Oasis Report Please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by OBAF, this thread has received 1 replies and been viewed 434 times.
post #1 of 2 (permalink) Old 08-09-2006, 03:20 AM Thread Starter
Oasis Report Please
Oasis please vin#1ftsw21px5eb03600 Thank's
OBAF is offline
post #2 of 2 (permalink) Old 08-11-2006, 03:17 AM
Squatch's Avatar
OASIS RESULT:
1FTSW21PX5EB03600
08/10/2006
22:16:43
© Copyright 2002-2006 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
10/19/2004 BUILD DATE
10/13/2004 SALE MILEAGE
ARN MESSAGES
BEFORE REPLACING HIGH PRESS. PUMP FOR HARD START OR OIL LEAK, SEE TSB 06-14-06
BEFORE ADDRESSING VEHICLE VIBRATION CONCERNS, SEE TSB 05-26-24
BEFORE REPLACING FS-10 A/C COMPRESSOR (19703), PLEASE SEE TSB 06-04-09
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL CONTACT
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
07/17/2006
DEALER: Ramey Ford Lincoln Mercury
WARRANTY CLAIM NUMBER: 103188 ODOMETER: 008754M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6N640AA GASKET TURBO TO MANI 001 6646AC 42 DOES NOT OPERATE PROPERLY
4C3Z 6K854BA PIPE (TURBO INLET LO 001 9438A2
W300006 002 MT9438
W301640 002
W300051 002
W300051 002
3C3Z 9433BE GASKET SET-MANIFOLD 001
3C3Z 9E933AA GSKT-EGR TO-TH-BDY 001
6C3Z 6C640A CONNECTION A/C DUCT 001
VERIFIED THAT TRUCK HAD A LOUD WHISTLING NOISE CALLED HOTLIN E SAID TO SMOKE SYS PERFORM SMOKE TEST SMOKE COMING FROM RIG HT SIDE DOWN TURBO REMOVED TUR BO AND EXHAUST REPLACED DOWN TUBE TURBO REINSTALLED TURBO RETESTED OK
06/07/2006
WARRANTY CLAIM NUMBER: 101404 ODOMETER: 008502M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6K775AA COOLER ASSY 001 6005F 42 DOES NOT OPERATE PROPERLY
4C3Z 6K682BA TURBO CHG-EXH DRIVE 001 6005F1
000 6005F2
000 6005F8
000 6005F9
000 6005F12
000 6005F13
000 6005F14
000 6005F22
000 6005F23
000 9438A
000 6775A
DIAGNOSIS PERFORM ELECTRONIC ENGINE DIAGNOSTICS INCLUDES MINOR ADJUSTMENT S
06/07/2006
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9J460A SENSOR ASY EGR PR VL 001 05E15G
COMPLETED RECALL
06/07/2006
LABOR OP
CONDITION CODE
CONDITION DESC
000 05B32B
COMPLETED RECALL
06/07/2006
LABOR OP
CONDITION CODE
CONDITION DESC
000 59B01A
COMPLETED RECALL
05/01/2006
WARRANTY CLAIM NUMBER: 099655 ODOMETER: 008397M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9J460A SENSOR ASY EGR PR VL 001 10346AT 42 DOES NOT OPERATE PROPERLY
4C3Z 10346BA ALTERNATOR LESS PULL 001 8146A
3C3Z 10346CA ALTERNATOR LESS PULL 001 9438A
5C3Z 12B637BA WIRING ENG CNTRL SNS 001 14200A1
3C3Z 14305BA WIRING ASY ALT TO RE 001 MT12B637
