oasis - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by fordboy2, this thread has received 1 replies and been viewed 402 times.
post #1 of 2 (permalink) Old 12-07-2006, 03:22 AM Thread Starter
Ford guru
oasis
an I get someone to give me a oasis on a truck I am looking at the vin is
1ftnw21p84ec26467 thanks in advance, aaron
fordboy2 is offline
post #2 of 2 (permalink) Old 12-13-2006, 12:39 PM
OASIS RESULT:
1FTNW21P84EC26467
12/13/2006
07:37:03
Copyright 2002-2006 Ford Motor Company. All rights reserved.
Hi,
Here you go:
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
WARNING MESSAGES
ARN MESSAGES
BEFORE REPLACING 6.0L EGR VALVE REFER TO 06-19-06
BEFORE REPLACING 6.0L TURBOCHARGER REFER TO 06-23-02
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
09/30/2004 BUILD DATE
01/30/2004 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
11/16/2006
DEALER: Hudspeth Motors Inc
WARRANTY CLAIM NUMBER: 017916 ODOMETER: 027665M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9F452A TRANSDCR-EGR BACK PR 001 12650D 42 DOES NOT OPERATE PROPERLY
000 12650D30
000 12650DX1
REPLACED EGR VALVE CLEARED CODES RETEST OK
10/16/2006
DEALER: Rick Ford Sales, Inc.
WARRANTY CLAIM NUMBER: 084364 ODOMETER: 025413M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 6C640AA CONNECTION A/C DUCT 001 9438A 42 DOES NOT OPERATE PROPERLY
3C3Z 6766AA CAP ASY OIL FILLER 001 6646AC
4C3Z 6K682ARM TURBO CHG-EXH DRIVE 001 6005F
000 6005F1
000 6005F1X1
000 6005F2
000 6005F11
000 6005F12
000 6005F14
000 6005F20
000 6005F25
VERIFY CONCERN. FOUND VEHICLE HAD BLOWN PRESSURE TUBE OFF OF TURBO BLUE RUB BER TUBE. INSTALLED TWO CLAMPS. CLEAR CODES. TEST DRIVE WHILE MONITORING EGR OPERATION & VCI OPERATION. BOTH ARE FINE. RETEST CODES P0299 PERFORM KOEO, KOER, EXHAUST RESTRCTN TES, BOOST PRESSRE- 32PSI, INTAKE RESTRCTN, EGR POSITION 1.14-3.76V, VGT TST INDICATES NORMAL MOVEMENT. PERFORM TSB 06-18-
08/24/2006
WARRANTY CLAIM NUMBER: 083997 ODOMETER: 024839M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9E527AA NOZZLE ASY-FUEL INJE 001 6005F 42 DOES NOT OPERATE PROPERLY
000 6005F1X1
000 6005F2
000 6005F6
000 6005F13
000 12650D45
000 6005F22
000 6005F33
000 9527AR
VERIFY CONCERN, TEST CODE P0275 CYL 5 CONTRBTN BAL. KOER INJ ELECT TEST PAS S, VISUAL INSPCTN SHOWS NO EVIDENCE OF ELECTRCL CNNCTR PRBLM. PNPOINT TEST P2 RESISTNC WITHIN .07 TO 1.5 OHMS & GREATER THAN 10000 OHMS. P-3 RESISTNCE LESS THAN 5 OHMS. COMPRESSION TEST OF #5 CYL IS 425LBS. REPLACE FUEL INJTR & TEST PASS CYL CONTBTN TEST. TEST DRIVE OK
08/24/2006
LABOR OP
CONDITION CODE
CONDITION DESC
VC 4A 003 ADD 01 BROKEN/CRACKED
VC 8 MOTORCRAFT BATTERY 001 8287A
8287 CLAMP ASY-RAD HOSE 000
OSP 001
07/07/2006
WARRANTY CLAIM NUMBER: 083592 ODOMETER: 023473M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9E527AA NOZZLE ASY-FUEL INJE 002 6005F 55 PLUGGED/RESTRICTED
OSP 001 6005F1X1
000 6005F2
000 6005F6
000 6005F9
000 6005F22
000 12650D45
000 9527AR
000 6051A11
000 6005F33
1FTNW21P84EC26467 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 30-JAN-2004 30-SEP-2004 148534 USA 13 2H01 * * * * * * 11239
AWS Claim Key: 7056419 Trx Code: 05B29 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 09792 - * Name: RICK FORD SALES, INC. Ph: 989-6425261 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:26-SEP-2005 Doc #:08109701
Cust Comments: HAS RECALL 05B29
Tech Comments: REPLACE CAC DUCT AND CLAMPS
1FTNW21P84EC26467 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 30-JAN-2004 30-SEP-2004 148534 USA 13 * * * * * * * 11239
AWS Claim Key: 7056420 Trx Code: 05S34 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 09792 - * Name: RICK FORD SALES, INC. Ph: 989-6425261 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:26-SEP-2005 Doc #:08109702
Cust Comments: HAS RECALL 05S24
Tech Comments: INSPECT AND INSTALL FICM HARNESS REPAIR KITM INSTALL ICP HARNESS REPAIR KIT
AWS Claim Key: 7056421 Trx Code: 05E15 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 09792 - * Name: RICK FORD SALES, INC. Ph: 989-6425261 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:26-SEP-2005 Doc #:08109703
Cust Comments: HAS RECALL 05E15
Tech Comments: INSTALL EBP HARNESS REPAIR KIT REPLACE EBP SENSOR. NEW CALIB IS 4U7A12A650BFGVXBC7A3. REPROGRAM PCM, FICM AND TCM.
