Oasis Please! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by aald4x4, this thread has received 2 replies and been viewed 504 times.
post #1 of 3 (permalink) Old 09-25-2006, 03:02 AM Thread Starter
Oasis Please!
looking at a Used 2005 F250
VIN: 1FTSW21P75EA36874
aald4x4 is offline
post #2 of 3 (permalink) Old 09-25-2006, 12:15 PM
Good Morning,
OASIS RESULT:
1FTSW21P75EA36874
09/25/2006
07:13:34
Copyright 2002-2006 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
05/31/2005 BUILD DATE
08/12/2004 SALE MILEAGE
00453
ARN MESSAGES
BEFORE REPLACING HIGH PRESS. PUMP FOR HARD START OR OIL LEAK, SEE TSB 06-17-06
BEFORE ADDRESSING VEHICLE VIBRATION CONCERNS, SEE TSB 05-26-24
WARNING MESSAGES
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
1FTSW21P75EA36874 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 12-AUG-2004 31-MAY-2005 152746 USA 2 6N04 010802 5C3Z 16720 VA B66 05 3082
AWS Claim Key: 1552945 Trx Code: 1 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 04554 - * Name: BOEHM FORD Ph: 361-5942931 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:14-JUL-2005 Doc #:02033501
Cust Comments: NAME PLATES ARE PEELING PAINT
Tech Comments: CHECKED AND FOUND PAINT WAS PEELING ON THE NAME PLATES ON BOTH SIDES
1FTSW21P75EA36874 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 12-AUG-2004 31-MAY-2005 152746 USA 2 6N04 010807 5C3Z 9942528 DA B66 05 3082
AWS Claim Key: 1552946 Trx Code: 1 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 04554 - * Name: BOEHM FORD Ph: 361-5942931 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:14-JUL-2005 Doc #:02033502
Cust Comments: NAME PLATE ON TAILGATE IS PEELING PAINT
Tech Comments: CHECKED AND FOUND PAINT ON NAME PLATE ON TAILGATE WAS PEELING PAINT ALSO REPLACED NAME PLATE
1FTSW21P75EA36874 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 12-AUG-2004 31-MAY-2005 152746 USA 8 * * * * * * * 18728
AWS Claim Key: 3319383 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 04554 - * Name: BOEHM FORD Ph: 361-5942931 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:18-JAN-2006 Doc #:01440701
Cust Comments: OWNER NOTIFICATION
Tech Comments: CHECKED OASIS AND FOUND OPEN CAMPAIGN ON EXHAUST PRESSURE SENSOR PREFORMED REPAIR AS PER INSTRUCTIONS
AWS Claim Key: 3319384 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 04554 - * Name: BOEHM FORD Ph: 361-5942931 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:18-JAN-2006 Doc #:01440702
Tech Comments: CHECKED OASIS AND FOUND OPEN CAMPAIGN ON DEGAG BOTTLE PREFORMED FEPAIR AS PER INSTRUCTIONS
1FTSW21P75EA36874 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 12-AUG-2004 31-MAY-2005 152746 USA 8 5Q03 110203 5C3Z 3691 CA L68 30 18728
AWS Claim Key: 3319385 Trx Code: E84 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 04554 - * Name: BOEHM FORD Ph: 361-5942931 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:18-JAN-2006 Doc #:01440703
Cust Comments: LEAKING POWER STEERING FLUID
Tech Comments: CUSTOMER SAID THERE WAS POWER STEERING FLUID LEAKING ON LEFT SIDE OF TRUCK I FOUND THE HOSE FROM RESVORE TO PUMP WAS LEAKING IREPLACED HOSE AND FOUND NO OTHER LEAK
AWS Claim Key: 3436005 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 04554 - * Name: BOEHM FORD Ph: 361-5942931 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:18-JAN-2006 Doc #:01440704
Tech Comments: CHECKED OASIS AND FOUND ELIGABLE FOR ONE TIME ASSURANCE TEST DRIVE PREFORMED AS PER INSTRUCTIONS
1FTSW21P75EA36874 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 12-AUG-2004 31-MAY-2005 152746 USA 13 2E06 030008 4C3Z 9E527 AA D42 42 28680
AWS Claim Key: 5264491 Trx Code: S07 Labor Hrs: 5.7
Dlr Cd-Sub Cd: 04554 - * Name: BOEHM FORD Ph: 361-5942931 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:13-JUN-2006 Doc #:00535501
Cust Comments: VEHICLE HAS NO POWER AND IS SKIPPING
Tech Comments: CUSTOMER SAID VEHICLE WAS RUNNING BAD HAD NO POWERAND SKIPPING KOEO,KOEC,KOER,INJECTOR ELECTRICAL SELF TEST,CRANKCASE PRESSURE TEST,RELATIVE COMPRESSION TEST,FUEL PRESSURE TEST DTCS P0263 P0269,P0275,AND P0281 REPLACED ALL INJECTORS ON PASSENGER SIDE.
Thanks,
Vivian
MOMBENZ is offline
post #3 of 3 (permalink) Old 09-25-2006, 06:31 PM Thread Starter
thanks
thank you!
aald4x4 is offline
