Report Please. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Rocky, this thread has received 1 replies and been viewed 470 times.
post #1 of 2 (permalink) Old 08-23-2006, 01:58 AM Thread Starter
Report Please.
1FTNW21P44EC82681 Thank you very much.
Rocky is offline
post #2 of 2 (permalink) Old 08-23-2006, 03:54 AM
Squatch's Avatar
OASIS RESULT:
1FTNW21P44EC82681
08/22/2006
22:54:05
© Copyright 2002-2006 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
04/05/2004 BUILD DATE
03/10/2004 SALE MILEAGE
00021
ARN MESSAGES
BEFORE ADDRESSING VEHICLE VIBRATION CONCERNS, SEE TSB 05-26-24
WARNING MESSAGES
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
01/24/2006
DEALER: Berge Ford
WARRANTY CLAIM NUMBER: 376865 ODOMETER: 070818M
LABOR OP
CONDITION CODE
CONDITION DESC
XO 15W40QSD 001 6007D D1 POROSITY
OSP 003 VERIFY60
3C3Z 6701AA CRANKSHAFT REAR SEAL 001 7000A
3C3Z 6D083AA GASKET-RR COVER 001 MTREARCVR
4C2Z 12A690AB WIRING ASY EC SENSOR 001 MTGPHRNS
.5-2.6ST GP 3.0-4.0 VERIFY CONCERN. INSTALL DYE. FIND LEAKING AT REAR COVE R ADN PASS SIDE GLOW PLUG HARNESS. REMOVE TRANS AND INSTALL NEW REAR COVER A DN SEAL. RUN 1.0 FOR REAR SEAL. RUN 1.9 ST FOR GLOW PLUG HARNESS. CLEAN AND TEST DRIVE FOR 10 MILES FOUND NO MORE DRIPPING.
11/04/2005
DEALER: Berge Ford
WARRANTY CLAIM NUMBER: 364538 ODOMETER: 067501M
LABOR OP
CONDITION CODE
CONDITION DESC
OSP 003 6642A
5C3Z 6C640AA CONNECTION A/C DUCT 001 6646AH
6C2Z 6K786AA CLAMP AIR COOLING 002 MTCACUPPER
3C3Z 9433BE GASKET SET-MANIFOLD 001 MTTURBOBOLT
3C3Z 6619BA GASKET (OIL PUMP) 001 MTGROUND
3C3Z 6619CA GASKET (OIL PUMP) 001 6731A
3C3Z 6A831AA GSKT-OIL FLTR ELEM S 001
OSP 003
3C3Z 6731AA ELEMENT ASY OIL FILT 001
XO 15W405QSD 003
3C3Z 6766BA CAP ASY OIL FILLER 001
INSTALL DYE FIND LEAKING AT CAC TUBE. INSTALL NEW UPPER CAC TUBE. RAN .4 ST FOR THAT. RECHECK LEAKING AT OIL COOLER. WHILE REMOVEING TURBO BOLT STRIPPED RAN 1.7ST TO GET OUT BOL T. ALSO FOUND INJ HARNESS GROUND BROKE. RAN .5 ST TO INSTALL NEW ILET. INSTALL NEW COOLER SEALS FOUND NO MORE LEAKS AT TH IS T IME. OIL GOT CONTAMINATED WHILE PERFORMING REPAIR PERFOR
11/04/2005
DEALER: Berge Ford
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9E527AA NOZZLE ASY-FUEL INJE 001 6005F 42 DOES NOT OPERATE PROPERLY
4C3Z 9E527AA NOZZLE ASY-FUEL INJE 001 6005F1
000 6005F1X1
000 6005F2
000 6005F6
000 6005F8
000 6005F11
000 6005F12
000 6005F14
000 6005F18
000 6005F22
000 6005F23
000 9527AT
000 VERIFY60
000 6005F33
1 TEST DRIVE TO VERIFY. FIND IT STARTS OK. CUSTOMER NEEDS TO FOLLOW MY DI RECTIONS FROM LAST RO. FOUND IT RUNNING ROUGH HAS LATEST REPROGRAM. CHECK FO R INTAKE AND EXH RESTRICTIONS OK. CHECK FUEL QUALITY PASS 36 CETANE. CHECK I CP 595 PSI IPR 21% OK CHECK FOR OIL AERATION PASS. PERFORM POWER BALANCE FI ND #3 AND #8 MISSING. PERFROM FUEL PRESSURE TEST 52 PSI OK
