Oasis Report Please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by hydromatikman, this thread has received 1 replies and been viewed 1257 times.
post #1 of 2 (permalink) Old 08-09-2006, 06:37 PM Thread Starter
Oasis Report Please
1FTSW31P24EC16915
Thanks
hydromatikman is offline
post #2 of 2 (permalink) Old 08-11-2006, 03:20 AM
Squatch's Avatar
OASIS RESULT:
1FTSW31P24EC16915
08/10/2006
22:19:48
© Copyright 2002-2006 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
D1 ENGINE CALIBRATION
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
03/23/2004 BUILD DATE
01/23/2004 SALE MILEAGE
00036
ARN MESSAGES
BEFORE ADDRESSING VEHICLE VIBRATION CONCERNS, SEE TSB 05-26-24
BEFORE REPLACING FS-10 A/C COMPRESSOR (19703), PLEASE SEE TSB 06-04-09
WARNING MESSAGES
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
02/03/2006
DEALER: Henry Day Ford, Inc.
WARRANTY CLAIM NUMBER: 785345 ODOMETER: 023074M
LABOR OP
CONDITION CODE
CONDITION DESC
4C2Z 12A690AB WIRING ASY EC SENSOR 001 6007D D8 FAILED GASKET/SEAL
4C2Z 12A690BA WIRING ASY EC SENSOR 001 6584AT
5C3Z 6C640AA CONNECTION A/C DUCT 001 6646AC
D8 12A650 1764 BLACKLIGHT TEST FOR OIL LEAK. REPLACE LEAKING GLOW PLUG HARNE SS, LEFT AND RIGHT SIDE. REPLACE TORN CAC TUBE CONNECTOR 6C640, AT TURBO.
01/26/2006
DEALER: Butterfield Ford
WARRANTY CLAIM NUMBER: 132659 ODOMETER: 022696M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9J460A SENSOR ASY EGR PR VL 001 05E15F
5C3Z 12224A 3 WAY VACUUM CONNECT 001
22696 REPLACE EBP SNSOR AND EBP CONNECTOR PER RECALL RECALIBRATE PCM, TCM, AND FICM TEST DRIVE OK AT THIS TIME
01/26/2006
LABOR OP
CONDITION CODE
CONDITION DESC
000 59B01A
22696 TEST DROVE VERIFIED RECALL OK AT THIS TIME
01/26/2006
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 2561203AAB SEAT BELT BUCKLE END 001 MT61203 42 DOES NOT OPERATE PROPERLY
22696 BAD SEAT BELT BUCKLE R&I DRIVERS SEAT TO REPLACE SEATBELT BUCLE AND R ETEST ALL OPERS NORMAL
01/26/2006
LABOR OP
CONDITION CODE
CONDITION DESC
F4CZ 13466A SMALL BULBS 001 13465A 42 DOES NOT OPERATE PROPERLY
22696 BURNT OUT BULB TEST PWR AND GND CIR OK REPLACED BULB AND RE TEST ALL OPERS NORMAL R&I RT REAR TAIL LITE ASSEMBLY FOR ACCESS
08/03/2005
WARRANTY CLAIM NUMBER: 120467 ODOMETER: 018085M
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 6C640AA CONNECTION A/C DUCT 001 05B29B
18085 RECALL REPLACED CAC TUBE
08/03/2005
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 12224A 3 WAY VACUUM CONNECT 001 05S34F
4C3Z 14A099A SHIELD WIRING 001
18085 RECALL INSPECT WIREING INSTALL REPAIR KIT AND REPLACED ICP CONNECTOR 05S34F 1.3
08/03/2005
LABOR OP
CONDITION CODE
CONDITION DESC
000 59B01A
18085 RECALL ROADTEST FOR CUST ASSURANCE
08/03/2005
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9J460A SENSOR ASY EGR PR VL 001 12650D81 42 DOES NOT OPERATE PROPERLY
000 12650D9
000 12650D84
000 6005F
000 6005E2
000 6005E3
000 6005F1
000 6005F2
000 6005F8
000 6005F20
18085 EBP SENSOR EEC TEST KOEO PASS CMDTCS P0299 TURBO UNDER BOOST KOER PAS S KOEO INJECTOR ELECT. TEST PASS PID MONITOR TEST EGR AND EBP ICP FOUND EB P OUT OF SPEC REPLACED EBP AND PRFORM LOW IDLE STUB- ILTY TE3ST VERIFIED 6. 0L REPAIR REPROGRAM PCM FICUM AND TCM FILL OUT DIAG. SHEET
END OF OASIS REPORT FOR 1FTSW31P24EC16915
Standard Claims List For Model Year 2004
1FTSW31P24EC16915 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 23-JAN-2004 23-MAR-2004 156025 USA 11 2G05 031405 * RECAL * D50 42 12548
AWS Claim Key: 3512036 Trx Code: E84 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 08404 - * Name: BUTTERFIELD FORD Ph: 801-5662441 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:27-JAN-2005 Doc #:106125A
Cust Comments: CUSTOMER STATES MISFIRED AT HARD TAKE OFF, INTERMITTENT
Tech Comments: 12548 TEST DRIVE, PREFROM WDS SELF TESTS, NO CODES TEST DRIVE AND PID MONITOR CK FOR BIASED SENSO R READINGS, ALL GOOD. REPROGRAM PCM W UPDATED CALIBRATION. 4U7A 12A650 BFD. CLEAR CODES AND AND RETEST OK
1FTSW31P24EC16915 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 23-JAN-2004 23-MAR-2004 156025 USA 17 2H01 * * * * * * 18085
AWS Claim Key: 6332230 Trx Code: 05B29 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 08404 - * Name: BUTTERFIELD FORD Ph: 801-5662441 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:03-AUG-2005 Doc #:120467A
