Oasis Request - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by wardlandscape, this thread has received 1 replies and been viewed 455 times.
post #1 of 2 (permalink) Old 12-10-2006, 12:29 AM Thread Starter
Oasis Request
vin 1FDAW56P53EC51216
Thank you.
wardlandscape is offline
post #2 of 2 (permalink) Old 12-13-2006, 12:46 PM
Hi,
OASIS RESULT:
1FDAW56P53EC51216
12/13/2006
07:45:10
Copyright 2002-2006 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 F-SERIES BODY STYLE
F-550 CC CHASIS 4X2 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
K8 ENGINE CALIBRATION
WARNING MESSAGES
ARN MESSAGES
BEFORE REPLACING 6.0L EGR VALVE REFER TO 06-19-06
BEFORE REPLACING 6.0L TURBOCHARGER REFER TO 06-23-02
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
08/02/2003 BUILD DATE
03/06/2003 SALE MILEAGE
00069
59B01
ELIGIBLE FOR ONE-TIME CUSTOMER ASSURANCE TEST DRIVE. SEE EMISSIONS RECALL 05E15 OR 06E17 FOR DETAILS.
06E17
CONTROL MODULE RECALIBRATION
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
01/23/2006
DEALER: Akins Ford Corporation
WARRANTY CLAIM NUMBER: 060204 ODOMETER: 098905M
LABOR OP
CONDITION CODE
CONDITION DESC
PM 15 001 6005F 42 DOES NOT OPERATE PROPERLY
3C3Z 9E527AE NOZZLE ASY-FUEL INJE 003 6005F1
3C3Z 6766BA CAP ASY OIL FILLER 001 6005F1X1
000 6005F2
000 6005F6
000 6005F8
000 6005F12
000 6005F18
000 6005F20
000 6005F22
000 9527AL
000 12650D81
PERFORM DIESEL DIAG, CODE P0284, MONITOR DATALOGGER, ALL PIDS LOOK GOOD. GO TO POWER BALANCE, START COLD, CYL 8 OFF UNTIL EOT REACHED 100 DEGREES. ROA D TEST, WHEN ACCELLING UPHILL, CYL 4 DROPPING OUT. CHECK RELATIVE COMPRESSI ON, GOOD. REPLACE CYL 4, 6, 8 INJECTORS, CLEAR CODES, ROAD TEST, RETEST, SY STEM PASS.
1FDAW56P53EC51216 T/F7 F T/BC T/EB T/B A1 T/BE T/YB 06-MAR-2003 02-AUG-2003 121480 USA 9 2G05 031405 * RECAL * P69 07 26810
AWS Claim Key: 5578843 Trx Code: E84 Labor Hrs: 1
Dlr Cd-Sub Cd: 00892 - * Name: BENSON FORD-MERCURY INC Ph: 864-8555383 St:SC Ctry Cd: USA Reg Cd: NA Repr Date:30-MAR-2004 Doc #:13913803
Cust Comments: CUSTOMER STATES TRANS SEEMS TO SLIP ON LOAD
Tech Comments: TEST SYSTEM ALL PASS NO PROBLEMS FOUND AT THIS TIME
1FDAW56P53EC51216 T/F7 F T/BC T/EB T/B A1 T/BE T/YB 06-MAR-2003 02-AUG-2003 121480 USA 11 2G01 * * * * * * 33854
AWS Claim Key: 6342347 Trx Code: 03L12 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 00402 - * Name: AKINS FORD CORPORATION Ph: 770-8679136 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:01-JUN-2004 Doc #:09601250
Cust Comments: RECALL 03L12
Tech Comments: RECALL 03L12 RECALL INSTALL EECI LABEL
1FDAW56P53EC51216 T/F7 F T/BC T/EB T/B A1 T/BE T/YB 06-MAR-2003 02-AUG-2003 121480 USA 11 2E06 030008 3C3Z 9E527 AE D42 42 33854
AWS Claim Key: 6342348 Trx Code: S07 Labor Hrs: 3.6
Dlr Cd-Sub Cd: 00402 - * Name: AKINS FORD CORPORATION Ph: 770-8679136 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:01-JUN-2004 Doc #:09601255
Cust Comments: CK FOR VEH HAS LOW POWER,AND IS SLUGGISH ON TAKE OFFS
Tech Comments: PERFORM DIESEL DIAG, CODES P0231, P0266, P0267, P0270, P0279, P0284, P2614, P2617, TRUCK SKIPPING BADLY. REPROGRAM PCM, FICM, & TCM TO VERSION 31.5. STILL SKIPPING, GO TO POWER BALANCE, CYL 4 & 8 OFF AT ALL TIMES & CYL 2 INTERMITTENT. CK RELATIVE COMPRESSION, OK, 0% LOSS. REPLACE CYL 2, 4, & 8 INJECTORS, INSTALL OIL RAIL, REASSEMBLE. CLEAR CODES, ROAD TEST, RETEST, PASS.
