OASIS Report - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by blownwhite03, this thread has received 2 replies and been viewed 423 times.
post #1 of 3 (permalink) Old 12-13-2006, 02:53 AM Thread Starter
OASIS Report
Please.
vin#1ftww31p75eb86104
blownwhite03 is offline
post #2 of 3 (permalink) Old 12-13-2006, 12:57 PM
Hi,
OASIS RESULT:
1FTWW31P75EB86104
12/13/2006
07:56:12
Copyright 2002-2006 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
WARNING MESSAGES
ARN MESSAGES
BEFORE REPLACING HIGH PRESS. PUMP FOR HARD START OR OIL LEAK, SEE TSB 06-17-06
BEFORE REPLACING 6.0L TURBOCHARGER REFER TO 06-23-02
BEFORE REPLACING 6.0L EGR VALVE REFER TO 06-19-06
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
01/20/2005 BUILD DATE
01/09/2005 SALE MILEAGE
00028
05B32
DE-GAS BOTTLE FILL LEVEL LABEL AND FLUID LEVEL ADJUSTMENT
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
02/20/2006
DEALER: Olathe Ford Sales, Inc.
WARRANTY CLAIM NUMBER: 038005 ODOMETER: 038031M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9E527AA NOZZLE ASY-FUEL INJE 004 6005F 42 DOES NOT OPERATE PROPERLY
000 6005F1
000 6005F2
000 6005F6
000 6005F11
000 6005F12
000 6005F18
000 9527AL
000 VERIFY60
PERFORM ENGINE PERFORMANCE DIAG HARD START FROM INJECTORS 2 4 6 8 NOT WORKIN G WHEN COLD REMOVE AND REPL 2 4 6 8 RETEST AND DRIVE
02/20/2006
LABOR OP
CONDITION CODE
CONDITION DESC
4C4Z 8592AA CONNECTION-CYL HD WA 001 8005D D8 FAILED GASKET/SEAL
6C3Z 6C646AA DUCT ASY-ENG CHG AIR 001 6646AH
000 MT8592
CHK FOR FLUID LEAK COOLANT LEAK PRESSURE TEST COOLANT SYSTEM EGR COOLER HOSE LEAKING DISASSEMBLE AND REPL COOLER HOSE RETEST ALSO FOUND HOTSIDE INTERCOO LER TUBE LEAKING OIL REPL INTERCOOLER HOSE CLEAN AND RETEST
01/11/2006
WARRANTY CLAIM NUMBER: 034784 ODOMETER: 034530M
LABOR OP
CONDITION CODE
CONDITION DESC
7820124 DOOR ASY-FRONT 000 20124A 07 IMPROPERLY ADJUSTED/FITS POORLY
CHK PASS DOOR OUT OF ADJUSTMENT ADJUST DOOR RETEST
01/11/2006
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 9J460A SENSOR ASY EGR PR VL 001 05E15G
COMPLETE RECALL
01/11/2006
LABOR OP
CONDITION CODE
CONDITION DESC
000 59B01A
COMPLETE PROGRAM
11/15/2005
DEALER: Visteon Aftermarket - U.S.
WARRANTY CLAIM NUMBER: 650248 ODOMETER: 027782M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3T 18C868AH DUAL MEDIA RADIO T10 000 42 DOES NOT OPERATE PROPERLY
PI30 001
REQUESTING DEALER'S P/A CODE 02840
1FTWW31P75EB86104 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 09-JAN-2005 20-JAN-2005 153006 USA 1 7D03 170106 F81Z 15442 AA L29 39 11
AWS Claim Key: 443545 Trx Code: MVC Labor Hrs: 3
Dlr Cd-Sub Cd: 03964 - * Name: EXTREME FORD, INC. Ph: 913-3231600 St:KS Ctry Cd: USA Reg Cd: NA Repr Date:21-JAN-2005 Doc #:257335A
Tech Comments: MISBUILT VEH CLAIM. VEH DELIVERED WITHOUT CLEARANCE LIGHTS ABOV. R&I HEADLINER. MEASURE ROOF ARBA FOR 5 HOLES ACCROSS FRONT EDGE OF ROOF FOR INSTALLING LIGHTS. DRILL 5 HOLES FOR ACCESSING WIRE LOOMS. ATTACH WIRES TO LIGHTS. POSITION BACK LIGHTS ACROSS FRONT EDGE OF ROOF DRILL TWO MORE MOUNT HOLES PER LIGHT A TOTAL OF 15 HOLES. REMOVE LIGHTS SPOT REFINISH FRONT EDGE OF ROOF TO PROTECT FR
1FTWW31P75EB86104 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 09-JAN-2005 20-JAN-2005 153006 USA 10 7M01 150102 5C3T 18C868 AH A07 42 27782
