06-22-9 6.0l - Mil On With Dtc P2138, P2139, And P2140 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Squatch, this thread has received 0 replies and been viewed 4511 times.
post #1 of 1 (permalink) Old 03-22-2007, 03:58 AM Thread Starter
Squatch's Avatar
Printable View (47 KB)
TSB
06-22-9 6.0L - MIL ON WITH DTC P2138, P2139, AND P2140
Publication Date: October 23, 2006
FORD: 2005-2006 E-350, E-450
2005-2007 F-Super Duty
This article supersedes TSB 06-13-10 to update the vehicle model years coverage.
ISSUE:
Some 2005-2006 E-Series vehicles built through 6/12/2006 and 2005-2007 F-Super Duty vehicles built through 6/5/2006, equipped with a 6.0L diesel engine may exhibit the malfunction indicator lamp (MIL) on with diagnostic trouble codes (DTCs) P2138 P2139, and P2140.
ACTION:
Reprogram the powertrain control module (PCM) to the latest calibration using IDS release IDS-45.8 and higher. This new calibration is not included in the 2006.9 DVD. This calibration contains a revised strategy to eliminate the occurrence of a false P2138, P2139, or P2140. Calibration files may also be obtained at www.motorcraft.com. Follow normal diagnostics if any of these DTCs still occur after reprogramming.
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage
OPERATION DESCRIPTION TIME
062209A 2005-2007 F-Super Duty 6.0L 2005-2006 Econoline 6.0L: Check For DTCs And Reprogram The PCM (Do Not Use With 12650D, 12650D84) 0.7 Hr.
MT062209 Use SLTS Operations If Available; Claim Additional Diagnosis Or Labor Performed As Actual Time Actual Time
DEALER CODING
BASIC PART NO. CONDITION CODE
recalem 04
Copyright 2006 Ford Motor Company
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
