OASIS Report - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by CombatSent, this thread has received 1 replies and been viewed 420 times.
post #1 of 2 (permalink) Old 12-10-2006, 01:26 PM Thread Starter
OASIS Report
I would very much appreciate it if someone could get me an OASIS report for my truck.
Vin# 1ftsw31p93ed65045
Thanks for the help.
CombatSent is offline
post #2 of 2 (permalink) Old 12-13-2006, 12:51 PM
Good Morning,
OASIS RESULT:
1FTSW31P93ED65045
12/13/2006
07:49:55
Copyright 2002-2006 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
D1 ENGINE CALIBRATION
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL CONTACT
ARN MESSAGES
BEFORE REPLACING 6.0L EGR VALVE REFER TO 06-19-06
BEFORE REPLACING 6.0L TURBOCHARGER REFER TO 06-23-02
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
07/11/2003 BUILD DATE
06/04/2003 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
03/15/2006
DEALER: Century Ford of Mt Airy, Inc.
WARRANTY CLAIM NUMBER: 189464 ODOMETER: 097142M
LABOR OP
CONDITION CODE
CONDITION DESC
000 06E17B
PERFORM RECALL PER INSTRUCTIONS
03/15/2006
LABOR OP
CONDITION CODE
CONDITION DESC
000 59B01A
1FTSW31P93ED65045 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 04-JUN-2003 11-JUL-2003 127044 USA 8 2H01 030008 3C3Z 6K682 AARM N12 42 24036
AWS Claim Key: 4587552 Trx Code: S07 Labor Hrs: 5.4
Dlr Cd-Sub Cd: 00042 - * Name: THE FREDERICK MOTOR COMPANY Ph: 301-6636111 St:MD Ctry Cd: USA Reg Cd: NA Repr Date:17-FEB-2004 Doc #:388447A
Cust Comments: CUSTOMER STATES WHISTLING NOISE IN ENGINE
Tech Comments: 24039 INSPECT AIR INTAKE SYSTEM REMOVE AND INSPECT TUBO EXHAUST SYSTEM INSTALL WDS AND EXERZISE VGT SOLINOID REPLACE TURBO ASSEMBLY REPROGRAM PCM ROAD TEST OK
1FTSW31P93ED65045 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 04-JUN-2003 11-JUL-2003 127044 USA 9 2H01 030008 3C3Z 6K854 DA N11 01 27123
AWS Claim Key: 5964402 Trx Code: E84 Labor Hrs: 0
Dlr Cd-Sub Cd: 00042 - * Name: THE FREDERICK MOTOR COMPANY Ph: 301-6636111 St:MD Ctry Cd: USA Reg Cd: NA Repr Date:22-MAR-2004 Doc #:391129A
Cust Comments: CUSTOMER STATES TURBO MAKING LOUD WHINING NOISE AT IDLE
Tech Comments: 27135 TURBO INLET PIPE INSPECT ENGINE CONDITION FOR NOISE RUN OASIS REPORT CONTACT HOT LINE (REPORT #4CVBMO1O) INSTALL WDS AND MONITOR PIDS WHILE CHANGING VGT AND EGR REMOVE INTAKE AND INSPECT EGR COOLER GASKET AT EXHAUST INLET PER HOT LINE REASSEMBLY AND ROAD TEST NO FIX BUT NOISE CHANGED LISTEN FOR NOISE WITH STETHOSCOPE FOUND NOISE AT TURBO INLET REMOVE TURBOINLET REMOVE TURBO A
1FTSW31P93ED65045 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 04-JUN-2003 11-JUL-2003 127044 USA 10 4C01 090100 3C3Z 5A231 AA N12 31 28380
AWS Claim Key: 5577690 Trx Code: E84 Labor Hrs: 8
Dlr Cd-Sub Cd: 00039 - * Name: CENTURY FORD OF MT AIRY, INC Ph: 301-8315252 St:MD Ctry Cd: USA Reg Cd: NA Repr Date:07-APR-2004 Doc #:170412A
Cust Comments: HEAR NOISE LIKE VACUUM LEAK AROUND TURBO
Tech Comments: HEARD NOISE NOT A NORMAL NOISE AS TOLD PER FREDERICK MOTOR CO EXHAUST LEAK AT TURBO AND FLEX PIPE I LOOSENED ALL INTER COOLER PIPES AND TURBO COULD NOT GET LINED UP FREDERICK DIDNT TIGHTEN IN CORRECT ORDER TO FIX HAD TO REMOVE AND REPLACE TRANS COMPLFREDERICK INSTALLED ALSO HAD TO REPLACE CLAMP AT DOWN PIPE TO TURBO THAT WAS OVER TIGHTENED RECHEC KED TOPPED OFF TRANS FLUID OK NOW
1FTSW31P93ED65045 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 04-JUN-2003 11-JUL-2003 127044 USA 28 2E06 030008 3C3Z 9F838 EA L65 D1 82757
AWS Claim Key: 12217554 Trx Code: E72 Labor Hrs: 1.8
Dlr Cd-Sub Cd: 00039 - * Name: CENTURY FORD OF MT AIRY, INC Ph: 301-8315252 St:MD Ctry Cd: USA Reg Cd: NA Repr Date:13-OCT-2005 Doc #:185335A
Cust Comments: CHECK FOR OIL LEAK TOP BACK OF ENG
Tech Comments: CHECKED FOR OIL LEAK, INSTALLED DYE, RAN, CHECKED WITH BLACK LIGHT, FOUND ICP SENSOR LEAKING, TEST DROVE, OK, MAY HAVE SOME EXCESSIVE OIL IN BELL HOUSING
1FTSW31P93ED65045 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 04-JUN-2003 11-JUL-2003 127044 USA 33 * * * * * * * 97142
AWS Claim Key: 13322601 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 00039 - * Name: CENTURY FORD OF MT AIRY, INC Ph: 301-8315252 St:MD Ctry Cd: USA Reg Cd: NA Repr Date:15-MAR-2006 Doc #:189464A
Cust Comments: 06E17 CONTROL MODULE RECALIBRATION PROGRAM
Tech Comments: PERFORM RECALL PER INSTRUCTIONS
AWS Claim Key: 13322602 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 00039 - * Name: CENTURY FORD OF MT AIRY, INC Ph: 301-8315252 St:MD Ctry Cd: USA Reg Cd: NA Repr Date:15-MAR-2006 Doc #:189464B
Cust Comments: RECALL 59B01
Thanks,
Vivian
MOMBENZ is offline
