oasis report please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by detailman, this thread has received 2 replies and been viewed 613 times.
post #1 of 3 (permalink) Old 12-12-2006, 03:53 PM Thread Starter
Banned
oasis report please
just wondering what all is on this report here is my vin number.
1FTWF31P46EA81957
thanks brian
oh just wondering how long this normally takes thanks again
detailman is offline
post #2 of 3 (permalink) Old 12-13-2006, 12:53 PM
Hi Brian,
OASIS RESULT:
1FTWF31P46EA81957
12/13/2006
07:52:02
Copyright 2002-2006 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2006 F-SERIES BODY STYLE
F-350 RC PICKUP 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
6F710D0A
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL CONTACT
ARN MESSAGES
BEFORE REPLACING 6.0L EGR VALVE REFER TO 06-19-06
BEFORE REPLACING 6.0L TURBOCHARGER REFER TO 06-23-02
BEFORE REPLACING HIGH PRESS. PUMP FOR HARD START OR OIL LEAK, SEE TSB 06-17-06
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
06/16/2006 BUILD DATE
08/03/2005 SALE MILEAGE
00010
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
11/21/2006
DEALER: Raabe Motor Sales, Inc.
WARRANTY CLAIM NUMBER: 053493 ODOMETER: 014000M
LABOR OP
CONDITION CODE
CONDITION DESC
F81Z 7A029AA GEAR-TRANS LOW 001 07 IMPROPERLY ADJUSTED/FITS POORLY
REPLACE CHAIN
10/26/2006
DEALER: Kerns Ford-Lincoln-Mercury, In
WARRANTY CLAIM NUMBER: 098151 ODOMETER: 013428M
LABOR OP
CONDITION CODE
CONDITION DESC
F75Z 1565501AA ADJUSTER FRT SEAT BK 001 MT165501 42 DOES NOT OPERATE PROPERLY
TESTED VERIFIED CONCERN VISUALLY INSPECTED LUMBAR TESTED THE VERIFEID CONCER N CHECKED THE LUMBAR SUPPORT VERFIEID CONCERN RR THE SEAT BACK TESTED THE LU MBAR NOT WORKING RR THE SEAT BACK REPLACED THE LUMBAR SUPPORT INSIDE THE BAC K OF SEAT REASSEMBLED AND RTESTED AGAIN SEVERAL TIMES OK MT TIME TO REMOVE A ND REPLACE LUMBAR SUPPORT
10/26/2006
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 6K682DA TURBO CHG-EXH DRIVE 001 9438A 42 DOES NOT OPERATE PROPERLY
W300013 004
W300051 004
TEST DROVE VERIFIED CONCERN VISUALLY INSPECTED FOR NOISE RAN OASIS REMOVED T URBO TUBES INSPECTED SHAFT ON TURBO TURBO LEAKING OIL BAD SHAFT RAN TEST ON TURBO TRIED TO CLEAN TURBO DID NOT HELP REPLACED TURBO AND RETEST DROVE AGAI N TEST DROVE FINE NO CODES FOR NOISE FROM TURBO AREA
10/26/2006
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 6051EA GASKET CYL HEAD 002 6051AT D8 FAILED GASKET/SEAL
3C3Z 9229AA GASKET CARB FUEL INL 008 6051A20
4C3Z 9P456AF COOLER - EGR 001 8005D
VC 7B 002
XO 10W30QSD 015
3C3Z 6731AA ELEMENT ASY OIL FILT 001
INSPECTED VISUALLY DID NOT SEE ANY COOLANT PRESSURE TESTED THE COOLING SYSTE M FOUND COOLANT FORCING OU THE OVERFLOW TANK TRIED TO REPLACE CAP RAN COMBUS TION GAS TEST ON THE COOLING SYSTEM FOUND COMBUSTION GASES IN ENGIEN DISASSE MBLED ENG TO BLOCK FOUND HEAD GASKETS BLOWN REPLACED BOTH HEAD GASKETS AND E GR COOLER CHANGED OIL AND FILTER FOR REPAIR OK
09/13/2006
DEALER: Lucas Ford
WARRANTY CLAIM NUMBER: 288134 ODOMETER: 009506M
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 3B396BA LOCKING HUB ASSEMBLY 001 1105A 42 DOES NOT OPERATE PROPERLY
000 MTDIAG
9506 44 WOULD WORK INTERMITTENTLY. FOUND RIGHT HUB NOT ALWAYS LOCKING IN. R EPLACE HUB ASSEMBLY TOOK CUST FOR TEST DRIVE.
