Oasis Please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by scuddy, this thread has received 1 replies and been viewed 525 times.
post #1 of 2 (permalink) Old 12-06-2006, 09:06 AM Thread Starter
Oasis Please
Vin # 1FTNX20F4XEA25045
Thanks.
scuddy is offline
post #2 of 2 (permalink) Old 12-13-2006, 01:01 PM
Hi,
OASIS RESULT:
1FTNX20F4XEA25045
12/13/2006
08:00:50
Copyright 2002-2006 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
1999 F-SERIES BODY STYLE
F-250 SUPER CAB 4X2 ENGINE
7.3L TURBO - DI
TRANSMISSION
4R100 (E4OD) 4SP O/D AXLE CODE
C1 ENGINE CALIBRATION
WARNING MESSAGES
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
03/13/1998 BUILD DATE
03/03/1998 SALE MILEAGE
00088
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
1FTNX20F4XEA25045 T/F7 F T/BD T/BD T/B A1 T/DE T/DS 03-MAR-1998 13-MAR-1998 124012 USA 3 * * * * * * * 5786
AWS Claim Key: 126952 Trx Code: 98S17 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 04817 - * Name: FLAMINGO FORD Ph: 305-2475112 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:01-JUN-1998 Doc #:001190A
Cust Comments: STEERING SHAFT RECALL 98S17
Tech Comments: 5787 INSPECT STEERING SHAFT NORMAL
1FTNX20F4XEA25045 T/F7 F T/BD T/BD T/B A1 T/DE T/DS 03-MAR-1998 13-MAR-1998 124012 USA 5 5U88 000615 * NPF * N22 82 8575
AWS Claim Key: 140180 Trx Code: 1 Labor Hrs: 1
Dlr Cd-Sub Cd: 02836 - * Name: WORLD FORD/HOMESTEAD Ph: 305-2475112 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:14-JUL-1998 Doc #:004673B
Cust Comments: VEH HAS VIBRATION WHEN TAKING OFF SEE CHRIS
Tech Comments: 8579 NPF TEST DROVE VERFIY CONCERN,TEST DROVE ALIKE VECHILE,SAME CHARACTERISTIC OF VECHILE.
1FTNX20F4XEA25045 T/F7 F T/BD T/BD T/B A1 T/DE T/DS 03-MAR-1998 13-MAR-1998 124012 USA 6 7G03 120303 * 19850 * C24 D1 11326
AWS Claim Key: 181982 Trx Code: 1 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 02836 - * Name: WORLD FORD/HOMESTEAD Ph: 305-2475112 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:18-AUG-1998 Doc #:006242A
Cust Comments: WATER DRIPS ON FLOORBOARD SOP IN
Tech Comments: 11326 RESEAL SPLIT IN A C EVAP CASE CC D1 BP 19850
1FTNX20F4XEA25045 T/F7 F T/BD T/BD T/B A1 T/DE T/DS 03-MAR-1998 13-MAR-1998 124012 USA 11 5R02 110601 F81Z 3600 BAB T90 D4 24058
AWS Claim Key: 852019 Trx Code: E84 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 02836 - * Name: WORLD FORD/HOMESTEAD Ph: 305-2475112 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:02-FEB-1999 Doc #:00013351
Cust Comments: STEERING WHEEL MATERIAL DISTORTED S.O.P. HERE
Tech Comments: STEERING WHEEL MATERIAL DEFECTIVESTEERING WHEEL REPLACE
1FTNX20F4XEA25045 T/F7 F T/BD T/BD T/B A1 T/DE T/DS 03-MAR-1998 13-MAR-1998 124012 USA 11 7X01 011000 F65Z 14A701 AA S15 42 24058
AWS Claim Key: 1186353 Trx Code: E83 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 02836 - * Name: WORLD FORD/HOMESTEAD Ph: 305-2475112 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:02-FEB-1999 Doc #:00013352
Cust Comments: DRIVERS SEAT CONTROL INOP
