Oasis Report - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 1QKBRD, this thread has received 2 replies and been viewed 504 times.
post #1 of 3 (permalink) Old 08-09-2006, 12:25 AM Thread Starter
Oasis Report
could i please get a report on my truck thank you in advance.
Vin
1FTNW21F32EA25435
wARREN
[COLOR="DarkRed"]2002 7.3 Super Duty CC Lariat 4x4, Toreador redSOLD
DP Tuner- Stock, 80HP Econo, 80 tow, 120 fun
ITP OB
Triple A-pillar Gauges
4" Stainless
4" Aero Turbine Stainless Muffler
Cold air(air raid)
ZooDad
:Thumbup:
1QKBRD is offline
post #2 of 3 (permalink) Old 08-11-2006, 03:24 AM
Squatch's Avatar
OASIS RESULT:
1FTNW21F32EA25435
08/10/2006
22:23:46
© Copyright 2002-2006 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2002 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
7.3L TURBO - DI
TRANSMISSION
4R100 4SP (DIESEL) AXLE CODE
ENGINE CALIBRATION
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
09/29/2001 BUILD DATE
08/14/2001 SALE MILEAGE
ARN MESSAGES
BEFORE REPLACING DIESEL HIGH PRESSURE PUMP (-9A543-) SEE TSB 04-04-04
BEFORE REPLACING 7.3L DIESEL TURBO PEDESTALS (-6N639-) SEE TSB 04-20-02
WARNING MESSAGES
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
10/03/2005
DEALER: Earnhardt Ford Sales Company
WARRANTY CLAIM NUMBER: 903683 ODOMETER: 084221M
LABOR OP
CONDITION CODE
CONDITION DESC
F81Z 6K682BARM TURBO CHG-EXH DRIVE 001 042002A D8 FAILED GASKET/SEAL
OSP 002
2C3Z 9P466AB O-RING KIT 001
1C3Z 6C640LA CONNECTION A/C DUCT 002
YC3Z 6C640PA CONNECTION A/C DUCT 002
1C3Z 6K786CA CLAMP AIR COOLING 004
84228 CC42 9P466 6C640 ADD OIL DIE AND TEST DRIVE AND CHECK FOR OIL LEAKS WI TH BLACK LIGHT REMOVE HOT AND COLD SIDE INTERCOOLER TUBE AND AND REPLACE H OT AND COLD ENDS . AND PERFORM TSB 04-20-2 REPLACE THE EXHAUST BACK PRESSURE EBP SEAL INCLUDES TIME TO REMOVE AND INSTALL TURBO . CLEAN ENGINE AND TEST DRIVE AND RECK FOR LEAKS NO LEAKS AT THIS TIME
END OF OASIS REPORT FOR 1FTNW21F32EA25435
Standard Claims List For Model Year 2002
1FTNW21F32EA25435 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 14-AUG-2001 29-SEP-2001 171175 USA 18 5V07 060704 2C3Z 2005 BB H20 42 26163
AWS Claim Key: 4874729 Trx Code: E84 Labor Hrs: 1.9
Dlr Cd-Sub Cd: 03789 - * Name: SUPERSTITION FORD, INC. Ph: 480-4742500 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:06-MAR-2003 Doc #:113929A
Cust Comments: C S THAT INTERMIT THAT ON A REGULAR STOP THAT THE PEDAL CAVATES CHECK AND ADVISE
Tech Comments: 26195 TEST DRIVE FOR BRAKE CONCEREN . FOUND ON FRIST HIT OF BRAKE PEDEL PEDEL KICLKS BACK INSPECT BRAKE SYS ALL OK CALL FORD HOT LINE TALKED TO LYOD CONTACT #3CGBP017 WAS OKED TO INSTALL NEW HYDROBOOST UNIT . INSTALL NEW HYDROBOOST BLEED SYSTEM REROAD TEST PEDEL STILL KICKS BACK DON H CALLED PAUL BERARDI FOR ANNY MORE INFO CAN NOT GET ANNY AT THIS TIME CONDITION
1FTNW21F32EA25435 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 14-AUG-2001 29-SEP-2001 171175 USA 18 6H06 011108 * 5423209 * G07 42 26163
AWS Claim Key: 4874730 Trx Code: E84 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 03789 - * Name: SUPERSTITION FORD, INC. Ph: 480-4742500 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:06-MAR-2003 Doc #:113929C
Cust Comments: C S THAT LEFT FRONT WINDOW STICKS SHUDDERS WHEN GOING DOWN CHECK AND ADVISE
Tech Comments: 26168 DRIVERS POWER WINDOW RUN VERIFIED THAT THE DRIVERS POWER WINDOW SHUTTERS. ACCESSED DRIVERS DOOR PANEL. CLEANED AND LUBED DRIVERS POWER WINDOW RUN AND REGULATOR. FUNCTION TEST PASS. S A CONFIRMED REPAIR.
1FTNW21F32EA25435 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 14-AUG-2001 29-SEP-2001 171175 USA 18 5I01 110204 F1TZ 3A674 DBRM N58 42 26163
AWS Claim Key: 4874731 Trx Code: E84 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 03789 - * Name: SUPERSTITION FORD, INC. Ph: 480-4742500 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:06-MAR-2003 Doc #:113929E
Cust Comments: C S THAT THE POWER STEERING MAKES A HIGH PITCH WHINING NOISE CHECK AND ADVISE
Tech Comments: 26175 TEST DRIVE FOR P S NOISE FOUND P.S PUMP VARRY NOISEY USE ELECTRINIC EARS TO VARIFY NOISE CONCERN REMOVE AND REPLACE P S PUMP AND REFILL FLUID TEST DRIVE ALL OK CONDITION CODE 42 MILES IN 26168 MILES OUT 26175
1FTNW21F32EA25435 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 14-AUG-2001 29-SEP-2001 171175 USA 49 2H01 030008 2C3Z 9P466 AB L65 D8 84221
AWS Claim Key: 14404375 Trx Code: E72 Labor Hrs: 2.3
Dlr Cd-Sub Cd: 03786 - * Name: EARNHARDT FORD SALES COMPANY Ph: 480-8930000 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:03-OCT-2005 Doc #:903683A
Cust Comments: CUST STATES VEH STILL LEAKING OIL. ALSO HAS LOUD SQUEAL AT HIGH RPMS FROM ENG COMP. STILL BLOWS SMOKE IN AM. PLS CHK AND ADV.
Tech Comments: 84228 CC42 9P466 6C640 ADD OIL DIE AND TEST DRIVE AND CHECK FOR OIL LEAKS WITH BLACK LIGHT REMOVE HOT AND COLD SIDE INTERCOOLER TUBE AND AND REPLACE HOT AND COLD ENDS . AND PERFORM TSB 04 20 2 REPLACE THE EXHAUST BACK PRESSURE EBP SEAL INCLUDES TIME TO REMOVE AND INSTALL TURBO . CLEAN ENGINE AND TEST DRIVE AND RECK FOR LEAKS NO LEAKS AT THIS TIME
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
post #3 of 3 (permalink) Old 08-11-2006, 04:26 AM Thread Starter
Thank you again looks like it's had some work.
ITP OB
4" Stainless
Cold air(air raid)
ZooDad
:Thumbup:
1QKBRD is offline
