oasis please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by bisket, this thread has received 1 replies and been viewed 342 times.
post #1 of 2 (permalink) Old 09-16-2006, 09:45 PM Thread Starter
oasis please
1ftsw31p13ed81482
bisket is offline
post #2 of 2 (permalink) Old 09-18-2006, 04:35 AM
Squatch's Avatar
OASIS RESULT:
1FTSW31P13ED81482
09/17/2006
23:34:33
© Copyright 2002-2006 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
41 ENGINE CALIBRATION
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
09/13/2003 BUILD DATE
06/26/2003 SALE MILEAGE
WARNING MESSAGES
59B01
ELIGIBLE FOR ONE-TIME CUSTOMER ASSURANCE TEST DRIVE. SEE EMISSIONS RECALL 05E15 OR 06E17 FOR DETAILS.
06E17
CONTROL MODULE RECALIBRATION
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
11/01/2005
DEALER: Tenvoorde Ford, Inc.
WARRANTY CLAIM NUMBER: 253371 ODOMETER: 060147M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6B898AA GASKET OIL RETURN LI 001 9438A 01 BROKEN/CRACKED
W300006 002 9438A2
3C3Z 6K854DA PIPE (TURBO INLET LO 001
3C3Z 6N640AA GASKET TURBO TO MANI 001
W300051 004
W300013 002
N803946SW 003
60147 TEST DROVE AND VERIFIED CONCERN, CHECKED CROSS OVER PIPES BEHIND TURB O AND FOUND THAT THE LH PIPE IS BAD, REMOVED TURBO, REMOVED LH CROSS OVER PIPE AND INBSTALLED NEW ONE, REASSEMBLED AND TEST DROVE OK
08/23/2005
WARRANTY CLAIM NUMBER: 249197 ODOMETER: 055578M
LABOR OP
CONDITION CODE
CONDITION DESC
OSP 001 6007D D8 FAILED GASKET/SEAL
XO 10W30QSD 005 9838A
3C3Z 9F838EA SENSR ASY F/I TIMING 001 6666A
3C3Z 6766BA CAP ASY OIL FILLER 001 14200A
5C3Z 12224A 3 WAY VACUUM CONNECT 001
55578 ADDED DYE TO THE OIL AND PERFORMED A OIL LEAK DIAG, FOUND THAT THE LE AK IS COMING FROM THE HP OIL PUMP AREA, REMOVED AIR BOX ASSY AND REMOVED CO OLANT RESERVOIR, REMOVED FICM TO GAIN ACCESS TO THE BACK OF THE HP OIL PUMP COVER. FOUND T HAT THE ICP SENSOR IS LEAKING, ALSO THE ICP SENSOR WIRING IS SWELLED UP, INSTALLED A NEW ICP SENSOR, SPLICED IN A NEW CONNECTOR PIGTA
08/23/2005
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6750AA INDICATOR ASY OIL LE 001 MT6750 01 BROKEN/CRACKED
55578 ORDERED NEW DIPSTICK
END OF OASIS REPORT FOR 1FTSW31P13ED81482
Standard Claims List For Model Year 2003
1FTSW31P13ED81482 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-JUN-2003 13-SEP-2003 158633 USA 0 6Y05 000001 * TDRIVE * A9* 82 9
AWS Claim Key: 2142720 Trx Code: R7U Labor Hrs: 0.4
Dlr Cd-Sub Cd: 09240 - * Name: YARMON FORD, INC. Ph: 320-2434235 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:31-JUL-2003 Doc #:5976881
Cust Comments: 2003 6.0L DIESEL WORKSHEET
Tech Comments: SPECIAL ROAD TEST ALLOWANCE FOR 6.0 DIESEL
1FTSW31P13ED81482 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-JUN-2003 13-SEP-2003 158633 USA 1 2E06 030008 3C3Z 9E527 AE D50 42 400
AWS Claim Key: 2617604 Trx Code: S07 Labor Hrs: 9.3
Dlr Cd-Sub Cd: 09572 - * Name: HOLT MOTORS, INC. Ph: 320-2862176 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:16-SEP-2003 Doc #:00607351
Cust Comments: 6.0 RUNABILITY PROBLEM
Tech Comments: CHECK WITH TECH HOTLINE, REPLACE #1 FUEL INJECTOR, CLEAR CODES ROAD TEST 20 MILES OK**MUCH TIME SPENT MAKING SENSE OF TESTING PROCEDURE, OTHER INJECTORS TESTED FURTHER OUT OF SPEC BUT STILL WORKED**NO TIME ON C D*** ENGINE PERFORMANCE DIAGNOSTICS DIESEL ENGINE DIAGNOSIS RE PROGRAM PCM, FICM AND TCM MODULES
1FTSW31P13ED81482 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-JUN-2003 13-SEP-2003 158633 USA 24 2E06 030008 3C3Z 9F838 EA L65 D8 55578
AWS Claim Key: 12064993 Trx Code: E72 Labor Hrs: 1.8
Dlr Cd-Sub Cd: 09473 - * Name: TENVOORDE FORD, INC. Ph: 320-2510540 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:23-AUG-2005 Doc #:249197A
Cust Comments: CUSTOMER STATES THAT THERE IS A OIL LEAK DRIPPING ON THE FLOOR PLEASE CHECK AND ADVISE
Tech Comments: 55578 ADDED DYE TO THE OIL AND PERFORMED A OIL LEAK DIAG, FOUND THAT THE LEAK IS COMING FROM THE HP OIL PUMP AREA, REMOVED AIR BOX ASSY AND REMOVED COOLANT RESERVOIR, REMOVED FICM TO GAIN ACCESS TO THE BACK OF THE HP OIL PUMP COVER. FOUND T HAT THE ICP SENSOR IS LEAKING, ALSO THE ICP SENSOR WIRING IS SWELLED UP, INSTALLED A NEW ICP SENSOR, SPLICED IN A NEW CONNECTOR PIGTAIL,
1FTSW31P13ED81482 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-JUN-2003 13-SEP-2003 158633 USA 24 1D05 030008 3C3Z 6750 AA D50 01 55578
AWS Claim Key: 12064994 Trx Code: E72 Labor Hrs: 0.1
Dlr Cd-Sub Cd: 09473 - * Name: TENVOORDE FORD, INC. Ph: 320-2510540 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:23-AUG-2005 Doc #:249197B
Cust Comments: CUSTOMER STATES THAT THE DIPSTICK SHOULD BE REPLACED
Tech Comments: 55578 ORDERED NEW DIPSTICK
1FTSW31P13ED81482 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-JUN-2003 13-SEP-2003 158633 USA 27 2H01 030008 3C3Z 6K854 DA E41 01 60147
AWS Claim Key: 12361138 Trx Code: E72 Labor Hrs: 3.1
Dlr Cd-Sub Cd: 09473 - * Name: TENVOORDE FORD, INC. Ph: 320-2510540 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:01-NOV-2005 Doc #:253371A
Cust Comments: CUST STATES WHEN TURNING ON THE HEAT OR A C THERE IS AN EXHAUST SMELL COMIN
Tech Comments: 60147 TEST DROVE AND VERIFIED CONCERN, CHECKED CROSS OVER PIPES BEHIND TURBO AND FOUND THAT THE LH PIPE IS BAD, REMOVED TURBO, REMOVED LH CROSS OVER PIPE AND INBSTALLED NEW ONE, REASSEMBLED AND TEST DROVE OK
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