000 12650D9
BATTERY LIGHT ON VERIFIED THAT BATTERY LIGHT COMES ON PERFORM PIN POINT T EST PF1-PF8 NO HELP CALLED HOTLINE ADVISED TO REPLACE PRIMARY AL T NO HELP C ALLED HOTLINE BACK ADVISED TO CK OVERLAY WIRE FRO M PCM INST. CLUSTER NO HEL P CALLED BACK SAID TO REPLACE ALT LOWER SIDE NO HELP CALLED BACK SAID OVERLA Y WIRE C 1751 TO C 138 ALT NO HELP CALLED BACK CK VOLTAGE DROP FROM B+ TO GR
04/14/2006
WARRANTY CLAIM NUMBER: 098851 ODOMETER: 008248M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6K775AA COOLER ASSY 001 6775A 42 DOES NOT OPERATE PROPERLY
6C3Z 6C646BA DUCT ASY-ENG CHG AIR 001
FOUND SIDE OF INTERCOOLER SEPERATED REPLACED COOLER AND FOUND HOLE IN CAC TUBE REPLACED TUBE CLEARED DTCS
12/05/2005
WARRANTY CLAIM NUMBER: 092773 ODOMETER: 007315M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 6K682AARM TURBO CHG-EXH DRIVE 001 6005F 42 DOES NOT OPERATE PROPERLY
000 6005F13
000 6005F1
000 6005F2
000 6005F14
000 VERIFY60
000 9438A
PERFORM DIAG FOUND TURBO OVER BOOSTING REPLACED TURBO ROAD TEST
END OF OASIS REPORT FOR 1FTSW21PX5EB03600
Standard Claims List For Model Year 2005
1FTSW21PX5EB03600 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 13-OCT-2004 19-OCT-2004 147402 USA 8 1H03 030008 5C3Z 9F452 AA D36 42 3430
AWS Claim Key: 1052397 Trx Code: S07 Labor Hrs: 1
Dlr Cd-Sub Cd: 01903 - * Name: DELIGNE SALES & SERVICE, INC. Ph: 304-6585126 St:WV Ctry Cd: USA Reg Cd: NA Repr Date:26-MAY-2005 Doc #:00803501
Cust Comments: ENGIEN LOOSES PWR. TURBO SEEMS TO DUMP UNDER PRESSURE.
Tech Comments: TEST ENGINE PERF. KOEO KOER INJ. TEST REPLACE EGR VALVE.
1FTSW21PX5EB03600 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 13-OCT-2004 19-OCT-2004 147402 USA 14 2H01 030008 4C3Z 6K682 AARM D42 42 7315
AWS Claim Key: 2790457 Trx Code: S07 Labor Hrs: 3.3
Dlr Cd-Sub Cd: 09051 - * Name: RAMEY FORD LINCOLN MERCURY Ph: 304-2567400 St:WV Ctry Cd: USA Reg Cd: NA Repr Date:05-DEC-2005 Doc #:09277301
Cust Comments: C S DOESNT RUN GOOD WHEN COLD,MISSING AND TURBO WONT KICK
Tech Comments: PERFORM DIAG FOUND TURBO OVER BOOSTING REPLACED TURBO ROAD TEST
1FTSW21PX5EB03600 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 13-OCT-2004 19-OCT-2004 147402 USA 19 2H01 031202 3C3Z 6K775 AA D42 42 8248
AWS Claim Key: 4440134 Trx Code: S07 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 09051 - * Name: RAMEY FORD LINCOLN MERCURY Ph: 304-2567400 St:WV Ctry Cd: USA Reg Cd: NA Repr Date:14-APR-2006 Doc #:09885101
Cust Comments: CS ON COLD START BLACK SMOKE AND WONT HARDLY RUN.
