OASIS Please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by DieselDan, this thread has received 2 replies and been viewed 414 times.
post #1 of 3 (permalink) Old 07-28-2006, 07:09 AM Thread Starter
OASIS Please
Hay Squatch could you look up one for me
1FMNU43S0YEE49655
Thanks in advance this is on a Excursion if that makes any difference
DieselDan is offline
post #2 of 3 (permalink) Old 07-31-2006, 02:25 AM
Squatch's Avatar
OASIS RESULT:
1FMNU43S0YEE49655
07/30/2006
21:24:47
© Copyright 2002-2006 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2000 EXCURSION BODY STYLE
LIMITED 4 DR 4X4 ENGINE
6.8L EFI SOHC
TRANSMISSION
4R100 (E4OD) 4SP O/D AXLE CODE
ENGINE CALIBRATION
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
08/25/2000 BUILD DATE
07/21/2000 SALE MILEAGE
ARN MESSAGES
BEFORE REPLACING DIESEL HIGH PRESSURE PUMP (-9A543-) SEE TSB 04-04-04
BEFORE REPLACING 7.3L DIESEL TURBO PEDESTALS (-6N639-) SEE TSB 04-20-02
WARNING MESSAGES
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
0741 - USA 2004 USED 36/36,000 EXTRACARE W/ROADSIDE ASSIST
STANDARD DEDUCTIBLE: 100 USD
OWNER NAME: BONNIE TRACY
OPTIONS:
EXPIRATION DATE: 12/03/2006
DISTANCE: 71,687
RENTAL: 28 UP TO 10 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 08926
ESP CONTRACT START DATE: 12/03/2003
REPAIR HISTORY
NO REPAIR HISTORY ON VEHICLE
END OF OASIS REPORT FOR 1FMNU43S0YEE49655
Standard Claims List For Model Year 2000
1FMNU43S0YEE49655 T/L1 F T/WD T/CA T/E A1 T/DE T/WA 21-JUL-2000 25-AUG-2000 111553 USA 1 6N09 010809 YC3Z 16N454 AAB B64 07 370
AWS Claim Key: 3044577 Trx Code: 1 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 01531 - * Name: GRANITE FORD Ph: 603-3322585 St:NH Ctry Cd: USA Reg Cd: NA Repr Date:14-SEP-2000 Doc #:01877501
Cust Comments: PASS SIDE RUNNING BOARD HAS FLAW IN IT POOR FIT
Tech Comments: VERIFY FLAW IN RUNNING BOARD COVER AT FRONT LIGHT AREA REPLACE RUNNING BOARD COVER OKAY
1FMNU43S0YEE49655 T/L1 F T/WD T/CA T/E A1 T/DE T/WA 21-JUL-2000 25-AUG-2000 111553 USA 6 6D01 011001 YC3Z 7864417 DAA S55 31 7217
AWS Claim Key: 6385495 Trx Code: 1 Labor Hrs: 1.1
Dlr Cd-Sub Cd: 01531 - * Name: GRANITE FORD Ph: 603-3322585 St:NH Ctry Cd: USA Reg Cd: NA Repr Date:14-FEB-2001 Doc #:02231201
Cust Comments: THREADING IS SEPERATING, SOP IS IN
Tech Comments: FOUND FRONT SEAT COVER BACK WAS FRAYING, REMOVED AND REPLACED FAULTY SEAT BACK COVER
1FMNU43S0YEE49655 T/L1 F T/WD T/CA T/E A1 T/DE T/WA 21-JUL-2000 25-AUG-2000 111553 USA 8 5K04 040402 * ALBAL * N25 D9 8696
AWS Claim Key: 7569424 Trx Code: 1 Labor Hrs: 1.9
Dlr Cd-Sub Cd: 01531 - * Name: GRANITE FORD Ph: 603-3322585 St:NH Ctry Cd: USA Reg Cd: NA Repr Date:06-APR-2001 Doc #:02356401
Cust Comments: CUST STATE SHE HAS A VIBRATION SSINCE TIRES WEREW ROTATED
Tech Comments: ROAD TESTED VEH, FOR VIBRATION, FOUND THE TIRES OUT OF BALANCE REBALANCED ALL TIRES
1FMNU43S0YEE49655 T/L1 F T/WD T/CA T/E A1 T/DE T/WA 21-JUL-2000 25-AUG-2000 111553 USA 9 5V01 050301 F81Z 1125 DA N27 14 9224
AWS Claim Key: 8043230 Trx Code: 1 Labor Hrs: 1.7
Dlr Cd-Sub Cd: 01531 - * Name: GRANITE FORD Ph: 603-3322585 St:NH Ctry Cd: USA Reg Cd: NA Repr Date:30-APR-2001 Doc #:02427501
Cust Comments: FEEL VIBRATION OVER 30 MPH AND UP THIRD TIME IN,GETS WORSE WHEN BRAKING TO SLOW
Tech Comments: BRAKE ROTORS OUT OF ROUND ROAD TEST, CHECKED FOUR BRAKE ROTORS, REPLACED FRONT AND REAR BRAKE ROTORS, BLEED SYSTEM. ROAD TEST OK
1FMNU43S0YEE49655 T/L1 F T/WD T/CA T/E A1 T/DE T/WA 21-JUL-2000 25-AUG-2000 111553 USA 13 * * * * * * * 13510