AWS Claim Key: 3013994 Trx Code: E83 Labor Hrs: 0
Dlr Cd-Sub Cd: 48915 - * Name: VISTEON AFTERMARKET - U.S. Ph: *-* St:MI Ctry Cd: USA Reg Cd: NA Repr Date:15-NOV-2005 Doc #:65024800
Tech Comments: REQUESTING DEALER'S P/A CODE 02840
1FTWW31P75EB86104 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 09-JAN-2005 20-JAN-2005 153006 USA 11 7M01 150101 * 18806 * A16 42 27782
AWS Claim Key: 2555887 Trx Code: E83 Labor Hrs: 0
Dlr Cd-Sub Cd: 02840 - * Name: MARCUS ALLEN'S BROADWAY FORD, INC. Ph: 816-7534915 St:MO Ctry Cd: USA Reg Cd: NA Repr Date:23-NOV-2005 Doc #:104876A
Cust Comments: CORRECT WILL NOT ACCEPT CDS
Tech Comments: OSL TO REMOVE AND INSTALL RADIO FOR REPAIR
1FTWW31P75EB86104 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 09-JAN-2005 20-JAN-2005 153006 USA 12 6F18 010301 * 7820124 * R22 07 34530
AWS Claim Key: 3163623 Trx Code: E84 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 05238 - * Name: OLATHE FORD SALES, INC. Ph: 913-7820881 St:KS Ctry Cd: USA Reg Cd: NA Repr Date:11-JAN-2006 Doc #:03478451
Cust Comments: WIND NOISE PASSENGER SIDE DOOR AT HWY SPEEDS
Tech Comments: CHK PASS DOOR OUT OF ADJUSTMENT ADJUST DOOR RETEST
1FTWW31P75EB86104 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 09-JAN-2005 20-JAN-2005 153006 USA 12 * * * * * * * 34530
AWS Claim Key: 3129125 Trx Code: 05E15 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 05238 - * Name: OLATHE FORD SALES, INC. Ph: 913-7820881 St:KS Ctry Cd: USA Reg Cd: NA Repr Date:11-JAN-2006 Doc #:03478452
Cust Comments: 05E15 EXHAUST PRESSURE SENSOR REPL
Tech Comments: COMPLETE RECALL
AWS Claim Key: 3129126 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 05238 - * Name: OLATHE FORD SALES, INC. Ph: 913-7820881 St:KS Ctry Cd: USA Reg Cd: NA Repr Date:11-JAN-2006 Doc #:03478453
Cust Comments: 59B01 ONE TIME CUSTOMER ASSURANCE ROAD TEST
Tech Comments: COMPLETE PROGRAM
1FTWW31P75EB86104 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 09-JAN-2005 20-JAN-2005 153006 USA 14 2E06 030008 4C3Z 9E527 AA D03 42 38031
AWS Claim Key: 3707547 Trx Code: S07 Labor Hrs: 4.1
Dlr Cd-Sub Cd: 05238 - * Name: OLATHE FORD SALES, INC. Ph: 913-7820881 St:KS Ctry Cd: USA Reg Cd: NA Repr Date:20-FEB-2006 Doc #:03800551
Cust Comments: HAS A LONG CRANK ON START UP AFTER STARTED RUNS ROUGH SPUTTERS AND DIES
Tech Comments: PERFORM ENGINE PERFORMANCE DIAG HARD START FROM INJECTORS 2 4 6 8 NOT WORKING WHEN COLD REMOVE AND REPL 2 4 6 8 RETEST AND DRIVE
1FTWW31P75EB86104 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 09-JAN-2005 20-JAN-2005 153006 USA 14 1G01 03XXXX 4C4Z 8592 AA L87 D8 38031
AWS Claim Key: 3707548 Trx Code: E72 Labor Hrs: 5.2
Dlr Cd-Sub Cd: 05238 - * Name: OLATHE FORD SALES, INC. Ph: 913-7820881 St:KS Ctry Cd: USA Reg Cd: NA Repr Date:20-FEB-2006 Doc #:03800552
Cust Comments: CHK FOR A FLUID LEAK ON THE TOP OF ENGINE CUST THINTS IT IS FUEL CUST STATES BOTH THE RUNNING CONDITION AND LEAK STARTED AFTER FUELING
Tech Comments: CHK FOR FLUID LEAK COOLANT LEAK PRESSURE TEST COOLANT SYSTEM EGR COOLER HOSE LEAKING DISASSEMBLE AND REPL COOLER HOSE RETEST ALSO FOUND HOTSIDE INTERCOOLER TUBE LEAKING OIL REPL INTERCOOLER HOSE CLEAN AND RETEST
Thanks,
Vivian
MOMBENZ is offline
post #3 of 3 (permalink) Old 12-14-2006, 12:50 AM Thread Starter
Thanks!