AWS Claim Key: 7056422 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 09792 - * Name: RICK FORD SALES, INC. Ph: 989-6425261 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:26-SEP-2005 Doc #:08109704
Cust Comments: HAS RECALL 59B01
Tech Comments: TEST DRIVE OK
1FTNW21P84EC26467 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 30-JAN-2004 30-SEP-2004 148534 USA 22 2E06 030008 4C3Z 9E527 AA D21 55 23473
AWS Claim Key: 9856707 Trx Code: S07 Labor Hrs: 4.2
Dlr Cd-Sub Cd: 09792 - * Name: RICK FORD SALES, INC. Ph: 989-6425261 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:07-JUL-2006 Doc #:08359201
Cust Comments: TRUCK QUITS WHILE DRIVING
Tech Comments: ENGINE PERF DIAG, KOEO, KOER CODE P0269 CONTR BAL. PERF INJ ELEC TEST PASS, NO VISUAL PROBLEMS WITH ELEC WRNG, OIL LEVEL & QUALTY GOOD. INSTRCTD TO GO TO PIN PNT TEST P15, THEN CRNKCS PRS TST 4HG, PRFM COMPRSN TST OF SUSPCT CYL450 PSI GOOD, PINPNT TEST P16, INSTRCTD PRFM VISUAL OF PUSHRDS, RCKR ARMS, VALVES, VALVE SPRINGS. RMVD RT SIDE VALV CVR NO PRBLM WITH AVOVE AREAS. INSTRCTD TO REPLCE INJCTR
1FTNW21P84EC26467 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 30-JAN-2004 30-SEP-2004 148534 USA 24 2E06 030402 4C3Z 9E527 AA D42 42 24839
AWS Claim Key: 10281562 Trx Code: S07 Labor Hrs: 3.6
Dlr Cd-Sub Cd: 09792 - * Name: RICK FORD SALES, INC. Ph: 989-6425261 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:24-AUG-2006 Doc #:08399701
Cust Comments: TRUCK HAS NO POWER WHEN PULLING A TRAILER.
Tech Comments: VERIFY CONCERN, TEST CODE P0275 CYL 5 CONTRBTN BAL. KOER INJ ELECT TEST PASS, VISUAL INSPCTN SHOWS NO EVIDENCE OF ELECTRCL CNNCTR PRBLM. PNPOINT TEST P2 RESISTNC WITHIN .07 TO 1.5 OHMS & GREATER THAN 10000 OHMS. P 3 RESISTNCE LESS THAN 5 OHMS. COMPRESSION TEST OF #5 CYL IS 425LBS. REPLACE FUEL INJTR & TEST PASS CYL CONTBTN TEST. TEST DRIVE OK
1FTNW21P84EC26467 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 30-JAN-2004 30-SEP-2004 148534 USA 24 1F03 030304 * 8287 * L87 01 24839
AWS Claim Key: 10272020 Trx Code: E84 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 09792 - * Name: RICK FORD SALES, INC. Ph: 989-6425261 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:24-AUG-2006 Doc #:08399702
Tech Comments: ADD ON LIN FOR COOLANT LEAK. FOUND HOSE CLAMP AT OUTPUT OF WATER PUMP IS BROKEN. REMOVE AND INSTALL A NEW CLAMP REFILL TEST OK
1FTNW21P84EC26467 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 30-JAN-2004 30-SEP-2004 148534 USA 25 2H01 030407 4C3Z 6K682 ARM D42 42 25413
AWS Claim Key: 10566080 Trx Code: S07 Labor Hrs: 5.2
Dlr Cd-Sub Cd: 09792 - * Name: RICK FORD SALES, INC. Ph: 989-6425261 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:16-OCT-2006 Doc #:08436401
Cust Comments: TRUCK HAS NO POWER & STUMBLES
Tech Comments: VERIFY CONCERN. FOUND VEHICLE HAD BLOWN PRESSURE TUBE OFF OF TURBO BLUE RUBBER TUBE. INSTALLED TWO CLAMPS. CLEAR CODES. TEST DRIVE WHILE MONITORING EGR OPERATION & VCI OPERATION. BOTH ARE FINE. RETEST CODES P0299 PERFORM KOEO, KOER, EXHAUST RESTRCTN TES, BOOST PRESSRE 32PSI, INTAKE RESTRCTN, EGR POSITION 1.14 3.76V, VGT TST INDICATES NORMAL MOVEMENT. PERFORM TSB 06 18 03. INSPCT TURBO CH
1FTNW21P84EC26467 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 30-JAN-2004 30-SEP-2004 148534 USA 26 1H03 030008 4C3Z 9F452 A D50 42 27665
AWS Claim Key: 10703337 Trx Code: S07 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 05894 - * Name: HUDSPETH MOTORS INC Ph: 870-7433200 St:AR Ctry Cd: USA Reg Cd: NA Repr Date:16-NOV-2006 Doc #:01791601
Cust Comments: CUSTOMER STATES ENGINE RUNS ROUGH AND SPUDERS
Tech Comments: REPLACED EGR VALVE CLEARED CODES RETEST OK
Thanks,
Vivian
MOMBENZ is offline
