Oasis request? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Ace13, this thread has received 3 replies and been viewed 505 times.
post #1 of 4 (permalink) Old 12-08-2006, 03:33 PM Thread Starter
Oasis request?
Could someone provide an Oasis report for the following:
1FTNW21P83ED04812
Thanks in advance!!!!
Ace13 is offline
post #2 of 4 (permalink) Old 12-13-2006, 12:44 PM
Hi,
You're Welcome.
OASIS RESULT:
1FTNW21P83ED04812
12/13/2006
07:43:08
Copyright 2002-2006 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
WARNING MESSAGES
ARN MESSAGES
BEFORE REPLACING 6.0L EGR VALVE REFER TO 06-19-06
BEFORE REPLACING 6.0L TURBOCHARGER REFER TO 06-23-02
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
05/13/2003 BUILD DATE
04/15/2003 SALE MILEAGE
00012
59B01
ELIGIBLE FOR ONE-TIME CUSTOMER ASSURANCE TEST DRIVE. SEE EMISSIONS RECALL 05E15 OR 06E17 FOR DETAILS.
06E17
CONTROL MODULE RECALIBRATION
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
1FTNW21P83ED04812 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 15-APR-2003 13-MAY-2003 121746 USA 0 6N07 010801 * 8200 * C05 42 10
AWS Claim Key: 980574 Trx Code: 1 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 00986 - * Name: THOMASVILLE FORD, INC. Ph: 336-4727731 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:23-APR-2003 Doc #:07529201
Cust Comments: AC DOES NOT COOL
Tech Comments: ? AC PERFORMANCE TEST EVACUATE AND RECHARGE SYSTEM R AND R GRILLE TO GAIN ACCESS TO CONDENSOR TO TIGHTEN CLAMP
1FTNW21P83ED04812 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 15-APR-2003 13-MAY-2003 121746 USA 1 7H06 120303 1W1Z 19E889 LA C05 D8 10
AWS Claim Key: 1162373 Trx Code: 1 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 00986 - * Name: THOMASVILLE FORD, INC. Ph: 336-4727731 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:14-MAY-2003 Doc #:07574101
Cust Comments: AC NOT COLING
Tech Comments: 1 EVACUATE AND RECHARGE SYSTEM REPLACE O RING AT CONDENSOR
1FTNW21P83ED04812 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 15-APR-2003 13-MAY-2003 121746 USA 1 7V01 180101 * 14289 * E29 B4 684
AWS Claim Key: 1848526 Trx Code: 1 Labor Hrs: 2.2
Dlr Cd-Sub Cd: 00986 - * Name: THOMASVILLE FORD, INC. Ph: 336-4727731 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:30-MAY-2003 Doc #:07606601
Cust Comments: CHECK ENGINE LITE IS ON
Tech Comments: WDS TEST PINPOINT TEST TEST ICP SENSOR CONNECTOR REPAIR SHORTED HOT WIRE CRT#C270D LB W REPLACE FUSE
1FTNW21P83ED04812 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 15-APR-2003 13-MAY-2003 121746 USA 2 2E06 030008 3C3Z 9F838 EA E29 42 1542
AWS Claim Key: 1848527 Trx Code: 1 Labor Hrs: 1.7
Dlr Cd-Sub Cd: 00986 - * Name: THOMASVILLE FORD, INC. Ph: 336-4727731 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:26-JUN-2003 Doc #:07668401
Cust Comments: CHECK ENGINE LITE IS ON, AFTER IT WARMS UP IT IDLES TOO HIGH WANTS TO PULL ITSELF
Tech Comments: WDS TEST WDS SHUT DOWN WOULD NOT COMMUNICATE CALLED HOTLINE REFLASH FICM TCM PCM PER HOTLINE REPLACED ICP SENSOR
1FTNW21P83ED04812 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 15-APR-2003 13-MAY-2003 121746 USA 13 2E05 100106 3C3Z 9B249 AB G29 42 20757
AWS Claim Key: 6122085 Trx Code: E84 Labor Hrs: 2
Dlr Cd-Sub Cd: 00986 - * Name: THOMASVILLE FORD, INC. Ph: 336-4727731 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:21-MAY-2004 Doc #:08365301
Cust Comments: WATER IN FUEL LIGHT ON TWICE LAST TIME ABOUT A WEEK AGO 00?
Tech Comments: REPLACE FUEL MODULE
1FTNW21P83ED04812 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 15-APR-2003 13-MAY-2003 121746 USA 13 2G05 031405 * RECALEM * D13 42 20757
AWS Claim Key: 6122084 Trx Code: S07 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 00986 - * Name: THOMASVILLE FORD, INC. Ph: 336-4727731 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:21-MAY-2004 Doc #:08365305
Cust Comments: HAS A ROUGH IDLE
Tech Comments: REPROGRAM PCM FICM TCM
1FTNW21P83ED04812 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 15-APR-2003 13-MAY-2003 121746 USA 25 2E05 100106 3C3Z 9B249 AB G29 42 42725
AWS Claim Key: 10723091 Trx Code: E72 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 00986 - * Name: THOMASVILLE FORD, INC. Ph: 336-4727731 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:10-MAY-2005 Doc #:09067501
Cust Comments: WATER IN FUEL LIGHT ON DRAINED SEPERATOR LAST VISIT CAME BACK ON
Tech Comments: REPLACE WATER SEPERATOR
1FTNW21P83ED04812 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 15-APR-2003 13-MAY-2003 121746 USA 25 2H01 030008 3C3Z 6K854 DA E41 42 42725
AWS Claim Key: 10723090 Trx Code: E72 Labor Hrs: 4
Dlr Cd-Sub Cd: 00986 - * Name: THOMASVILLE FORD, INC. Ph: 336-4727731 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:10-MAY-2005 Doc #:09067502
Cust Comments: CAN SEE ON THE LEFT FENDER AT HOOD EXHAUST COMING FROM UNDER HOOD AND SMELL EXHAUST IN CAB AT TIMES
Tech Comments: R AMD R VALVE COVER R AND R TURBO REPLACE TUBE
1FTNW21P83ED04812 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 15-APR-2003 13-MAY-2003 121746 USA 27 2H01 031202 3C3Z 6K769 DA N12 42 44818
AWS Claim Key: 11290735 Trx Code: E72 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 00986 - * Name: THOMASVILLE FORD, INC. Ph: 336-4727731 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:06-JUL-2005 Doc #:09182501
Cust Comments: DRIVING HEARD A LOUD POP THEN TRUCK STARTED MAKING A WHISTLING NOISE
Tech Comments: REPLACE HOT SIDE AIR DUCT
Thanks,
Vivian
MOMBENZ is offline
post #3 of 4 (permalink) Old 12-13-2006, 01:32 PM Thread Starter
Awesome!!! Thanks so much!!!
Ace13 is offline
post #4 of 4 (permalink) Old 12-13-2006, 02:16 PM
My pleasure Ace. :Thumbup:
Vivian
MOMBENZ is offline