10/13/2005
DEALER: Berge Ford
WARRANTY CLAIM NUMBER: 360990 ODOMETER: 066548M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 12224A 3 WAY VACUUM CONNECT 001 05E15G
4C3Z 9J460A SENSOR ASY EGR PR VL 001
REPROGRAM AND INSTALL NEW CONNECTOR HAS UPDATED EBP SENSOR
10/13/2005
DEALER: Berge Ford
LABOR OP
CONDITION CODE
CONDITION DESC
000 59B01A
QUALITY ASSURANCE ROAD TEST
END OF OASIS REPORT FOR 1FTNW21P44EC82681
Standard Claims List For Model Year 2004
1FTNW21P44EC82681 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 10-MAR-2004 05-APR-2004 171179 USA 5 2E06 100106 3C3Z 9C407 AB D03 63 19974
AWS Claim Key: 1807950 Trx Code: E84 Labor Hrs: 4.3
Dlr Cd-Sub Cd: 20360 - * Name: BELL FORD Ph: 602-8661776 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:01-SEP-2004 Doc #:16107901
Cust Comments: CHECK SLOW LONG CRANK AFTER VEHICLE HAS BEEN SITTING AFTER D RIVING, WHILE ENGINE IS HOT
Tech Comments: INSP VEHICLE.NO MIL.ROAD TESTED AND LET HOT SOAK.VERIFIED LONG CRANK BEFORE STARTING.SCAN PCM.KOEO PASS,KOEC PASS,KOEO INJ TEST PASS,KOER PASS,LO IDLE TEST PASS,BOOST TEST PASS,EXHAUST RESTRICTION TEST PASS,FUEL QUALITY OK,FUEL PSI PASSES WHEN COLD BUT IS SLOW TO BUILD PSI WHEN WARM.REPL FUEL FILTERS AND RETEST,STILL SLUGGISH,REPLD FUEL PUMP,RETESTED OK.ROAD TEST, HOT SOAK TO VERIFY,NORMAL START.
1FTNW21P44EC82681 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 10-MAR-2004 05-APR-2004 171179 USA 6 2E06 030008 4C3Z 9A543 AARM D03 28 20666
AWS Claim Key: 2032652 Trx Code: E84 Labor Hrs: 19.4
Dlr Cd-Sub Cd: 20360 - * Name: BELL FORD Ph: 602-8661776 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:08-SEP-2004 Doc #:16178101
Cust Comments: CUST STS THE VEHICLE HAS A LONG CRANK BEFORE STARTING
Tech Comments: MT9A543 8.4 MULTIPLE HI PSI AIR LEAKS CHECKS AND TEAR DOWN.ROAD TEST,HOT SOAK.WOULDNT RESTART.SCAN PCM.NO DTCS.FUEL PSI OK.GLOW PLUG SYST OK.MONITOR ENG OPS WHILE CRANKING,IPR DEFAULTS AND ICP PSI LOW.SWAP IPR WITH KNOWN GOOD,NO CHANGE.HI PSI AIR CK,FIND LEAK UNDER FRT CVR AT U PIPE OUTLET O RING,REPL PIPE,RETEST NO LEAKS,LO PWR,SLOW START.HI PSI OIL PRESS LOW.REPL HI PSI PUMP,REASSEMBLE,ROAD TEST
1FTNW21P44EC82681 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 10-MAR-2004 05-APR-2004 171179 USA 10 2E06 030008 4C3Z 9F838 AB D13 42 36819
AWS Claim Key: 3317872 Trx Code: E72 Labor Hrs: 4.1
Dlr Cd-Sub Cd: 20360 - * Name: BELL FORD Ph: 602-8661776 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:17-JAN-2005 Doc #:17411701
Cust Comments: CUSTOMER STATES AT TIMES WILL IDLE ROUGH, AND AFTER DRIVING FOR ABOUT 20 OR MORE MILES, CAN FEEL A MISS, THEN WHEN