Tech Comments: FOUND SIDE OF INTERCOOLER SEPERATED REPLACED COOLER AND FOUND HOLE IN CAC TUBE REPLACED TUBE CLEARED DTCS
1FTSW21PX5EB03600 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 13-OCT-2004 19-OCT-2004 147402 USA 19 7S06 030008 5C3Z 12B637 BA C26 42 8397
AWS Claim Key: 4823319 Trx Code: S07 Labor Hrs: 8.6
Dlr Cd-Sub Cd: 09051 - * Name: RAMEY FORD LINCOLN MERCURY Ph: 304-2567400 St:WV Ctry Cd: USA Reg Cd: NA Repr Date:01-MAY-2006 Doc #:09965502
Cust Comments: C S BATTERY LIGHT KEEPS COMING ON
Tech Comments: BATTERY LIGHT ON VERIFIED THAT BATTERY LIGHT COMES ON PERFORM PIN POINT TEST PF1 PF8 NO HELP CALLED HOTLINE ADVISED TO REPLACE PRIMARY AL T NO HELP CALLED HOTLINE BACK ADVISED TO CK OVERLAY WIRE FRO M PCM INST. CLUSTER NO HELP CALLED BACK SAID TO REPLACE ALT LOWER SIDE NO HELP CALLED BACK SAID OVERLAY WIRE C 1751 TO C 138 ALT NO HELP CALLED BACK CK VOLTAGE DROP FROM B+ TO GRO
1FTSW21PX5EB03600 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 13-OCT-2004 19-OCT-2004 147402 USA 20 2H01 030008 4C3Z 6K682 BA D42 42 8502
AWS Claim Key: 5013598 Trx Code: S07 Labor Hrs: 5.6
Dlr Cd-Sub Cd: 09051 - * Name: RAMEY FORD LINCOLN MERCURY Ph: 304-2567400 St:WV Ctry Cd: USA Reg Cd: NA Repr Date:07-JUN-2006 Doc #:10140401
Cust Comments: CS VEHICLE HAS NO POWER TO PULL HILLS WROTE UP AS PER GARY BLACKBURN.
Tech Comments: DIAGNOSIS PERFORM ELECTRONIC ENGINE DIAGNOSTICS INCLUDES MINOR ADJUSTMENTS
1FTSW21PX5EB03600 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 13-OCT-2004 19-OCT-2004 147402 USA 20 * * * * * * * 8502
AWS Claim Key: 5013597 Trx Code: 05E15 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 09051 - * Name: RAMEY FORD LINCOLN MERCURY Ph: 304-2567400 St:WV Ctry Cd: USA Reg Cd: NA Repr Date:07-JUN-2006 Doc #:10140402
Cust Comments: PERFORM RECALL 05E15
Tech Comments: COMPLETED RECALL
AWS Claim Key: 4999217 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 09051 - * Name: RAMEY FORD LINCOLN MERCURY Ph: 304-2567400 St:WV Ctry Cd: USA Reg Cd: NA Repr Date:07-JUN-2006 Doc #:10140403
Cust Comments: RECALL 05B32
AWS Claim Key: 4999216 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 09051 - * Name: RAMEY FORD LINCOLN MERCURY Ph: 304-2567400 St:WV Ctry Cd: USA Reg Cd: NA Repr Date:07-JUN-2006 Doc #:10140404
Cust Comments: RECALL 59B01
1FTSW21PX5EB03600 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 13-OCT-2004 19-OCT-2004 147402 USA 22 2H01 030008 4C3Z 6K854 BA N12 42 8754
AWS Claim Key: 5452853 Trx Code: E91 Labor Hrs: 2.7
Dlr Cd-Sub Cd: 09051 - * Name: RAMEY FORD LINCOLN MERCURY Ph: 304-2567400 St:WV Ctry Cd: USA Reg Cd: NA Repr Date:17-JUL-2006 Doc #:10318801
Cust Comments: CS HAS A LOUD WHISTLING NOISE WHEN GO TO GIVE IT A LITTLE GAS.
Tech Comments: VERIFIED THAT TRUCK HAD A LOUD WHISTLING NOISE CALLED HOTLIN E SAID TO SMOKE SYS PERFORM SMOKE TEST SMOKE COMING FROM RIG HT SIDE DOWN TURBO REMOVED TURBO AND EXHAUST REPLACED DOWN TUBE TURBO REINSTALLED TURBO RETESTED OK
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
