report request please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by vr6dub, this thread has received 1 replies and been viewed 331 times.
post #1 of 2 (permalink) Old 10-29-2006, 03:11 PM Thread Starter
May I get a report on this please.
1FTNW21P84EC38246
Thanks for the info,
Mike
vr6dub is offline
post #2 of 2 (permalink) Old 10-29-2006, 06:08 PM
OASIS RESULT:
1FTNW21P84EC38246
10/29/2006
13:07:58
© Copyright 2002-2006 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
WARNING MESSAGES
ARN MESSAGES
BEFORE REPLACING 6.0L EGR VALVE REFER TO 06-19-06
BEFORE REPLACING 6.0L TURBOCHARGER REFER TO 06-18-03
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
03/22/2004 BUILD DATE
02/01/2004 SALE MILEAGE
00055
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
05/03/2006
DEALER: Dan Wiebold Ford
WARRANTY CLAIM NUMBER: 098669 ODOMETER: 050573M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 6K682BA TURBO CHG-EXH DRIVE 001 6005F 69 FROZEN/SEIZED/BINDING
4C3Z 9F452A TRANSDCR-EGR BACK PR 001 6005F1
000 6005F1X1
000 6005F2
000 6005F6
000 6005F8
000 6005F11
000 6005F12
000 6005F14
000 6005F18
000 6005F20
000 6005F23
000 6005F25
000 9438A
TURBO DEFECTIVE, AND EGR VALVE STUCK OPEN. CC 69 QC TEST DRIVE VEHICLE, V ERIFY CONCERNS. VEHICLE LACKS POWER, AND CHUGS WHEN AT IDLE. PERFORM WDS SEL F TEST. FOUND CODES P0404, AND P0299. TEST DROVE VEHICLE TO MONITOR RELATED PIDS PERFORM 6.0L PERFORMANCE DIAG SHEET. PERFORM WDS ACTIVE COMMANDS FOR RE LATED SYSTEMS. VGT DOES NOT RESPOND TO ACCTIVE COMMANDS. EGR SHOWS STUCK PAR
05/03/2006
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6701AA CRANKSHAFT REAR SEAL 001 6007D D8 FAILED GASKET/SEAL
5C3Z 6C640AA CONNECTION A/C DUCT 001 6701A
3C3Z 6734AA GASKET-ENG OIL PAN D 001
3C3Z 9N693HA RING-SEALING 001
4C2Z 12A690BA WIRING ASY EC SENSOR 001
3C3Z 9N693JA RING-SEALING 001
3C3Z 6D083AA GASKET-RR COVER 001
OSP 001
REAR ENGINE COVER GASKET, REAR MAIN SEAL, DRIVER SIDE GLOW PLUG BUSS BAR, CM P SENSOR O-RINGS, AND HOT SIDE CAC TUBE WERE LEAKING ENGINE OIL. CC D8 QC V ERIFIED CONCERN. ADDED ENGINE OIL LEAK DYE, TEST DROVE VEHICLE. INSPECTED WI TH BLACK LIGHT. FOUND CMP SENSOR O-RING DRIVER SIDE GLOW PLUG BUSS BAR O-RIN GS, REAR ENGINE COVER, REAR MAIN SEAL, HOT SIDE CAC TUBE, AND ENGINE DRAIN P
05/03/2006
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9J460A SENSOR ASY EGR PR VL 001 05E15G
RECALL COMPLETED RECALL AS PER RECALL 05E15
END OF OASIS REPORT FOR 1FTNW21P84EC38246
2006 F250 XLT 6.0 CC Shortbed auto with Leer cap and fire engine red. Stock everything but running a
SCT Xcal2 tuned by Innovative Diesel. :smoke
Gillagorilla is offline