Tech Comments: TEST 1 18 CONTINIOUS DTC P2285 0299 CLEAR FUEL PSI AT 65 INSPECT LOOMS WIGGLE ICP CONNECTOR ENGINE WOULD FLARE, REPL CONNECTOR ENGINE AND ICP, RETEST PASS, WDS COMMAND VGT, NO TURBO PITCH CHANGE REPL VGT , RETEST PASS, REPROGRAM PCM TO LATEST LEVEL PER SSM 17048
1FTNW21P44EC82681 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 10-MAR-2004 05-APR-2004 171179 USA 15 1H03 030008 4C3Z 9J460 A D41 42 55045
AWS Claim Key: 5647709 Trx Code: E72 Labor Hrs: 3.7
Dlr Cd-Sub Cd: 20305 - * Name: BERGE FORD Ph: 480-4971111 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:13-JUN-2005 Doc #:34007801
Cust Comments: C S ENGINE SPITS AND SPUTTERS AT TIMES ABOVE 60 70MPH WHILE DRIVING BLACK SMOKE FROM EXHAUST WHEN THIS HAPPENS
Tech Comments: FAILED EBP SENSOR AND STICKING EGR VALVE CC 42 BP 9J460 VERIFIED SURGE AT CRUISE AND BLACK SMOKE AT TIMES PERFORMED DIESEL DIAG STEPS 1 7 AND 11.VISUAL INSPECTION OK,CLEAN FUEL OK,ENGINE OIL LEVEL OK,KOEO PASS,CONTINUOUS CODES P0404 EGR VALVE PERFORMANCE FAULT,KOEO INJECTOR SELF TEST PASS,INTAKE RESTRICTION 2,KOER PASS.CLEARED CODES AND ROAD TEST WHILE MONITORING PIDS FOUND THAT WHEN CONCERN WAS
1FTNW21P44EC82681 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 10-MAR-2004 05-APR-2004 171179 USA 15 2H01 * * * * * * 55045
AWS Claim Key: 5647708 Trx Code: 05B29 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 20305 - * Name: BERGE FORD Ph: 480-4971111 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:13-JUN-2005 Doc #:34007802
Cust Comments: 05B29 RECALL
Tech Comments: PERFORMED RECALL 05B29 REPLACED COLD SIDE CAC TUBE
1FTNW21P44EC82681 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 10-MAR-2004 05-APR-2004 171179 USA 15 * * * * * * * 55045
AWS Claim Key: 5647707 Trx Code: 05S34 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 20305 - * Name: BERGE FORD Ph: 480-4971111 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:13-JUN-2005 Doc #:34007803
Cust Comments: 05S34 RECALL
Tech Comments: PERFORMED RECALL 05S34,INSPECTED FICM HARNESS FOR CHAFES, NONE FOUND INSTALLED PROTECTIVE REPAIR KIT AND REPLACED ICP CONNECTOR REPAIR KIT.ROAD TEST AFTER REPAIRS ALL OK.
1FTNW21P44EC82681 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 10-MAR-2004 05-APR-2004 171179 USA 15 3A03 * * * * * * 55045
AWS Claim Key: 5647706 Trx Code: 04B24 Labor Hrs: 11.6
Dlr Cd-Sub Cd: 20305 - * Name: BERGE FORD Ph: 480-4971111 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:13-JUN-2005 Doc #:34007804
Cust Comments: 04B24 RECALL
Tech Comments: RECALL R&R TRANS AND REPLACE PARTS AS PER RECALL 04B24 REFILL AND ROAD TEST, OK.