Tech Comments: POWER SEAT SWITCH INP NECC TO REPLACE
1FTNX20F4XEA25045 T/F7 F T/BD T/BD T/B A1 T/DE T/DS 03-MAR-1998 13-MAR-1998 124012 USA 11 7H01 120301 * 19703 * C01 42 24058
AWS Claim Key: 1173652 Trx Code: E83 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 02836 - * Name: WORLD FORD/HOMESTEAD Ph: 305-2475112 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:02-FEB-1999 Doc #:00013353
Cust Comments: A.C. COMPRESSOR CYCLES WHEN HOT
Tech Comments: REFRIGERANT OVERCHARGED EVAC AND RECHARGE
1FTNX20F4XEA25045 T/F7 F T/BD T/BD T/B A1 T/DE T/DS 03-MAR-1998 13-MAR-1998 124012 USA 11 5N01 110301 * 3281 * E35 33 24058
AWS Claim Key: 1173653 Trx Code: E84 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 02836 - * Name: WORLD FORD/HOMESTEAD Ph: 305-2475112 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:02-FEB-1999 Doc #:00013354
Cust Comments: FRT. END CLUNK WHEN PULLING INTO PARKING SPACE
Tech Comments: ROAD TEST,PINPOINT NOISE,RETORQUE LOOSE TIE ROD SLEEVE
1FTNX20F4XEA25045 T/F7 F T/BD T/BD T/B A1 T/DE T/DS 03-MAR-1998 13-MAR-1998 124012 USA 12 5R02 110601 F81Z 3600 BAA T90 81 25409
AWS Claim Key: 1135603 Trx Code: E90 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 02836 - * Name: WORLD FORD/HOMESTEAD Ph: 305-2475112 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:04-MAR-1999 Doc #:00144051
Cust Comments: T90 STEERING WHEEL DISCOLOREDD S.O.P. HERE BOB DAY SEE TODD
Tech Comments: REPLACE STEERING WHEEL DISCOLORED STEERING WHEEL DISCRED REPL ON RO 133 2 2 99 AND 24065 MILES
1FTNX20F4XEA25045 T/F7 F T/BD T/BD T/B A1 T/DE T/DS 03-MAR-1998 13-MAR-1998 124012 USA 15 5B01 040103 * 3006 * A99 12 30410
AWS Claim Key: 2323401 Trx Code: E84 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 02836 - * Name: WORLD FORD/HOMESTEAD Ph: 305-2475112 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:02-JUN-1999 Doc #:00549352
Cust Comments: E35 CLUNK NOISE AFTER TURNING GOING STRAIGHT FIRST FEW FEET
Tech Comments: TEST DRIVE ATTACH CHASSIS EARS TO LOCATE LOOSE AXLE ATTACHING BOLT
1FTNX20F4XEA25045 T/F7 F T/BD T/BD T/B A1 T/DE T/DS 03-MAR-1998 13-MAR-1998 124012 USA 15 1F05 030306 F81Z 8A616 DA C02 42 30458
AWS Claim Key: 2372506 Trx Code: E84 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 02836 - * Name: WORLD FORD/HOMESTEAD Ph: 305-2475112 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:04-JUN-1999 Doc #:00559654
Cust Comments: C02 WHEN TRUCK IS HOT ON RESTART AT IDLE A.C. BLOWS HOT AIR
Tech Comments: TESST DROVE TRUCK A C COOL WELL SHUT OFF AND RESTARTED A C HIGH SIDE PRESSURE SWITCH WAS SHUTTING A C OFF REPLACED ENGINE FAN CLUTCH
1FTNX20F4XEA25045 T/F7 F T/BD T/BD T/B A1 T/DE T/DS 03-MAR-1998 13-MAR-1998 124012 USA 16 1F03 030304 * 8260 * L68 33 30692
AWS Claim Key: 2613143 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 02836 - * Name: WORLD FORD/HOMESTEAD Ph: 305-2475112 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:14-JUN-1999 Doc #:00595351
Cust Comments: D50 OIL LEAKING FROM TURBO TUBES
Tech Comments: LOOSE CLAMPS INSPECT OIL LEAK AT AIR TUBE CLEANED AND RETIGHTENED CLAMPS
