OASIS Report Please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by bakantor, this thread has received 2 replies and been viewed 648 times.
post #1 of 3 (permalink) Old 01-02-2007, 05:13 AM Thread Starter
Smile OASIS Report Please
VIN: 1FMSU45P14EA71061
Thanks in advance!
Brad
bakantor is offline
post #2 of 3 (permalink) Old 01-03-2007, 01:50 AM
Squatch's Avatar
OASIS RESULT:
1FMSU45P14EA71061
01/02/2007
20:50:41
FCXWS44
© Copyright 2002-2006 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 EXCURSION BODY STYLE
4 DR EDDIE BAUER 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL CONTACT
ARN MESSAGES
BEFORE REPLACING FUEL INJECTORS FOR COLD ENGINE OPERATION SEE TSB 06-22-03
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
12/16/2003 BUILD DATE
09/15/2003 SALE MILEAGE
00025
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
12/04/2006
DEALER: Metropolitan Ford, LLC
WARRANTY CLAIM NUMBER: 121815 ODOMETER: 061162M
LABOR OP
CONDITION CODE
CONDITION DESC
6C2Z 11002AA STARTER MOTOR ASY 001 10200AB 42 DOES NOT OPERATE PROPERLY
000 14200A
000 11000A
000 11002A
000 MTDIAG
CC 42 BASIC 11002 RAV BATTERY WERE DEAD, TRIED TO CHARGE THE BATTERY BUT S PARKS CAME OFF THE BATTERYS. DISCONNECTED BOTH BATTERY AND CHARGED . WHEN TH E BATTERY WERE CHARGED TRIED TO HOOK THE BATTERY CABELS BACK UP BUT THE STAR T WOULD TURN OVER. TESTED THE STARTER RELAY, GOOD. INSPECTED THE IGNTION SWI TCH AND WIRE, FOUND WIRE 1522 DG OPEN BY THE SWITCH, REPAIRED THE WIRE AND
08/16/2006
DEALER: Pearson Ford
WARRANTY CLAIM NUMBER: 313643 ODOMETER: 060974M
LABOR OP
CONDITION CODE
CONDITION DESC
RAV REACQUIRED VEHICLE 000 RAV 82 FREIGHT/POSTAGE/MAINTENANCE
PERFORMED RAV INSPECTION OTHER IS FOR 1 HOUR DIESEL ROAD TEST AND FOR FUEL
08/16/2006
LABOR OP
CONDITION CODE
CONDITION DESC
DIAG DIAGNOSIS 000 12650D 82 FREIGHT/POSTAGE/MAINTENANCE
TEST ENGINE CONTROL SYSTEM NO PROBLEM FOUND
08/16/2006
LABOR OP
CONDITION CODE
CONDITION DESC
DIAG DIAGNOSIS 000 12650D81 82 FREIGHT/POSTAGE/MAINTENANCE
08/16/2006
LABOR OP
CONDITION CODE
CONDITION DESC
DIAG DIAGNOSIS 000 12650D45 82 FREIGHT/POSTAGE/MAINTENANCE
08/16/2006
LABOR OP
CONDITION CODE
CONDITION DESC
RECAL ECC PROCESSOR RECAL 000 03T02B 79 SPECIAL CODE: USE ONLY AS INSTRUCTED
06/16/2006
DEALER: Drew Ford
WARRANTY CLAIM NUMBER: 055012 ODOMETER: 060589M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6K682BARM TURBO CHG-EXH DRIVE 001 6005F 41 STICKS/BINDS/GRABS
000 6005F1
000 12650D45
000 9438A
000 6005F1X1
VERIFY REFER TO PCED CHART 6 KOEO P123B REFER TO PINPOINT TEST KA1THRU6 TEST VGT OPERATION REPLACE STICKING TURBO ASSY RETEST KOEO PASS
06/02/2006
DEALER: Drew Ford
WARRANTY CLAIM NUMBER: 052467 ODOMETER: 061005M
LABOR OP
CONDITION CODE
CONDITION DESC
MISC FOR REPAIRS NOT COVE 000 82 FREIGHT/POSTAGE/MAINTENANCE
REFUND ENTERPRISE RAC REFUND
05/30/2006
DEALER: Drew Ford
WARRANTY CLAIM NUMBER: 051812 ODOMETER: 060004M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9E527AE NOZZLE ASY-FUEL INJE 001 6005F 41 STICKS/BINDS/GRABS
3C3Z 9C995AA RET-FU/INJ INLT TUB 001 6005F1
3C3Z 6584BA GASKET VALVE ROCKER 001 12650D45
OSP 001 6005F18
000 6005F9
000 6005F13
000 9527AL
000 6005F1X1
VERIFY REFER TO PCED CHART 6 KOEO P0262 REFER TO PINPOINT TEST P1HTUR7 TEST FUEL SAMPLE PASS FUEL PRESSURE 50PSI PASS CRANKCASE PRESSURE PASS REPALCE ST ICKING INJECTOR #2 CYL RETEST KOEO PASS PROGRAM PASS
05/10/2006
DEALER: Drew Ford
WARRANTY CLAIM NUMBER: 048621 ODOMETER: 059300M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9C995AA RET-FU/INJ INLT TUB 001 6005F13
3C3Z 6K769DA DUCT A COOLER 001 6005F14
5C3Z 6C640AA CONNECTION A/C DUCT 001 6005F1
6C3Z 6C640B CONNECTION A/C DUCT 001 6005F2