1FTNW21P44EC82681 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 10-MAR-2004 05-APR-2004 171179 USA 19 * * * * * * * 66548
AWS Claim Key: 7321669 Trx Code: 05E15 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 20305 - * Name: BERGE FORD Ph: 480-4971111 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:13-OCT-2005 Doc #:36099005
Cust Comments: RECALL #05E15 EXH. PRESSURE SENS.
Tech Comments: REPROGRAM AND INSTALL NEW CONNECTOR HAS UPDATED EBP SENSOR
AWS Claim Key: 7321668 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 20305 - * Name: BERGE FORD Ph: 480-4971111 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:13-OCT-2005 Doc #:36099006
Cust Comments: RECALL # 59B01 ROAD TEST
Tech Comments: QUALITY ASSURANCE ROAD TEST
1FTNW21P44EC82681 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 10-MAR-2004 05-APR-2004 171179 USA 20 2H01 031202 5C3Z 6C640 AA L65 D1 67501
AWS Claim Key: 7673400 Trx Code: E72 Labor Hrs: 9
Dlr Cd-Sub Cd: 20305 - * Name: BERGE FORD Ph: 480-4971111 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:04-NOV-2005 Doc #:36453801
Cust Comments: C S CHECK OIL LEAK UNDER VEH.
Tech Comments: INSTALL DYE FIND LEAKING AT CAC TUBE. INSTALL NEW UPPER CAC TUBE. RAN .4 ST FOR THAT. RECHECK LEAKING AT OIL COOLER. WHILE REMOVEING TURBO BOLT STRIPPED RAN 1.7ST TO GET OUT BOL T. ALSO FOUND INJ HARNESS GROUND BROKE. RAN .5 ST TO INSTALL NEW ILET. INSTALL NEW COOLER SEALS FOUND NO MORE LEAKS AT TH IS TIME. OIL GOT CONTAMINATED WHILE PERFORMING REPAIR PERFOR
1FTNW21P44EC82681 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 10-MAR-2004 05-APR-2004 171179 USA 20 2E06 030008 4C3Z 9E527 AA D13 42 67501
AWS Claim Key: 7658449 Trx Code: E72 Labor Hrs: 7.5
Dlr Cd-Sub Cd: 20305 - * Name: BERGE FORD Ph: 480-4971111 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:04-NOV-2005 Doc #:36453802
Cust Comments: C S CHECK POOR COLD START WITH ROUGH IDLE BEFORE VEHEICLE WARMS UP.
Tech Comments: 1 TEST DRIVE TO VERIFY. FIND IT STARTS OK. CUSTOMER NEEDS TO FOLLOW MY DIRECTIONS FROM LAST RO. FOUND IT RUNNING ROUGH HAS LATEST REPROGRAM. CHECK FOR INTAKE AND EXH RESTRICTIONS OK. CHECK FUEL QUALITY PASS 36 CETANE. CHECK ICP 595 PSI IPR 21% OK CHECK FOR OIL AERATION PASS. PERFORM POWER BALANCE FI ND #3 AND #8 MISSING. PERFROM FUEL PRESSURE TEST 52 PSI OK
1FTNW21P44EC82681 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 10-MAR-2004 05-APR-2004 171179 USA 22 1D01 03XXXX 3C3Z 6701 AA L65 D1 70818
AWS Claim Key: 8417577 Trx Code: E72 Labor Hrs: 8.7
Dlr Cd-Sub Cd: 20305 - * Name: BERGE FORD Ph: 480-4971111 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:24-JAN-2006 Doc #:37686501
Cust Comments: C S ENGINE LEAKING OIL
Tech Comments: .5 2.6ST GP 3.0 4.0 VERIFY CONCERN. INSTALL DYE. FIND LEAKING AT REAR COVER ADN PASS SIDE GLOW PLUG HARNESS. REMOVE TRANS AND INSTALL NEW REAR COVER ADN SEAL. RUN 1.0 FOR REAR SEAL. RUN 1.9 ST FOR GLOW PLUG HARNESS. CLEAN AND TEST DRIVE FOR 10 MILES FOUND NO MORE DRIPPING.
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