09/07/2006
DEALER: Lucas Ford
WARRANTY CLAIM NUMBER: 287894 ODOMETER: 009011M
LABOR OP
CONDITION CODE
CONDITION DESC
000 MTDIAG
9011 44 INOP FOUND RIGHT FRONT HUB BAD ORDER HUB REPLACE LEFT HUB ASSEMBLT R ETEST DRIVE OK
09/07/2006
DEALER: Lucas Ford
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 2C006AA CONTR ASY-TRLR MOD 001 2006D 42 DOES NOT OPERATE PROPERLY
000 2006D1
000 2006D2
9011 2006D, 2006D1,. 2006D2 .2, .3, .2 CONTOLLER STUCK ON 10 TRAILER BRAKE CONTROLLER TEST PASSED TRAILER DIAG REPLACE BRAKE CONTROLL
08/18/2006
DEALER: Lucas Ford
WARRANTY CLAIM NUMBER: 287133 ODOMETER: 001937M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 9942528AA PLATE-LUGG COMPT T G 001 B 33 LOOSE PART
LT DOOR EMBLEM LETTERING PEELING. REMOVE CLEAN ADHESIVE AND REPLACE WITH NE W.
06/28/2006
DEALER: Lucas Ford
WARRANTY CLAIM NUMBER: 285287 ODOMETER: 001383M
LABOR OP
CONDITION CODE
CONDITION DESC
3520124 DOOR ASY-FRONT 000 20124A 07 IMPROPERLY ADJUSTED/FITS POORLY
RT FRT DOOR NOT ADJUSTED CAUSING WIND NOISE.ADJ UST STRIKER AND DOOR IN AT TOP.TEST DRIVE TO CH ECK WIND LEAK.PROBLEM CORRECTED.
06/28/2006
DEALER: Lucas Ford
LABOR OP
CONDITION CODE
CONDITION DESC
16005 FENDER ASY FRONT 000 B D4 FLAW IN MATERIAL
DIRT IN LT AND RT FENDERS. WETS SAND AND BUFF O UT.
1FTWF31P46EA81957 T/F7 F T/BB T/CD T/E A1 T/BE T/YB 03-AUG-2005 16-JUN-2006 148079 USA 1 6P05 010301 * 3520124 * B02 07 1383
AWS Claim Key: 1237221 Trx Code: 2 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 08505 - * Name: LUCAS FORD Ph: 419-2243673 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:28-JUN-2006 Doc #:285287A
Cust Comments: RT FRT DOOR OUT OF ALIGNMENT
Tech Comments: RT FRT DOOR NOT ADJUSTED CAUSING WIND NOISE.ADJ UST STRIKER AND DOOR IN AT TOP.TEST DRIVE TO CH ECK WIND LEAK.PROBLEM CORRECTED.
1FTWF31P46EA81957 T/F7 F T/BB T/CD T/E A1 T/BE T/YB 03-AUG-2005 16-JUN-2006 148079 USA 1 6A01 010203 * 16005 * F20 D4 1383
AWS Claim Key: 1237222 Trx Code: 2 Labor Hrs: 1
Dlr Cd-Sub Cd: 08505 - * Name: LUCAS FORD Ph: 419-2243673 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:28-JUN-2006 Doc #:285287B
Cust Comments: DIRT IN RT AND LT FENDERS
Tech Comments: DIRT IN LT AND RT FENDERS. WETS SAND AND BUFF O UT.
1FTWF31P46EA81957 T/F7 F T/BB T/CD T/E A1 T/BE T/YB 03-AUG-2005 16-JUN-2006 148079 USA 3 6N04 010805 5C3Z 9942528 AA B66 33 1937
AWS Claim Key: 1632806 Trx Code: 2 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 08505 - * Name: LUCAS FORD Ph: 419-2243673 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:18-AUG-2006 Doc #:287133A
Cust Comments: REPLACE LT DOOR EMBLEM POWER STROKE TURBO DIESEL
Tech Comments: LT DOOR EMBLEM LETTERING PEELING. REMOVE CLEAN ADHESIVE AND REPLACE WITH NEW.
1FTWF31P46EA81957 T/F7 F T/BB T/CD T/E A1 T/BE T/YB 03-AUG-2005 16-JUN-2006 148079 USA 3 5B04 050306 6C3Z 3B396 BA P82 42 9011
AWS Claim Key: 1705182 Trx Code: 2 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 08505 - * Name: LUCAS FORD Ph: 419-2243673 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:07-SEP-2006 Doc #:287894A
Cust Comments: 4 X 4 IS INOP
Tech Comments: 9011 44 INOP FOUND RIGHT FRONT HUB BAD ORDER HUB REPLACE LEFT HUB ASSEMBLT RETEST DRIVE OK
1FTWF31P46EA81957 T/F7 F T/BB T/CD T/E A1 T/BE T/YB 03-AUG-2005 16-JUN-2006 148079 USA 3 7T03 061003 6C3Z 2C006 AA H20 42 9011
AWS Claim Key: 1705183 Trx Code: 2 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 08505 - * Name: LUCAS FORD Ph: 419-2243673 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:07-SEP-2006 Doc #:287894B
Cust Comments: TRAILER CONTROL BRAKE STUCK ON 10 SETTING
Tech Comments: 9011 2006D, 2006D1,. 2006D2 .2, .3, .2 CONTOLLER STUCK ON 10 TRAILER BRAKE CONTROLLER TEST PASSED TRAILER DIAG REPLACE BRAKE CONTROLL
1FTWF31P46EA81957 T/F7 F T/BB T/CD T/E A1 T/BE T/YB 03-AUG-2005 16-JUN-2006 148079 USA 3 5B04 050306 6C3Z 3B396 BA N50 42 9506
AWS Claim Key: 1822865 Trx Code: E93 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 08505 - * Name: LUCAS FORD Ph: 419-2243673 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:13-SEP-2006 Doc #:288134A
Cust Comments: RF HUB NOT ENGAGING
Tech Comments: 9506 44 WOULD WORK INTERMITTENTLY. FOUND RIGHT HUB NOT ALWAYS LOCKING IN. REPLACE HUB ASSEMBLY TOOK CUST FOR TEST DRIVE.
