07-5-11 Vibration/hop At 40-48 Mph (68-77 Km/h) - (8.0 Hz) - Trailer Hitch Equipped V - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Squatch, this thread has received 12 replies and been viewed 7177 times.
post #1 of 13 (permalink) Old 03-22-2007, 03:38 AM Thread Starter
Squatch's Avatar
Printable View (47 KB)
TSB
07-5-11 VIBRATION/HOP AT 40-48 MPH (68-77 KM/H) - (8.0 HZ) - TRAILER HITCH EQUIPPED VEHICLES ONLY
Publication Date: March 1, 2007
FORD: 2005-2007 F-Super Duty
ISSUE:
Some 2005-2007 F-Super Duty vehicles with a long wheelbase of 156", 158", or 172" (396, 401, or 437 cm) and equipped with a trailer hitch may exhibit a vehicle vertical vibration, often described as "hopping", on smooth or coarse road surfaces in the 42-48 MPH (68-77 Km/h) speed range. Although this behavior is considered normal for an over 8500 GVW truck, some customers may be sensitive to the concern.
ACTION:
To improve the 42-48 MPH (68-77 Km/h) vertical vibration, follow the instruction sheet included in the Damper Service Kit.
NOTE: THE INSTALLATION OF THIS DAMPER WILL NOT IMPROVE RIDE ON SEGMENTED CONCRETE HIGHWAYS, STEERING WHEEL VIBRATION/SHIMMY, OR GENERAL HARSH RIDE CONCERNS.
PART NUMBER PART NAME
5C3Z-5D008-A Damper Service Kit
WARRANTY STATUS:
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
070511A 2005-2007 F-Super Duty With Trailer Hitch: Install The Damper Service Kit. 0.6 Hr.
DEALER CODING
BASIC PART NO. CONDITION CODE
5D008 42
Copyright 2007 Ford Motor Company
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
post #2 of 13 (permalink) Old 05-24-2007, 11:00 PM
Old Geezer-TDG Mafia #19
LargeCar's Avatar
Images: 9
Had this one done on my truck, it is a big honking weight mounted in rubber that goes on the left rear frame horn by the hitch mount. Can't tell that it made any differance.
LargeCar :mafia
LargeCar
Mafia # 19 The Dually Club # 19
If a country does not remember and honor its fallen heroes of the past, in the future that country will not be honored or remembered.
G.R. Wemmer
A veteran is someone who, at one point in his/her life wrote a blank check made payable to 'The United States of America' for an amount of 'up to and including their life.' That is Honor, and there are way too many people in this country who no longer understand it.
LargeCar is offline
post #3 of 13 (permalink) Old 05-24-2007, 11:28 PM
8upwitHDs's Avatar
how does putting a weight on your truck fix something that is driveshaft or pinion related fix the problem?? BTW mine hops too.
8upwitHDs is offline
post #4 of 13 (permalink) Old 05-25-2007, 05:17 AM
LargeCar's Avatar
Images: 9
The hop is due to the wheelbase and the distance between the seams in the road. This is an attempt by ford to cure the sometimes present hop or bounce from the stiffness of the springs and the dips in the road surface getting in time and causing the hop at the speed in the TSB. I had the thing put on and it does not stop the seam hop thing. The TSB does not say this is for driveline related vibrations or hops.
I agree that a weight on the rear of the frame would do little for a drivetrain related issue. It would to some extent counter-act the whole truck starting the seam hop that gets worse as it progresses. I have found that a change in speed is the most effective cure, under 55 is smooth, over 75 is smooth, speed here is 65 so to avoid tickets (and the wifes rath) I do the 55 thing.
Largecar :mafia
LargeCar
G.R. Wemmer
LargeCar is offline
post #5 of 13 (permalink) Old 06-09-2007, 05:17 PM
I dont think that my truck did this when it was new and I have wondered if there is a problem with my truck. Atleast I know there is nothing seriosly wrong with the truck. Now my truck has about 60000 miles on it. With my truck the hopping has absolutely nothing to do with road conditions. Whenever I am accelerating through 40 to 45 mph or driving in that speed range the truck will hop up and down. Even if I am accelerating quickly the truck will still do it for a split second inside of the 40 to 45 speed range. It feels like the frame is flexing more than the suspension is moving but I cant really tell what it is.
AaronS is offline
post #6 of 13 (permalink) Old 06-27-2007, 02:52 AM
Tornsteel's Avatar
I've had this problem since day one. Had the stealer ship look at it before this TSB. I guess that I'll go back and show them this. Haven't had a good fight in a while. Looking forward to shoving this TSB in their face. Thanks guys.on:
2006 XLT 6.0, 72,000 miles. First owner. Build date 10/05, CC,LB,3.73LS,SRW,ISSPRO Pyro-Boost-Trans on the APillar,ARP Studs,Stock HG's,ELITE SCT Tadd's Tunes,Sinister SCT,Innovative tunes,EGR delete,4" turbo back dual exhst, zoodad, ccv mod, Coolant bypass filter, Cage leveling kit,upfitter high idle, running Amsoil 3000 with Archoil, 6.4 banjo's, Blue spring, 03 Turbo w/ 03 pedestal.
Issues: Rear main seal at 1'700 mls. EGR valve, EGR cooler and Oil cooler @ about 43k, Stock Head Gaskets @55k, Black Onyx HG's @72k.
https://www.thedieselgarage.com/galle...028_393362.jpg
Sean H
Tornsteel is offline
post #7 of 13 (permalink) Old 06-27-2007, 03:18 AM
has any one ever seen how much flex in the frame of a ford its alot
86 1 tonhauler is offline
post #8 of 13 (permalink) Old 07-04-2007, 09:07 PM
On my '06 it had the hop/vibration from day 1. Dealer at first said "they all do it nothing is wring with yours". With a 3400lb slide in camper on the back it will spill coffee, the service manager spilled his, riding with me. The damper does work. I almost kind-of get how, kinda like the weights in skyscrapers to dampen wind or earthquake sway. It sets up a movement out of phase with the vibration.
longcaster
longcaster is offline
post #9 of 13 (permalink) Old 07-14-2007, 06:27 AM
Tornsteel's Avatar
Just had the TSB done today. For the guys that had this thing installed. Did they install it on the hitch. This is where they installed it on mine. Can't feel a dif. yet.
Name:	IMGP0359 (Medium).JPG
Sean H
post #10 of 13 (permalink) Old 07-14-2007, 05:18 PM
8upwitHDs's Avatar
I had new gears put in a week ago, got the power back but it still shook.
I had Farmboy Fabrications traction bars put in and that took care of some of it, but it is still there being somewhat masked by the bars.
I am going to have the driveshaft looked at next as soon as I get a chance.
