OASIS Request for F150 please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by imported_4x4freak, this thread has received 2 replies and been viewed 493 times.
post #1 of 3 (permalink) Old 11-13-2006, 07:01 PM Thread Starter
1FTRW08L71KB33459
Thanks in advance
imported_4x4freak is offline
post #2 of 3 (permalink) Old 11-15-2006, 01:56 AM
Squatch's Avatar
OASIS RESULT:
1FTRW08L71KB33459
11/14/2006
20:56:08
© Copyright 2002-2006 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2001 F-SERIES LD BODY STYLE
F-150 CREW FLARE SIDE 4X4 ENGINE
5.4L SOHC EFI
TRANSMISSION
4R70W 4 SPD AUTO AXLE CODE
H9 ENGINE CALIBRATION
1F514F0A
WARNING MESSAGES
ARN MESSAGES
BEFORE ADDRESSING AXLE NOISE (WHINE/HOWL), SEE TSB 05-23-03
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
04/23/2001 BUILD DATE
04/09/2001 SALE MILEAGE
00023
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
05/03/2006
DEALER: Freeway Ford
WARRANTY CLAIM NUMBER: 053563 ODOMETER: 105327M
LABOR OP
CONDITION CODE
CONDITION DESC
D5AZ 7B498A OIL SEAL MAIN CTRL V 001 7000E D1 POROSITY
XT 5QM 012 7191A
87034S94 001 7191AXQ
F75Z 7C493AA SHAFT MANUAL CONTROL 001 7191AZG
F75Z 7A256AA LEVER ASY-MANUAL CON 001 7191A5
7000 TRANSMISSION ASY-AUT 000
RAISE VEICHLE ON HOIST,PERFORM AUTO TRANS BLACKLIGHT TESTS TO FIND MANUAL SH AFT LEAKING. R&R PAN FOR ACCESS CLEAN AND INSPECT REUSEABLE PAN GASKET. REPL ACE MANUAL SHIFT LEVER SEAL AND SHAFT DO TO EXC. WEAR. REFILL TO SPECS. ROAD TEST. SERVICE INSTALLED PARTS ON 4-17-06 AT ACCURED MILES OF 267, CROSS REF RO# 52712,( COMPLETE ASSY REPLACED BEFORE)
05/03/2006
LABOR OP
CONDITION CODE
CONDITION DESC
4W1Z 14A411BC WIRE ASY MAIN JUMPER 001 05S28D
INSPECT THE SPEED CONTROL DEACTIVATION SWITCH ELECTRICAL CONNECTOR FORBRAKE FLUID CONTAMINATION, NONE FOUND INSTALL THE FUSED JUMPER HARNESS PER RECALL.
END OF OASIS REPORT FOR 1FTRW08L71KB33459
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
post #3 of 3 (permalink) Old 11-15-2006, 12:06 PM Thread Starter
Thanks!!
