Oasis Please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Canuck_04_6L, this thread has received 2 replies and been viewed 472 times.
post #1 of 3 (permalink) Old 10-04-2006, 06:24 PM Thread Starter
Oasis Please
VIN: 1FTWW32P64EB69579
Thanks in advance.
Canuck_04_6L is offline
post #2 of 3 (permalink) Old 10-07-2006, 12:14 AM
Squatch's Avatar
OASIS RESULT:
1FTWW32P64EB69579
10/06/2006
19:14:01
© Copyright 2002-2006 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-350 CREW CAB 4X2 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
61 ENGINE CALIBRATION
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
12/10/2003 BUILD DATE
12/01/2003 SALE MILEAGE
ARN MESSAGES
BEFORE REPLACING 6.0L EGR VALVE REFER TO 06-19-06
BEFORE REPLACING 6.0L TURBOCHARGER REFER TO 06-18-03
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL CONTACT
VERIFY VIN/WARRANTY COVERAGE
VEHICLE SOLD IN CANADA
SERVICE INFO MAY BE UNAVAILABLE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
08/24/2006
DEALER: Discovery Ford Burlington
WARRANTY CLAIM NUMBER: 346485 ODOMETER: 075232K
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 10346AA ALTERNATOR LESS PULL 001 10200AB 42 DOES NOT OPERATE PROPERLY
000 10346A
000 10654CA
AVR TEST. CHECK BATTERY, REPLACE ALT NOT CHARGING, RECHECK, OK
04/28/2006
DEALER: Eastgate Ford Sales & Serv 82
WARRANTY CLAIM NUMBER: 255313 ODOMETER: 061495K
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 6K682BA TURBO CHG-EXH DRIVE 001 6005F 42 DOES NOT OPERATE PROPERLY
000 6005F1
000 6005F1X1
000 6005F2
000 6005F6
000 6005F8
000 6005F11
000 6005F12
000 6005F13
000 6005F14
000 6005F18
000 6005F19
000 6005F21
000 6005F22
000 6005F23
000 9438A
EEC TEST, MONITOR TEST, CHECK FOR FUEL CONTAMINATION CHECK FOR OIL CONTAMINA TION, CHECK INJECTOR PRESSURES,CHECK FUEL PRESSURES.REPLACE FAULTY TURBO. NO BOOST
04/28/2006
LABOR OP
CONDITION CODE
CONDITION DESC
6K682 TURBO CHG-EXH DRIVE 000 42 DOES NOT OPERATE PROPERLY
WAIVE DEDUCTIBLE
04/17/2006
WARRANTY CLAIM NUMBER: 254646 ODOMETER: 060725K
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9P456AC COOLER - EGR 001 6005F 42 DOES NOT OPERATE PROPERLY
4C3Z 9F452A TRANSDCR-EGR BACK PR 001 6005F1
CVC 7A 001 6005F1X1
000 6005F2
000 6005F6
000 6005F8
000 6005F11
000 6005F13
000 6005F14
000 6005F18
000 6005F19
000 6005F20
000 6005F21
000 6005F22
000 9456A
000 12650D30
EEC TEST, MONITOR TEST, CHECK FOR FUEL CONTAMINATION CHECK FOR OIL CONTAMINA TION, CHECK INTAKE RESTRICTIONCHECK INJECTOR PRESSURES, CHECK FUEL PRESSURES , CHECK EGR FLOW. REPLACE PLUGGED EGR VALVE. REPLACE CONTAMINATED EGR COOLER . RETEST.
04/17/2006
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9433AA GASKET SET-MANIFOLD 001 9438A D8 FAILED GASKET/SEAL
000 9438A3
R/R TURBO , TO REPLACE DEFECTIVE TUBE IN EGR COOLER
04/10/2006
WARRANTY CLAIM NUMBER: 254252 ODOMETER: 059986K
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 1102CA HUB & ROTOR ASY FRON 002 2001BFD 42 DOES NOT OPERATE PROPERLY
F81Z 3105BA SPINDLE ASY 001 2001B5CT
F81Z 2C204AD SENSOR ANTI LK FRONT 001 2001B8F
374504S100 001 2134ABT
E7TZ 1195A WSHR FRT HUB OTR BEA 001 2219D2
390622S 001
C8TZ 1131C CAP FRONT HUB GREASE 001
E2TZ 2B160B GSKT-FRT BRK SPLASH 002
E7TZ 1S190B SEAL-FRONT BRAKE HUB 001
72071S 008
C9AZ 4221A CONE ROLLER DIFF BRG 001
4C3Z 1216AA CONE RLLR FRT WHL OU 001
3C3Z 2B120AA CALIPER ASY FRONT BR 001
F81Z 2B292AB PLATE-FRT DISC BRK C 001
CPM 1 001
REPLACE RIGHT FRONT WHEEL BEARING, BOTH ROTORS, RIGHT FRONT CALIPER AND SPEE D SENSOR
03/07/2006
WARRANTY CLAIM NUMBER: 252239 ODOMETER: 058123K
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 3050DA KIT-FRT SUSP LWR SPD 001 3049ATB 33 LOOSE PART
5C2Z 3049AA JOINT ASY-FRT SUSP L 001
72071S 004
DIAG, REPLACE BOTH UPPER AND LOWER 'LEFT' SIDE BALL JOINTS
03/07/2006
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 12K073AA TRNSDC ASY-C/SHT PSN 001 6007D D8 FAILED GASKET/SEAL
000 12650D60
DIAG OIL LEAK, REPLACE CAM POSITION SENSOR
11/21/2005
WARRANTY CLAIM NUMBER: 246815 ODOMETER: 053291K
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6D083AA GASKET-RR COVER 001 6007D D8 FAILED GASKET/SEAL
3C3Z 6701AA CRANKSHAFT REAR SEAL 001 6701A
000 MT9D030
R/R TRANS TO REPLACE REAR MAIN SEAL AND GASKET
11/21/2005
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 1102CA HUB & ROTOR ASY FRON 002 2001BFD 13 OUT OF ROUND
1125 DISC - FRONT WHEEL B 000 2001B5CT
R/R BRAKE AND REPLACE FRONT ROTORS
11/21/2005
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 3050DA KIT-FRT SUSP LWR SPD 001 3049AC 33 LOOSE PART
72107S 002
REPLACE RIGHT SIDE BALL JOINT LOOSE
09/30/2005
WARRANTY CLAIM NUMBER: 244038 ODOMETER: 046759K
LABOR OP
CONDITION CODE
CONDITION DESC
XG 8 MOTORCRAFT BATTERY 001 042606A 42 DOES NOT OPERATE PROPERLY
4602 DRIVESHAFT ASY INCL 000
R/R DRIVESHAFT LUBRICATE
09/12/2005
WARRANTY CLAIM NUMBER: 242953 ODOMETER: 044494K
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 6C646AA DUCT ASY-ENG CHG AIR 001 6646AT 42 DOES NOT OPERATE PROPERLY
6C3Z 6C640AA CONNECTION A/C DUCT 001
REPLACE BOTH HOT/COLD AIR TO AIR TUBES DDDR2= 1ST REPAIR USING OLD PART, 2ND REPAIR REPLACED WITH UPDATED PART
END OF OASIS REPORT FOR 1FTWW32P64EB69579
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
post #3 of 3 (permalink) Old 10-07-2006, 04:54 PM Thread Starter
Thank you very much. Your efforts are greatly appreciated.
