06-23-2 6.0l Turbocharger Carbon Deposit Diagnostics And Service Tips - Lack Of Power - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Squatch, this thread has received 0 replies and been viewed 5419 times.
post #1 of 1 (permalink) Old 03-22-2007, 03:54 AM Thread Starter
Squatch's Avatar
Printable View (255 KB)
TSB
06-23-2 6.0L TURBOCHARGER CARBON DEPOSIT DIAGNOSTICS AND SERVICE TIPS - LACK OF POWER, WHITE OR BLACK SMOKE, SURGE, P0238, P0299, P0404, P0478, P2262, AND/OR P2263
Publication Date: November 2, 2006
FORD: 2003-2005 Excursion
2003-2007 F-Super Duty
2004-2006 E-350, E-450
This article supersedes TSB 06-18-3 to update the Service Procedure, Parts List and add Labor Times.
ISSUE:
Some 2003-2007 F-Super Duty, 2003-2005 Excursion, and 2004-2006 E-Series vehicles equipped with a 6.0L diesel engine and built on or before 10/1/2006 may exhibit any one, or a combination, of the following concerns: lack of power, white/black smoke or a surge.
These concerns may or may not be accompanied by any one, or a combination, of the following diagnostic trouble codes (DTCs): P0238, P0299, P0404, P0478, P2262, and/or P2263. These concerns and/or DTCs could be a result of coking deposits inside the turbocharger.
Coking deposits inside the turbocharger turbine housing can impede vane response causing high or low instances of exhaust pressure. Unexpected exhaust pressure results can cause over-boost, under-boost, insufficient or excessive exhaust gas recirculation, or unexpected EGR valve position, resulting in these symptoms. This TSB is only for diagnosing and cleaning a turbo that is coked because of excess oil.
ACTION:
Follow pin point test KA in the Powertrain Controls/Emissions Diagnosis (PC/ED) Manual diagnostics. If the pin point test in the PC/ED Manual diagnostics lead to turbocharger replacement, follow this Service Procedure to check for internal turbocharger oil leaks and to determine if the turbocharger can be cleaned instead of replaced.
SERVICE PROCEDURE
NOTE: VEHICLE PERFORMANCE ISSUES RELATED TO FUEL QUALITY, MAINTENANCE, AND AFTERMARKET MODIFICATIONS ARE NOT COVERED BY FORD MOTOR COMPANY WARRANTY.
Remove the turbocharger for inspection following Workshop Manual (WSM), Section 303-04D: Fuel Charging and Controls.
Inspect compressor and turbine wheel fins for damage. Replace the turbocharger if fins are damaged. If fins are damaged, inspect the air intake system for damage allowing dirt or contamination to bypass the air filter.
Perform a turbocharger Bearing Clearance Check following WSM, Section 303-04D. Replace turbocharger if bearing fails the check.
Cover the inlet and outlet of the turbocharger compressor housing with duct tape or covers. Clean oil supply line mounting surface and cover with duct tape or covers. Place a clean paper towel or cover into the turbocharger oil drain passage.
Using a paint pen, mark the location and direction of the v-clamp. (Figure 1)
Figure 1 - Article 06-23-2
Using a paint pen, mark the location of the turbine housing at unison ring crank to make reassembly easier. (Figure 2)
Figure 2 - Article 06-23-2
NOTE: DO NOT REMOVE TURBINE WHEEL/COMPRESSOR WHEEL ASSEMBLY OR COMPRESSOR HOUSING.
Remove the v-clamp retaining nut completely from clamp assembly. Move v-clamp from flanges so the turbocharger housings can be separated. (Figure 3)
Figure 3 - Article 06-23-2
Separate the housings by using a hammer and brass drift.
Separate vanes and unison ring from turbine housing and center housing and check for coking from oil. If turbocharger is coked with carbon deposits from oil the deposits will be wet and black and cover the complete inside of the turbo. (Figure 4)
Figure 4 - Article 06-23-2
If the turbocharger is oil coked, continue with this TSB.
If the turbocharger is not oil coked, replace the turbocharger and do not clean the turbocharger. This TSB is only for cleaning a turbo that is coked because of excess oil. DO NOT ATTEMPT TO CLEAN RUST OR CORROSION.
NOTE: IF THE REPLACEMENT TURBO DOES NOT COME WITH A VGT, TRANSFER THE VGT FROM THE TURBO BEING REPLACED.
Inspect the unison ring for cracks. Replace the turbocharger if the unison ring is cracked.
To clean the carbon deposits, wet the unison ring, vanes, and turbine housing and center housing unison ring and vane contact areas with Carburetor Cleaner (PM-2). (Figure 5)
Figure 5 - Article 06-23-2
NOTE: DO NOT CLEAN THE TURBINE WHEEL AND USE CAUTION WHEN CLEANING AROUND IT.
NOTE: A RAZOR BLADE IN A HOLDER MAY BE USED WHERE THERE IS SUFFICIENT ACCESS TO REMOVE THE BULK OF CARBON DEPOSITS.
NOTE: USE A DUST MASK WHEN CLEANING TURBO CHARGER SURFACES.