AWS Claim Key: 11145279 Trx Code: 01S24 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 01531 - * Name: GRANITE FORD Ph: 603-3322585 St:NH Ctry Cd: USA Reg Cd: NA Repr Date:13-SEP-2001 Doc #:02795002
Cust Comments: RECALL 01S24 WIPER COVER
Tech Comments: COMPLETED RECALL
1FMNU43S0YEE49655 T/L1 F T/WD T/CA T/E A1 T/DE T/WA 21-JUL-2000 25-AUG-2000 111553 USA 13 5V01 050301 F81Z 1125 DA N27 14 13510
AWS Claim Key: 11145278 Trx Code: E84 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 01531 - * Name: GRANITE FORD Ph: 603-3322585 St:NH Ctry Cd: USA Reg Cd: NA Repr Date:13-SEP-2001 Doc #:02795003
Cust Comments: FEEL VIBRATION ON HIGHWAY 50 TO 75 AND WHEN START BRAKING YOU FEEL IT IN STEERING WHEEL
Tech Comments: VERIFY CONCERN ROTORS ARE OUT BY MEASURMNETS REPLACED ROTORS
1FMNU43S0YEE49655 T/L1 F T/WD T/CA T/E A1 T/DE T/WA 21-JUL-2000 25-AUG-2000 111553 USA 20 6D06 011003 * 7863804 * S06 33 21239
AWS Claim Key: 15452357 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 01531 - * Name: GRANITE FORD Ph: 603-3322585 St:NH Ctry Cd: USA Reg Cd: NA Repr Date:03-APR-2002 Doc #:03288103
Cust Comments: C S PASS MIDDLE SEAT STRAP TO PULL UP SEAT IS LOOSE PLS REPAIR
Tech Comments: LOOSE STRAP VERIFIED ABOVE CONCERN, REPAIRED AND TIGHTENED STRAP OK NOW
1FMNU43S0YEE49655 T/L1 F T/WD T/CA T/E A1 T/DE T/WA 21-JUL-2000 25-AUG-2000 111553 USA 20 5V01 050301 F81Z 1125 DA N27 14 21490
AWS Claim Key: 15792518 Trx Code: E84 Labor Hrs: 4.3
Dlr Cd-Sub Cd: 01531 - * Name: GRANITE FORD Ph: 603-3322585 St:NH Ctry Cd: USA Reg Cd: NA Repr Date:16-APR-2002 Doc #:03316101
Cust Comments: C S WHEN SLOWING DOWN FROM 70 TO 30 MPH IN THAT RANGE YOU FEEL A BRAKE PULSATION AND IT SHAKES THE CAR
Tech Comments: ROAD TESTED AND VERIFY CONCERN RECOMMEND REPLACING FRONT AND REAR ROTORS WHEN ROTORS HEAT UP THEY WORP OUT REPLACED ALL ROTORS AND CLEANED AND LUBRICATED CALIPER SLIDES ROAD TESTS OKA
1FMNU43S0YEE49655 T/L1 F T/WD T/CA T/E A1 T/DE T/WA 21-JUL-2000 25-AUG-2000 111553 USA 33 5V01 060301 * 1125 * N27 13 30618
AWS Claim Key: 20561418 Trx Code: E84 Labor Hrs: 2.7
Dlr Cd-Sub Cd: 01531 - * Name: GRANITE FORD Ph: 603-3322585 St:NH Ctry Cd: USA Reg Cd: NA Repr Date:29-APR-2003 Doc #:04199403
Cust Comments: CUSTOMER STATES VIBRATION WHEN BRAKING
Tech Comments: VERIFY THE FRONT AND REAR BRAKES PULSTAE MACHINED THE FRONTS AND REAR ROTORS AND ROAD TESTED AND IS OKAY NOW
1FMNU43S0YEE49655 T/L1 F T/WD T/CA T/E A1 T/DE T/WA 21-JUL-2000 25-AUG-2000 111553 USA 33 5N01 110301 F81Z 3E651 DA C50 D8 30618
AWS Claim Key: 20561417 Trx Code: E84 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 01531 - * Name: GRANITE FORD Ph: 603-3322585 St:NH Ctry Cd: USA Reg Cd: NA Repr Date:29-APR-2003 Doc #:04199404
Cust Comments: CUSTOMER STATES STEERING DAMPENER LEAKING FLUID
Tech Comments: THE DAMPNER IS LEAKING FLUID REPLACED THE STEERING DAMPNER
1FMNU43S0YEE49655 T/L1 F T/WD T/CA T/E A1 T/DE T/WA 21-JUL-2000 25-AUG-2000 111553 USA 44 5K06 * * * * * * 38159
AWS Claim Key: 22533653 Trx Code: 04B14 Labor Hrs: 2.2
Dlr Cd-Sub Cd: 08926 - * Name: FRAMINGHAM FORD Ph: 508-8791320 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:18-MAR-2004 Doc #:18100701
Cust Comments: FIRESTONE TIRE RECALL
Tech Comments: TIRE RECALL, OLD TIRES VNW81X02700,VNW81XO2700, VNW81X02700,VNW81X02700,VNW81X02700. NEW TIRES
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
post #3 of 3 (permalink) Old 08-01-2006, 02:56 AM Thread Starter
thanks Squatch