1FDAW56P53EC51216 T/F7 F T/BC T/EB T/B A1 T/BE T/YB 06-MAR-2003 02-AUG-2003 121480 USA 24 * * * * * * * 79478
AWS Claim Key: 11389290 Trx Code: 04S15 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 00976 - * Name: D & D MOTORS, INC. Ph: 864-8770711 St:SC Ctry Cd: USA Reg Cd: NA Repr Date:13-JUL-2005 Doc #:23787102
Cust Comments: 04S15 RECALL
Tech Comments: TECH 644 RECALL 04S15 REPLACED GROUND STUD
1FDAW56P53EC51216 T/F7 F T/BC T/EB T/B A1 T/BE T/YB 06-MAR-2003 02-AUG-2003 121480 USA 27 2E06 030008 3C3Z 9F838 EA L65 D1 88443
AWS Claim Key: 12273293 Trx Code: E72 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 00402 - * Name: AKINS FORD CORPORATION Ph: 770-8679136 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:07-OCT-2005 Doc #:04868655
Cust Comments: OIL LEAK ON LEFT SIDE
Tech Comments: ICP LEAKING SENSOR INJECTION CONTROL PRESSURE (ICP) REPLACE
1FDAW56P53EC51216 T/F7 F T/BC T/EB T/B A1 T/BE T/YB 06-MAR-2003 02-AUG-2003 121480 USA 27 2E06 030008 3C3Z 9E527 AE D42 42 88443
AWS Claim Key: 12296279 Trx Code: E72 Labor Hrs: 6.8
Dlr Cd-Sub Cd: 00402 - * Name: AKINS FORD CORPORATION Ph: 770-8679136 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:07-OCT-2005 Doc #:04868656
Cust Comments: CUST STATES WHEN STARTED COLD SKIPS & NO POWER, OK AFTER WARM
Tech Comments: PERFORM DIESEL DIAG, CODES P2269, P0266, P0269, SKIPPING COLD, WATER IN FUEL LIGHT ON, DRAIN, LIGHT STILL ON. REPLACE WATER IN FUEL MODULE. GO TO POWER BALANCE, CYL 2 & 3 OFF. CHECK RELATIVE COMPRESSION, OK. REPLACE CYL 2 & 3 INJECTORS, CLEAR CODES, REPROGRAM PCM, FICM, & TCM TO VERSION 39.8. ROAD TEST, RETEST, PASS.
1FDAW56P53EC51216 T/F7 F T/BC T/EB T/B A1 T/BE T/YB 06-MAR-2003 02-AUG-2003 121480 USA 31 2E06 030008 3C3Z 9E527 AE D42 42 98905
AWS Claim Key: 13036562 Trx Code: E72 Labor Hrs: 4.8
Dlr Cd-Sub Cd: 00402 - * Name: AKINS FORD CORPORATION Ph: 770-8679136 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:23-JAN-2006 Doc #:06020455
Cust Comments: CUST STATES SKIPPING ON ACCELERATION & SMOKING CUST WILL PICK LOANER UP ON SAT OKAY PER SCOTT S.
Tech Comments: PERFORM DIESEL DIAG, CODE P0284, MONITOR DATALOGGER, ALL PIDS LOOK GOOD. GO TO POWER BALANCE, START COLD, CYL 8 OFF UNTIL EOT REACHED 100 DEGREES. ROAD TEST, WHEN ACCELLING UPHILL, CYL 4 DROPPING OUT. CHECK RELATIVE COMPRESSION, GOOD. REPLACE CYL 4, 6, 8 INJECTORS, CLEAR CODES, ROAD TEST, RETEST, SYSTEM PASS.
Thanks,
Vivian
MOMBENZ is offline