Cust Comments: RECALL #05B29, CHARGE AIR COOLER REPLACEMENT
Tech Comments: 18085 RECALL REPLACED CAC TUBE
1FTSW31P24EC16915 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 23-JAN-2004 23-MAR-2004 156025 USA 17 * * * * * * * 18085
AWS Claim Key: 6332231 Trx Code: 05S34 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 08404 - * Name: BUTTERFIELD FORD Ph: 801-5662441 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:03-AUG-2005 Doc #:120467B
Cust Comments: RECALL #05S34, FUEL INJECTOR WIRING HARNESS
Tech Comments: 18085 RECALL INSPECT WIREING INSTALL REPAIR KIT AND REPLACED ICP CONNECTOR 05S34F 1.3
AWS Claim Key: 6332232 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 08404 - * Name: BUTTERFIELD FORD Ph: 801-5662441 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:03-AUG-2005 Doc #:120467C
Cust Comments: RECALL #59B01, TEST DRIVE
Tech Comments: 18085 RECALL ROADTEST FOR CUST ASSURANCE
1FTSW31P24EC16915 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 23-JAN-2004 23-MAR-2004 156025 USA 17 1H03 030008 4C3Z 9J460 A D50 42 18085
AWS Claim Key: 6359437 Trx Code: S07 Labor Hrs: 2.7
Dlr Cd-Sub Cd: 08404 - * Name: BUTTERFIELD FORD Ph: 801-5662441 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:03-AUG-2005 Doc #:120467D
Cust Comments: LACKS POWER WHEN TOWING AND ACCELERATING FROM A STOP, CUST STS
Tech Comments: 18085 EBP SENSOR EEC TEST KOEO PASS CMDTCS P0299 TURBO UNDER BOOST KOER PASS KOEO INJECTOR ELECT. TEST PASS PID MONITOR TEST EGR AND EBP ICP FOUND EBP OUT OF SPEC REPLACED EBP AND PRFORM LOW IDLE STUB ILTY TE3ST VERIFIED 6.0L REPAIR REPROGRAM PCM FICUM AND TCM FILL OUT DIAG. SHEET
1FTSW31P24EC16915 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 23-JAN-2004 23-MAR-2004 156025 USA 23 * * * * * * * 22696
AWS Claim Key: 8413813 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 08404 - * Name: BUTTERFIELD FORD Ph: 801-5662441 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:26-JAN-2006 Doc #:132659A
Cust Comments: RECALL 05E15 EBP SENSOR
Tech Comments: 22696 REPLACE EBP SNSOR AND EBP CONNECTOR PER RECALL RECALIBRATE PCM, TCM, AND FICM TEST DRIVE OK AT THIS TIME
AWS Claim Key: 8413814 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 08404 - * Name: BUTTERFIELD FORD Ph: 801-5662441 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:26-JAN-2006 Doc #:132659B
Cust Comments: RECALL 59B01 TEST DRIVE
Tech Comments: 22696 TEST DROVE VERIFIED RECALL OK AT THIS TIME
1FTSW31P24EC16915 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 23-JAN-2004 23-MAR-2004 156025 USA 23 6R01 01XXXX 5C3Z 2561203 AAB S26 42 22696
AWS Claim Key: 8413815 Trx Code: E84 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 08404 - * Name: BUTTERFIELD FORD Ph: 801-5662441 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:26-JAN-2006 Doc #:132659C
Cust Comments: DRIVERS SEAT BUCKLE DOES NOT LATCH CUST STS
Tech Comments: 22696 BAD SEAT BELT BUCKLE R&I DRIVERS SEAT TO REPLACE SEATBELT BUCLE AND RETEST ALL OPERS NORMAL
1FTSW31P24EC16915 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 23-JAN-2004 23-MAR-2004 156025 USA 23 7D07 17XXXX F4CZ 13466 A L26 42 22696
AWS Claim Key: 8413816 Trx Code: E83 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 08404 - * Name: BUTTERFIELD FORD Ph: 801-5662441 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:26-JAN-2006 Doc #:132659I
Cust Comments: UPON STATE INSPECTION FOUND RIGHT REAR BRAKE LIGHT OUT
Tech Comments: 22696 BURNT OUT BULB TEST PWR AND GND CIR OK REPLACED BULB AND RE TEST ALL OPERS NORMAL R&I RT REAR TAIL LITE ASSEMBLY FOR ACCESS
1FTSW31P24EC16915 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 23-JAN-2004 23-MAR-2004 156025 USA 23 2G02 030008 4C2Z 12A690 AB L65 D8 23074
AWS Claim Key: 8512743 Trx Code: S07 Labor Hrs: 3.5
Dlr Cd-Sub Cd: 03030 - * Name: HENRY DAY FORD, INC. Ph: 801-9737030 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:03-FEB-2006 Doc #:78534504
Cust Comments: ENGINE IS LEAKING OIL
Tech Comments: D8 12A650 1764 BLACKLIGHT TEST FOR OIL LEAK. REPLACE LEAKING GLOW PLUG HARNESS, LEFT AND RIGHT SIDE. REPLACE TORN CAC TUBE CONNECTOR 6C640, AT TURBO.
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
