oasis needed please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by prenn, this thread has received 1 replies and been viewed 489 times.
post #1 of 2 (permalink) Old 09-17-2006, 11:12 PM Thread Starter
Real Trucks Have 2 Sticks
prenn's Avatar
oasis needed please
1ftnx21po3ed57968
2008 GMC 2500hd duramax cc sb 4 linked solid axle, 38'' toyos on 20" novakanes
www.renntransportation.com
prenn is offline
post #2 of 2 (permalink) Old 09-18-2006, 04:33 AM
Squatch's Avatar
OASIS RESULT:
1FTNX21P03ED57968
09/17/2006
23:32:53
© Copyright 2002-2006 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 F-SERIES BODY STYLE
F-250 SUPER CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
06/17/2003 BUILD DATE
05/27/2003 SALE MILEAGE
00022
WARNING MESSAGES
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
09/12/2006
DEALER: Bob Lynch Ford Inc
WARRANTY CLAIM NUMBER: 109742 ODOMETER: 049913M
LABOR OP
CONDITION CODE
CONDITION DESC
000 06E17B
09/12/2006
LABOR OP
CONDITION CODE
CONDITION DESC
000 59B01A
END OF OASIS REPORT FOR 1FTNX21P03ED57968
Standard Claims List For Model Year 2003
1FTNX21P03ED57968 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 27-MAY-2003 17-JUN-2003 172429 USA 4 6F18 010702 3C3Z 2820708 AB R22 01 10920
AWS Claim Key: 2943402 Trx Code: 1 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 07766 - * Name: MARTY FRANICH FORD LINCOLN-MERCURY Ph: 831-7224181 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:13-OCT-2003 Doc #:09416001
Cust Comments: REPLACE BROKEN RIGHT FRONT DOOR WEATHERSTRIP.
Tech Comments: 1 INSPECTED, REPLACED RIGHT FRONT DOOR WEATHERSTRIP.
1FTNX21P03ED57968 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 27-MAY-2003 17-JUN-2003 172429 USA 4 2G05 031405 * RECAL * D50 79 10920
AWS Claim Key: 2943401 Trx Code: 1 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 07766 - * Name: MARTY FRANICH FORD LINCOLN-MERCURY Ph: 831-7224181 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:13-OCT-2003 Doc #:09416002
Cust Comments: CHECK FOR IDLE FLUCTUATION SURGE, WHEN HOT.
Tech Comments: 1 INSPECTED EECV PASSED, NO DTC, REPROGRAMED PCM PER TSB 3 20 12
1FTNX21P03ED57968 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 27-MAY-2003 17-JUN-2003 172429 USA 4 3A88 000615 * NPF * P66 82 10920
AWS Claim Key: 2943400 Trx Code: 1 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 07766 - * Name: MARTY FRANICH FORD LINCOLN-MERCURY Ph: 831-7224181 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:13-OCT-2003 Doc #:09416003
Cust Comments: CHECK FOR TRANSMISSION CLUNK ON ACCELERATION WHEN FIRST SHIFTED TO DRIVE.
Tech Comments: 1 ROAD TESTED, COULD NOT VERIFIE CONCERN, CHECKED OASIS NO CARES.
1FTNX21P03ED57968 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 27-MAY-2003 17-JUN-2003 172429 USA 4 6L88 000615 * NPF * N33 82 10920
AWS Claim Key: 2943399 Trx Code: 1 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 07766 - * Name: MARTY FRANICH FORD LINCOLN-MERCURY Ph: 831-7224181 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:13-OCT-2003 Doc #:09416004
Cust Comments: CHECK FOR DASH RATTLE ON LEFT SIDE OF RADIO.
Tech Comments: NO PROBLEM FOUND
1FTNX21P03ED57968 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 27-MAY-2003 17-JUN-2003 172429 USA 4 6P05 010301 * 2822800 * B02 07 10920
AWS Claim Key: 2943398 Trx Code: 1 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 07766 - * Name: MARTY FRANICH FORD LINCOLN-MERCURY Ph: 831-7224181 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:13-OCT-2003 Doc #:09416005
Cust Comments: CHECK RIGHT FRONT DOOR ALIGNMENT FROM TOP TO BOTTOM IS NOT EVEN.
Tech Comments: 1 ALIGN RIGHT FRONT DOOR MISALIGNED GAP WAS UNEVEN FROM TOP AND BOTTOM OF REAR DOOR
1FTNX21P03ED57968 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 27-MAY-2003 17-JUN-2003 172429 USA 13 * * * * * * * 29727
AWS Claim Key: 6738070 Trx Code: 03E03 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 07802 - * Name: SWANSON FORD Ph: 408-3562101 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:07-JUL-2004 Doc #:20002301
Cust Comments: CUSTOMER STATES THAT CEL LIGHT IS ON AND HAS EXPERIENCED LOSS OF POWER STILL UNDER DEFECT
Tech Comments: TECH CHECKED FOR ANY CMDTC S NONE FOUND. TECH CHECKED OASIS FOUND 03E03 PCM RECALL TECH REPROGRAMED PCM TCM FICM PER 03B03 CHECKED FOR CODES AS PER 03E03 TESTED ALL OK AT THIS TIME
1FTNX21P03ED57968 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 27-MAY-2003 17-JUN-2003 172429 USA 27 1D01 03XXXX 3C3Z 6701 AA L65 D8 34565
AWS Claim Key: 11736803 Trx Code: E84 Labor Hrs: 5
Dlr Cd-Sub Cd: 04240 - * Name: THE FORD STORE MORGAN HILL Ph: 408-7828201 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:17-AUG-2005 Doc #:0044591
Cust Comments: THER IS AN OIL LEAK BETWEEN THE ENGINE AND BELL HOUSING
Tech Comments: CHKED OIL LEAK DIAG FOUND LEAK AT REAR CRANK SEAL PERF CRANK CASE PRESS TEST PASSED REPLACED SEAL TEST DROVE
1FTNX21P03ED57968 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 27-MAY-2003 17-JUN-2003 172429 USA 40 * * * * * * * 49913
AWS Claim Key: 14397423 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 07756 - * Name: BOB LYNCH FORD INC Ph: 408-8471111 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:12-SEP-2006 Doc #:109742A
AWS Claim Key: 14397424 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 07756 - * Name: BOB LYNCH FORD INC Ph: 408-8471111 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:12-SEP-2006 Doc #:109742B
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
