 7B 002
1 YPIPE LEAKING FROM THE FLEX PIPE CAUSING THE THE EXHAUST SMELL IN THE C AB.R&R TRANSMISSION TO REPLACE Y PIPE.
02/21/2006
WARRANTY CLAIM NUMBER: 352791 ODOMETER: 030827M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9E527AA NOZZLE ASY-FUEL INJE 002 9527AT 42 DOES NOT OPERATE PROPERLY
VC 7B 002 6005E2
PM 15 001 6005F
000 6005E3
000 12650D47
1 PERFORMED KOEO TEST FOUND CODE P0301 INJECTOR 1MISFIRE AND P0308 INJECT OR 8 MISFIRE . PERFORMED POWER BALANCE AND FOUND #1 AND #8 INJECTOR -20 DEVI ANT . BOTH INJECTORS HAD BLOWN RINGS CASUING THE MISFIRE CODES . REPLACE BOT H INJECTORS AND CLEAR CODES .TEST DRIVE VEHICLE.
02/21/2006
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 7A098AA SCREEN ASY - OIL PAN 001 7000F 42 DOES NOT OPERATE PROPERLY
3C3Z 7B155BA FLTR&HD ASY TRNS OIL 001 12650D84
4C3Z 7G383AA EPC SOLENOID 001 7191A
3C3Z 7C155DA GSKT CONTROL VALVE 001 7191AXQ
XT 6QSP 016 7191AZG
000 7191A2
000 7191A10
000 7000A43
000 MT7000
CK FLUID--OK. TEST DRIVE-TRANS HAS INTERMITTENT DELAYED ENGAGEMENT-WAS UNABL E TO DUPLICATE HARSH SHIFTS. EEC TEST PASS. PRESSURE TEST-LINE PRESSURE LOW AND FLUCTUATING 30-100 PSI AND WHEN SELECTI WEAR DEBRIS. R R TRANS PAN FOR I NSPECTION--CLEAN. R R AND CLEAN VALVE-SOLENOID BODY AND REPLACE STICKING LIN E PRESSURE CONTROL SOLENOID AND CLEAN PAN GSK. INSTALL NEW REMOTE FILTE DISC
02/21/2006
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9J460A SENSOR ASY EGR PR VL 001 05E15M
1 REPLACE EBP SENSOR AND REPROGRAM MOUDLES PER RECALL 05E15
02/21/2006
LABOR OP
CONDITION CODE
CONDITION DESC
000 59B01A
1 TEST DRIVE PER RECALL 59B01
02/21/2006
LABOR OP
CONDITION CODE
CONDITION DESC
000 05B32B
1 ADD LABLE PER RECALL 05B32
02/21/2006
LABOR OP
CONDITION CODE
CONDITION DESC
MAINT VEHICLE MAINTENANCE 000 MB30 82 FREIGHT/POSTAGE/MAINTENANCE
4C3Z 9601AA ELEMENT ASY-AIR CLEA 001 MULTI
XO 15W40QSD 016
3C3Z 6731AA ELEMENT ASY OIL FILT 001
1 CHANGED OIL AND FILTER AND TOPPED OFF FLUID LEVELS AND REPLACE AIR FILT ER
09/12/2005
WARRANTY CLAIM NUMBER: 341462 ODOMETER: 017858M
LABOR OP
CONDITION CODE
CONDITION DESC
MAINT VEHICLE MAINTENANCE 000 MU15 82 FREIGHT/POSTAGE/MAINTENANCE
XO 15W40QSD 016
3C3Z 9N184CA WATER-FUEL SEP ELEM 001
1 CHANGED FILTERS. QUALITY CHECK 758
09/12/2005
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 6K682AARM TURBO CHG-EXH DRIVE 001 6005F 42 DOES NOT OPERATE PROPERLY
000 6005F1
000 6005F1X1
000 6005F2
000 6005F6
000 6005F12
000 6005E4
000 9438A
000 9438AZW
000 6005F25
MIKE 5IMCV004 PERFORMED DIESEL PERFORMANCE DIAG, KOEO, KOER, BUZZ TEST P0299 , EGR POSITION CHECK-OK PID DATA MONITIOR, VGT DIAG NO MOVEMENT NOTIED ON CA M FOLLOWER, REMOVER VGT AND COMMAND OUTPUT STATE, MOVEMENT FROM VGT, REPLACE D TURBO AND RETEST P1000. BOOST TEST 25.3 PSI. QUALITY CHECK 758
END OF OASIS REPORT FOR 1FTSW21P25EA92737
Standard Claims List For Model Year 2005
1FTSW21P25EA92737 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 30-SEP-2004 10-FEB-2005 152046 USA 1 3A15 0701XX 4C3Z 7G383 AA P59 42 4700
