oasis please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by nykn72, this thread has received 2 replies and been viewed 759 times.
post #1 of 3 (permalink) Old 10-23-2006, 01:56 AM Thread Starter
oasis please
1ftnw21p14ec12572 thanks in advance
nykn72 is offline
post #2 of 3 (permalink) Old 10-23-2006, 02:44 AM
Squatch's Avatar
OASIS RESULT:
1FTNW21P14EC12572
10/22/2006
21:44:13
© Copyright 2002-2006 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
4F710N0A
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
02/02/2004 BUILD DATE
01/26/2004 SALE MILEAGE
ARN MESSAGES
BEFORE REPLACING 6.0L EGR VALVE REFER TO 06-19-06
BEFORE REPLACING 6.0L TURBOCHARGER REFER TO 06-18-03
WARNING MESSAGES
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
08/30/2006
DEALER: Orleans Ford-Mercury Inc
WARRANTY CLAIM NUMBER: 017397 ODOMETER: 033913M
LABOR OP
CONDITION CODE
CONDITION DESC
D6TZ 15A442B SOCKET & WIRE B/SIDE 001 MT15A442 42 DOES NOT OPERATE PROPERLY
C2AZ 13466C SMALL BULBS 001
F2AZ 14488B CONNECTOR-WIRE 002
LEFT PLATE LAMP SOCKET CORRODED,REPLACE PLATE LAMPSOCKET
07/18/2006
DEALER: Courtesy Ford, Inc.
WARRANTY CLAIM NUMBER: 192999 ODOMETER: 033041M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9J460A SENSOR ASY EGR PR VL 001 12650D9 42 DOES NOT OPERATE PROPERLY
VC 7B 001 6005F
000 6005F1
000 6005F1X1
000 6005F2
000 6005F6
000 6005F11
000 6005F20
EEC TEST P0470, REPLACE EBP SENSOR
05/11/2006
WARRANTY CLAIM NUMBER: 189244 ODOMETER: 032471M
LABOR OP
CONDITION CODE
CONDITION DESC
1C3Z 4L616BA SEAL FRONT AXLE 001 3010B 42 DOES NOT OPERATE PROPERLY
F81Z 3249AA KIT-FRT AXLE SHFT U/ 002 3010B4
B5A 4616B CUP-DRIVING PINION B 001 4602B1
B5A 4621B CONE & ROLLER-DR PIN 001 4602B3
E5TZ 4616A CUP-DRIVING PINION B 001
EOTZ 1244A CONE & ROLLER RR WHL 002
351126S2 001
B7A 4662A SPACER DRIVE PINION 001
F81Z 3254CB OIL SEAL-FRONT AXLE 002
F81Z 1S175HCA BEARING-AXLE REAR 002
6C2Z 4320AA NUT RR AXLE DRV PNON 001
XY 80W90QL 004
NVH AND REPLACE FT U JOINTS AND OVERHAUL FT DII
05/11/2006
LABOR OP
CONDITION CODE
CONDITION DESC
TCAA 1244A CONE & ROLLER RR WHL 002 4205A 42 DOES NOT OPERATE PROPERLY
B5D 4222A CUP DIFFERENTIAL BRG 002 4205A8C
F81Z 4947AA PLATE-DIFF CLUTCH 001
B6D 4616A CUP-DRIVING PINION B 001
B5D 4630A PINION BEARING 001
E8TZ 4676B SEAL ASY-DRIVE PINIO 001
BB 1239A CUP WHEEL BEARING 002
TBAA 4621A CONE & ROLLER-DR PIN 001
F81Z 4630AA PINION BEARING 001
F81Z 4628AA CUP DRIVING PINION B 001
390313S100 001
XY 75W140QL 004
DIAG AND REPL REAR CLUTCHES AND REPL PINION BEARINGS
05/11/2006
LABOR OP
CONDITION CODE
CONDITION DESC
F6DZ 8100A CAP ASY RADIATOR 001 8100A 42 DOES NOT OPERATE PROPERLY
VC 7B 001 9622A
5C3Z 9N622A IND ASY ENG A/C REST 001 8005D
PRESSURE TEST AND REPL CAP
05/02/2006
WARRANTY CLAIM NUMBER: 188723 ODOMETER: 031370M
LABOR OP
CONDITION CODE
CONDITION DESC
1215 BEARING-FT WHEEL 000 3049AT 42 DOES NOT OPERATE PROPERLY
F81Z 4A322AA SEAL FRT WHL HUB 002 2134ABT
5C3Z 3050A KIT-FRT SUSP LWR SPD 002
4C3Z 3049DA JOINT ASY-FRT SUSP L 002
3C3Z 1104BA HUB ASSY-FRONT 002
DIAGNOSE AND REPL BOTH FT HUB AND BEARING ASSEMBLIES
05/02/2006
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 8A616AA CLUTCH ASY-FAN A/C 001 8616A 42 DOES NOT OPERATE PROPERLY
CK AND REPL CLUTCH FAN
01/10/2006
WARRANTY CLAIM NUMBER: 182779 ODOMETER: 029739M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9P456AC COOLER - EGR 001 9456A 42 DOES NOT OPERATE PROPERLY
4C4Z 8592AA CONNECTION-CYL HD WA 001 MT9424
3C3Z 12A697AA AIR CHARGE TEMP SENS 001 6005F
4C3Z 9F452A TRANSDCR-EGR BACK PR 001 6005F1
3C3Z 6731AA ELEMENT ASY OIL FILT 001 6005F1X1
VC 8 MOTORCRAFT BATTERY 001 6005F2
3C3Z 8146AJ SHROUD FAN 001 6005F6
VC 7B 002 6731A
000 MT8146
TEST SYSTEM PIN POINT AND REPL EGR COOLER AND VALVE
12/05/2005
WARRANTY CLAIM NUMBER: 181070 ODOMETER: 029400M
LABOR OP
CONDITION CODE
CONDITION DESC
1215 BEARING-FT WHEEL 000 2134AD 42 DOES NOT OPERATE PROPERLY
1C3Z 3B396CB LOCKING HUB ASSEMBLY 001
3C3Z 1104BA HUB ASSY-FRONT 001
F81Z 4A322AA SEAL FRT WHL HUB 001
CKED FRT END AND REPLACED HUB L.FRT
11/28/2005
WARRANTY CLAIM NUMBER: 180644 ODOMETER: 029306M
LABOR OP
CONDITION CODE
CONDITION DESC
8005 RADIATOR ASY 000 8005D 42 DOES NOT OPERATE PROPERLY
PRESSURE TEST SYSTEM NO LEAKS FOUND
11/28/2005
LABOR OP
CONDITION CODE
CONDITION DESC
1C3Z 3B396CB LOCKING HUB ASSEMBLY 002 1105AT 41 STICKS/BINDS/GRABS
SEIZED CKED AND REPLACED HUBS
END OF OASIS REPORT FOR 1FTNW21P14EC12572
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
post #3 of 3 (permalink) Old 10-23-2006, 02:56 AM Thread Starter
thank you so much.. cant thank you enough
nykn72 is offline