1FTNX20F4XEA25045 T/F7 F T/BD T/BD T/B A1 T/DE T/DS 03-MAR-1998 13-MAR-1998 124012 USA 16 5C01 050100 * 4602 * E35 42 30692
AWS Claim Key: 2613144 Trx Code: E84 Labor Hrs: 2.3
Dlr Cd-Sub Cd: 02836 - * Name: WORLD FORD/HOMESTEAD Ph: 305-2475112 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:14-JUN-1999 Doc #:00595352
Cust Comments: E35 DRIVE LINE VIBRATION ON HARD ACCELL FROM DEAD STOP SEE NOTE OVER
Tech Comments: M TIME TO CHECK NOISE VIBRATION HARSHNESS DIAG R&R BOTH DRIVESHAFT CHECK CENTER BRACKET AND SHIM PER SSM 11844 AND 11845 ROAD TEST
1FTNX20F4XEA25045 T/F7 F T/BD T/BD T/B A1 T/DE T/DS 03-MAR-1998 13-MAR-1998 124012 USA 16 5Y01 0602XX * 1126 * N27 13 30692
AWS Claim Key: 2613145 Trx Code: E84 Labor Hrs: 1.1
Dlr Cd-Sub Cd: 02836 - * Name: WORLD FORD/HOMESTEAD Ph: 305-2475112 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:14-JUN-1999 Doc #:00595354
Cust Comments: N27 WHOLE TRUCK SHAKES WHEN BRAKING
Tech Comments: MACHINE BOTH FRONT ROTORS 8 LUG ON VEHICLE
1FTNX20F4XEA25045 T/F7 F T/BD T/BD T/B A1 T/DE T/DS 03-MAR-1998 13-MAR-1998 124012 USA 17 2G03 031405 * 12A646 * A99 33 32469
AWS Claim Key: 3118359 Trx Code: S07 Labor Hrs: 2.9
Dlr Cd-Sub Cd: 02836 - * Name: WORLD FORD/HOMESTEAD Ph: 305-2475112 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:20-JUL-1999 Doc #:00749051
Cust Comments: D50 ENGINE RUNNING SLUGGISH,LOW POWER UNDER LOAD (TOWING)
Tech Comments: M TIME TO PERFORM DIAGNOSTIC STEPS 1 THROUGH 12 TES
1FTNX20F4XEA25045 T/F7 F T/BD T/BD T/B A1 T/DE T/DS 03-MAR-1998 13-MAR-1998 124012 USA 17 7X01 011000 F65Z 14A701 AA T90 42 32469
AWS Claim Key: 3118360 Trx Code: E83 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 02836 - * Name: WORLD FORD/HOMESTEAD Ph: 305-2475112 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:20-JUL-1999 Doc #:00749052
Cust Comments: DRIVER SEAT CONTROL SWITCH KNOB FELL OFF.. SEE S.O.P. IN STOCK #99166024
Tech Comments: R&R DRIVER SEAT SWITCH KNOB FELL OFF FROM SWITCH
1FTNX20F4XEA25045 T/F7 F T/BD T/BD T/B A1 T/DE T/DS 03-MAR-1998 13-MAR-1998 124012 USA 22 5Y01 060401 F81Z 2C026 CA A99 30 40993
AWS Claim Key: 6221995 Trx Code: P05 Labor Hrs: 1
Dlr Cd-Sub Cd: 02836 - * Name: WORLD FORD/HOMESTEAD Ph: 305-2475112 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:08-DEC-1999 Doc #:01333251
Cust Comments: CUSTOMER REPORTS FRONT BRAKE ROTORS WARPED
Tech Comments: EXCESSIVE WARPING ON REAR ROTORS BRAKE SHOES PAD ASSEMBLIES HYDRAULIC INSPECT
1FTNX20F4XEA25045 T/F7 F T/BD T/BD T/B A1 T/DE T/DS 03-MAR-1998 13-MAR-1998 124012 USA 42 6Y21 * * * * A98 * 83435
AWS Claim Key: 17620180 Trx Code: 99S11 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 04332 - * Name: ARMSTRONG FORD OF HOMESTEAD Ph: 305-2475112 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:14-AUG-2001 Doc #:00848504
Cust Comments: PERFORM RECALL ON FUEL INTEGRITY #99S11
Tech Comments: RECALL 99S11B R I FUEL TANK AND INSTALLED BRACKET AND RETAINER STRAPS AS PER RECALL 99S11B
Thanks,
Vivian
MOMBENZ is offline
