06-26-5 King Ranch Crew Cab Model Only - White Corrosion On Running Boards - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Squatch, this thread has received 0 replies and been viewed 1746 times.
post #1 of 1 (permalink) Old 03-22-2007, 03:48 AM Thread Starter
Squatch's Avatar
Printable View (47 KB)
TSB
06-26-5 KING RANCH CREW CAB MODEL ONLY - WHITE CORROSION ON RUNNING BOARDS
Publication Date: December 19, 2006
FORD: 1999-2007 F-Super Duty
ISSUE:
Some 1999-2007 F-Super Duty King Ranch Crew Cab vehicles may exhibit white corrosion on the running boards. It is not necessary to replace the entire running board assembly for this concern. Only replace the diamond plate.
ACTION:
Follow the Service Procedure steps to replace the diamond plate.
SERVICE PROCEDURE
Remove all ten (10) nuts from under side of running board.
Replace Diamond Plate
Secure with all ten (10) nuts and torque 16 lb-in (1.8 N-m).
PART NUMBER PART NAME
XC3Z-16A470-AA Step Assembly
WARRANTY STATUS:
OPERATION DESCRIPTION TIME
062605A 1999-2007 F-Super Duty King Ranch Crew Cab: Replace The Diamond Plate Insert On ONE Running Board 0.4 Hr.
062605B 1999-2007 F-Super Duty King Ranch Crew Cab: Replace The Diamond Plate Insert On BOTH Running Boards 0.5 Hr.
DEALER CODING
BASIC PART NO. CONDITION CODE
16450 d4
Copyright 2006 Ford Motor Company
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