AWS Claim Key: 565484 Trx Code: S07 Labor Hrs: 4.6
Dlr Cd-Sub Cd: 04462 - * Name: RANDALL REED'S TEAM FORD Ph: 281-4469171 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:09-MAR-2005 Doc #:32799002
Cust Comments: CS WHEN PUT INTO REVERSE TRANS FELT LIKE IT WAS SLIPPING ALSO WHEN DRIVING FORWARD SHIFT AT HIGH RPMS. HARSH
Tech Comments: CK FLUID OK. TEST DRIVE INTERMITTENT DELAY ENGAGEMENTS.EEC TEST PASS. PRESSURE TEST P40 80 R55 90 D40 80 PRESSURES TRANS ADAPTIVE STRATEGY. CK PCM FICM TCM CALIBRATION HAD LATEST CALIBRATION. POST ROAD TEST HAS NORMAL ENGAGEMENTS
1FTSW21P25EA92737 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 30-SEP-2004 10-FEB-2005 152046 USA 5 6Y05 000001 * MAINT * A9* 82 10737
AWS Claim Key: 1175180 Trx Code: 0712S Labor Hrs: 1.1
Dlr Cd-Sub Cd: 04462 - * Name: RANDALL REED'S TEAM FORD Ph: 281-4469171 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:23-JUN-2005 Doc #:33582102
Cust Comments: PERFORM 10K MAINTENANCE
Tech Comments: CHANGED OIL AND FITLER AND ROTATED TIRES QUALITY CHECKED BY TECH 1659
1FTSW21P25EA92737 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 30-SEP-2004 10-FEB-2005 152046 USA 8 6Y05 000001 * MAINT * A9* 82 17858
AWS Claim Key: 1901539 Trx Code: 0712S Labor Hrs: 1.6
Dlr Cd-Sub Cd: 04462 - * Name: RANDALL REED'S TEAM FORD Ph: 281-4469171 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:12-SEP-2005 Doc #:34146202
Cust Comments: 15K SERVICE CHANGE OIL AND FILTER, FUEL FILTER AND AIR FILTER
Tech Comments: 1 CHANGED FILTERS. QUALITY CHECK 758
1FTSW21P25EA92737 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 30-SEP-2004 10-FEB-2005 152046 USA 8 2H01 030008 4C3Z 6K682 AARM D36 42 17858
AWS Claim Key: 1901538 Trx Code: S07 Labor Hrs: 4.6
Dlr Cd-Sub Cd: 04462 - * Name: RANDALL REED'S TEAM FORD Ph: 281-4469171 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:12-SEP-2005 Doc #:34146203
Cust Comments: CS VEH BLOWS BLACK SMOKE ON ACELL AT TIMES
Tech Comments: MIKE 5IMCV004 PERFORMED DIESEL PERFORMANCE DIAG, KOEO, KOER, BUZZ TEST P0299, EGR POSITION CHECK OK PID DATA MONITIOR, VGT DIAG NO MOVEMENT NOTIED ON CAM FOLLOWER, REMOVER VGT AND COMMAND OUTPUT STATE, MOVEMENT FROM VGT, REPLACED TURBO AND RETEST P1000. BOOST TEST 25.3 PSI. QUALITY CHECK 758
1FTSW21P25EA92737 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 30-SEP-2004 10-FEB-2005 152046 USA 13 2E06 030008 4C3Z 9E527 AA D02 42 30827
AWS Claim Key: 3826776 Trx Code: S07 Labor Hrs: 4.3
Dlr Cd-Sub Cd: 04462 - * Name: RANDALL REED'S TEAM FORD Ph: 281-4469171 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:21-FEB-2006 Doc #:35279101
Cust Comments: CS VEH WILL NOT START....HAS TO JUMP
Tech Comments: 1 PERFORMED KOEO TEST FOUND CODE P0301 INJECTOR 1MISFIRE AND P0308 INJECTOR 8 MISFIRE . PERFORMED POWER BALANCE AND FOUND #1 AND #8 INJECTOR 20 DEVIANT . BOTH INJECTORS HAD BLOWN RINGS CASUING THE MISFIRE CODES . REPLACE BOTH INJECTORS AND CLEAR CODES .TEST DRIVE VEHICLE.
