please check for me - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by hotshot4819, this thread has received 2 replies and been viewed 530 times.
post #1 of 3 (permalink) Old 11-05-2006, 01:08 AM Thread Starter
please check for me
vin # is
1fdwx37p73ed76675
hotshot4819 is offline
post #2 of 3 (permalink) Old 11-06-2006, 05:05 PM
OASIS RESULT:
1FDWX37P73ED76675
11/06/2006
12:05:10
© Copyright 2002-2006 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 F-SERIES BODY STYLE
F-350 S/CAB CHASSIS CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
E2 ENGINE CALIBRATION
WARNING MESSAGES
ARN MESSAGES
BEFORE REPLACING 6.0L EGR VALVE REFER TO 06-19-06
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
08/06/2003 BUILD DATE
06/22/2003 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
09/11/2006
DEALER: Granite Ford
WARRANTY CLAIM NUMBER: 021337 ODOMETER: 042842M
LABOR OP
CONDITION CODE
CONDITION DESC
12A650 PROCESSOR ASSY 000 6005F 42 DOES NOT OPERATE PROPERLY
000 6005F1
000 6005F1X1
000 6005F2
000 6005F8
000 6005F12
000 6005F13
000 6005F20
000 6005F25
POWER PERFORMED DIESEL DIAG WITH KOEO CHECK INJECTOR SELF TEST, ICP TEST, BO OST PRESSURE TEST, FUEL CONTAMINATION CHECK, EGR TEST, AND VGT TEST ALL PASS RECAL PRECESSOR ALL OK AT THIS TIME
08/29/2006
WARRANTY CLAIM NUMBER: 021074 ODOMETER: 042100M
LABOR OP
CONDITION CODE
CONDITION DESC
000 06E17B
REPROGRAMMED PCM PER CAMPAIGN 06E17
08/29/2006
LABOR OP
CONDITION CODE
CONDITION DESC
000 59B01A
CUST ASSURANCE TEST DRIVE
02/06/2006
WARRANTY CLAIM NUMBER: 016949 ODOMETER: 033290M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 3049DA JOINT ASY-FRT SUSP L 001 3001A 33 LOOSE PART
5C3Z 3050A KIT-FRT SUSP LWR SPD 001 3001A1T
3C3Z 3254CA OIL SEAL-FRONT AXLE 001 3504C
F81Z 4A322AA SEAL FRT WHL HUB 001 3049ATB
F81Z 1S175HCA BEARING-AXLE REAR 001
W300020 001
FOUND RIGHT SIDE BALL JOINTS,UPPER & LOWER LOOSE,STEERING BOX HAS EXCESSIVE PLAY, R&R UPPER AND LOWER BALL JOINTS ADJUSTED STEERING BOX,ADJUSTED CAMBER & TOE BOTH SIDES,ROADTESTED OK
02/06/2006
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6K682AARM TURBO CHG-EXH DRIVE 001 6005F 42 DOES NOT OPERATE PROPERLY
4C3Z 9F452A TRANSDCR-EGR BACK PR 001 6005F1
5C3Z 12224A 3 WAY VACUUM CONNECT 001 6005F1X1
000 6005F2
000 6005F6
000 6005F8
000 6005F9
000 6005F11
000 6005F12
000 6005F13
000 6005F14
000 6005F18
000 6005F19
000 6005F20
000 6005F21
000 6005F22
000 6005F23
000 6005F25
000 6005F33
000 9438A
000 12650D30
000 14200A
PERFORMED DIESEL DIAGNOSIS,FOUND EGR VALVE ER RATIC,R&R EGR VALVE,PERFORMED INJECTOR ENHANCED TEST,FOUND TURBO BAD,STICKING REPLACED TURBO ROADTESTED OK
12/20/2005
WARRANTY CLAIM NUMBER: 015995 ODOMETER: 031574M
LABOR OP
CONDITION CODE
CONDITION DESC
RECAL ECC PROCESSOR RECAL 000 6005F 42 DOES NOT OPERATE PROPERLY
000 6005F11
000 6005F12
000 6005F13
000 6005F23
000 12650D84
HESITATING & MISFIRING. TECHNICIAN PERFORMED A DIESEL DIAG, COMPLETED THE DI AG SHEET, PERFORMED A VGT TEST, PASSED. NPF, CALLED HOT LINE REFERENCE USECE TARE BOOSTER & LOWER IDLE TIME. ADVISED TO CHECKPCM TCM FICM CALIBRATION. CH ECK & UPDATE CALIBRAT ION.
END OF OASIS REPORT FOR 1FDWX37P73ED76675
2006 F250 XLT 6.0 CC Shortbed auto with Leer cap and fire engine red. Stock everything but running a
SCT Xcal2 tuned by Innovative Diesel. :smoke
Gillagorilla is offline
post #3 of 3 (permalink) Old 11-06-2006, 09:22 PM Thread Starter
Thanks for getting to the report. can someone tell me what they honestly think, everything seemed great on the truck when i drove it. can just tell me opinions and what to watch out for. if possible get to this reply today thinking about getting it tomarrow