1FTWF31P46EA81957 T/F7 F T/BB T/CD T/E A1 T/BE T/YB 03-AUG-2005 16-JUN-2006 148079 USA 5 6E01 0110XX F75Z 1565501 AA S06 42 13428
AWS Claim Key: 2263401 Trx Code: E84 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 01899 - * Name: KERNS FORD-LINCOLN-MERCURY, INC. Ph: 419-3947691 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:26-OCT-2006 Doc #:09815101
Cust Comments: CUSTOMER STATES DRIVERS LUMBAR INOP
Tech Comments: TESTED VERIFIED CONCERN VISUALLY INSPECTED LUMBAR TESTED THE VERIFEID CONCERN CHECKED THE LUMBAR SUPPORT VERFIEID CONCERN RR THE SEAT BACK TESTED THE LUMBAR NOT WORKING RR THE SEAT BACK REPLACED THE LUMBAR SUPPORT INSIDE THE BACK OF SEAT REASSEMBLED AND RTESTED AGAIN SEVERAL TIMES OK MT TIME TO REMOVE AND REPLACE LUMBAR SUPPORT
1FTWF31P46EA81957 T/F7 F T/BB T/CD T/E A1 T/BE T/YB 03-AUG-2005 16-JUN-2006 148079 USA 5 2H01 030407 5C3Z 6K682 DA D42 42 13428
AWS Claim Key: 2263402 Trx Code: S07 Labor Hrs: 2
Dlr Cd-Sub Cd: 01899 - * Name: KERNS FORD-LINCOLN-MERCURY, INC. Ph: 419-3947691 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:26-OCT-2006 Doc #:09815103
Cust Comments: CUSTOMER STATES TURBO NOISEY
Tech Comments: TEST DROVE VERIFIED CONCERN VISUALLY INSPECTED FOR NOISE RAN OASIS REMOVED TURBO TUBES INSPECTED SHAFT ON TURBO TURBO LEAKING OIL BAD SHAFT RAN TEST ON TURBO TRIED TO CLEAN TURBO DID NOT HELP REPLACED TURBO AND RETEST DROVE AGAIN TEST DROVE FINE NO CODES FOR NOISE FROM TURBO AREA
1FTWF31P46EA81957 T/F7 F T/BB T/CD T/E A1 T/BE T/YB 03-AUG-2005 16-JUN-2006 148079 USA 5 1A02 030102 4C3Z 6051 EA L87 D8 13428
AWS Claim Key: 2263403 Trx Code: E84 Labor Hrs: 14.9
Dlr Cd-Sub Cd: 01899 - * Name: KERNS FORD-LINCOLN-MERCURY, INC. Ph: 419-3947691 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:26-OCT-2006 Doc #:09815105
Cust Comments: CUSTOMER STATES VEHICLE LEAKING COOLANT
Tech Comments: INSPECTED VISUALLY DID NOT SEE ANY COOLANT PRESSURE TESTED THE COOLING SYSTEM FOUND COOLANT FORCING OU THE OVERFLOW TANK TRIED TO REPLACE CAP RAN COMBUSTION GAS TEST ON THE COOLING SYSTEM FOUND COMBUSTION GASES IN ENGIEN DISASSEMBLED ENG TO BLOCK FOUND HEAD GASKETS BLOWN REPLACED BOTH HEAD GASKETS AND EGR COOLER CHANGED OIL AND FILTER FOR REPAIR OK
1FTWF31P46EA81957 T/F7 F T/BB T/CD T/E A1 T/BE T/YB 03-AUG-2005 16-JUN-2006 148079 USA 6 3Y02 070701 F81Z 7A029 AA K01 07 14000
AWS Claim Key: 2308883 Trx Code: E90 Labor Hrs: 0
Dlr Cd-Sub Cd: 02188 - * Name: RAABE MOTOR SALES, INC. Ph: 419-6920055 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:21-NOV-2006 Doc #:053493A
Cust Comments: CHAIN IS TOO LOOSE
Tech Comments: REPLACE CHAIN
Thanks,
Vivian
MOMBENZ is offline
post #3 of 3 (permalink) Old 12-13-2006, 10:20 PM Thread Starter
Banned
mombenz i really appreciate this. i would give you a thanks for this post but i dont know how to.
