Printable View (47 KB)
TSB
07-2-7 6.0L - REDUCED ENGINE PERFORMANCE - HIGH ALTITUDE
Publication Date: January 22, 2007
FORD: 2005-2007 F-Super Duty
ISSUE:
Some 2005-2007 F-Super Duty vehicles equipped with a 6.0L diesel engine may exhibit reduced engine performance condition with no diagnostic trouble codes (DTCs) when operated above 5,000 feet above sea level. This condition may affect 2005-2006 vehicles built before 3/15/2006 that had a powertrain control module (PCM) recalibration, and 2006-2007 vehicles built 3/15/2006 or later.
ACTION:
Reprogram the powertrain control module (PCM) to the latest calibration using IDS release IDS 47.3 and higher. This new calibration is not included in the 2007.1 DVD. Calibration files may also be obtained at www.motorcraft.com.
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage
OPERATION DESCRIPTION TIME
070207A 2005-2007 F-Super Duty 6.0L: Check For Diagnostic Trouble Codes And Reprogram The Powertrain Control Module (Do Not Use With 12650D, 12650D84) 0.7 Hr.
DEALER CODING
BASIC PART NO. CONDITION CODE
recalem 04
Copyright © 2007 Ford Motor Company
TSB
ISSUE:
ACTION:
WARRANTY STATUS:
DEALER CODING
recalem 04