000 6005F8
000 6005F23
000 6600B
000 6005F6
000 6005F18
000 6005F20
000 6005F33
000 9527AR
000 6005F9
VERFIY REFER TO PCED CHART 6 FUEL OIL AIR PASS KOEO PASS KOEO INJ PASS OIL O IL PRESS OIL AIRIATION FUEL PRESSURE 50PSI PASS EGR OPERATION FAILED LOW BEL OW SPEC CLN52 STILL RUNS ROUGH CONT TO KOER PASS CRANKCASE PASS INJECTOR INT ERUPT PASS REPLACE STICKING INJECTOR #5 CYL RETEST OK
05/10/2006
DEALER: Drew Ford
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9F452A TRANSDCR-EGR BACK PR 001 12650D30 41 STICKS/BINDS/GRABS
VERIFY SEE LN51 CAUSING BACKFIRING SURGE CONCERN CRUISE REPLACE STICKING EG R VALVE RETEST OK
04/03/2006
DEALER: Drew Ford
WARRANTY CLAIM NUMBER: 041890 ODOMETER: 057639M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9C995AA RET-FU/INJ INLT TUB 007 6005F 42 DOES NOT OPERATE PROPERLY
4C3Z 9E527AA NOZZLE ASY-FUEL INJE 007 6005F13
3C3Z 9A543AARM PUMP ASY-FUEL INJECT 001 6005F14
3C3Z 9C968AA FUEL PRESSURE REG 001 6005F1
3C3Z 6619EA GASKET (OIL PUMP) 001 6005F2
3C3Z 9433BE GASKET SET-MANIFOLD 001 6005F8
VC 7B 002 6005F23
XO 15W40QSD 015 6005F18
3C3Z 6731AA ELEMENT ASY OIL FILT 001 6600B
3C3Z 6734AA GASKET-ENG OIL PAN D 001 6005F6
3C3Z 6A831AA GSKT-OIL FLTR ELEM S 001 9543A
3C3Z 9F838EA SENSR ASY F/I TIMING 001 12650D30
3C3Z 9J332AA TUBE ASY FUEL/LN EXT 001 9968B
3C3Z 9T288AA KIT-TUB OIL PMP (FUE 001 9527AT
4C3Z 9F452A TRANSDCR-EGR BACK PR 001 6005F9
000 6005F20
000 9838A
000 12650D45
000 6005F33
000 6005F1X1
VERFIY REFER TO PCED CHART 6 FUEL OIL AIR PASS KOEO P0401 P2290 REFER TO PIN POINT TEST W2 TEST EGR OP REPLACE STICKING EGR RETEST KOEO P2290 REFER TO AO 9THRU14 REPLACE ICP SENSOR RETEST P2290 REPLACE IPR FAILED REPALCE HIGH PRES SURE PUMP RETEST KOEO PASS STILL ROUGH CONT KOEO INJ KOER OIL AIR FUEL PRES S 50PSI OIL LOW PRESS CRANKCASE PASS INJECTOR INTERUPT FAILED REPL INJECTOR
03/08/2006
DEALER: Drew Ford
WARRANTY CLAIM NUMBER: 037279 ODOMETER: 056466M
LABOR OP
CONDITION CODE
CONDITION DESC
000 59B01A
RECALL ROAD TEST OK
03/08/2006
DEALER: Drew Ford
LABOR OP
CONDITION CODE
CONDITION DESC
000 06E17B
06E17 RECALL REPROGRAM
03/08/2006
DEALER: Drew Ford
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9E527AA NOZZLE ASY-FUEL INJE 001 6005F 41 STICKS/BINDS/GRABS
VC 7B 001 6005F14
6C3Z 9G282AA PMP & FLTR ASY-FUL 001 6005F1
6C3Z 9F759A WIRE ASY FUEL VAPOR 001 6005F2
000 6005F8
000 6005F23
000 6005F18
000 6600B
000 6005F6
000 6005F9
000 6005F19
000 6005F20
000 6005F33
000 9527AL
000 9350E
VERIFY REFER TO PCED CHART 6 FUEL OIL AIR PASS KOEO PASS KOEO INJ PASS LOW O IL AND LOW IDLE PASS EGR OP PASS CRANKCASE PASS OIL AIRIATION PASS FUEL PRE SSURE 15PSI FAILED TEST RESTRICTION 2HG PASS REPALCE FAASULTY FUEL PUMP RETE ST STILL ROUGH CONT INJ INTERUPT FAILED REPALCE STICKING INJECTOR #2 CYL RET EST OK
01/06/2006
DEALER: Drew Ford
WARRANTY CLAIM NUMBER: 025711 ODOMETER: 051727M
LABOR OP
CONDITION CODE
CONDITION DESC
OSL OUTSIDE LABOR - HERTZ
12/12/2005
DEALER: Drew Ford
WARRANTY CLAIM NUMBER: 021491 ODOMETER: 051727M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9F838EA SENSR ASY F/I TIMING 001 6007D D8 FAILED GASKET/SEAL
3C3Z 6701AA CRANKSHAFT REAR SEAL 001 6701A
OSP 001 9838A
VERIFY OIL LEAK ADD BLACK LIGHT DYE REPLACE LEAKING REAR MAIN SEAL ANDICP SE NSOR RETEST OK
12/12/2005
DEALER: Drew Ford
LABOR OP
CONDITION CODE
CONDITION DESC
F81Z 19712AA CORE ASY A/C COND 001 19700A 42 DOES NOT OPERATE PROPERLY
YN 19 056 19700A7
END OF OASIS REPORT FOR 1FMSU45P14EA71061
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
post #3 of 3 (permalink) Old 01-03-2007, 06:34 AM Thread Starter
Squatch - Thanks! It's great you're willing to do this.
Brad
bakantor is offline