1FTSW21P25EA92737 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 30-SEP-2004 10-FEB-2005 152046 USA 13 3A15 0701XX 4C3Z 7G383 AA P59 42 30827
AWS Claim Key: 3826775 Trx Code: S07 Labor Hrs: 4.8
Dlr Cd-Sub Cd: 04462 - * Name: RANDALL REED'S TEAM FORD Ph: 281-4469171 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:21-FEB-2006 Doc #:35279103
Cust Comments: CS TRANS HAS HARSH SHIFT ON ACELL AND DELAYED ENGAGEMENT WHEN GOING INTO GEAR
Tech Comments: CK FLUID OK. TEST DRIVE TRANS HAS INTERMITTENT DELAYED ENGAGEMENT WAS UNABLE TO DUPLICATE HARSH SHIFTS. EEC TEST PASS. PRESSURE TEST LINE PRESSURE LOW AND FLUCTUATING 30 100 PSI AND WHEN SELECTI WEAR DEBRIS. R R TRANS PAN FOR INSPECTION CLEAN. R R AND CLEAN VALVE SOLENOID BODY AND REPLACE STICKING LINE PRESSURE CONTROL SOLENOID AND CLEAN PAN GSK. INSTALL NEW REMOTE FILTE DISCONNECT BATTERYS TO C
1FTSW21P25EA92737 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 30-SEP-2004 10-FEB-2005 152046 USA 13 * * * * * * * 30827
AWS Claim Key: 3826771 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 04462 - * Name: RANDALL REED'S TEAM FORD Ph: 281-4469171 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:21-FEB-2006 Doc #:35279105
Cust Comments: RECALL 05E15 EXHAUST SENSOR
Tech Comments: 1 REPLACE EBP SENSOR AND REPROGRAM MOUDLES PER RECALL 05E15
AWS Claim Key: 3826774 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 04462 - * Name: RANDALL REED'S TEAM FORD Ph: 281-4469171 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:21-FEB-2006 Doc #:35279106
Cust Comments: RECALL 59B01 TEST DRIVE
Tech Comments: 1 TEST DRIVE PER RECALL 59B01
AWS Claim Key: 3826773 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 04462 - * Name: RANDALL REED'S TEAM FORD Ph: 281-4469171 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:21-FEB-2006 Doc #:35279107
Cust Comments: RECALL 05B32 DE GAS BOTTLE FILL LABLE AND ADJUSTMENT
Tech Comments: 1 ADD LABLE PER RECALL 05B32
1FTSW21P25EA92737 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 30-SEP-2004 10-FEB-2005 152046 USA 13 6Y05 000001 * MAINT * A9* 82 30827
AWS Claim Key: 3826772 Trx Code: 0712S Labor Hrs: 2.4
Dlr Cd-Sub Cd: 04462 - * Name: RANDALL REED'S TEAM FORD Ph: 281-4469171 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:21-FEB-2006 Doc #:35279108
Cust Comments: DIESEL OIL AND FILTER CHANGE 6.0L
Tech Comments: 1 CHANGED OIL AND FILTER AND TOPPED OFF FLUID LEVELS AND REPLACE AIR FILTER
1FTSW21P25EA92737 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 30-SEP-2004 10-FEB-2005 152046 USA 13 2E06 100106 6C3Z 9G282 AA D13 42 30875
AWS Claim Key: 3898542 Trx Code: E84 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 04462 - * Name: RANDALL REED'S TEAM FORD Ph: 281-4469171 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:03-MAR-2006 Doc #:35349001
Cust Comments: CS VEH RUNS ROUGH AFTER STARTING AND WILL DIE..SOMETIMES WILL RESTART...NO SMOKE
Tech Comments: CHECKED FUEL PRESSURE AND FUEL PUMP ONLY PUTTING OUT 24PSI CAUSING THE ROUGH IDLE .REPLACE FUEL PUMP AND TEST DROVE VEHICLE ABOUT 20MILES.LET SET OVER NIGHT AND TEST DRIVE AGAIN IN THE MORING .
1FTSW21P25EA92737 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 30-SEP-2004 10-FEB-2005 152046 USA 13 2H01 030008 5C3Z 6K854 BA E41 42 30875
AWS Claim Key: 3898541 Trx Code: E84 Labor Hrs: 7.2
Dlr Cd-Sub Cd: 04462 - * Name: RANDALL REED'S TEAM FORD Ph: 281-4469171 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:03-MAR-2006 Doc #:35349002
Cust Comments: CS VEH HAS EXCESSIVE EXHAUST SMELL IN CAB OF VEH
Tech Comments: 1 YPIPE LEAKING FROM THE FLEX PIPE CAUSING THE THE EXHAUST SMELL IN THE CAB.R&R TRANSMISSION TO REPLACE Y PIPE.
1FTSW21P25EA92737 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 30-SEP-2004 10-FEB-2005 152046 USA 16 2E06 030008 4C3Z 9E527 AA D50 42 32472
AWS Claim Key: 4747410 Trx Code: S07 Labor Hrs: 6.7
Dlr Cd-Sub Cd: 04402 - * Name: JOE MYERS FORD Ph: 713-8968200 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:11-MAY-2006 Doc #:519154A
Cust Comments: QCP C S BLOWING BLACK SMOKE FROM TAIL PIPE & RUNNING VERY ROUGH
Tech Comments: 32472 WF 36 36 9E527 42 RAN COMPLETE DIESEL DIAG SHEET FOUND ENGINE MIS FIRE CODE P0278 CYL #6,FOUND #6 INJ FAILED R R DRIVER SIDE VALVE COVER,REPLACED #6 INJ *** Y,TEST DROVE,RAN REST OF DIAG SHEET TO CONFIRM REPAIRS,LL PRESS IN SPEC,BOOST AT 25 PSI ALL OK AT THIS TIME
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
