OASIS Report Request - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Excursion_Nut, this thread has received 1 replies and been viewed 1136 times.
post #1 of 2 (permalink) Old 10-20-2006, 02:23 AM Thread Starter
Looking to get an OASIS report on VIN #1FMSU43P94ED26087.
Thanks in advance.
Excursion_Nut is offline
post #2 of 2 (permalink) Old 10-20-2006, 05:18 PM
VEHICLE DESCRIPTION
2004 EXCURSION BODY STYLE
LIMITED 4 DR 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
07/14/2004 BUILD DATE
04/26/2004 SALE MILEAGE
WARNING MESSAGES
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
08/29/2006
DEALER: Wray Ford, Inc.
WARRANTY CLAIM NUMBER: 105046 ODOMETER: 068444M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9E527AA NOZZLE ASY-FUEL INJE 002 6005F 42 DOES NOT OPERATE PROPERLY
PM 15 001 6005F1
000 6005F1X1
000 9527AT
42-INOP--9E527--INJECTORS ENGINE PERF. DIAG. TESTS-#1-#9. CODE0PO262, P02 78. REMOVE BOTH VALVE COVERS AND REPLACE #1 INJ. AND #6 INJ. START ENGINE AN D RETEST P1000. ROADTEST REPAIR 14 MILES.
08/22/2006
WARRANTY CLAIM NUMBER: 104694 ODOMETER: 068325M
LABOR OP
CONDITION CODE
CONDITION DESC
PM 15 001 6005F1
000 6005F1X1
000 6005F2
000 6005F6
000 9527AL
42-INOP--9E527--INJECTORS ENGINE PERF. DIAG.TESTS-#1-#15. FUEL PSI. AT55L BS. CODES-PO272, PO278. REMOVE LEFT VALVE COVER AND REPLACE #4 AND #6 FUEL I NJECTORS. RUN CYL. BAL. TEST P1000 ROADTES REPAIR 20 MILE. RETEST REPAIR OK.
07/14/2006
DEALER: Excel Ford Lincoln Mercury, LP
WARRANTY CLAIM NUMBER: 049431 ODOMETER: 066066M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9J460A SENSOR ASY EGR PR VL 001 6005F 41 STICKS/BINDS/GRABS
4C3Z 9F452A TRANSDCR-EGR BACK PR 001 6005F1
000 6005F2
000 6005F13
000 6005F14
000 6005F20
000 6005F18
000 12650D30
000 VERIFY60
000 MT9452
TEST DROVE VEHICLE TO VERIFY CONCERN, VEHICLE ALSO ACTS UP WHILE AT IDLE FOR LONG PERIODS OF TIME, PERFORMED 6.0 DIAG, COULDNT DUPLICATE CONCERN AT THE TIME. CALLED HOTLINE WAS TOLD TO MEASURE FUEL PRESSURE WHEN CONCERN WAS PRES ENT,MEASURED FUEL-52PSI OK CALLED HOTLINE AGAIN WAS HOTLINE AGAIN. WAS TOLD TO REMOVE & VISUALLY INSPECT EGR
07/12/2006
WARRANTY CLAIM NUMBER: 049398 ODOMETER: 060955M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9C968AA FUEL PRESSURE REG 001 6005F 42 DOES NOT OPERATE PROPERLY
3C3Z 9A543AARM PUMP ASY-FUEL INJECT 001 6005F13
5C3Z 9A332A HOSE ASY (FUEL HIGH 001 6005F1
3C3Z 9T288AA KIT-TUB OIL PMP (FUE 001 6005F2
3C3Z 9T514AD KIT-HDW TRBCH MTNG 001 6005F14
VC 7B 001 6005F20
000 6005F11
000 6005F18
000 6005F19
000 6005F21
000 6005F6
000 6005F8
000 6005F22
000 6005F12
000 6005F23
000 9968B
000 MT6584
000 9424A
ROADTEST VEHICLE-RAN 6.0 PERF. DIAG AND DOWNLOADED SELECTED INTO VDR AND GAV E BACK TO CUSTOMER-VDR SHOWED NOTHING-CALLED HOT LINE-HOT LINE ADVISED TO LO OK FOR STICKING IPR-MONITORED VDR PIDS,IPR STAYS AT 34.4% DOE 10 SECONDS, IC P DROPS THEN SPIKES AND ENG DIES. REPLACED IPR VALVE AND ROADTEST-ENGINE SUR GES AND DIES,REMOVED RIGHT VALVE COVER TO ACCES OIL RAIL
03/06/2006
WARRANTY CLAIM NUMBER: 046510 ODOMETER: 056532M
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 9B249A HEADER-FUEL FILTER 001 9249A 42 DOES NOT OPERATE PROPERLY
VERIFY WIF LIGHT IS ON-CODE P2269-DRAINED SEPERATOR AND CODE WILL NOT CLEAR- REMOVED COVER AND CLEANED DEBRIS AND REPLACED THE COVER-LIGHT WENT OUT-CLEAR ED CODE
03/06/2006
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9F452A TRANSDCR-EGR BACK PR 001 6007D 42 DOES NOT OPERATE PROPERLY
3C3Z 9433AA GASKET SET-MANIFOLD 001 6051AT
VC 7B 002 6051A20
OSP 001 6005F
3C3Z 6049AA CYLINDER HEAD 002 6005F13
4C3Z 9P456AC COOLER - EGR 001 6005F1
4C3Z 9E527AA NOZZLE ASY-FUEL INJE 001 6005F2
PM 15 001 6005F14
W708761SS32N 001 6005F18
VC 7B 003 6005F21
XO 15W40QSD 015 6005F6
3C3Z 6731AA ELEMENT ASY OIL FILT 001 6005F23
000 12650D47
000 MT9527
1 ADDED OIL DYE,ROADTEST AND CHECK WITH BLACK LIGHT FOR OIL LEAK, FOUND O IL LEAKING FROM BOTH HEADS AND REAR OF ENGINE- ACCESS BOTH HEADS,MEASURED BO TH HEADS ARE WARPED,RPL BOTH HEADS,REASSEMBLED AND FILLED FLUID-CHANGED OIL AND FILTER. ROADTEST -ENG IS MISSING BAD,RUN 6.0 TEST P0404-PPT W-RPL EGR VA LVE,POWER BALANCE TEST-#2 INJ -35 ACCESS-RPL #2 INJ AND REASSEMBLE-RETEST RO
09/12/2005
WARRANTY CLAIM NUMBER: 042295 ODOMETER: 035972M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9F452A TRANSDCR-EGR BACK PR 000 6005F 69 FROZEN/SEIZED/BINDING
000 6005F1
000 6005F2
000 6005F6
000 6005F13
000 6005F14
000 6005F20
000 6005F21
000 12650D30
000 6005F1X1
000 12650D45
END OF OASIS REPORT FOR 1FMSU43P94ED26087
2006 F250 XLT 6.0 CC Shortbed auto with Leer cap and fire engine red. Stock everything but running a
SCT Xcal2 tuned by Innovative Diesel. :smoke
Gillagorilla is offline