Finish cleaning the center housing, unison ring and vanes with a Scotch-Brite 2" (5 cm) abrasive disc 051131-07480, or equivalent (obtain locally). Ensure these areas are free of carbon (Figure 5):
Center housing unison ring hub
Center housing facing surface
Unison ring inner diameter
Unison ring outer diameter
Unison ring facing surfaces
Unison ring crank pin slot
Unison ring vane slots
Vanes - all contact points
Using scissors, cut the Scotch-Brite disc used in Step 12 to match a 1" (2.5 cm) 3M holder (61-5000-7982-9). (Figures 6 and 7)
Figure 6 - Article 06-23-2
Figure 7 - Article 06-23-2
NOTE: THE DISC MUST BE MODIFIED TO THE 1" (2.5 cm) SIZE TO COMPLETE THE CLEANING EFFECTIVELY.
NOTE: AVOID DAMAGING VANE PIVOT PINS DURING THE CLEANING PROCESS. PIN DAMAGE CAN CAUSE UNWANTED NOISE AND/OR IMPAIR TURBOCHARGER PERFORMANCE. (FIGURE 5)
Finish cleaning the turbine housing using the modified disc. Remove the carbon deposits from all surfaces that contact moving parts, as well as the mating surfaces of the housing. (Figures 5 and 8)
Figure 8 - Article 06-23-2
Apply a thin layer of engine oil to the turbine housing, center housing and unison ring. This procedure is to temporarily protect against surface corrosion. Applying anti-seize is not recommended.
Install the vanes into the turbine housing.
Index the unison ring onto the vanes.
Align the crank pin slot with the paint pen mark on the turbine housing. (Figures 2 and 5)
Verify free movement of the vanes and unison ring.
Position v-clamp on the turbine housing in direction of paint pen mark.
Lower the center housing section onto the turbine housing, aligning the unison ring crank first, then the housing dowel.
Align the v-clamp with the paint marks. Coat the threads with anti-seize.
Install the locknut using Steps a through d:
Torque to 13 lb-ft / 160 lb-in (18 N-m).
Loosen nut and torque to 4 lb-ft / 50 lb-in (5 N-m).
Stand turbocharger on exhaust outlet then tap around the aluminum compressor housing with a rubber mallet to ensure complete seating.
Torque to 12 lb-ft / 150 lb-in (17 N-m).
Remove the duct tape or covers from the turbocharger. Remove any tape residue with a paper towel dampened with brake cleaner.
Re-install the turbocharger with a new oil drain tube following WSM, Section 303-04D: Fuel Charging and Controls. The oil drain tube has been revised for greater turbocharger oil flow.
PART NUMBER PART NAME
6C3Z-9T515-A Oil Drain Tube
PM-2 Carburetor Tune-Up Cleaner
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage
OPERATION DESCRIPTION TIME
062302A 2003-2007 Super Duty, 2003-2005 Excursion 6.0L: Follow Pin Point Test KA In The PC/ED Manual. If Lead To Turbocharger Replacement, Follow Service Procedure To Determine If Turbocharger Can be Cleaned, Turbo FAILS INSPECTION, Replace Turbocharger, Includes Time To Remove Turbo For Inspection, Transfer The VGT Control To The New Turbocharger And Install (Do Not Use With 6089A, 9438A Or Any 6005 or 12650D Series Diagnostic Labor Operations) 5.6 Hrs.
062302B 2003-2007 Super Duty, 2003-2005 Excursion 6.0L: Follow Pin Point Test KA In The PC/ED Manual. If Lead To Turbocharger Replacement, Follow Service Procedure To Determine If Turbocharger Can be Cleaned, Turbo PASSíS INSPECTION Perform Procedure To Clean Turbocharger, Includes Time To Remove Turbo For Inspection And Reinstall After Cleaning (Do Not Use With 6089A, 9438A Or Any 6005 or 12650D Series Diagnostic Labor Operations) 6.4 Hrs.
062302C 2004-2006 Econoline 6.0L: Follow Pin Point Test KA In The PC/ED Manual. If Lead To Turbocharger Replacement, Follow Service Procedure To Determine If Turbocharger Can be Cleaned, Turbo FAILS INSPECTION, Replace Turbocharger, Includes Time To Remove Turbo For Inspection, Transfer The VGT Control To The New Turbocharger And Install (Do Not Use With 6089A, 9438A Or Any 6005 or 12650D Series Diagnostic Labor Operations) 6.3 Hrs.
062302D 2004-2006 Econoline 6.0L: Follow Pin Point Test KA In The PC/ED Manual. If Lead To Turbocharger Replacement, Follow Service Procedure To Determine If Turbocharger Can be Cleaned, Turbo PASSíS INSPECTION Perform Procedure To Clean Turbocharger, Includes Time To Remove Turbo For Inspection And Reinstall After Cleaning (Do Not Use With 6089A, 9438A Or Any 6005 or 12650D Series Diagnostic Labor Operations) 7.1 Hrs.
DEALER CODING
BASIC PART NO. CONDITION CODE
6F089 42
Copyright © 2006 Ford Motor Company
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
